2014 Škoda Yeti footwell lights
Gizmo
S.E.Kent UK
C?ID=49193
I am ¾ the way through installing footwell lights in a new facelift Yeti.
On previous cars I have taken the power supply from pin B50 on the CECM (white plug) but on the Yeti this is already occupied (and as footwell lights are not an option in the UK on any Yeti it must use another pin).
Any ideas which pin it is to power them (so they can be controlled via the maxidot.
Gizmo
S.E.Kent UK
C?ID=49193
I have tried B7 (which Bold Sport - the footwell light suppliers claim is correct for a MKV Golf) without success, although I not get a DTC despite them being activated and turned on in the maxidot.
Gizmo
S.E.Kent UK
C?ID=49193
On a 2014 F/L Yeti, pin B50 now operates the rear fog light - as when I code the car to have footwell lights fitted the rear fog light comes on when you open the door!
Here is a full scan (the Address 42: Door Elect, Driver, is down to an iffy LED)
Sunday,08,June,2014,19:48:14:22041
VCDS Version: 14.6.0.0
Data version: 20140601
VIN: TMBME75L8E604****   License Plate: **14 ***
Mileage: 180km-111mi   Repair Order: After code
Chassis Type: 5L (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 36 37 42 44 46 4F 52 55 56
          62 72 77
VIN: TMBME75L8E604****   Mileage: 180km-111miles
Address 01: Engine (J623-CFJA)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 QM    HW: 03L 907 309 AG
   Component: R4 2,0L EDC   H25 4786
   Revision: 42H25---    Serial number:
   Coding: 00190012042700080000
   Shop #: WSC 33361 790 00052
   ASAM Dataset: EV_ECM20TDI01103L906018QM 003005
   ROD: EV_ECM20TDI01103L906018QM.rod
   VCID: 050A24E384773F1238-8050
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 963F600E092601FE691206EC901C808AA1015023
   VCID: 7EF84B0FE9A16CCA79-802B
   Part No SW: 3T0 907 044 CJ    HW: 3T0 907 044 CJ
   Component: Climatronic   H19 0709
   Revision: 00001009
   Coding: 0010000002
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 7CFC4107F7BD7EDA57-8029
   Part No SW: 1K0 937 087 AK    HW: 1K0 937 087 AK
   Component: BCM PQ35  H   112 0771
   Revision: AF112771
   Coding: 48000ABBE85BF1C0400800C0510089EC4B7800AE726D8760808140040040
   VCID: 7AF0471FF58940EA45-802F
   Subsystem 1 - Part No: 5L2 955 119 B  Labels: 1KX-955-119.CLB
   Component: SK356  26  0610
   Coding: 00F7B5
   Component: RLS 240414 05  54  0403
   Coding: 062BED
Address 10: Park/Steer Assist (J791)       Labels: 3T0-919-475-V2.clb
   Part No SW: 3T0 919 475 E    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0009
   Revision: --------    Serial number: 56261410501227
   Coding: 149007
   ASAM Dataset: EV_EPHVA2CAS46X0000 002001
   ROD: EV_EPHVA2CAS46X0000.rod
   VCID: 3F86F60BA62BA5C232-806A
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    014 0613
   Serial number: 003G5RAT1VE7
   Coding: 00004E42
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3162A033607F43B2B4-8064
   Serial number: 3572MSME3F4F7843ZZZ9
   Serial number: 3582MSME3A517843ZZZZ
   Serial number: 3516KSME676E552CZZZ3
   Serial number: 3526KSME2E15562CZZZ.
   Part No SW: 5K0 953 521 DQ    HW: 5K0 953 569 AH
   Revision: FF010042    Serial number: 20140416500038
   Coding: 1082140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7EF84B0FE1A16CCA79-802B
   Subsystem 1 - Part No SW: 5E0 919 719 F    HW: 5E0 919 719 F
   Coding: 820000
   Part No SW: 5L0 920 940 M    HW: 5L0 920 940 M
   Component: KOMBI         H06 0811
   Coding: 720E01
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 3668932F8911648AE1-8063
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 190414F2001994
   Coding: 356303
   VCID: 7BFE421BFAB379E25E-802E
Address 22: AWD (J492)       Labels: None
   Part No SW: 0AY 907 554 F    HW: 0AY 907 554 F
   Component: Haldex4Motion H52 7521
   Serial number: HA1-00025.03.14
   Coding: 0301
   Shop #: WSC 73430 790 00052
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 4E98DBCF11813C4AC9-801B
   Component: IMMO          H06 0811
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: 6AD0775F8D29F06AB5-803F
   Part No SW: 3C8 959 760 E    HW: 3C8 959 760 E
   Component: Sitzmemory    H05 3101
   Revision: 00H05000
   Coding: 000038
   Shop #: WSC 82242 150 616934
   VCID: 37769E2B861B9D82FA-8062
   Part No SW: 3T0 035 686 H    HW: 3T0 035 686 H
   Component: RNS-MID       H23 6270
   Revision: AB001001    Serial number: SKZ6Z7P6112045
   Coding: 04000402000300811000
   VCID: 3B7E821BBA33B9E21E-806E
   Subsystem 1 - Part No: 3T0 051 859 Q
   Component: EU West V10  8048
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 G    HW: 7N0 959 793 G
   Component: TSG FA        H03 0553
   Revision:             Serial number: 0000100136249
   Coding: 01150220DE01231004
   VCID: 4688E3EFF1F1F40A71-8013
02123 - Door Warning Light / Entry Light
                    Fault Status: 01101100
                    Reset counter: 4
                    Mileage: 180 km
                    Date: 2014.06.08
                    Time: 19:39:16
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 71     3501
   Revision: 00H22000
   VCID: 39729813700F8BF20C-806C
   Component: EZE_2         H55 1642
   Coding: 050B0500
   VCID: 6FE6664BBECB1542E2-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 G    HW: 7N0 959 792 G
   Component: TSG BF        H03 0553
   Revision:             Serial number: 0000100143476
   Coding: 01150020DE01231004
   VCID: 458AE4E3CCF7FF1278-8010
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H04 0111
   Coding: 035E00003F000000
   ROD: EV_HeadlRegulVWAFSPt.rod
   VCID: 37769E2B8E1B9D82FA-8062
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B
   Component: LeiMo links  H06 0009
   Coding: A00000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B
   Component: LeiMo rechts  H06 0009
   Coding: A00000
Address 62: Door, Rear Left (J388)       Labels: 7N0-959-795.clb
   Part No SW: 7N0 959 795 E    HW: 7N0 959 795 E
   Component: TSG HL        H03 0553
   Revision:             Serial number: 0000100351535
   Coding: 010000200001531004
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-795.clb
   Component: TSG HR        H03 0553
   Revision:             Serial number: 0000100350896
   Part No SW: 7P6 035 730 N    HW: 7P6 035 730 N
   Component: TELEFON       H15 4217
   Revision: 1B001001    Serial number: 00007666134649
   Coding: 0211000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3D7A8C03AC27B7D220-8068
End-------------------------(Elapsed Time: 03:58)--------------------------
bambazonke
Mackay Qld Australia
C?ID=240542
I have just checked on WinElsa and it is also Pin B50 for my 2012 facelifted Tiguan. Unfortunately my version of Win Elsa only covers VW models. Your best bet is try and obtain the latest version of WIN Elsa that includes Skoda & Audi (Q3?). Does the user's manual mention them as an option? If it does then at least you know it achievable.
Have you managed to get your electric mirrors to fold remotely? Your door modules coding and number of bytes is similar to an Autoscan of a Q3 I saw recently.
United States
I agree bambazonke, the coding structure in that type of door module is similar to the 2009+ B8 Audi models and they should support that tweak.
I do not have any comments on the footwell lights but checking the factory level diagrams would be the best place to start!
I remember back when I was comparing everything I could possibly tweak on the 2010 Gti and using Octavia among other diagrams for similar PQ35 BCM cars to try to compile a complete pin out. Due to the variables in Brands and Part Numbers that didn't work out so well...but it did get me on-track for the rear fog retrofit after Byte 18 schooled me :) If the RoW erWin websites are similar to NAR VW you may have success looking for Control units in front part of vehicle under Component Locations and scrolling down to the Onboard supply control unit -J519 section.
Gizmo
S.E.Kent UK
C?ID=49193
They are coded from the factory (Byte4 Bit 4 & 6) ‘Comfort Mirror Folding active’... but they only fold if the remote is kept pressed.
Gizmo
S.E.Kent UK
C?ID=49193
Has anyone else come across this on any other 2014 model?
If so what pin did you use for the power supply.
