VW Golf 7 ABS Brakes (J104) 15.7.4 and Beta 16.6 No Texts!
barstanders
C?ID=277262
Yesterday i have installed the latest Beta 16.6.
First impression its start verry slow 10% 20 % 30 % ....
After instalation i see again no Bytes and Bits on the ABS Brakes this was on the 15.7.4 and now olso with the beta 16.6.
See the link: https://youtu.be/tvHdmeHpquw
I olso cannot change the setting on the gateway
(1)-Range gain-Range gain AC system,activated
(2)-Range gain-Range gain auxiliary heater,activated
(3)-Range gain-Range gain window defogger,activated
(4)-Range gain-Range gain seat heater front,activated
(5)-Range gain-Range gain front set ventilation,activated
(6)-Range gain-Range gain rear heater,activated
(7)-Range gain-Range gain fog light,activated
(8)-Range gain-Range gain rear fog light,activated
See link for the guestion: http://vagcomforum.de/index.php?showtopic=28393
I olso cannot change the setting on the instrument cluster this was on the 15.7.4 and now olso with the beta 16.6.
ID 190 (1)-Illumination_algorithm-Scale_switching_algorithm > parking_light
ID 191 (2)-Illumination_algorithm-Pointer_illumination_algorithim > terminal_58xd_log_bus_parkinglight
http://forums.ross-tech.com/showthr...nstrument-cluster-retrofit-to-Premium-1-fault
Saturday,09,July,2016,23:31:13:42750
VCDS Version: 16.6.0.2
Data version: 20160602 DS251
VIN: WVWZZZAUZDP010048   License Plate:
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZDP010048   Mileage: 47379km-29439miles
Address 01: Engine (J623-CJZB)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 E    HW: 04E 907 309 A
   Component: 1.2l R4 TSI   H08 7695
   Revision: WAH08---
   Coding: 01110032232415082000
   Shop #: WSC 51969 000 1048576
   ASAM Dataset: EV_ECM12TFS01104E906016E 001011
   ROD: EV_ECM12TFS01104E906016.rod
   VCID: 2468B6F82F7D01639D-8070
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Revision: 00000000    Serial number:
   Coding: 01FA6AA120212A6C0377060401CB2580560454C06080A4F30028F02AC0
   Shop #: WSC 12345 123 123465
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: 7DDEA39CEC5790ABB2-8028
   Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00020004200100011005000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 364C7CB089E183F333-8062
   Air quality sensor:
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 L
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011227800350
   Coding: 00040846C2C102FB0BA44080B11C0708100A000000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 77D2B1B4CE6BBAFBE8-8022
   Component: WWS    120910  042 0551
   Serial number:         120924160900
   Coding: 0E4DD5
   Component: RLFS  024 0042
   Serial number: Y12M09D26H11M47S40S4
   Coding: 06A8DD
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY1306406H5
   Serial number: 00000000000056969920
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Revision: --------    Serial number: 61131204002703
   Coding: 0031161041
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_VW37.rod
   VCID: 3D5E639CACD750ABF2-8068
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Component: AirbagVW20    011 0361
   Serial number: 003F5R00E6ZJ
   Shop #: WSC 00028 028 00057
   VCID: 40A01A68DB253D4399-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 310 12
   Serial number: 35767000000E2845EB00
   Subsystem 2 - Part No SW: -----------    HW: 480 001 708 13
   Serial number: 35867000000ED2CC6D0F
   Subsystem 3 - Part No SW: -----------    HW: 480 400 910 12
   Serial number: 3516502A90D19C31C0EK
   Subsystem 4 - Part No SW: -----------    HW: 480 400 910 12
   Serial number: 3526502AD0CD5EB313CY
   Subsystem 5 - Part No SW: -----------    HW: 480 400 210 12
   Serial number: 3556502B30CD5EB4531M
   Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
   Revision: --------    Serial number: 1510120003004H
   Coding: 8400
   Shop #: WSC 51454 001 104857
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 75CEBBBCD467C8EBFA-8020
   Part No SW: 5G0 920 871     HW: 5G0 920 871
   Component: KOMBI         353 2200
   Coding: 07AD0A00239000080D087E00040000
   ROD: EV_DashBoardVDDMQBAB_VW37.rod
   VCID: 67F2E1F49ECB2A7B78-8032
   Part No SW: 5Q0 907 530 L    HW: 5Q0 907 530 E
   Component: GW MQB Mid    121 1144
   Revision: --------    Serial number: 0000104516
   Coding: 030100042B086400EF000648080F00010001000000000000000000000000
   Shop #: WSC 51454 001 1048576
   ROD: EV_GatewLear.rod
   VCID: 3A546880BDF96793D7-806E
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
   Component: E221__MFL-DC1  H14 0035
   Serial number: 23130000529820100291
   Coding: 280000
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 5430458201
1537 - Data Set Implausible
          B2012 00 [009] -  -
                    Reset counter: 77
                    Mileage: 47049 km
                    Date: 2016.06.26
                    Time: 10:52:06
                    Supply voltage; Terminal 30: 14.7 V
                    Terminal 15: On
   Serial number: 29051301100188
   Coding: 001F0220D000020000001000
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Serial number: 00000000000000243883
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 03
   ROD: EV_SteerAssisMQB_VW37.rod
   Component: TSG BFS       020 0023
   Serial number: 06031302090088
   Coding: 001F0020DE00020000801000
   VCID: 3FA21994A6DB42BBE0-806A
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Serial number: 00000000000000247280
   Coding: 090000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 846 A    HW: 5G0 035 846
   Component: MU-S-N-ER     038 0421
   Serial number: V1F01510120522
   Coding: 02730001FF00000011110001000800001F0100940100010045
   Shop #: WSC 12345 666 54321
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 2772A1F45E4BEA7BB8-8072
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H51 0022
   Serial number: VWZ8Z9NJ902C5F
   Subsystem 2 - Part No SW: 5G0 919 866 AD    HW: -----------
   Component:  ECE 2016/17  --- 0059
End-------------------------(Elapsed Time: 02:42)--------------------------
Specs of PC? What nannyware do you have installed on it?
barstanders
C?ID=277262
Intel Atom Quad core (4) 1330 MHZ windows 10.
vcds 15.7.4 verry fast!
You didn't answer about nannyware. ;)
barstanders
C?ID=277262
Nannyware you mean a antivirus program?
The laptop used only for vcds and i have eset security installed
Try turning it off (temporarily) or telling it to ignore the stuff in the folder you have the Beta installed in to see if it makes any difference.
barstanders
C?ID=277262
Can i uninstall everthing with vcds like the 15.7.4 EN and DE Beta and then reinstall again the beta only.
You can, but I don't think there's much point in it.
barstanders
C?ID=277262
Oke, and what about the other options what dont work.
Like changing the gateway settings and instrument cluster adaptations, and olso the byte and bit discription ABS . will this work when i final release coms???
Just because an Adaptation channel might exist (by having being included in the list provided by VCDS), or even does exist (as indicated by a value being readable) does not mean the module's diagnostic API allows changes to that channel.
If/when we come across proper documentation for the coding of these ABS modules, we'll included it in VCDS. Unfortunately, such documentation does not exist, even in the factory tool.
Please keep in mind that VW gives us NO assistance of any kind with this stuff.
lala30
Croatia
C?ID=71949
But for few byte you now for what is ! But no description in coding helper!
barstanders
C?ID=277262
Oke, Please can you tell me what is the differnts between Fuel tank variant 1 to 8
and Tire Circumference 1 to 8 on the german vcds.
I want to now this because i have the problem to finding the right coding to the instrument cluster
Old valeu feul tank varaint 3 and the car variant where 0, but 0 is now for 3 doors and i have 5 doors.
Old cluster 07A502002390000800086A00040000
do i need to recode it to 07A50A2390000800086A00040000
golfi_vend
Tartu, Estonia
C?ID=195131
Please understand that a lot of coding bits description comes from factory program. There isn't also no further description about it.
barstanders
C?ID=277262
Oke i understand that but when a german version shows more discription possibilities you desagree somtimes
barstanders
C?ID=277262
Disable Antivirus, Remove old vcds 15.7.4 and reinstall 16.6 Beta, it still shows 20% 40 % 60 % when starting.
Again the old version Englisch and German had no problem with this, maybe the firmware..
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Definitely not in this case, we'll be happy to look into that if you have a specific situation where you believe that is the case - other than that I would very much appreciate, not starting such rumors.
barstanders
C?ID=277262
Hello Uwe,
I have put a video online you can see what i meen.
https://youtu.be/4ePa-K3OueM
Hello Sebastian,
I have olso put i video for you.
https://youtu.be/kdaZCzaP-wg
I dont understand why you think is a rumor!
Just read the post, when you have read you understand what i meen and dont say this i a rumor.
http://vagcomforum.de/index.php?showtopic=28509
On the german 15.7.4 you have that option englisch not and again on the Beta german 16.5 and again not with 16.6!
Olso the wheel circle byte have more options on the german englisch standaard.
Yes i use the instrument cluster many times because i have a problem with the right coding, and then you see the differnce.
And olso hoping that someone can help me , even 1 thing to say maybe try byte 14 bit 2???? i dont care just one option.
But on the EN site here there will be some answers, Thanks but the german site!
So i can confirm that the 300 euro was spending right. 1 thing!
I dont think i will sugest somone else to buy a orginal cable!
Sorry but i am verry frustrated Now 1.5 months looking for solution! every day read vcds the car changing code every kind of code!!!
Than you need help with tips look here or try this... But Nothing
I have made a apointment with the VW garage maybe the cluster can get a update and maybe the can put a right code online.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Video #1, the NEW progress indicator when querying an installation list is an added feature because VCDS 16.5/16.6 actually covers more addresses/lists than VCDS 15.7. So yes, it may be slightly slower but it ensures that we are covering all addresses in you car. The reason why you won't see an actual difference is because your car simply doesn't have too many factory options. So to be clear, this isn't a bug - it's a new feature.
Video #2, in your original post/question you're asking about ABS/ESP coding. What does the instrument cluster have to do with that? The fuel tank variants have already been addressed, the German and English versions are using different datasets - so you're comparing apples and oranges here.
barstanders
C?ID=277262
video 1 ok, this was not a complaning just a sugestion to the ross tech team because this i a beta maybe when you tell the can chanche with final release so this is a new option.
Video 2
I olso say that the gateway you cant change the adaptations olso the ilumination instrument cluster cant change, yes and i refer to the bytes and bits.
But how i can resolve my iseu when i see on the german 8 tank options and more than 10 variants for the car symbol.
So my car is 1 option i dont have 8 cars!
And englisch 3 options.
Ther is more possiblity to recode on the german and not the englisch.
So than please tell me what i can do with this options from 1 to 8 and car options 10.
And olso Tire Circumference 8 options on the german and 1 on the englisch STANDARD.
So if this is not confused for somone how wants to recode find the right code!!!!
