- May 2, 2014
- 169
- 83
- Alexandria/fairfax county VA
- C?ID=99408
following up on my questions in the how-to section. http://forums.ross-tech.com/showthread.php?633-Tis’-the-HVAC-Season
is the requested current auto-scan results.
The problem identified is a hesitation in start of cooling when starting after it has been off overnight (or at least a while.)
discussion on other sites indicates a common problem with swaged plate compressors on these cars is a sticking Refrigerant Control valve.
(search "TDI RCV" for a sample)
I logged a couple drives using advance measuring values from the HVAC controller. fan on 2, temp set to full cold. mode set to dash
You can see that while the current stays in what is reported to be maximum activation, (0.82 amps), the coolant pressure (R143a high side) stays around ambient [7 bar or so] (it was a warm morning) for a while. after a while, I turned the AC switch off for a couple seconds, then on again. this resulted in some cooling performance, and a climb of pressure to around 12 bar .
I logged a shorter drive this morning, and noted the delay, gave up early and toggled the ac switch. in this case, I increased the temperature control after a while, and the current reading is reduced for a while (indicating the system needed less volume from the pump) the pressure did not come down..... In this case, I also included compressor load, and noted it increased roughly with the high side pressure reading, but not in lock step. (answering part of my query on what exactly the compressor load represents)
sometimes there is no delay (like after a short stop for fuel on a trip, or parked for a couple hours) but it is becoming more consistent.
Thursday,07,July,2016,17:18:45:51928
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: 3VWPL71K89M272852 License Plate:
Mileage: 276640km-171896mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
75
VIN: 3VWPL71K89M272852 Mileage: 276640km-171896miles
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 016 P HW: 03L 906 022 J
Component: R4 2,0L EDC G000AG 8681
Revision: --H01--- Serial number: VWX7Z0H72491JO
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 3FA390536EB764C647-806A
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 050 D HW: 02E 927 770 AD
Component: GSG DSG 082 1402
Revision: 05108020 Serial number: 00001009261684
Shop #: WSC 04940 001 00001
VCID: 130B6CE332BF50A6D3-8046
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 113B600D492900FC881306E9921B0042B100
VCID: 75CF327BDC0BEE965D-8020
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 7CD9275F3F21BFDE22-8028
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000001014370
Coding: 14898F2340041500070000001C000000000873075C000120000000000000
VCID: 3245C967ADE5B9AEB8-8066
Component: Wischer 230808 021 0501
Coding: 00037781
Shop #: WSC 00066
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0382262
Coding: 0000100
VCID: 334BCC6352FFB0A6B3-8066
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 78 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M06G1H$
Coding: 0014136
VCID: 6CF9171F4F412F5EB2-8038
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME3B0044340
Subsystem 3 - Serial number: 6342MSME3E307878M
Subsystem 4 - Serial number: 6351HSME174A4C71D
Subsystem 5 - Serial number: 6361HSME175F5826H
Subsystem 6 - Serial number: 63727SME16701603R
Subsystem 7 - Serial number: 63827SME16701021M
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 051 0101
Coding: 0010042
VCID: 032B5CA342DFC02663-8056
00888 - Wiper Switch for Intermittent Operation (E22)
Part No SW: 1K0 920 974 N HW: 1K0 920 974 N
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0003000 Serial number: VWX7Z0H72491JO
Coding: 0007203
VCID: 3957FE4B70934AF679-806C
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 020708F1000751
Coding: ED807F072013022002
VCID: 354FF27B5C8BAE969D-8060
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T2EKX03
VCID: 7DDF2A5B243BB6D615-8028
Component: IMMO 3HL 2418
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000532488807
Coding: 0001205
VCID: 6FC300137E57D44697-803A
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A75D1078535F16E00-807E
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139007885283281B0904058FB0880F0488DC00
VCID: 04295FBF47D1C71E5A-8050
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Fault Status: 01100111
Reset counter: 187
Mileage: 205700 km
Time: 13:05:22
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 00000552988807
Coding: 0001204
VCID: 70C1036F6369CBBE8E-8024
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Fault Status: 00101100
Fault Frequency: 8
Reset counter: 62
Mileage: 270101 km
Fault Status: 00111000
Reset counter: 62
Mileage: 275438 km
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2224675
Coding: 0010400
VCID: 29772E0B8033FA7609-807C
00003 - Control Module
014 - Defective
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003360131
Coding: 0001168
VCID: 76CD3577010DE58E54-8022
Component: RDK 0450
Coding: 0100101
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003383939
Coding: 0001168
VCID: 77D3387306079C864F-8022
Address 75: Telematics
End-------------------------(Elapsed Time: 01:30)--------------------------
Wednesday,06,July,2016,06:59:00:51928-VCID:7CD9275F3F21BFDE22-8028,VCDS Version: Release 15.7.4 (x64),Data version: 20160216
1K0 820 047 HS,ADVMB,Climatic PQ35 142 1111,
,,G001,F0,G001,F1,G002,F1,G002,F2,G003,F0,G004,F0,G004,F3,G005,F0,G006,F0,G007,F0,G012,F0,G012,F1,
Marker,TIME,Group 1 - Field 0,TIME,Group 1 - Field 1,TIME,Group 2 - Field 1,TIME,Group 2 - Field 2,TIME,Group 3 - Field 0,TIME,Group 4 - Field 0,TIME,Group 4 - Field 3,TIME,Group 5 - Field 0,TIME,Group 6 - Field 0,TIME,Group 7 - Field 0,TIME,Group 12 - Field 0,TIME,Group 12 - Field 1,
,STAMP,Compressor - Shut-Off Code,STAMP,Engine Speed,STAMP,Compressor - Current (specified),STAMP,Compressor - Speed,STAMP,Coolant - Pressure,STAMP,Outside Temp. - (unfiltered),STAMP,Coolant - Temperature,STAMP,Outlet Blower - Temperature,STAMP,Evaporator - Temperature,STAMP,Fan/Blower - Status,STAMP,Current Value,STAMP,Specified Value,
,,,, /min,, A,, /min,, bar,,°C,,°C,,°C,,°C,,,,,,,
,0.57,7.0,0.57,800,0.72,0.000,0.72,0,0.86,6.4,0.98,25.5,0.98,32.0,0.09,26.0,0.21,24.0,0.32,OFF,0.45,38.0,0.45,32.0,
,1.62,7.0,1.62,800,1.76,0.000,1.76,0,1.88,6.4,2.02,25.5,2.02,32.0,1.10,26.0,1.24,24.0,1.37,OFF,1.49,38.0,1.49,32.0,
,2.71,0.0,2.71,800,2.85,0.820,2.85,1000,2.99,6.4,3.12,25.5,3.12,32.0,2.14,26.0,2.28,24.0,2.42,OFF,2.56,38.0,2.56,32.0,
,3.77,0.0,3.77,800,3.91,0.820,3.91,1000,4.04,6.8,4.16,25.5,4.16,32.0,3.24,26.0,3.37,24.0,3.51,ON,3.63,32.0,3.63,32.0,
,4.82,0.0,4.82,800,4.96,0.820,4.96,1000,5.08,7.2,5.21,25.5,5.21,32.0,4.28,26.0,4.42,24.0,4.55,ON,4.68,32.0,4.68,32.0,
,5.84,0.0,5.84,800,5.97,0.820,5.97,1000,6.13,7.8,6.26,25.5,6.26,32.0,5.32,26.0,5.43,24.0,5.58,ON,5.71,31.0,5.71,32.0,
,6.93,0.0,6.93,800,7.07,0.820,7.07,1000,7.22,9.0,7.35,25.5,7.35,32.0,6.39,26.0,6.51,24.0,6.66,ON,6.79,31.0,6.79,32.0,
,7.99,0.0,7.99,800,8.11,0.820,8.11,1000,8.26,8.2,8.39,25.5,8.39,32.0,7.48,26.0,7.60,24.0,7.74,ON,7.86,31.0,7.86,32.0,
,9.07,0.0,9.07,800,9.21,0.820,9.21,1000,9.36,8.6,9.50,25.5,9.50,32.0,8.51,26.0,8.63,24.0,8.79,ON,8.93,31.0,8.93,32.0,
,10.16,0.0,10.16,800,10.28,0.820,10.28,1000,10.42,8.6,10.55,25.5,10.55,32.0,9.62,26.0,9.74,24.0,9.89,ON,10.02,31.0,10.02,32.0,
,11.19,0.0,11.19,800,11.31,0.820,11.31,1000,11.46,9.0,11.59,25.5,11.59,32.0,10.66,26.0,10.79,24.0,10.94,ON,11.06,31.0,11.06,32.0,
,12.22,0.0,12.22,800,12.35,0.820,12.35,1000,12.50,9.0,12.63,25.5,12.63,32.0,11.71,26.0,11.83,24.0,11.96,ON,12.08,31.0,12.08,32.0,
,13.30,0.0,13.30,800,13.44,0.820,13.44,1000,13.58,10.0,13.71,25.5,13.71,32.0,12.76,25.0,12.87,24.0,13.02,ON,13.16,31.0,13.16,32.0,
,14.36,0.0,14.36,800,14.49,0.820,14.49,1000,14.63,10.0,14.75,25.5,14.75,32.0,13.83,25.0,13.95,24.0,14.11,ON,14.24,31.0,14.24,32.0,
,15.39,0.0,15.39,800,15.52,0.820,15.52,900,15.66,9.0,15.78,25.5,15.78,32.0,14.88,25.0,14.99,24.0,15.14,ON,15.27,31.0,15.27,32.0,
,16.41,0.0,16.41,800,16.55,0.820,16.55,1000,16.67,8.8,16.82,25.5,16.82,32.0,15.91,25.0,16.02,24.0,16.14,ON,16.28,31.0,16.28,32.0,
,17.46,0.0,17.46,800,17.59,0.820,17.59,1000,17.72,8.6,17.84,25.5,17.84,32.0,16.94,25.0,17.05,23.0,17.17,ON,17.30,31.0,17.30,32.0,
,18.50,0.0,18.50,1000,18.63,0.820,18.63,1300,18.77,8.4,18.91,25.5,18.91,32.0,17.98,25.0,18.10,23.0,18.23,ON,18.36,31.0,18.36,32.0,
,19.60,0.0,19.60,1000,19.73,0.820,19.73,1300,19.87,8.4,19.98,25.5,19.98,32.0,19.05,25.0,19.18,24.0,19.31,ON,19.44,31.0,19.44,32.0,
,20.64,0.0,20.64,900,20.76,0.820,20.76,1100,20.90,8.2,21.01,25.5,21.01,32.0,20.13,25.0,20.24,23.0,20.37,ON,20.50,31.0,20.50,32.0,
,21.67,0.0,21.67,800,21.79,0.820,21.79,1000,21.92,8.2,22.04,25.5,22.04,32.0,21.15,25.0,21.27,23.0,21.40,ON,21.53,31.0,21.53,32.0,
,22.70,0.0,22.70,800,22.82,0.820,22.82,1000,22.95,9.2,23.07,25.5,23.07,32.0,22.18,25.0,22.30,23.0,22.43,ON,22.56,31.0,22.56,32.0,
,23.73,0.0,23.73,800,23.85,0.820,23.85,1000,23.98,8.2,24.10,25.5,24.10,32.0,23.21,25.0,23.33,23.0,23.46,ON,23.59,31.0,23.59,32.0,
,24.76,0.0,24.76,800,24.89,0.820,24.89,1000,25.03,8.2,25.17,25.5,25.17,32.0,24.24,25.0,24.36,23.0,24.49,ON,24.62,31.0,24.62,32.0,
,25.83,0.0,25.83,800,25.96,0.820,25.96,1000,26.09,8.0,26.23,25.5,26.23,33.0,25.31,25.0,25.44,23.0,25.57,ON,25.69,31.0,25.69,32.0,
,26.86,0.0,26.86,800,27.01,0.820,27.01,1000,27.15,8.0,27.29,25.5,27.29,33.0,26.37,25.0,26.47,23.0,26.60,ON,26.73,31.0,26.73,32.0,
,27.91,0.0,27.91,800,28.05,0.820,28.05,1400,28.19,8.4,28.31,25.5,28.31,33.0,27.40,25.0,27.53,23.0,27.66,ON,27.79,31.0,27.79,32.0,
,28.98,0.0,28.98,1200,29.12,0.820,29.12,1500,29.25,8.2,29.39,25.5,29.39,33.0,28.44,25.0,28.57,23.0,28.71,ON,28.84,31.0,28.84,32.0,
,30.04,0.0,30.04,1000,30.18,0.820,30.18,1100,30.31,8.4,30.43,25.5,30.43,33.0,29.52,25.0,29.66,23.0,29.79,ON,29.92,31.0,29.92,32.0,
,31.07,0.0,31.07,800,31.22,0.820,31.22,1000,31.35,8.2,31.48,26.0,31.48,33.0,30.55,25.0,30.69,23.0,30.82,ON,30.95,31.0,30.95,32.0,
,32.17,0.0,32.17,800,32.32,0.820,32.32,1000,32.45,8.0,32.60,26.0,32.60,33.0,31.61,24.0,31.75,23.0,31.89,ON,32.03,31.0,32.03,32.0,
,33.26,0.0,33.26,800,33.43,0.820,33.43,1000,33.56,8.2,33.70,26.0,33.70,33.0,32.70,25.0,32.84,23.0,32.98,ON,33.13,31.0,33.13,32.0,
,34.37,0.0,34.37,900,34.52,0.820,34.52,1300,34.65,8.0,34.79,25.5,34.79,33.0,33.83,25.0,33.97,22.0,34.10,ON,34.23,31.0,34.23,32.0,
,35.43,0.0,35.43,1400,35.57,0.820,35.57,1800,35.69,8.4,35.82,26.0,35.82,33.0,34.90,24.0,35.05,23.0,35.18,ON,35.30,31.0,35.30,32.0,
,36.47,0.0,36.47,1400,36.62,0.820,36.62,1800,36.76,8.2,36.90,25.5,36.90,33.0,35.96,24.0,36.09,23.0,36.22,ON,36.35,31.0,36.35,32.0,
,37.60,0.0,37.60,1500,37.74,0.820,37.74,2000,37.86,8.0,37.99,26.0,37.99,33.0,37.04,24.0,37.18,22.0,37.32,ON,37.46,31.0,37.46,32.0,
,38.63,0.0,38.63,1800,38.77,0.820,38.77,2200,38.89,7.8,39.02,26.0,39.02,33.0,38.10,25.0,38.25,22.0,38.38,ON,38.50,31.0,38.50,32.0,
,39.67,0.0,39.67,1200,39.82,0.820,39.82,1600,39.96,7.8,40.10,26.0,40.10,33.0,39.15,24.0,39.28,22.0,39.41,ON,39.54,31.0,39.54,32.0,
,40.77,0.0,40.77,1400,40.91,0.820,40.91,1800,41.04,7.8,41.17,26.0,41.17,33.0,40.22,24.0,40.36,22.0,40.50,ON,40.62,31.0,40.62,32.0,
,41.82,0.0,41.82,1500,41.97,0.820,41.97,1900,42.08,9.2,42.22,25.5,42.22,33.0,41.29,24.0,41.43,22.0,41.56,ON,41.69,31.0,41.69,32.0,
,42.85,0.0,42.85,1600,43.00,0.820,43.00,2000,43.11,8.2,43.24,26.0,43.24,33.0,42.33,24.0,42.47,22.0,42.60,ON,42.73,31.0,42.73,32.0,
,43.89,0.0,43.89,1700,44.04,0.820,44.04,2200,44.18,8.0,44.33,26.0,44.33,33.0,43.35,24.0,43.50,22.0,43.63,ON,43.77,31.0,43.77,32.0,
,44.99,0.0,44.99,1400,45.14,0.820,45.14,1900,45.27,8.0,45.39,25.5,45.39,33.0,44.45,24.0,44.59,22.0,44.72,ON,44.85,31.0,44.85,32.0,
,46.03,0.0,46.03,1200,46.18,0.820,46.18,1400,46.31,8.0,46.44,25.5,46.44,33.0,45.51,24.0,45.65,22.0,45.78,ON,45.91,31.0,45.91,32.0,
,47.08,0.0,47.08,900,47.22,0.820,47.22,1100,47.35,8.0,47.49,25.5,47.49,33.0,46.55,24.0,46.70,22.0,46.83,ON,46.95,31.0,46.95,32.0,
,48.16,0.0,48.16,900,48.31,0.820,48.31,1100,48.45,8.0,48.56,25.5,48.56,33.0,47.62,24.0,47.76,22.0,47.89,ON,48.02,31.0,48.02,32.0,
,49.20,0.0,49.20,1100,49.34,0.820,49.34,1400,49.47,8.0,49.59,25.5,49.59,33.0,48.68,24.0,48.82,22.0,48.95,ON,49.08,31.0,49.08,32.0,
,50.23,0.0,50.23,1300,50.38,0.820,50.38,1600,50.51,7.8,50.64,25.5,50.64,34.0,49.71,24.0,49.85,22.0,49.98,ON,50.11,31.0,50.11,32.0,
,51.28,0.0,51.28,1500,51.42,0.820,51.42,1900,51.54,9.0,51.67,25.5,51.67,34.0,50.75,24.0,50.90,22.0,51.03,ON,51.15,31.0,51.15,32.0,
,52.29,0.0,52.29,1500,52.42,0.820,52.42,1900,52.56,8.0,52.68,25.5,52.68,34.0,51.78,24.0,51.92,22.0,52.04,ON,52.17,31.0,52.17,32.0,
,53.31,0.0,53.31,1600,53.45,0.820,53.45,2000,53.57,8.0,53.70,25.5,53.70,34.0,52.80,24.0,52.92,22.0,53.03,ON,53.18,31.0,53.18,32.0,
,54.35,0.0,54.35,1800,54.49,0.820,54.49,2400,54.63,8.0,54.78,25.5,54.78,34.0,53.83,24.0,53.95,22.0,54.07,ON,54.23,31.0,54.23,32.0,
,55.44,0.0,55.44,2100,55.56,0.820,55.56,2700,55.69,8.0,55.85,25.5,55.85,35.0,54.91,24.0,55.03,22.0,55.17,ON,55.31,31.0,55.31,32.0,
,56.50,0.0,56.50,2200,56.62,0.820,56.62,2800,56.75,7.8,56.89,25.5,56.89,35.0,55.98,24.0,56.10,22.0,56.24,ON,56.37,31.0,56.37,32.0,
,57.56,0.0,57.56,2300,57.69,0.820,57.69,2900,57.83,8.0,57.98,25.5,57.98,35.0,57.01,24.0,57.13,22.0,57.26,ON,57.41,31.0,57.41,32.0,
,58.64,0.0,58.64,1600,58.78,0.820,58.78,2000,58.92,8.0,59.06,25.5,59.06,35.0,58.10,24.0,58.22,22.0,58.37,ON,58.51,31.0,58.51,32.0,
,59.72,0.0,59.72,1500,59.85,0.820,59.85,1900,59.98,8.0,60.12,25.5,60.12,35.0,59.17,24.0,59.30,22.0,59.43,ON,59.58,31.0,59.58,32.0,
,60.78,0.0,60.78,1600,60.93,0.820,60.93,2000,61.06,8.0,61.22,25.5,61.22,36.0,60.24,24.0,60.36,22.0,60.50,ON,60.65,31.0,60.65,32.0,
,61.88,0.0,61.88,1600,62.01,0.820,62.01,2000,62.13,8.0,62.29,25.5,62.29,36.0,61.34,24.0,61.48,22.0,61.62,ON,61.76,31.0,61.76,32.0,
,62.95,0.0,62.95,1700,63.09,0.820,63.09,2200,63.23,8.0,63.37,25.5,63.37,36.0,62.41,24.0,62.53,22.0,62.66,ON,62.81,31.0,62.81,32.0,
,64.01,0.0,64.01,1700,64.15,0.820,64.15,2200,64.27,8.0,64.41,25.5,64.41,36.0,63.48,24.0,63.61,22.0,63.74,ON,63.88,31.0,63.88,32.0,
,65.05,0.0,65.05,1600,65.18,0.820,65.18,2000,65.30,8.0,65.45,25.5,65.45,36.0,64.53,24.0,64.65,22.0,64.79,ON,64.93,31.0,64.93,32.0,
,66.10,0.0,66.10,1600,66.22,0.820,66.22,2000,66.35,8.0,66.49,25.5,66.49,36.0,65.57,24.0,65.70,22.0,65.83,ON,65.97,31.0,65.97,32.0,
,67.10,0.0,67.10,1500,67.22,0.820,67.22,1900,67.35,9.0,67.48,25.5,67.48,36.0,66.60,24.0,66.71,22.0,66.83,ON,66.96,31.0,66.96,32.0,
,68.15,0.0,68.15,1500,68.29,0.820,68.29,1900,68.42,8.0,68.56,25.5,68.56,36.0,67.62,24.0,67.75,22.0,67.87,ON,68.00,31.0,68.00,32.0,
,69.25,0.0,69.25,1600,69.37,0.820,69.37,2000,69.50,8.0,69.62,25.5,69.62,37.0,68.71,24.0,68.84,22.0,68.97,ON,69.10,31.0,69.10,32.0,
,70.30,0.0,70.30,1600,70.41,0.820,70.41,2000,70.54,8.0,70.66,25.5,70.66,37.0,69.75,24.0,69.87,22.0,70.01,ON,70.15,31.0,70.15,32.0,
,71.32,0.0,71.32,1600,71.44,0.820,71.44,2000,71.57,8.8,71.69,25.5,71.69,37.0,70.80,25.0,70.93,22.0,71.06,ON,71.18,31.0,71.18,32.0,
,72.37,0.0,72.37,1600,72.51,0.820,72.51,1900,72.66,8.0,72.79,25.5,72.79,38.0,71.83,25.0,71.95,22.0,72.08,ON,72.21,31.0,72.21,32.0,
,73.46,0.0,73.46,1500,73.60,0.820,73.60,1900,73.74,8.0,73.86,25.5,73.86,38.0,72.93,24.0,73.04,22.0,73.18,ON,73.32,31.0,73.32,32.0,
,74.52,0.0,74.52,1500,74.64,0.820,74.64,1900,74.77,8.0,74.90,25.5,74.90,38.0,74.00,24.0,74.12,22.0,74.25,ON,74.38,31.0,74.38,32.0,
,75.57,0.0,75.57,1500,75.71,0.820,75.71,1900,75.85,8.0,75.99,25.5,75.99,38.0,75.04,24.0,75.17,22.0,75.30,ON,75.42,31.0,75.42,32.0,
,76.66,0.0,76.66,1600,76.78,0.820,76.78,2000,76.91,7.8,77.06,25.5,77.06,39.0,76.13,24.0,76.27,22.0,76.39,ON,76.52,31.0,76.52,32.0,
,77.72,0.0,77.72,1600,77.85,0.820,77.85,2000,77.99,7.6,78.13,25.5,78.13,39.0,77.20,24.0,77.33,22.0,77.45,ON,77.58,31.0,77.58,32.0,
,78.81,0.0,78.81,1600,78.94,0.820,78.94,2000,79.08,7.6,79.20,25.5,79.20,39.0,78.27,24.0,78.40,22.0,78.53,ON,78.66,31.0,78.66,32.0,
,79.87,0.0,79.87,1600,80.00,0.820,80.00,2000,80.12,7.6,80.25,25.5,80.25,39.0,79.34,24.0,79.46,22.0,79.59,ON,79.72,31.0,79.72,32.0,
,80.86,0.0,80.86,1600,81.01,0.820,81.01,1900,81.13,8.0,81.26,25.5,81.26,39.0,80.38,24.0,80.50,22.0,80.62,ON,80.75,31.0,80.75,32.0,
,81.92,0.0,81.92,1500,82.07,0.820,82.07,1900,82.22,7.8,82.36,25.5,82.36,39.0,81.38,24.0,81.52,22.0,81.65,ON,81.79,31.0,81.79,32.0,
,83.02,0.0,83.02,1400,83.17,0.820,83.17,1800,83.31,7.8,83.44,25.5,83.44,39.0,82.48,25.0,82.62,22.0,82.76,ON,82.88,31.0,82.88,32.0,
,84.10,0.0,84.10,1300,84.24,0.820,84.24,1600,84.38,7.8,84.52,25.5,84.52,40.0,83.57,25.0,83.71,22.0,83.85,ON,83.97,31.0,83.97,32.0,
,85.17,0.0,85.17,1200,85.31,0.820,85.31,1500,85.44,8.0,85.58,25.5,85.58,40.0,84.65,24.0,84.79,22.0,84.92,ON,85.05,31.0,85.05,32.0,
,86.23,0.0,86.23,1100,86.38,0.820,86.38,1400,86.51,8.0,86.64,25.5,86.64,40.0,85.71,24.0,85.85,22.0,85.98,ON,86.11,31.0,86.11,32.0,
,87.28,0.0,87.28,1000,87.42,0.820,87.42,1100,87.55,8.0,87.69,25.5,87.69,40.0,86.75,24.0,86.88,22.0,87.02,ON,87.15,31.0,87.15,32.0,
,88.36,0.0,88.36,900,88.52,0.820,88.52,1300,88.64,8.0,88.78,25.5,88.78,41.0,87.82,24.0,87.96,22.0,88.09,ON,88.23,31.0,88.23,32.0,
,89.45,0.0,89.45,1100,89.59,0.820,89.59,1500,89.71,8.0,89.84,25.5,89.84,41.0,88.89,24.0,89.04,22.0,89.17,ON,89.31,31.0,89.31,32.0,
,90.48,0.0,90.48,1200,90.62,0.820,90.62,1500,90.75,7.8,90.89,25.5,90.89,41.0,89.95,24.0,90.10,22.0,90.23,ON,90.35,31.0,90.35,32.0,
,91.56,0.0,91.56,1300,91.71,0.820,91.71,1600,91.84,8.0,91.96,25.5,91.96,41.0,91.02,24.0,91.16,22.0,91.29,ON,91.42,31.0,91.42,32.0,
,92.62,0.0,92.62,1400,92.76,0.820,92.76,1800,92.88,8.0,93.01,25.5,93.01,41.0,92.08,25.0,92.22,22.0,92.35,ON,92.48,31.0,92.48,32.0,
,93.65,0.0,93.65,1400,93.79,0.820,93.79,1800,93.91,8.0,94.04,25.5,94.04,42.0,93.12,24.0,93.27,22.0,93.40,ON,93.52,31.0,93.52,32.0,
,94.68,0.0,94.68,1200,94.79,0.820,94.79,1500,94.94,8.0,95.09,25.5,95.09,42.0,94.15,24.0,94.26,22.0,94.42,ON,94.55,31.0,94.55,32.0,
,95.75,0.0,95.75,900,95.89,0.820,95.89,1100,96.04,7.8,96.17,25.5,96.17,42.0,95.22,24.0,95.34,22.0,95.49,ON,95.62,31.0,95.62,32.0,
,96.84,0.0,96.84,800,96.96,0.820,96.96,1000,97.11,7.8,97.25,25.5,97.25,42.0,96.32,24.0,96.45,22.0,96.59,ON,96.71,31.0,96.71,32.0,
,97.92,0.0,97.92,1200,98.06,0.820,98.06,1500,98.21,7.8,98.34,25.5,98.34,42.0,97.38,24.0,97.50,22.0,97.65,ON,97.78,31.0,97.78,32.0,
,98.99,0.0,98.99,1400,99.12,0.820,99.12,1800,99.26,8.0,99.39,25.5,99.39,42.0,98.45,24.0,98.58,22.0,98.73,ON,98.87,31.0,98.87,32.0,
,100.04,0.0,100.04,1400,100.18,0.820,100.18,1800,100.32,8.6,100.46,25.5,100.46,42.0,99.50,24.0,99.62,22.0,99.78,ON,99.92,31.0,99.92,32.0,
,101.12,0.0,101.12,1600,101.26,0.820,101.26,2000,101.41,7.8,101.54,25.5,101.54,42.0,100.58,24.0,100.71,22.0,100.85,ON,100.99,31.0,100.99,32.0,
,102.18,0.0,102.18,1900,102.32,0.820,102.32,2600,102.48,8.0,102.62,25.5,102.62,42.0,101.67,24.0,101.79,22.0,101.93,ON,102.05,31.0,102.05,32.0,
,103.30,0.0,103.30,2200,103.43,0.820,103.43,2800,103.57,8.0,103.71,25.5,103.71,42.0,102.75,24.0,102.87,22.0,103.02,ON,103.15,31.0,103.15,32.0,
,104.37,0.0,104.37,1600,104.50,0.820,104.50,2000,104.66,7.8,104.78,25.5,104.78,43.0,103.83,24.0,103.95,22.0,104.10,ON,104.24,31.0,104.24,32.0,
,105.42,0.0,105.42,1700,105.55,0.820,105.55,2200,105.69,8.0,105.82,25.5,105.82,43.0,104.90,24.0,105.02,22.0,105.17,ON,105.30,31.0,105.30,32.0,
,106.49,0.0,106.49,1800,106.63,0.820,106.63,2400,106.78,8.0,106.91,25.5,106.91,43.0,105.95,24.0,106.07,22.0,106.22,ON,106.35,31.0,106.35,32.0,
,107.55,0.0,107.55,2000,107.67,0.820,107.67,2600,107.81,7.8,107.94,25.5,107.94,43.0,107.02,24.0,107.15,22.0,107.30,ON,107.42,31.0,107.42,32.0,
,108.57,0.0,108.57,1400,108.70,0.820,108.70,1800,108.85,8.0,108.98,25.5,108.98,43.0,108.05,24.0,108.18,22.0,108.32,ON,108.44,31.0,108.44,32.0,
,109.61,0.0,109.61,1400,109.73,0.820,109.73,1800,109.88,8.0,110.00,25.5,110.00,43.0,109.10,25.0,109.21,22.0,109.35,ON,109.47,31.0,109.47,32.0,
,110.68,0.0,110.68,1300,110.82,0.820,110.82,1800,110.97,7.8,111.11,25.5,111.11,44.0,110.12,24.0,110.25,22.0,110.40,ON,110.54,31.0,110.54,32.0,
,111.75,0.0,111.75,1300,111.89,0.820,111.89,1600,112.02,7.8,112.15,25.5,112.15,44.0,111.23,24.0,111.36,22.0,111.50,ON,111.64,31.0,111.64,32.0,
,112.82,0.0,112.82,1100,112.96,0.820,112.96,1400,113.11,8.0,113.24,25.5,113.24,44.0,112.26,24.0,112.38,22.0,112.54,ON,112.68,31.0,112.68,32.0,
,113.91,0.0,113.91,900,114.05,0.820,114.05,1100,114.21,8.6,114.35,25.5,114.35,44.0,113.37,24.0,113.49,22.0,113.64,ON,113.77,31.0,113.77,32.0,
,115.03,0.0,115.03,1000,115.16,0.820,115.16,1100,115.31,7.6,115.44,25.5,115.44,44.0,114.49,24.0,114.60,22.0,114.76,ON,114.88,31.0,114.88,32.0,
,116.11,0.0,116.11,900,116.23,0.820,116.23,1000,116.38,8.0,116.51,25.5,116.51,45.0,115.55,24.0,115.68,22.0,115.83,ON,115.97,31.0,115.97,32.0,
,117.14,0.0,117.14,800,117.26,0.820,117.26,1300,117.41,7.8,117.54,25.5,117.54,45.0,116.63,24.0,116.75,22.0,116.89,ON,117.01,31.0,117.01,32.0,
,118.22,0.0,118.22,1300,118.36,0.820,118.36,1600,118.50,8.0,118.64,25.5,118.64,45.0,117.66,24.0,117.78,22.0,117.94,ON,118.08,31.0,118.08,32.0,
,119.29,0.0,119.29,1600,119.42,0.820,119.42,2000,119.58,7.8,119.71,25.5,119.71,45.0,118.77,24.0,118.89,22.0,119.04,ON,119.17,31.0,119.17,32.0,
,120.39,0.0,120.39,1900,120.53,0.820,120.53,2600,120.68,8.0,120.81,25.5,120.81,45.0,119.83,24.0,119.96,22.0,120.11,ON,120.25,31.0,120.25,32.0,
,121.48,0.0,121.48,1900,121.59,0.820,121.59,2300,121.74,8.0,121.86,25.5,121.86,45.0,120.94,24.0,121.06,22.0,121.21,ON,121.34,31.0,121.34,32.0,
,122.50,0.0,122.50,1500,122.63,0.820,122.63,1900,122.77,8.0,122.91,25.5,122.91,45.0,121.98,24.0,122.11,22.0,122.26,ON,122.38,31.0,122.38,32.0,
,123.59,0.0,123.59,1600,123.73,0.820,123.73,2000,123.89,8.6,124.01,25.5,124.01,45.0,123.05,24.0,123.16,22.0,123.31,ON,123.44,31.0,123.44,32.0,
,124.65,0.0,124.65,1700,124.78,0.820,124.78,2200,124.94,8.0,125.08,25.5,125.08,45.0,124.13,24.0,124.25,22.0,124.40,ON,124.53,31.0,124.53,32.0,
,125.75,0.0,125.75,1800,125.89,0.820,125.89,2300,126.03,8.0,126.15,25.5,126.15,45.0,125.21,24.0,125.33,22.0,125.48,ON,125.61,31.0,125.61,32.0,
,126.81,0.0,126.81,1800,126.95,0.820,126.95,2300,127.11,8.0,127.26,25.5,127.26,46.0,126.27,24.0,126.39,22.0,126.54,ON,126.67,31.0,126.67,32.0,
,127.92,0.0,127.92,1300,128.06,0.820,128.06,1500,128.21,8.0,128.34,25.5,128.34,46.0,127.38,24.0,127.50,22.0,127.65,ON,127.78,31.0,127.78,32.0,
,128.98,0.0,128.98,1200,129.12,0.820,129.12,1500,129.28,8.0,129.42,25.5,129.42,46.0,128.45,24.0,128.58,22.0,128.73,ON,128.85,31.0,128.85,32.0,
,130.10,0.0,130.10,1100,130.23,0.820,130.23,1400,130.38,8.0,130.51,25.5,130.51,47.0,129.56,24.0,129.67,22.0,129.83,ON,129.95,31.0,129.95,32.0,
,131.16,0.0,131.16,1000,131.29,0.820,131.29,1300,131.43,7.6,131.55,25.5,131.55,47.0,130.64,24.0,130.76,22.0,130.91,ON,131.04,31.0,131.04,32.0,
,132.19,0.0,132.19,900,132.32,0.820,132.32,1100,132.47,8.0,132.60,25.5,132.60,47.0,131.67,24.0,131.79,22.0,131.94,ON,132.07,31.0,132.07,32.0,
,133.24,0.0,133.24,1100,133.36,0.820,133.36,1300,133.51,8.0,133.65,25.5,133.65,47.0,132.71,24.0,132.84,22.0,132.99,ON,133.11,31.0,133.11,32.0,
,134.32,0.0,134.32,900,134.46,0.820,134.46,1100,134.60,8.0,134.72,25.5,134.72,47.0,133.78,24.0,133.90,22.0,134.05,ON,134.18,31.0,134.18,32.0,
,135.38,0.0,135.38,1100,135.50,0.820,135.50,1400,135.63,7.6,135.77,25.5,135.77,48.0,134.84,24.0,134.96,22.0,135.11,ON,135.24,31.0,135.24,32.0,
,136.41,0.0,136.41,1400,136.52,0.820,136.52,1800,136.67,7.8,136.81,25.5,136.81,48.0,135.88,24.0,136.01,22.0,136.15,ON,136.27,31.0,136.27,32.0,
,137.43,0.0,137.43,1600,137.55,0.820,137.55,2000,137.70,7.6,137.83,25.5,137.83,48.0,136.93,24.0,137.04,22.0,137.18,ON,137.30,31.0,137.30,32.0,
,138.46,0.0,138.46,1800,138.58,0.820,138.58,2400,138.73,8.0,138.87,25.5,138.87,48.0,137.95,24.0,138.07,22.0,138.21,ON,138.33,31.0,138.33,32.0,
,139.54,0.0,139.54,2000,139.68,0.820,139.68,2400,139.83,8.0,139.97,26.0,139.97,48.0,139.00,24.0,139.12,22.0,139.27,ON,139.40,31.0,139.40,32.0,
,140.60,0.0,140.60,1400,140.73,0.820,140.73,1800,140.86,7.8,140.99,25.5,140.99,48.0,140.07,24.0,140.20,22.0,140.35,ON,140.48,31.0,140.48,32.0,
,141.63,0.0,141.63,1400,141.75,0.820,141.75,1900,141.89,7.8,142.02,25.5,142.02,48.0,141.10,24.0,141.23,22.0,141.38,ON,141.51,31.0,141.51,32.0,
,142.67,0.0,142.67,1500,142.80,0.820,142.80,1900,142.94,8.0,143.07,25.5,143.07,48.0,142.13,24.0,142.26,22.0,142.41,ON,142.55,31.0,142.55,32.0,
,143.70,0.0,143.70,1500,143.83,0.820,143.83,1900,143.96,7.8,144.11,25.5,144.11,48.0,143.18,24.0,143.30,22.0,143.42,ON,143.57,31.0,143.57,32.0,
,144.77,0.0,144.77,1500,144.92,0.820,144.92,2000,145.05,8.0,145.20,25.5,145.20,48.0,144.23,24.0,144.35,22.0,144.49,ON,144.65,31.0,144.65,32.0,
,145.87,0.0,145.87,1700,146.00,0.820,146.00,2200,146.12,8.0,146.27,25.5,146.27,49.0,145.32,24.0,145.44,22.0,145.58,ON,145.74,31.0,145.74,32.0,
,146.94,0.0,146.94,1800,147.08,0.820,147.08,2300,147.22,7.8,147.37,26.0,147.37,49.0,146.40,24.0,146.52,22.0,146.66,ON,146.81,31.0,146.81,32.0,
,148.01,0.0,148.01,1900,148.14,0.820,148.14,2400,148.26,7.8,148.40,25.5,148.40,49.0,147.50,24.0,147.61,22.0,147.75,ON,147.89,31.0,147.89,32.0,
,149.03,0.0,149.03,2000,149.15,0.820,149.15,2600,149.28,8.0,149.42,26.0,149.42,49.0,148.53,24.0,148.64,22.0,148.76,ON,148.89,31.0,148.89,32.0,
,150.09,0.0,150.09,1400,150.21,0.820,150.21,1800,150.33,8.0,150.45,25.5,150.45,49.0,149.56,24.0,149.69,22.0,149.81,ON,149.94,31.0,149.94,32.0,
,151.14,0.0,151.14,1300,151.27,0.820,151.27,1600,151.42,8.0,151.55,26.0,151.55,50.0,150.59,24.0,150.71,22.0,150.86,ON,150.99,31.0,150.99,32.0,
,152.22,0.0,152.22,1200,152.34,0.820,152.34,1500,152.47,8.0,152.59,25.5,152.59,50.0,151.69,24.0,151.82,22.0,151.95,ON,152.08,31.0,152.08,32.0,
,153.26,0.0,153.26,1100,153.39,0.820,153.39,1400,153.51,8.0,153.64,26.0,153.64,50.0,152.74,24.0,152.86,22.0,152.98,ON,153.11,31.0,153.11,32.0,
,154.31,0.0,154.31,1000,154.43,0.820,154.43,1300,154.56,8.0,154.68,26.0,154.68,50.0,153.77,24.0,153.89,22.0,154.02,ON,154.15,31.0,154.15,32.0,
,155.37,0.0,155.37,1200,155.50,0.820,155.50,1600,155.64,8.0,155.76,26.0,155.76,50.0,154.82,24.0,154.94,22.0,155.08,ON,155.22,31.0,155.22,32.0,
,156.43,0.0,156.43,1300,156.56,0.820,156.56,1600,156.68,8.0,156.81,25.5,156.81,50.0,155.89,24.0,156.02,22.0,156.15,ON,156.28,31.0,156.28,32.0,
,157.48,0.0,157.48,1200,157.60,0.820,157.60,1500,157.73,7.6,157.85,25.5,157.85,50.0,156.96,24.0,157.08,22.0,157.21,ON,157.34,31.0,157.34,32.0,
,158.51,0.0,158.51,1200,158.65,0.820,158.65,1500,158.78,7.6,158.92,25.5,158.92,50.0,157.99,24.0,158.11,22.0,158.24,ON,158.37,31.0,158.37,32.0,
,159.60,0.0,159.60,1100,159.74,0.820,159.74,1400,159.87,8.0,160.01,26.0,160.01,51.0,159.06,24.0,159.20,22.0,159.32,ON,159.45,31.0,159.45,32.0,
,160.67,0.0,160.67,900,160.80,0.820,160.80,1100,160.93,8.0,161.05,26.0,161.05,51.0,160.14,24.0,160.26,22.0,160.40,ON,160.52,31.0,160.52,32.0,
,161.71,0.0,161.71,900,161.84,0.820,161.84,1100,161.98,8.0,162.12,25.5,162.12,51.0,161.19,24.0,161.31,22.0,161.44,ON,161.57,31.0,161.57,32.0,
,162.78,0.0,162.78,800,162.90,0.820,162.90,1000,163.04,8.0,163.18,26.0,163.18,51.0,162.26,24.0,162.39,22.0,162.51,ON,162.64,31.0,162.64,32.0,
,163.85,0.0,163.85,800,163.97,0.820,163.97,1000,164.10,8.0,164.23,26.0,164.23,51.0,163.32,24.0,163.45,22.0,163.58,ON,163.70,31.0,163.71,32.0,
,164.85,0.0,164.85,800,165.01,0.820,165.01,1000,165.13,8.0,165.26,26.0,165.26,51.0,164.37,24.0,164.49,22.0,164.60,ON,164.73,31.0,164.73,32.0,
,165.88,0.0,165.88,800,166.02,0.820,166.02,1000,166.15,8.2,166.27,25.5,166.27,51.0,165.37,24.0,165.50,22.0,165.63,ON,165.76,31.0,165.76,32.0,
,166.91,0.0,166.91,800,167.06,0.820,167.06,1000,167.19,8.4,167.32,26.0,167.32,51.0,166.39,24.0,166.53,22.0,166.66,ON,166.79,31.0,166.79,32.0,
,167.96,0.0,167.96,800,168.10,0.820,168.10,1000,168.23,8.4,168.37,26.0,168.37,51.0,167.44,24.0,167.58,22.0,167.71,ON,167.83,31.0,167.83,32.0,
,169.04,0.0,169.04,800,169.19,0.820,169.19,1000,169.32,8.6,169.46,26.0,169.46,51.0,168.50,24.0,168.64,22.0,168.77,ON,168.90,31.0,168.90,32.0,
,170.14,0.0,170.14,800,170.29,0.820,170.29,1000,170.43,8.6,170.57,25.5,170.57,51.0,169.60,24.0,169.73,22.0,169.87,ON,170.00,31.0,170.00,32.0,
,171.24,0.0,171.24,800,171.38,0.820,171.38,1000,171.50,8.8,171.63,26.0,171.63,51.0,170.70,24.0,170.84,22.0,170.97,ON,171.10,31.0,171.10,32.0,
,172.27,0.0,172.27,1100,172.41,0.820,172.41,1800,172.53,8.8,172.66,26.0,172.66,51.0,171.74,24.0,171.88,22.0,172.02,ON,172.14,31.0,172.14,32.0,
,173.30,0.0,173.30,1600,173.44,0.820,173.44,2000,173.56,9.0,173.69,26.0,173.69,51.0,172.77,24.0,172.92,21.0,173.05,ON,173.17,31.0,173.17,32.0,
,174.33,0.0,174.33,1100,174.47,0.820,174.47,1300,174.59,8.8,174.72,26.0,174.72,51.0,173.80,24.0,173.95,21.0,174.08,ON,174.20,31.0,174.20,32.0,
,175.36,0.0,175.36,800,175.50,0.820,175.50,1000,175.62,8.8,175.75,26.0,175.75,51.0,174.83,24.0,174.98,21.0,175.11,ON,175.23,31.0,175.23,32.0,
,176.39,0.0,176.39,800,176.53,0.820,176.53,1000,176.66,8.2,176.80,26.0,176.80,52.0,175.87,24.0,176.01,21.0,176.13,ON,176.25,31.0,176.25,32.0,
,177.46,0.0,177.46,800,177.61,0.820,177.62,1000,177.74,8.4,177.86,26.0,177.86,52.0,176.93,23.0,177.06,21.0,177.19,ON,177.33,31.0,177.33,32.0,
,178.51,0.0,178.51,900,178.64,0.820,178.64,1400,178.77,8.6,178.89,26.0,178.89,52.0,177.98,23.0,178.12,21.0,178.25,ON,178.38,31.0,178.38,32.0,
,179.55,0.0,179.55,1400,179.69,0.820,179.69,1800,179.81,9.0,179.94,26.0,179.94,52.0,179.01,24.0,179.15,21.0,179.28,ON,179.41,31.0,179.41,32.0,
,180.58,0.0,180.58,1600,180.72,0.820,180.72,2200,180.84,9.0,180.97,26.0,180.97,52.0,180.05,23.0,180.20,21.0,180.33,ON,180.45,31.0,180.45,32.0,
,181.61,0.0,181.61,1900,181.75,0.820,181.75,2200,181.88,8.8,182.02,26.0,182.02,52.0,181.08,23.0,181.23,21.0,181.36,ON,181.48,31.0,181.48,32.0,
,182.69,0.0,182.69,1400,182.84,0.820,182.84,1800,182.97,8.6,183.12,26.0,183.12,52.0,182.15,23.0,182.29,21.0,182.42,ON,182.55,31.0,182.55,32.0,
,183.75,0.0,183.75,1800,183.92,0.820,183.92,2300,184.05,9.6,184.19,26.0,184.19,53.0,183.22,23.0,183.36,21.0,183.48,ON,183.61,31.0,183.61,32.0,
,184.86,0.0,184.86,2200,185.01,0.820,185.01,2800,185.14,8.6,185.26,26.0,185.26,53.0,184.32,23.0,184.46,20.0,184.59,ON,184.72,31.0,184.72,32.0,
,185.92,0.0,185.92,1700,186.06,0.820,186.06,2200,186.18,8.8,186.31,26.0,186.31,53.0,185.38,23.0,185.52,20.0,185.65,ON,185.78,31.0,185.78,32.0,
,186.96,0.0,186.96,1800,187.11,0.820,187.11,2300,187.25,9.0,187.39,26.0,187.39,53.0,186.44,23.0,186.58,20.0,186.71,ON,186.84,31.0,186.84,32.0,
,188.06,0.0,188.06,2000,188.21,0.820,188.21,2600,188.35,8.8,188.48,26.0,188.48,53.0,187.53,23.0,187.66,20.0,187.79,ON,187.92,31.0,187.92,32.0,
,189.13,0.0,189.13,1600,189.28,0.820,189.28,1900,189.42,8.8,189.56,26.0,189.56,53.0,188.59,23.0,188.73,20.0,188.87,ON,189.01,31.0,189.01,32.0,
,190.23,0.0,190.23,1500,190.37,0.820,190.37,1900,190.51,9.0,190.65,26.0,190.65,53.0,189.69,23.0,189.83,20.0,189.96,ON,190.08,31.0,190.08,32.0,
,191.30,0.0,191.30,1600,191.45,0.820,191.45,2000,191.58,9.0,191.72,26.0,191.72,53.0,190.78,23.0,190.92,20.0,191.04,ON,191.18,31.0,191.18,32.0,
,192.39,0.0,192.39,1700,192.54,0.820,192.54,2200,192.67,9.2,192.79,26.0,192.79,54.0,191.85,23.0,191.99,20.0,192.12,ON,192.25,31.0,192.25,32.0,
,193.45,0.0,193.45,1800,193.61,0.820,193.61,2300,193.75,9.2,193.89,26.0,193.89,54.0,192.92,22.0,193.05,20.0,193.18,ON,193.31,31.0,193.31,32.0,
,194.57,0.0,194.57,1700,194.71,0.820,194.71,2000,194.84,9.2,194.96,26.0,194.96,54.0,194.03,22.0,194.16,20.0,194.30,ON,194.42,31.0,194.42,32.0,
,195.63,0.0,195.63,1300,195.78,0.820,195.78,1600,195.91,8.8,196.04,26.0,196.04,54.0,195.09,22.0,195.24,20.0,195.37,ON,195.51,31.0,195.51,32.0,
,196.70,0.0,196.70,1500,196.85,0.820,196.85,1900,196.98,9.6,197.12,26.0,197.12,54.0,196.15,22.0,196.30,19.0,196.43,ON,196.56,31.0,196.56,32.0,
,197.77,0.0,197.77,1400,197.91,0.820,197.91,1800,198.04,9.6,198.16,26.0,198.16,54.0,197.23,22.0,197.37,19.0,197.51,ON,197.65,31.0,197.65,32.0,
,198.80,0.0,198.80,1300,198.94,0.820,198.94,1600,199.07,9.8,199.19,26.0,199.19,54.0,198.28,22.0,198.42,19.0,198.55,ON,198.68,31.0,198.68,32.0,
,199.83,0.0,199.83,1100,199.98,0.820,199.98,1300,200.12,9.8,200.26,26.0,200.26,54.0,199.31,22.0,199.45,19.0,199.58,ON,199.71,31.0,199.71,32.0,
,200.93,0.0,200.93,1000,201.09,0.820,201.09,1300,201.22,10.0,201.35,26.0,201.35,54.0,200.39,22.0,200.53,19.0,200.66,ON,200.79,31.0,200.79,32.0,
,202.00,0.0,202.00,900,202.15,0.820,202.15,1100,202.28,10.2,202.41,26.0,202.41,54.0,201.48,22.0,201.62,18.0,201.75,ON,201.88,31.0,201.88,32.0,
,203.04,0.0,203.04,800,203.18,0.820,203.18,1000,203.30,11.2,203.44,26.0,203.44,54.0,202.52,21.0,202.65,18.0,202.78,ON,202.91,31.0,202.91,32.0,
,204.08,0.0,204.08,800,204.21,0.820,204.21,1000,204.34,11.4,204.48,26.0,204.48,54.0,203.55,21.0,203.70,18.0,203.83,ON,203.94,31.0,203.94,32.0,
,205.15,0.0,205.15,700,205.31,0.820,205.31,900,205.44,10.2,205.57,26.0,205.57,55.0,204.62,21.0,204.75,18.0,204.88,ON,205.01,31.0,205.01,32.0,
,206.21,0.0,206.21,800,206.37,0.820,206.37,1000,206.51,10.6,206.63,26.0,206.63,55.0,205.68,21.0,205.83,18.0,205.96,ON,206.08,31.0,206.08,32.0,
,207.30,0.0,207.30,800,207.44,0.820,207.44,1000,207.58,10.8,207.71,26.0,207.71,55.0,206.75,20.0,206.89,18.0,207.03,ON,207.15,31.0,207.15,32.0,
,208.38,0.0,208.38,800,208.52,0.820,208.52,1000,208.64,11.8,208.77,26.0,208.77,55.0,207.84,20.0,207.98,18.0,208.11,ON,208.24,31.0,208.24,32.0,
,209.41,0.0,209.41,800,209.55,0.820,209.55,1000,209.67,12.0,209.80,26.0,209.80,56.0,208.88,20.0,209.02,17.0,209.16,ON,209.28,31.0,209.28,32.0,
,210.44,0.0,210.44,800,210.58,0.820,210.58,1100,210.70,11.0,210.83,26.0,210.83,56.0,209.91,20.0,210.06,17.0,210.19,ON,210.31,31.0,210.31,32.0,
,211.48,0.0,211.48,1300,211.63,0.820,211.63,1600,211.77,11.4,211.91,26.0,211.91,56.0,210.94,20.0,211.08,17.0,211.21,ON,211.34,31.0,211.34,32.0,
,212.58,0.0,212.58,1900,212.73,0.820,212.73,2400,212.86,11.8,212.98,26.0,212.98,56.0,212.04,20.0,212.18,17.0,212.31,ON,212.44,31.0,212.44,32.0,
,213.65,0.0,213.65,1600,213.80,0.820,213.80,1900,213.94,11.6,214.08,26.0,214.08,56.0,213.10,19.0,213.24,17.0,213.38,ON,213.52,31.0,213.52,32.0,
,214.75,0.0,214.75,1700,214.89,0.820,214.89,2300,215.01,11.4,215.14,26.0,215.14,56.0,214.21,20.0,214.35,17.0,214.48,ON,214.61,31.0,214.61,32.0,
,215.79,0.0,215.79,2100,215.94,0.820,215.94,2700,216.07,10.4,216.20,26.0,216.20,56.0,215.27,20.0,215.41,17.0,215.54,ON,215.67,31.0,215.67,32.0,
,216.82,0.0,216.82,1400,216.97,0.820,216.97,1800,217.10,10.0,217.22,26.0,217.22,56.0,216.31,19.0,216.44,16.0,216.57,ON,216.70,31.0,216.70,32.0,
,217.88,0.0,217.88,1400,218.03,0.820,218.03,1800,218.16,9.2,218.30,26.0,218.30,57.0,217.34,19.0,217.49,16.0,217.62,ON,217.75,31.0,217.75,32.0,
,218.95,0.0,218.95,1400,219.09,0.820,219.09,1800,219.22,9.0,219.36,26.5,219.36,57.0,218.44,19.0,218.58,16.0,218.71,ON,218.83,31.0,218.83,32.0,
,220.00,0.0,220.00,1300,220.14,0.820,220.14,1600,220.26,9.2,220.40,26.5,220.40,57.0,219.48,19.0,219.62,16.0,219.76,ON,219.87,31.0,219.87,32.0,
,221.05,0.0,221.05,1300,221.19,0.820,221.19,1600,221.34,9.0,221.47,26.0,221.47,57.0,220.53,19.0,220.66,16.0,220.79,ON,220.92,31.0,220.92,32.0,
,222.14,0.0,222.14,1300,222.29,0.820,222.29,1800,222.42,9.8,222.54,26.0,222.54,57.0,221.60,19.0,221.74,16.0,221.87,ON,222.00,31.0,222.00,32.0,
,223.18,0.0,223.18,1500,223.32,0.820,223.32,1900,223.45,8.8,223.57,26.5,223.57,57.0,222.66,19.0,222.80,16.0,222.93,ON,223.06,31.0,223.06,32.0,
,224.21,0.0,224.21,1700,224.36,0.820,224.36,2200,224.49,9.8,224.62,26.5,224.62,57.0,223.69,19.0,223.83,16.0,223.96,ON,224.09,31.0,224.09,32.0,
,225.25,0.0,225.25,1900,225.40,0.820,225.40,2400,225.53,9.6,225.67,26.5,225.67,57.0,224.73,19.0,224.86,16.0,224.99,ON,225.12,31.0,225.12,32.0,
,226.34,0.0,226.34,1500,226.49,0.820,226.49,1800,226.62,8.6,226.76,26.5,226.76,57.0,225.80,19.0,225.94,15.0,226.07,ON,226.20,31.0,226.20,32.0,
,227.41,0.0,227.41,1300,227.56,0.820,227.56,1600,227.69,8.4,227.82,26.5,227.82,57.0,226.87,20.0,227.01,16.0,227.15,ON,227.29,31.0,227.29,32.0,
,228.45,0.0,228.45,1300,228.60,0.820,228.60,1600,228.73,8.2,228.87,26.5,228.87,57.0,227.93,20.0,228.06,16.0,228.19,ON,228.32,31.0,228.32,32.0,
,229.54,0.0,229.54,1300,229.69,0.820,229.69,1600,229.82,8.4,229.96,26.5,229.96,57.0,229.00,20.0,229.14,16.0,229.27,ON,229.41,31.0,229.41,32.0,
,230.60,0.0,230.60,1300,230.76,0.820,230.76,1600,230.88,8.0,231.02,26.5,231.02,57.0,230.07,20.0,230.21,16.0,230.33,ON,230.46,31.0,230.46,32.0,
,231.68,0.0,231.68,1300,231.82,0.820,231.82,1600,231.96,8.4,232.09,26.5,232.09,58.0,231.14,20.0,231.28,16.0,231.41,ON,231.54,31.0,231.54,32.0,
,232.77,0.0,232.77,1300,232.91,0.820,232.91,1600,233.05,9.2,233.18,26.5,233.18,58.0,232.23,20.0,232.37,16.0,232.50,ON,232.63,31.0,232.63,32.0,
,233.83,0.0,233.83,1300,233.98,0.820,233.98,1600,234.12,8.2,234.26,26.5,234.26,58.0,233.30,21.0,233.44,16.0,233.57,ON,233.69,31.0,233.69,32.0,
,234.91,0.0,234.91,1300,235.05,0.820,235.05,1600,235.18,8.0,235.30,26.5,235.30,58.0,234.39,20.0,234.53,16.0,234.66,ON,234.79,31.0,234.79,32.0,
,235.94,0.0,235.94,1300,236.09,0.820,236.09,1600,236.22,8.2,236.35,26.5,236.35,58.0,235.42,20.0,235.56,16.0,235.69,ON,235.82,31.0,235.82,32.0,
,236.99,0.0,236.99,1200,237.13,0.820,237.13,1500,237.25,8.2,237.38,26.5,237.38,58.0,236.46,21.0,236.61,16.0,236.74,ON,236.86,31.0,236.86,32.0,
,238.00,0.0,238.00,1200,238.13,0.820,238.13,1500,238.27,8.2,238.39,26.5,238.39,58.0,237.49,21.0,237.60,16.0,237.75,ON,237.88,31.0,237.88,32.0,
,239.05,0.0,239.05,1200,239.17,0.820,239.17,1500,239.32,8.4,239.46,26.5,239.46,59.0,238.51,21.0,238.63,17.0,238.79,ON,238.92,31.0,238.92,32.0,
,240.13,0.0,240.13,1200,240.25,0.820,240.25,1500,240.39,9.2,240.52,26.5,240.52,59.0,239.59,22.0,239.71,17.0,239.86,ON,239.99,31.0,239.99,32.0,
,241.17,0.0,241.17,1300,241.30,0.820,241.30,1600,241.44,8.2,241.56,26.5,241.56,59.0,240.65,21.0,240.77,17.0,240.92,ON,241.05,31.0,241.05,32.0,
,242.19,0.0,242.19,1300,242.31,0.820,242.31,1600,242.44,8.2,242.59,26.5,242.59,59.0,241.68,21.0,241.80,17.0,241.92,ON,242.06,31.0,242.06,32.0,
,243.24,0.0,243.24,1300,243.37,0.820,243.37,1600,243.50,8.0,243.62,26.5,243.62,59.0,242.71,22.0,242.83,17.0,242.95,ON,243.08,31.0,243.08,32.0,
,244.28,0.0,244.28,1300,244.40,0.820,244.40,1600,244.52,8.2,244.64,26.5,244.64,59.0,243.76,22.0,243.88,17.0,244.01,ON,244.14,31.0,244.14,32.0,
,245.33,0.0,245.33,1300,245.47,0.820,245.47,1600,245.60,8.2,245.75,26.5,245.75,59.0,244.79,22.0,244.91,17.0,245.04,ON,245.17,31.0,245.17,32.0,
,246.42,0.0,246.42,1300,246.56,0.820,246.56,1600,246.69,8.0,246.82,26.5,246.82,60.0,245.88,22.0,246.03,17.0,246.14,ON,246.28,31.0,246.28,32.0,
,247.49,0.0,247.49,1200,247.63,0.820,247.63,1500,247.77,8.2,247.91,26.5,247.91,60.0,246.96,22.0,247.10,18.0,247.22,ON,247.34,31.0,247.34,32.0,
,248.58,0.0,248.58,1200,248.70,0.820,248.70,1500,248.83,8.0,248.97,26.5,248.97,60.0,248.05,22.0,248.18,17.0,248.31,ON,248.44,31.0,248.44,32.0,
,249.64,0.0,249.64,1200,249.77,0.820,249.77,1500,249.90,7.8,250.03,26.5,250.03,60.0,249.12,22.0,249.24,17.0,249.37,ON,249.50,31.0,249.50,32.0,
,250.70,0.0,250.70,1200,250.83,0.820,250.83,1500,250.98,8.0,251.11,26.5,251.11,60.0,250.16,23.0,250.29,18.0,250.43,ON,250.55,31.0,250.55,32.0,
,251.80,0.0,251.80,1100,251.93,0.820,251.93,1400,252.06,9.2,252.18,26.5,252.18,60.0,251.25,23.0,251.38,18.0,251.51,ON,251.64,31.0,251.64,32.0,
,252.84,0.0,252.84,1100,252.97,0.820,252.97,1400,253.11,7.8,253.25,26.5,253.25,60.0,252.32,23.0,252.44,18.0,252.57,ON,252.70,31.0,252.70,32.0,
,253.92,0.0,253.92,1100,254.04,0.820,254.04,1400,254.17,8.2,254.31,26.5,254.31,60.0,253.39,22.0,253.52,18.0,253.65,ON,253.78,31.0,253.78,32.0,
,254.95,0.0,254.95,1500,255.10,0.820,255.10,2000,255.23,8.4,255.35,26.5,255.35,60.0,254.45,23.0,254.56,18.0,254.70,ON,254.82,31.0,254.82,32.0,
,255.99,0.0,255.99,1700,256.13,0.820,256.13,2200,256.26,9.0,256.38,26.5,256.38,60.0,255.47,23.0,255.61,18.0,255.74,ON,255.87,31.0,255.87,32.0,
,257.02,0.0,257.02,1800,257.17,0.820,257.17,2300,257.31,7.8,257.45,26.5,257.45,60.0,256.50,22.0,256.64,18.0,256.77,ON,256.90,31.0,256.90,32.0,
,258.12,0.0,258.12,1800,258.28,0.820,258.28,2300,258.41,8.2,258.54,26.5,258.54,60.0,257.58,22.0,257.72,18.0,257.85,ON,257.98,31.0,257.98,32.0,
,259.18,0.0,259.18,1800,259.34,0.820,259.34,2300,259.47,9.0,259.60,26.5,259.60,61.0,258.67,23.0,258.80,18.0,258.93,ON,259.06,31.0,259.06,32.0,
,260.24,0.0,260.24,1900,260.37,0.820,260.37,2400,260.49,7.8,260.62,26.5,260.62,61.0,259.71,23.0,259.85,18.0,259.98,ON,260.10,31.0,260.10,32.0,
,261.24,0.0,261.24,1900,261.40,0.820,261.40,2600,261.53,8.0,261.67,26.5,261.67,61.0,260.74,23.0,260.87,18.0,260.99,ON,261.12,31.0,261.12,32.0,
,262.34,0.0,262.34,1500,262.48,0.820,262.48,1900,262.60,8.0,262.73,26.5,262.73,61.0,261.80,23.0,261.94,18.0,262.07,ON,262.20,31.0,262.20,32.0,
,263.38,0.0,263.38,1400,263.52,0.820,263.52,1800,263.65,8.0,263.77,26.5,263.77,61.0,262.86,23.0,263.00,18.0,263.13,ON,263.26,31.0,263.26,32.0,
,264.41,0.0,264.41,1400,264.56,0.820,264.56,1800,264.69,8.0,264.82,26.5,264.82,61.0,263.89,23.0,264.03,18.0,264.16,ON,264.29,31.0,264.29,32.0,
,265.46,0.0,265.46,1400,265.60,0.820,265.60,1800,265.73,8.0,265.87,26.5,265.87,62.0,264.93,23.0,265.08,18.0,265.21,ON,265.33,31.0,265.33,32.0,
,266.54,0.0,266.54,1500,266.69,0.820,266.69,1900,266.83,9.0,266.96,26.5,266.96,62.0,266.00,23.0,266.14,19.0,266.27,ON,266.40,31.0,266.40,32.0,
,267.60,0.0,267.60,1400,267.76,0.820,267.76,1800,267.90,8.0,268.04,26.5,268.04,62.0,267.08,23.0,267.21,19.0,267.33,ON,267.46,31.0,267.46,32.0,
,268.71,0.0,268.71,1400,268.86,0.820,268.86,1800,268.99,9.2,269.11,26.5,269.11,62.0,268.17,23.0,268.31,19.0,268.44,ON,268.57,31.0,268.57,32.0,
,269.75,0.0,269.75,1400,269.89,0.820,269.89,1800,270.02,8.0,270.14,26.5,270.14,62.0,269.23,23.0,269.37,19.0,269.50,ON,269.63,31.0,269.63,32.0,
,270.78,0.0,270.78,1300,270.92,0.820,270.92,1600,271.05,8.0,271.19,26.5,271.19,62.0,270.26,23.0,270.40,19.0,270.53,ON,270.65,31.0,270.65,32.0,
,271.84,0.0,271.84,1300,272.00,0.820,272.00,1600,272.13,8.2,272.27,26.5,272.27,62.0,271.32,23.0,271.45,19.0,271.59,ON,271.72,31.0,271.72,32.0,
,272.94,0.0,272.94,1400,273.10,0.820,273.10,1600,273.23,7.8,273.35,26.5,273.35,63.0,272.40,23.0,272.53,19.0,272.66,ON,272.80,31.0,272.80,32.0,
,273.99,0.0,273.99,1300,274.14,0.820,274.14,1600,274.27,8.0,274.39,26.5,274.39,63.0,273.46,23.0,273.61,19.0,273.74,ON,273.87,31.0,273.87,32.0,
,275.04,0.0,275.04,1200,275.19,0.820,275.19,1500,275.32,8.0,275.46,26.5,275.46,63.0,274.51,23.0,274.65,19.0,274.78,ON,274.91,31.0,274.91,32.0,
,276.11,0.0,276.11,1100,276.25,0.820,276.25,1400,276.38,7.8,276.52,26.5,276.52,63.0,275.59,23.0,275.73,19.0,275.86,ON,275.99,31.0,275.99,32.0,
,277.17,0.0,277.17,1100,277.31,0.820,277.31,1400,277.44,8.0,277.56,26.5,277.56,63.0,276.65,23.0,276.79,19.0,276.92,ON,277.05,31.0,277.05,32.0,
,278.20,0.0,278.20,1000,278.35,0.820,278.35,1300,278.48,8.0,278.61,26.5,278.61,63.0,277.68,23.0,277.82,19.0,277.95,ON,278.08,31.0,278.08,32.0,
,279.23,0.0,279.23,900,279.38,0.820,279.38,1100,279.51,8.0,279.64,26.5,279.64,63.0,278.72,23.0,278.85,20.0,278.98,ON,279.11,31.0,279.11,32.0,
,280.26,0.0,280.26,1200,280.41,0.820,280.41,1500,280.55,8.0,280.69,26.5,280.69,63.0,279.75,23.0,279.88,20.0,280.01,ON,280.14,31.0,280.14,32.0,
,281.36,0.0,281.36,1200,281.50,0.820,281.50,1500,281.63,8.0,281.75,26.5,281.75,64.0,280.82,23.0,280.96,20.0,281.09,ON,281.22,31.0,281.22,32.0,
,282.41,0.0,282.41,1200,282.55,0.820,282.55,1500,282.69,8.0,282.81,26.5,282.81,64.0,281.88,23.0,282.02,20.0,282.15,ON,282.28,31.0,282.28,32.0,
,283.45,0.0,283.45,1100,283.59,0.820,283.59,1400,283.71,8.0,283.84,26.5,283.84,65.0,282.92,23.0,283.07,20.0,283.20,ON,283.32,31.0,283.32,32.0,
,284.46,0.0,284.46,1000,284.59,0.820,284.59,1300,284.73,8.0,284.85,26.5,284.85,65.0,283.96,23.0,284.09,20.0,284.21,ON,284.34,31.0,284.34,32.0,
,285.48,0.0,285.48,800,285.60,0.820,285.60,1000,285.73,8.2,285.87,26.5,285.87,65.0,284.97,23.0,285.08,20.0,285.21,ON,285.34,31.0,285.34,32.0,
,286.48,0.0,286.48,800,286.62,0.820,286.62,900,286.76,8.0,286.89,26.5,286.89,65.0,285.98,23.0,286.09,20.0,286.22,ON,286.35,31.0,286.35,32.0,
,287.55,0.0,287.55,800,287.69,0.820,287.69,1000,287.83,8.0,287.97,26.5,287.97,65.0,287.02,23.0,287.14,20.0,287.26,ON,287.40,31.0,287.40,32.0,
,288.66,0.0,288.66,800,288.78,0.820,288.78,1000,288.91,8.4,289.03,26.5,289.03,66.0,288.12,23.0,288.24,20.0,288.37,ON,288.50,31.0,288.50,32.0,
,289.71,0.0,289.71,800,289.82,0.820,289.82,1000,289.96,8.2,290.07,26.5,290.07,66.0,289.16,23.0,289.28,20.0,289.43,ON,289.56,31.0,289.56,32.0,
,290.73,0.0,290.73,800,290.85,0.820,290.85,1000,290.99,8.4,291.10,26.5,291.10,66.0,290.22,23.0,290.33,20.0,290.47,ON,290.59,31.0,290.59,32.0,
,291.76,0.0,291.76,800,291.88,0.820,291.88,1000,292.02,8.0,292.13,26.5,292.13,66.0,291.25,23.0,291.36,20.0,291.49,ON,291.62,31.0,291.62,32.0,
,292.79,0.0,292.79,800,292.92,0.820,292.92,1000,293.06,8.4,293.20,26.5,293.20,66.0,292.27,23.0,292.39,20.0,292.52,ON,292.65,31.0,292.65,32.0,
,293.89,0.0,293.89,800,294.02,0.820,294.02,1000,294.15,8.0,294.27,26.5,294.27,66.0,293.35,23.0,293.47,20.0,293.61,ON,293.74,31.0,293.74,32.0,
,294.94,0.0,294.94,800,295.07,0.820,295.07,1000,295.19,8.6,295.32,26.5,295.32,66.0,294.40,23.0,294.53,20.0,294.66,ON,294.79,31.0,294.79,32.0,
,295.98,0.0,295.98,800,296.12,0.820,296.12,1000,296.26,8.8,296.40,26.5,296.40,66.0,295.45,23.0,295.57,20.0,295.70,ON,295.83,31.0,295.83,32.0,
,297.08,0.0,297.08,800,297.21,0.820,297.21,1000,297.35,8.6,297.47,27.0,297.47,66.0,296.54,23.0,296.67,20.0,296.80,ON,296.93,31.0,296.93,32.0,
,298.10,0.0,298.10,800,298.26,0.820,298.26,1000,298.39,8.6,298.51,26.5,298.52,66.0,297.60,23.0,297.71,20.0,297.85,ON,297.97,31.0,297.97,32.0,
,299.14,0.0,299.14,800,299.29,0.820,299.29,1000,299.42,8.6,299.54,27.0,299.54,66.0,298.63,23.0,298.76,20.0,298.89,ON,299.02,31.0,299.02,32.0,
,300.17,0.0,300.17,800,300.31,0.820,300.31,1000,300.45,8.8,300.60,27.0,300.60,66.0,299.66,23.0,299.78,20.0,299.91,ON,300.05,31.0,300.05,32.0,
,301.27,0.0,301.27,800,301.42,0.820,301.42,1000,301.55,9.0,301.68,27.0,301.68,66.0,300.73,23.0,300.87,19.0,300.99,ON,301.13,31.0,301.13,32.0,
,302.32,0.0,302.32,800,302.47,0.820,302.47,1000,302.60,8.8,302.73,27.0,302.73,66.0,301.80,23.0,301.94,19.0,302.07,ON,302.19,31.0,302.19,32.0,
,303.40,0.0,303.40,800,303.55,0.820,303.55,1000,303.68,9.0,303.82,27.0,303.82,66.0,302.85,23.0,303.00,19.0,303.13,ON,303.26,31.0,303.26,32.0,
,304.47,0.0,304.47,800,304.61,0.820,304.61,1000,304.74,9.2,304.86,27.0,304.86,66.0,303.95,23.0,304.09,18.0,304.22,ON,304.35,31.0,304.35,32.0,
,305.50,0.0,305.50,800,305.65,0.820,305.65,1000,305.78,9.0,305.91,27.0,305.91,66.0,304.98,23.0,305.12,18.0,305.25,ON,305.38,31.0,305.38,32.0,
,306.55,0.0,306.55,800,306.69,0.820,306.69,1000,306.81,9.2,306.94,27.0,306.94,67.0,306.02,23.0,306.17,18.0,306.30,ON,306.42,31.0,306.42,32.0,
,307.58,6.0,307.58,800,307.70,0.000,307.70,0,307.85,9.0,307.99,27.0,307.99,67.0,307.05,23.0,307.16,18.0,307.32,ON,307.45,31.0,307.45,32.0,
,308.66,6.0,308.66,800,308.80,0.000,308.80,0,308.94,8.6,309.06,27.0,309.06,67.0,308.12,23.0,308.24,18.0,308.39,ON,308.52,31.0,308.52,32.0,
,309.70,6.0,309.70,800,309.83,0.000,309.83,0,309.97,8.6,310.09,27.0,310.09,67.0,309.18,22.0,309.30,18.0,309.45,ON,309.58,31.0,309.58,32.0,
,310.75,6.0,310.75,800,310.87,0.000,310.87,0,311.01,8.6,311.14,27.0,311.14,67.0,310.21,23.0,310.33,17.0,310.48,ON,310.61,31.0,310.61,32.0,
,311.78,0.0,311.78,800,311.90,0.820,311.90,1000,312.05,8.4,312.18,27.0,312.18,67.0,311.26,23.0,311.38,17.0,311.53,ON,311.65,31.0,311.65,32.0,
,312.87,0.0,312.87,800,313.00,0.820,313.00,1000,313.15,8.6,313.27,27.0,313.27,67.0,312.30,22.0,312.43,17.0,312.57,ON,312.72,31.0,312.72,32.0,
,313.95,0.0,313.95,800,314.06,0.820,314.06,1000,314.21,8.8,314.34,27.0,314.34,67.0,313.39,22.0,313.52,17.0,313.67,ON,313.81,31.0,313.81,32.0,
,314.97,0.0,314.97,800,315.09,0.820,315.09,1000,315.24,8.6,315.38,27.0,315.38,67.0,314.47,23.0,314.59,17.0,314.72,ON,314.84,31.0,314.84,32.0,
,316.05,0.0,316.05,800,316.20,0.820,316.20,1000,316.34,9.2,316.48,27.0,316.48,67.0,315.51,23.0,315.63,17.0,315.78,ON,315.91,31.0,315.91,32.0,
,317.14,0.0,317.14,800,317.27,0.820,317.27,1000,317.42,9.2,317.55,27.0,317.55,67.0,316.60,22.0,316.73,17.0,316.87,ON,317.01,31.0,317.01,32.0,
,318.22,0.0,318.22,800,318.36,0.820,318.36,1000,318.51,9.2,318.64,27.0,318.64,67.0,317.68,22.0,317.80,17.0,317.95,ON,318.08,31.0,318.08,32.0,
,319.28,0.0,319.28,800,319.42,0.820,319.42,1000,319.58,9.4,319.71,27.0,319.71,67.0,318.77,23.0,318.89,17.0,319.03,ON,319.15,31.0,319.15,32.0,
,320.34,0.0,320.34,800,320.46,0.820,320.46,1000,320.61,9.6,320.75,27.0,320.75,67.0,319.84,23.0,319.95,17.0,320.09,ON,320.21,31.0,320.21,32.0,
,321.43,0.0,321.43,800,321.56,0.820,321.56,1000,321.71,9.0,321.84,27.0,321.84,67.0,320.89,22.0,321.00,17.0,321.15,ON,321.28,31.0,321.28,32.0,
,322.48,0.0,322.48,800,322.60,0.820,322.60,1000,322.75,9.6,322.88,27.0,322.88,67.0,321.95,22.0,322.08,17.0,322.23,ON,322.35,31.0,322.35,32.0,
,323.54,0.0,323.54,800,323.66,0.820,323.66,1000,323.81,9.6,323.95,27.0,323.95,67.0,323.00,22.0,323.12,16.0,323.28,ON,323.41,31.0,323.41,32.0,
,324.62,0.0,324.62,800,324.76,0.820,324.76,1000,324.92,9.6,325.05,27.0,325.05,67.0,324.08,22.0,324.20,17.0,324.35,ON,324.48,31.0,324.48,32.0,
,325.68,0.0,325.68,800,325.80,0.820,325.80,1000,325.94,9.8,326.07,27.0,326.07,67.0,325.17,22.0,325.30,17.0,325.43,ON,325.55,31.0,325.55,32.0,
,326.71,0.0,326.71,800,326.82,0.820,326.82,1000,326.97,9.6,327.10,27.0,327.10,67.0,326.20,21.0,326.33,16.0,326.45,ON,326.58,31.0,326.58,32.0,
,327.73,0.0,327.73,800,327.85,0.820,327.85,1000,328.00,10.0,328.14,27.0,328.14,67.0,327.21,21.0,327.34,16.0,327.48,ON,327.60,31.0,327.60,32.0,
,328.76,0.0,328.76,800,328.88,0.820,328.88,1000,329.03,10.0,329.17,27.0,329.17,67.0,328.26,21.0,328.38,16.0,328.51,ON,328.63,31.0,328.63,32.0,
,329.84,0.0,329.84,800,329.99,0.820,329.99,1000,330.13,10.2,330.28,27.0,330.28,68.0,329.31,21.0,329.42,16.0,329.57,ON,329.70,31.0,329.70,32.0,
,330.93,0.0,330.93,800,331.05,0.820,331.05,1000,331.20,10.2,331.34,27.0,331.34,68.0,330.39,21.0,330.52,16.0,330.67,ON,330.80,31.0,330.80,32.0,
,332.01,0.0,332.01,800,332.15,0.820,332.15,1000,332.30,10.6,332.43,27.0,332.43,68.0,331.47,20.0,331.59,16.0,331.74,ON,331.87,31.0,331.87,32.0,
,333.07,0.0,333.07,800,333.19,0.820,333.19,1000,333.33,10.6,333.46,27.0,333.46,68.0,332.54,21.0,332.67,16.0,332.82,ON,332.94,31.0,332.94,32.0,
,334.10,0.0,334.10,800,334.22,0.820,334.22,1000,334.36,11.8,334.49,27.0,334.49,68.0,333.57,20.0,333.70,16.0,333.85,ON,333.97,31.0,333.97,32.0,
,335.13,0.0,335.13,800,335.25,0.820,335.25,1000,335.40,11.2,335.53,27.0,335.53,68.0,334.60,20.0,334.73,16.0,334.88,ON,335.00,31.0,335.00,32.0,
,336.21,0.0,336.21,800,336.35,0.820,336.35,1000,336.50,12.0,336.63,27.0,336.63,68.0,335.65,20.0,335.77,16.0,335.93,ON,336.07,31.0,336.07,32.0,
,337.30,0.0,337.30,800,337.42,0.820,337.42,1100,337.58,12.0,337.70,27.0,337.70,68.0,336.77,20.0,336.90,16.0,337.05,ON,337.17,31.0,337.17,32.0,
,338.38,0.0,338.38,1400,338.52,0.820,338.52,1800,338.67,13.4,338.80,27.0,338.80,68.0,337.82,20.0,337.94,16.0,338.10,ON,338.24,31.0,338.24,32.0,
,339.46,0.0,339.46,1600,339.59,0.820,339.59,2000,339.73,12.8,339.86,27.0,339.86,68.0,338.93,20.0,339.05,16.0,339.21,ON,339.34,31.0,339.34,32.0,
,340.49,0.0,340.49,1800,340.61,0.820,340.61,2300,340.77,13.2,340.91,27.0,340.91,68.0,339.97,19.0,340.10,15.0,340.24,ON,340.37,31.0,340.37,32.0,
,341.57,0.0,341.57,1300,341.71,0.820,341.71,1600,341.86,12.4,341.99,27.0,341.99,68.0,341.04,19.0,341.16,16.0,341.30,ON,341.44,31.0,341.44,32.0,
,342.63,0.0,342.63,1500,342.77,0.820,342.77,1900,342.91,13.2,343.03,27.0,343.03,68.0,342.12,19.0,342.24,15.0,342.38,ON,342.50,31.0,342.50,32.0,
,343.69,0.0,343.69,1600,343.81,0.820,343.81,2000,343.96,13.4,344.10,27.0,344.10,68.0,343.15,18.0,343.27,15.0,343.43,ON,343.56,31.0,343.56,32.0,
,344.77,0.0,344.77,1700,344.89,0.820,344.89,2200,345.03,13.2,345.16,27.0,345.16,68.0,344.23,18.0,344.35,15.0,344.50,ON,344.63,31.0,344.63,32.0,
,345.81,0.0,345.81,1700,345.94,0.820,345.94,2200,346.09,13.2,346.22,27.0,346.22,68.0,345.29,18.0,345.41,15.0,345.56,ON,345.69,31.0,345.69,32.0,
,346.87,0.0,346.87,1800,346.98,0.820,346.98,2300,347.12,13.2,347.25,27.0,347.25,68.0,346.36,18.0,346.47,14.0,346.61,ON,346.73,31.0,346.73,32.0,
,347.89,0.0,347.89,1900,348.01,0.820,348.01,2400,348.14,13.2,348.28,27.0,348.28,68.0,347.36,18.0,347.47,14.0,347.61,ON,347.76,31.0,347.76,32.0,
,348.93,0.0,348.93,2000,349.06,0.820,349.06,2700,349.18,13.2,349.33,27.0,349.33,68.0,348.39,17.0,348.50,14.0,348.64,ON,348.80,31.0,348.80,32.0,
,350.00,0.0,350.00,1500,350.14,0.820,350.14,1900,350.29,12.8,350.43,27.0,350.43,68.0,349.46,17.0,349.58,14.0,349.72,ON,349.87,31.0,349.87,32.0,
,351.07,0.0,351.07,1700,351.20,0.820,351.20,2200,351.34,12.8,351.48,27.0,351.48,68.0,350.55,16.0,350.67,14.0,350.81,ON,350.95,31.0,350.95,32.0,
,352.13,0.0,352.13,1900,352.26,0.820,352.26,2400,352.38,12.6,352.53,27.0,352.53,69.0,351.59,16.0,351.70,14.0,351.85,ON,352.00,31.0,352.00,32.0,
,353.20,0.0,353.20,2000,353.33,0.820,353.33,2600,353.46,12.6,353.59,27.0,353.59,69.0,352.66,17.0,352.78,14.0,352.92,ON,353.07,31.0,353.07,32.0,
,354.25,0.0,354.25,1700,354.38,0.820,354.38,2200,354.51,12.4,354.66,27.0,354.66,69.0,353.72,17.0,353.84,14.0,353.98,ON,354.12,31.0,354.12,32.0,
,355.33,0.0,355.33,1500,355.48,0.820,355.48,1900,355.61,12.2,355.76,27.0,355.76,69.0,354.79,16.0,354.91,13.0,355.04,ON,355.19,31.0,355.19,32.0,
,356.40,0.0,356.40,1600,356.53,0.820,356.53,2000,356.67,12.4,356.81,27.0,356.81,69.0,355.88,16.0,356.00,13.0,356.14,ON,356.28,31.0,356.28,32.0,
,357.45,0.0,357.45,1700,357.57,0.820,357.57,2200,357.70,12.4,357.86,27.0,357.86,69.0,356.92,16.0,357.05,13.0,357.18,ON,357.32,31.0,357.32,32.0,
,358.49,0.0,358.49,1700,358.62,0.820,358.62,2200,358.74,12.6,358.88,27.0,358.88,69.0,357.98,16.0,358.09,13.0,358.21,ON,358.36,31.0,358.36,32.0,
,359.52,0.0,359.52,1800,359.65,0.820,359.65,2300,359.77,12.6,359.92,27.0,359.92,69.0,359.00,16.0,359.12,12.0,359.24,ON,359.40,31.0,359.40,32.0,
,360.59,0.0,360.59,1800,360.73,0.820,360.73,2300,360.85,12.2,360.99,27.0,360.99,69.0,360.05,15.0,360.17,12.0,360.31,ON,360.46,31.0,360.46,32.0,
,361.65,0.0,361.65,1800,361.77,0.820,361.77,2300,361.90,12.8,362.05,27.0,362.05,69.0,361.11,16.0,361.23,12.0,361.37,ON,361.52,31.0,361.52,32.0,
,362.69,0.0,362.69,1800,362.82,0.800,362.82,2300,362.94,12.2,363.08,27.0,363.08,69.0,362.17,15.0,362.29,12.0,362.43,ON,362.57,31.0,362.57,32.0,
,363.72,0.0,363.72,1800,363.85,0.810,363.85,2300,363.97,12.8,364.12,27.0,364.12,69.0,363.20,15.0,363.32,12.0,363.46,ON,363.60,31.0,363.60,32.0,
,364.74,0.0,364.74,1800,364.86,0.810,364.86,2300,364.99,13.0,365.11,27.0,365.11,69.0,364.24,15.0,364.35,12.0,364.47,ON,364.60,31.0,364.60,32.0,
,365.79,0.0,365.79,1800,365.93,0.810,365.93,2300,366.07,12.8,366.21,27.0,366.21,69.0,365.25,15.0,365.37,12.0,365.50,ON,365.63,31.0,365.63,32.0,
,366.89,0.0,366.89,1800,367.01,0.800,367.01,2300,367.14,12.4,367.26,27.0,367.26,69.0,366.35,14.0,366.48,12.0,366.61,ON,366.74,31.0,366.74,32.0,
,367.91,0.0,367.91,1800,368.04,0.800,368.04,2300,368.16,12.8,368.29,27.0,368.29,70.0,367.40,14.0,367.52,12.0,367.66,ON,367.78,31.0,367.78,32.0,
,368.98,0.0,368.98,1800,369.12,0.800,369.12,2300,369.27,12.8,369.41,27.0,369.41,70.0,368.43,14.0,368.55,12.0,368.69,ON,368.83,31.0,368.83,32.0,
,370.07,0.0,370.07,1800,370.19,0.780,370.19,2300,370.32,12.8,370.46,27.0,370.46,70.0,369.54,14.0,369.68,12.0,369.80,ON,369.93,31.0,369.93,32.0,
,371.13,0.0,371.13,1800,371.25,0.790,371.25,2300,371.38,12.8,371.50,27.0,371.50,70.0,370.61,14.0,370.73,11.0,370.86,ON,370.99,31.0,370.99,32.0,
,372.13,0.0,372.13,1800,372.29,0.790,372.29,2300,372.42,12.8,372.55,27.0,372.55,71.0,371.63,14.0,371.74,11.0,371.86,ON,371.99,31.0,371.99,32.0,
,373.21,0.0,373.21,1800,373.36,0.790,373.36,2300,373.49,12.8,373.63,27.0,373.63,71.0,372.66,14.0,372.79,11.0,372.93,ON,373.07,31.0,373.07,32.0,
,374.30,0.0,374.30,1800,374.44,0.770,374.44,2300,374.56,12.2,374.70,27.0,374.70,72.0,373.76,13.0,373.90,11.0,374.03,ON,374.17,31.0,374.17,32.0,
,375.34,0.0,375.34,1800,375.49,0.780,375.49,2300,375.63,12.8,375.77,27.0,375.77,72.0,374.82,14.0,374.97,11.0,375.09,ON,375.23,31.0,375.23,32.0,
,376.44,0.0,376.44,1900,376.59,0.780,376.59,2400,376.72,13.6,376.86,27.0,376.86,72.0,375.90,14.0,376.04,11.0,376.17,ON,376.30,31.0,376.30,32.0,
,377.48,0.0,377.48,1900,377.61,0.780,377.61,2400,377.77,12.6,377.90,27.0,377.90,72.0,376.97,14.0,377.11,11.0,377.23,ON,377.36,31.0,377.36,32.0,
,378.53,0.0,378.53,1900,378.65,0.740,378.65,2400,378.80,12.8,378.93,27.0,378.93,72.0,378.02,13.0,378.14,10.0,378.28,ON,378.40,31.0,378.40,32.0,
,379.56,0.0,379.56,1900,379.68,0.750,379.68,2400,379.83,12.6,379.97,27.0,379.97,72.0,379.05,13.0,379.17,10.0,379.31,ON,379.43,31.0,379.43,32.0,
,380.64,0.0,380.64,1900,380.78,0.750,380.78,2400,380.93,12.8,381.06,27.0,381.06,73.0,380.10,13.0,380.22,10.0,380.37,ON,380.50,31.0,380.50,32.0,
,381.71,0.0,381.71,1900,381.83,0.750,381.83,2400,381.98,13.6,382.10,27.0,382.10,73.0,381.20,13.0,381.31,10.0,381.46,ON,381.58,31.0,381.58,32.0,
,382.74,0.0,382.74,1900,382.86,0.730,382.86,2200,382.98,12.6,383.13,27.0,383.13,73.0,382.22,13.0,382.33,10.0,382.45,ON,382.60,31.0,382.60,32.0,
,383.75,0.0,383.75,1500,383.87,0.740,383.87,1900,384.00,13.4,384.14,27.0,384.14,74.0,383.26,13.0,383.36,10.0,383.48,ON,383.61,31.0,383.61,32.0,
,384.76,0.0,384.76,1400,384.90,0.740,384.90,1800,385.03,12.2,385.15,27.0,385.15,74.0,384.27,13.0,384.39,10.0,384.51,ON,384.64,31.0,384.64,32.0,
,385.81,0.0,385.81,1400,385.95,0.740,385.95,1800,386.07,12.2,386.20,27.0,386.20,74.0,385.27,12.0,385.41,10.0,385.55,ON,385.68,31.0,385.68,32.0,
,386.86,0.0,386.86,1400,387.00,0.730,387.00,1800,387.15,13.0,387.28,27.0,387.28,75.0,386.31,13.0,386.42,10.0,386.58,ON,386.72,31.0,386.72,32.0,
,387.93,0.0,387.93,1300,388.06,0.730,388.06,1600,388.20,12.4,388.32,27.0,388.32,75.0,387.42,12.0,387.53,10.0,387.68,ON,387.81,31.0,387.81,32.0,
,388.96,0.0,388.96,1300,389.09,0.750,389.09,1600,389.25,12.0,389.38,27.0,389.38,75.0,388.44,13.0,388.56,10.0,388.71,ON,388.84,31.0,388.84,32.0,
,390.01,0.0,390.01,1200,390.13,0.730,390.13,1500,390.28,12.2,390.41,27.0,390.41,75.0,389.51,13.0,389.62,10.0,389.76,ON,389.88,31.0,389.88,32.0,
,391.04,0.0,391.04,1200,391.16,0.740,391.16,1500,391.31,11.8,391.45,27.0,391.45,75.0,390.53,12.0,390.65,10.0,390.79,ON,390.91,31.0,390.91,32.0,
,392.12,0.0,392.12,1100,392.26,0.740,392.26,1400,392.40,12.2,392.52,27.0,392.52,75.0,391.58,12.0,391.70,10.0,391.85,ON,391.98,31.0,391.98,32.0,
,393.19,0.0,393.19,1400,393.32,0.740,393.32,1800,393.46,12.2,393.58,27.0,393.58,75.0,392.65,13.0,392.78,10.0,392.94,ON,393.07,31.0,393.07,32.0,
,394.23,0.0,394.23,1300,394.36,0.740,394.36,1600,394.51,12.4,394.65,27.0,394.65,76.0,393.70,13.0,393.82,10.0,393.99,ON,394.11,31.0,394.11,32.0,
,395.31,0.0,395.31,1200,395.45,0.750,395.45,1500,395.61,12.2,395.73,27.0,395.73,76.0,394.78,12.0,394.90,10.0,395.04,ON,395.17,31.0,395.17,32.0,
,396.37,0.0,396.37,1000,396.51,0.750,396.51,1300,396.63,12.2,396.77,27.0,396.77,76.0,395.84,12.0,395.95,10.0,396.09,ON,396.24,31.0,396.24,32.0,
,397.42,0.0,397.42,1100,397.57,0.750,397.57,1400,397.69,12.0,397.82,27.0,397.82,76.0,396.89,13.0,397.01,10.0,397.13,ON,397.26,31.0,397.26,32.0,
,398.49,0.0,398.49,1100,398.63,0.730,398.63,1400,398.76,12.2,398.90,27.0,398.90,76.0,397.95,13.0,398.09,10.0,398.21,ON,398.35,31.0,398.35,32.0,
,399.57,0.0,399.57,900,399.69,0.740,399.69,1100,399.82,13.0,399.94,27.0,399.94,77.0,399.04,12.0,399.17,9.0,399.30,ON,399.43,31.0,399.43,32.0,
,400.60,0.0,400.60,800,400.72,0.740,400.72,1000,400.85,11.8,400.98,27.0,400.98,77.0,400.08,13.0,400.20,9.0,400.33,ON,400.46,31.0,400.46,32.0,
,401.65,0.0,401.65,800,401.79,0.760,401.79,1000,401.93,12.0,402.07,27.0,402.07,77.0,401.12,13.0,401.24,10.0,401.36,ON,401.50,31.0,401.50,32.0,
,402.75,0.0,402.75,800,402.88,0.750,402.88,900,403.02,12.0,403.14,27.0,403.14,77.0,402.21,12.0,402.34,9.0,402.47,ON,402.60,31.0,402.60,32.0,
,403.80,0.0,403.80,800,403.94,0.750,403.94,1000,404.06,12.0,404.19,27.0,404.19,77.0,403.27,12.0,403.38,9.0,403.52,ON,403.66,31.0,403.66,32.0,
,404.81,0.0,404.81,800,404.95,0.770,404.95,1000,405.08,12.0,405.20,27.0,405.20,77.0,404.32,13.0,404.44,10.0,404.56,ON,404.69,31.0,404.69,32.0,
,405.85,0.0,405.85,800,406.00,0.770,406.00,1000,406.12,12.0,406.25,27.0,406.25,77.0,405.32,13.0,405.46,10.0,405.59,ON,405.72,31.0,405.72,32.0,
,406.91,0.0,406.91,800,407.05,0.760,407.05,1000,407.20,12.2,407.33,27.0,407.33,77.0,406.36,13.0,406.47,9.0,406.63,ON,406.77,31.0,406.77,32.0,
,408.01,0.0,408.01,800,408.14,0.760,408.14,1000,408.27,12.0,408.39,27.0,408.39,77.0,407.47,13.0,407.58,9.0,407.73,ON,407.86,31.0,407.86,32.0,
,409.04,0.0,409.04,800,409.17,0.780,409.17,1000,409.32,12.2,409.46,27.0,409.46,77.0,408.52,13.0,408.64,10.0,408.79,ON,408.92,31.0,408.92,32.0,
,410.13,0.0,410.13,800,410.25,0.760,410.25,900,410.39,12.0,410.52,27.0,410.52,77.0,409.60,13.0,409.71,10.0,409.86,ON,409.99,31.0,409.99,32.0,
,411.19,0.0,411.19,800,411.32,0.770,411.32,1000,411.47,13.2,411.61,27.5,411.61,78.0,410.65,13.0,410.77,9.0,410.93,ON,411.07,31.0,411.07,32.0,
,412.27,0.0,412.27,1300,412.42,0.790,412.42,1800,412.56,13.0,412.69,27.5,412.69,78.0,411.73,13.0,411.86,9.0,412.00,ON,412.14,31.0,412.14,32.0,
,413.33,0.0,413.33,1600,413.47,0.790,413.47,2200,413.62,13.2,413.75,27.5,413.75,78.0,412.80,13.0,412.93,10.0,413.08,ON,413.20,31.0,413.20,32.0,
,414.39,0.0,414.39,1700,414.51,0.770,414.51,2000,414.66,13.0,414.79,27.5,414.79,78.0,413.86,13.0,413.99,9.0,414.14,ON,414.26,31.0,414.26,32.0,
,415.42,0.0,415.42,1700,415.55,0.780,415.55,2300,415.70,13.4,415.83,27.5,415.83,78.0,414.91,13.0,415.03,9.0,415.17,ON,415.29,31.0,415.29,32.0,
,416.50,0.0,416.50,2000,416.62,0.780,416.62,2600,416.76,13.2,416.89,27.5,416.89,78.0,415.96,13.0,416.08,9.0,416.23,ON,416.36,31.0,416.36,32.0,
,417.54,0.0,417.54,1400,417.67,0.780,417.67,1800,417.82,13.4,417.95,27.5,417.95,78.0,417.02,13.0,417.14,9.0,417.29,ON,417.42,31.0,417.42,32.0,
,418.59,0.0,418.59,1500,418.71,0.780,418.71,1900,418.85,14.4,418.98,27.5,418.98,78.0,418.06,13.0,418.19,9.0,418.34,ON,418.46,31.0,418.46,32.0,
,419.62,0.0,419.62,1600,419.76,0.770,419.76,2200,419.90,14.0,420.02,27.5,420.02,78.0,419.09,13.0,419.22,9.0,419.37,ON,419.49,31.0,419.49,32.0,
,420.66,0.0,420.66,1800,420.78,0.790,420.78,2400,420.91,13.4,421.05,27.5,421.05,78.0,420.14,12.0,420.26,9.0,420.38,ON,420.53,31.0,420.53,32.0,
,421.72,0.0,421.72,2000,421.86,0.790,421.86,2600,421.99,13.6,422.12,27.5,422.12,78.0,421.19,12.0,421.31,9.0,421.45,ON,421.60,31.0,421.60,32.0,
,422.79,0.0,422.79,1700,422.90,0.780,422.90,2000,423.03,14.0,423.17,27.5,423.17,78.0,422.25,13.0,422.37,9.0,422.51,ON,422.65,31.0,422.65,32.0,
,423.83,0.0,423.83,1500,423.95,0.780,423.95,2000,424.08,13.8,424.22,27.5,424.22,78.0,423.29,12.0,423.41,9.0,423.55,ON,423.69,31.0,423.69,32.0,
,424.90,0.0,424.90,1600,425.03,0.780,425.03,2000,425.17,14.0,425.32,27.5,425.32,78.0,424.35,12.0,424.47,9.0,424.61,ON,424.75,31.0,424.75,32.0,
,425.98,0.0,425.98,1700,426.12,0.780,426.12,2200,426.24,13.6,426.39,27.5,426.39,78.0,425.44,12.0,425.56,9.0,425.70,ON,425.85,31.0,425.85,32.0,
,427.02,0.0,427.02,1800,427.15,0.790,427.15,2300,427.27,14.4,427.42,27.5,427.42,78.0,426.51,12.0,426.62,9.0,426.75,ON,426.90,31.0,426.90,32.0,
,428.06,0.0,428.06,1800,428.19,0.790,428.19,2300,428.32,13.8,428.44,27.5,428.44,78.0,427.54,11.0,427.65,9.0,427.77,ON,427.90,31.0,427.90,32.0,
,429.13,0.0,429.13,1800,429.26,0.790,429.26,2300,429.40,13.6,429.55,27.5,429.55,78.0,428.58,12.0,428.70,9.0,428.84,ON,428.98,31.0,428.98,32.0,
,430.21,0.0,430.21,1700,430.34,0.770,430.34,2200,430.46,13.6,430.61,27.5,430.61,78.0,429.67,12.0,429.80,9.0,429.93,ON,430.08,31.0,430.08,32.0,
,431.29,0.0,431.29,1700,431.43,0.780,431.43,2200,431.57,13.6,431.71,27.5,431.71,78.0,430.75,11.0,430.87,9.0,431.00,ON,431.14,31.0,431.14,32.0,
,432.35,0.0,432.35,1600,432.50,0.800,432.50,2000,432.63,14.0,432.75,27.5,432.75,78.0,431.85,11.0,431.96,9.0,432.10,ON,432.22,31.0,432.22,32.0,
,433.39,0.0,433.39,1600,433.54,0.800,433.54,1900,433.67,13.2,433.80,27.0,433.80,78.0,432.87,12.0,433.01,9.0,433.14,ON,433.27,31.0,433.27,32.0,
,434.42,0.0,434.42,1500,434.57,0.780,434.57,1900,434.70,13.2,434.82,27.0,434.82,78.0,433.91,11.0,434.04,9.0,434.17,ON,434.30,31.0,434.30,32.0,
,435.45,0.0,435.45,1400,435.59,0.790,435.59,1800,435.73,12.4,435.87,27.0,435.87,78.0,434.94,12.0,435.06,9.0,435.20,ON,435.33,31.0,435.33,32.0,
,436.54,0.0,436.54,1400,436.69,0.790,436.69,1800,436.83,13.0,436.94,27.0,436.94,78.0,436.00,11.0,436.14,9.0,436.27,ON,436.41,31.0,436.41,32.0,
,437.59,0.0,437.59,1300,437.72,0.790,437.72,1600,437.85,13.0,437.97,27.0,437.97,78.0,437.07,11.0,437.21,9.0,437.34,ON,437.46,31.0,437.46,32.0,
,438.61,0.0,438.61,1200,438.76,0.770,438.76,1500,438.90,12.8,439.02,27.0,439.02,78.0,438.09,11.0,438.23,9.0,438.37,ON,438.49,31.0,438.49,32.0,
,439.66,0.0,439.66,1200,439.80,0.780,439.80,1500,439.94,13.8,440.06,27.0,440.06,79.0,439.14,11.0,439.26,8.0,439.40,ON,439.53,31.0,439.53,32.0,
,440.75,0.0,440.75,1100,440.89,0.800,440.89,1400,441.02,12.6,441.16,27.0,441.16,79.0,440.18,11.0,440.32,9.0,440.47,ON,440.60,31.0,440.60,32.0,
,441.80,0.0,441.80,1000,441.95,0.800,441.95,1300,442.08,12.6,442.20,27.0,442.20,79.0,441.27,11.0,441.41,9.0,441.55,ON,441.67,31.0,441.67,32.0,
,442.84,0.0,442.84,1100,442.99,0.790,442.99,1500,443.13,13.6,443.27,27.0,443.27,79.0,442.32,11.0,442.46,8.0,442.59,ON,442.72,31.0,442.72,32.0,
,443.94,0.0,443.94,1200,444.09,0.810,444.09,1400,444.22,12.6,444.36,27.0,444.36,79.0,443.40,11.0,443.54,8.0,443.67,ON,443.80,31.0,443.80,32.0,
,445.00,0.0,445.00,900,445.16,0.810,445.16,1100,445.29,12.4,445.43,27.0,445.43,80.0,444.47,11.0,444.61,9.0,444.73,ON,444.86,31.0,444.86,32.0,
,446.11,0.0,446.11,800,446.26,0.790,446.26,1000,446.39,12.6,446.51,27.0,446.51,80.0,445.55,11.0,445.70,9.0,445.83,ON,445.97,31.0,445.97,32.0,
,447.17,0.0,447.17,700,447.31,0.800,447.31,900,447.43,12.0,447.56,27.0,447.56,80.0,446.63,11.0,446.77,8.0,446.90,ON,447.03,31.0,447.03,32.0,
,448.21,0.0,448.21,800,448.36,0.800,448.36,1000,448.49,12.0,448.64,27.0,448.64,80.0,447.67,11.0,447.81,8.0,447.95,ON,448.09,31.0,448.09,32.0,
,449.31,0.0,449.31,800,449.45,0.820,449.45,1100,449.59,13.2,449.72,27.0,449.72,80.0,448.77,11.0,448.91,8.0,449.04,ON,449.16,31.0,449.16,32.0,
,450.37,0.0,450.37,1300,450.52,0.800,450.52,1600,450.67,12.6,450.81,27.0,450.81,80.0,449.84,11.0,449.97,8.0,450.10,ON,450.23,31.0,450.23,32.0,
,451.47,0.0,451.47,1400,451.62,0.810,451.62,1800,451.75,12.6,451.87,27.0,451.87,80.0,450.93,11.0,451.07,8.0,451.20,ON,451.33,31.0,451.33,32.0,
,452.51,0.0,452.51,1600,452.65,0.820,452.65,2200,452.78,13.2,452.90,27.0,452.90,80.0,451.99,11.0,452.13,9.0,452.26,ON,452.39,31.0,452.39,32.0,
,453.56,0.0,453.56,2000,453.70,0.820,453.70,2600,453.82,13.4,453.95,27.0,453.95,80.0,453.02,12.0,453.16,9.0,453.29,ON,453.42,31.0,453.42,32.0,
,454.59,0.0,454.59,1700,454.73,0.810,454.73,2000,454.85,13.6,454.98,27.0,454.98,80.0,454.06,12.0,454.21,8.0,454.34,ON,454.46,31.0,454.46,32.0,
,455.62,0.0,455.62,1600,455.76,0.820,455.76,2000,455.88,13.4,456.01,27.0,456.01,80.0,455.09,12.0,455.24,8.0,455.37,ON,455.49,31.0,455.49,32.0,
,456.65,0.0,456.65,1800,456.79,0.820,456.79,2300,456.92,13.4,457.06,27.0,457.06,80.0,456.12,11.0,456.27,9.0,456.40,ON,456.52,31.0,456.52,32.0,
,457.73,0.0,457.73,1900,457.88,0.820,457.88,2300,458.01,13.6,458.13,27.0,458.13,80.0,457.19,11.0,457.33,9.0,457.46,ON,457.59,31.0,457.59,32.0,
,458.77,0.0,458.77,1500,458.91,0.820,458.91,1900,459.04,13.4,459.16,27.0,459.16,80.0,458.25,11.0,458.39,8.0,458.52,ON,458.65,31.0,458.65,32.0,
,459.80,0.0,459.80,1600,459.95,0.820,459.95,2000,460.08,13.2,460.21,27.0,460.21,80.0,459.28,11.0,459.42,8.0,459.55,ON,459.68,31.0,459.68,32.0,
,460.83,0.0,460.83,1600,460.98,0.820,460.98,2200,461.11,14.2,461.24,27.0,461.24,80.0,460.32,11.0,460.45,9.0,460.58,ON,460.71,31.0,460.71,32.0,
,461.86,0.0,461.86,1700,462.01,0.820,462.01,2200,462.14,14.2,462.29,27.0,462.29,80.0,461.35,11.0,461.48,9.0,461.61,ON,461.74,31.0,461.74,32.0,
,462.95,0.0,462.95,1800,463.10,0.820,463.10,2300,463.23,13.0,463.37,27.0,463.37,80.0,462.42,11.0,462.56,8.0,462.69,ON,462.81,31.0,462.81,32.0,
,464.01,0.0,464.01,1400,464.16,0.820,464.16,1600,464.29,13.0,464.41,27.0,464.41,80.0,463.49,11.0,463.63,8.0,463.76,ON,463.88,31.0,463.88,32.0,
,465.07,0.0,465.07,1400,465.21,0.820,465.21,1800,465.34,13.2,465.48,27.0,465.48,81.0,464.53,11.0,464.67,8.0,464.81,ON,464.94,31.0,464.94,32.0,
,466.13,0.0,466.13,1400,466.27,0.800,466.27,1800,466.40,13.2,466.54,27.0,466.54,81.0,465.61,11.0,465.75,8.0,465.88,ON,466.01,31.0,466.01,32.0,
,467.21,0.0,467.21,1400,467.37,0.810,467.37,1800,467.52,14.0,467.65,27.0,467.65,81.0,466.67,11.0,466.81,8.0,466.94,ON,467.07,31.0,467.07,32.0,
,468.32,0.0,468.32,1500,468.47,0.820,468.47,1900,468.60,13.2,468.72,27.0,468.72,81.0,467.78,11.0,467.92,8.0,468.05,ON,468.18,31.0,468.18,32.0,
,469.38,0.0,469.38,1500,469.52,0.820,469.52,1900,469.64,12.6,469.77,27.0,469.77,81.0,468.84,11.0,468.98,8.0,469.11,ON,469.24,31.0,469.24,32.0,
,470.42,0.0,470.42,1500,470.57,0.810,470.57,1900,470.71,13.2,470.85,27.0,470.85,81.0,469.90,11.0,470.04,8.0,470.17,ON,470.30,31.0,470.30,32.0,
,471.52,0.0,471.52,1500,471.67,0.820,471.67,1900,471.80,13.8,471.92,27.0,471.92,81.0,470.98,10.0,471.12,8.0,471.25,ON,471.38,31.0,471.38,32.0,
,472.56,0.0,472.56,1500,472.70,0.820,472.70,1900,472.83,13.0,472.98,27.0,472.98,81.0,472.04,11.0,472.18,8.0,472.31,ON,472.44,31.0,472.44,32.0,
,473.66,0.0,473.66,1500,473.81,0.820,473.81,1900,473.94,12.4,474.06,27.0,474.06,81.0,473.10,11.0,473.25,8.0,473.38,ON,473.52,31.0,473.52,32.0,
,474.70,0.0,474.70,1500,474.83,0.820,474.83,1900,474.97,13.0,475.11,27.0,475.11,81.0,474.18,10.0,474.32,8.0,474.45,ON,474.57,31.0,474.57,32.0,
,475.76,0.0,475.76,1500,475.90,0.820,475.90,1900,476.03,13.0,476.15,27.0,476.15,81.0,475.24,10.0,475.37,8.0,475.50,ON,475.64,31.0,475.64,32.0,
,476.79,0.0,476.79,1500,476.93,0.820,476.93,1900,477.07,13.0,477.21,27.0,477.21,81.0,476.26,11.0,476.40,8.0,476.53,ON,476.66,31.0,476.66,32.0,
,477.88,0.0,477.88,1500,478.03,0.820,478.03,1900,478.17,13.8,478.30,27.0,478.30,81.0,477.32,11.0,477.46,8.0,477.60,ON,477.74,31.0,477.74,32.0,
,478.95,0.0,478.95,1500,479.10,0.820,479.10,1900,479.24,12.8,479.38,27.0,479.38,81.0,478.42,10.0,478.55,8.0,478.68,ON,478.80,31.0,478.80,32.0,
,480.05,0.0,480.05,1500,480.20,0.820,480.20,1900,480.33,12.8,480.45,27.0,480.45,81.0,479.51,10.0,479.65,8.0,479.78,ON,479.91,31.0,479.91,32.0,
,481.11,0.0,481.11,1500,481.25,0.820,481.25,1900,481.37,13.0,481.50,27.0,481.50,81.0,480.57,11.0,480.71,8.0,480.84,ON,480.97,31.0,480.97,32.0,
,482.15,0.0,482.15,1500,482.30,0.820,482.30,1900,482.43,12.8,482.56,27.0,482.56,81.0,481.63,11.0,481.77,8.0,481.90,ON,482.03,31.0,482.03,32.0,
,483.18,0.0,483.18,1500,483.33,0.820,483.33,1900,483.47,13.8,483.61,27.0,483.61,81.0,482.67,10.0,482.80,8.0,482.93,ON,483.06,31.0,483.06,32.0,
,484.28,0.0,484.28,1500,484.44,0.820,484.44,1900,484.57,12.8,484.70,27.0,484.70,81.0,483.74,10.0,483.88,8.0,484.01,ON,484.15,31.0,484.15,32.0,
,485.34,0.0,485.34,1500,485.48,0.820,485.48,1900,485.60,12.8,485.73,27.0,485.73,81.0,484.81,11.0,484.96,8.0,485.09,ON,485.21,31.0,485.21,32.0,
,486.38,0.0,486.38,1500,486.53,0.800,486.53,1900,486.67,13.0,486.81,27.0,486.81,81.0,485.84,10.0,486.00,8.0,486.13,ON,486.26,31.0,486.26,32.0,
,487.48,0.0,487.48,1500,487.62,0.810,487.62,1900,487.74,13.0,487.87,27.0,487.87,81.0,486.94,11.0,487.08,8.0,487.21,ON,487.34,31.0,487.34,32.0,
,488.49,0.0,488.49,1500,488.62,0.820,488.62,1900,488.77,13.2,488.90,27.0,488.90,82.0,487.98,10.0,488.12,8.0,488.23,ON,488.37,31.0,488.37,32.0,
,489.54,0.0,489.54,1500,489.68,0.820,489.68,1900,489.84,13.0,489.97,27.0,489.97,82.0,489.02,10.0,489.15,8.0,489.28,ON,489.41,31.0,489.41,32.0,
,490.65,0.0,490.65,1500,490.78,0.810,490.78,1900,490.93,13.2,491.06,27.0,491.06,82.0,490.11,10.0,490.23,8.0,490.37,ON,490.50,31.0,490.50,32.0,
,491.71,0.0,491.71,1500,491.84,0.820,491.84,1900,491.98,13.2,492.10,27.0,492.10,82.0,491.18,10.0,491.30,8.0,491.46,ON,491.59,31.0,491.59,32.0,
,492.78,0.0,492.78,1500,492.92,0.820,492.92,1900,493.07,13.2,493.20,27.0,493.20,82.0,492.22,10.0,492.34,8.0,492.50,ON,492.64,31.0,492.64,32.0,
,493.85,0.0,493.85,1500,493.98,0.820,493.98,1900,494.14,13.2,494.28,27.0,494.28,82.0,493.33,10.0,493.45,8.0,493.60,ON,493.73,31.0,493.73,32.0,
,494.91,0.0,494.91,1500,495.04,0.820,495.04,1900,495.18,13.2,495.31,27.0,495.31,82.0,494.39,10.0,494.52,8.0,494.66,ON,494.80,31.0,494.80,32.0,
,495.93,0.0,495.93,1500,496.05,0.820,496.05,1900,496.18,13.2,496.34,27.0,496.34,82.0,495.42,10.0,495.55,8.0,495.66,ON,495.80,31.0,495.80,32.0,
,497.01,0.0,497.01,1500,497.16,0.820,497.16,1900,497.29,13.2,497.44,27.0,497.44,82.0,496.47,10.0,496.59,8.0,496.72,ON,496.87,31.0,496.87,32.0,
,498.11,0.0,498.11,1500,498.24,0.820,498.24,1900,498.36,12.4,498.50,27.0,498.50,83.0,497.56,10.0,497.68,8.0,497.82,ON,497.98,31.0,497.98,32.0,
,499.13,0.0,499.13,1500,499.25,0.820,499.25,1900,499.38,13.0,499.50,27.0,499.50,83.0,498.62,10.0,498.74,8.0,498.86,ON,498.99,31.0,498.99,32.0,
,500.18,0.0,500.18,1500,500.32,0.820,500.32,2000,500.46,13.0,500.60,27.0,500.60,83.0,499.64,10.0,499.76,8.0,499.89,ON,500.03,31.0,500.03,32.0,
,501.27,0.0,501.27,1600,501.41,0.820,501.41,2000,501.52,13.0,501.66,27.0,501.66,83.0,500.74,10.0,500.87,8.0,501.00,ON,501.13,31.0,501.13,32.0,
,502.30,0.0,502.30,1600,502.44,0.820,502.44,2000,502.56,13.0,502.69,27.0,502.69,83.0,501.79,10.0,501.91,8.0,502.05,ON,502.16,31.0,502.16,32.0,
,503.35,0.0,503.35,1600,503.48,0.820,503.48,2000,503.61,13.8,503.73,27.0,503.73,83.0,502.84,10.0,502.96,8.0,503.08,ON,503.21,31.0,503.21,32.0,
,504.41,0.0,504.41,1600,504.54,0.820,504.54,1900,504.69,12.8,504.82,27.0,504.82,84.0,503.87,10.0,503.98,8.0,504.12,ON,504.26,31.0,504.26,32.0,
,505.51,0.0,505.51,1500,505.64,0.820,505.64,1900,505.77,13.6,505.89,27.0,505.89,84.0,504.96,10.0,505.09,8.0,505.22,ON,505.35,31.0,505.35,32.0,
,506.57,0.0,506.57,1500,506.71,0.820,506.71,1900,506.85,12.8,506.97,27.0,506.97,84.0,506.03,10.0,506.15,8.0,506.28,ON,506.42,31.0,506.42,32.0,
,507.64,0.0,507.64,1500,507.77,0.820,507.77,1900,507.89,12.4,508.02,27.0,508.02,84.0,507.10,10.0,507.23,8.0,507.36,ON,507.49,31.0,507.49,32.0,
,508.69,0.0,508.69,1500,508.82,0.820,508.82,1900,508.94,12.8,509.06,27.0,509.06,84.0,508.16,10.0,508.29,8.0,508.42,ON,508.55,31.0,508.55,32.0,
,509.72,0.0,509.72,1400,509.84,0.820,509.84,1800,509.97,12.8,510.09,27.0,510.09,84.0,509.20,10.0,509.32,8.0,509.45,ON,509.58,31.0,509.58,32.0,
,510.72,0.0,510.72,1500,510.86,0.810,510.86,1800,510.98,12.4,511.11,27.0,511.11,84.0,510.22,10.0,510.33,8.0,510.45,ON,510.58,31.0,510.58,32.0,
,511.75,0.0,511.75,1400,511.89,0.810,511.89,1800,512.03,12.8,512.15,27.0,512.15,84.0,511.22,10.0,511.37,7.0,511.50,ON,511.62,31.0,511.62,32.0,
,512.83,0.0,512.83,1400,512.98,0.820,512.98,1800,513.11,13.8,513.25,27.0,513.25,84.0,512.27,10.0,512.41,8.0,512.55,ON,512.69,31.0,512.69,32.0,
,513.90,0.0,513.90,1400,514.04,0.820,514.04,1800,514.17,13.0,514.29,27.0,514.29,84.0,513.38,10.0,513.52,8.0,513.65,ON,513.78,31.0,513.78,32.0,
,514.93,0.0,514.93,1400,515.07,0.820,515.07,1800,515.20,12.2,515.32,27.0,515.32,84.0,514.41,10.0,514.55,7.0,514.68,ON,514.81,31.0,514.81,32.0,
,515.95,0.0,515.95,1400,516.10,0.820,516.10,1800,516.25,12.8,516.40,27.0,516.40,84.0,515.44,10.0,515.58,7.0,515.71,ON,515.84,31.0,515.84,32.0,
,517.08,0.0,517.08,1400,517.24,0.820,517.24,1800,517.37,12.8,517.50,27.0,517.50,85.0,516.52,10.0,516.66,8.0,516.80,ON,516.94,31.0,516.95,32.0,
,518.13,0.0,518.13,1300,518.25,0.820,518.25,1600,518.39,12.8,518.51,27.0,518.51,85.0,517.62,10.0,517.75,8.0,517.87,ON,518.00,31.0,518.00,32.0,
,519.14,0.0,519.14,1300,519.26,0.820,519.26,1800,519.39,13.6,519.53,27.0,519.53,85.0,518.63,9.0,518.75,7.0,518.87,ON,519.01,31.0,519.01,32.0,
,520.18,0.0,520.18,1400,520.31,0.820,520.31,1800,520.43,12.6,520.58,27.0,520.58,85.0,519.64,9.0,519.77,7.0,519.90,ON,520.05,31.0,520.05,32.0,
,521.22,0.0,521.22,1400,521.35,0.820,521.35,1800,521.48,12.2,521.62,27.0,521.62,85.0,520.70,10.0,520.81,7.0,520.95,ON,521.09,31.0,521.09,32.0,
,522.28,0.0,522.28,1400,522.42,0.800,522.42,1800,522.56,12.8,522.72,27.0,522.72,85.0,521.74,10.0,521.86,7.0,521.99,ON,522.14,31.0,522.14,32.0,
,523.39,0.0,523.39,1400,523.51,0.810,523.51,1800,523.64,13.6,523.78,27.0,523.78,86.0,522.85,9.0,522.97,7.0,523.10,ON,523.25,31.0,523.25,32.0,
,524.46,0.0,524.46,1400,524.59,0.810,524.59,1800,524.73,12.6,524.88,27.0,524.88,86.0,523.92,9.0,524.03,7.0,524.17,ON,524.32,31.0,524.32,32.0,
,525.54,0.0,525.54,1400,525.66,0.810,525.66,1800,525.79,12.4,525.93,27.0,525.93,86.0,525.00,10.0,525.12,7.0,525.26,ON,525.41,31.0,525.41,32.0,
,526.58,0.0,526.58,1300,526.71,0.810,526.71,1600,526.83,12.6,526.98,27.0,526.98,86.0,526.04,9.0,526.17,7.0,526.30,ON,526.45,31.0,526.45,32.0,
,527.65,0.0,527.65,1300,527.79,0.800,527.79,1600,527.93,12.0,528.08,27.0,528.08,86.0,527.11,10.0,527.23,7.0,527.37,ON,527.52,31.0,527.52,32.0,
,528.72,0.0,528.72,1200,528.85,0.820,528.85,1500,528.97,12.2,529.12,27.0,529.12,86.0,528.20,10.0,528.32,7.0,528.46,ON,528.60,31.0,528.60,32.0,
,529.73,0.0,529.73,1300,529.86,0.820,529.86,1800,529.99,12.4,530.13,27.0,530.13,86.0,529.24,9.0,529.34,7.0,529.46,ON,529.59,31.0,529.59,32.0,
,530.74,0.0,530.74,1400,530.88,0.810,530.88,1800,531.01,12.4,531.13,27.0,531.13,87.0,530.25,9.0,530.37,7.0,530.49,ON,530.62,31.0,530.62,32.0,
,531.77,0.0,531.77,1400,531.91,0.810,531.91,1800,532.04,12.6,532.16,27.0,532.16,87.0,531.26,9.0,531.39,7.0,531.52,ON,531.65,31.0,531.65,32.0,
,532.80,0.0,532.80,1400,532.95,0.810,532.95,1800,533.08,12.6,533.21,27.0,533.21,87.0,532.28,9.0,532.42,7.0,532.55,ON,532.68,31.0,532.68,32.0,
,533.85,0.0,533.85,1300,533.99,0.810,533.99,1600,534.12,13.4,534.26,27.0,534.26,87.0,533.33,9.0,533.47,7.0,533.60,ON,533.72,31.0,533.72,32.0,
,534.93,0.0,534.93,1300,535.08,0.820,535.08,1600,535.21,12.4,535.36,27.0,535.36,87.0,534.39,9.0,534.53,7.0,534.66,ON,534.79,31.0,534.79,32.0,
,535.99,0.0,535.99,1200,536.14,0.820,536.14,1500,536.25,12.4,536.39,27.0,536.39,87.0,535.46,9.0,535.61,6.0,535.74,ON,535.87,31.0,535.87,32.0,
,537.00,0.0,537.00,1100,537.13,0.820,537.13,1400,537.28,12.2,537.41,27.0,537.41,87.0,536.49,9.0,536.63,7.0,536.75,ON,536.88,31.0,536.88,32.0,
,538.05,0.0,538.05,900,538.17,0.800,538.17,1300,538.32,12.0,538.46,27.0,538.46,87.0,537.52,9.0,537.65,7.0,537.80,ON,537.92,31.0,537.92,32.0,
,539.08,0.0,539.08,1200,539.20,0.810,539.20,1600,539.35,13.0,539.49,27.0,539.49,87.0,538.57,8.0,538.70,6.0,538.83,ON,538.95,31.0,538.95,32.0,
,540.16,0.0,540.16,1400,540.31,0.810,540.31,1800,540.45,12.2,540.58,27.0,540.58,87.0,539.62,9.0,539.74,6.0,539.89,ON,540.02,31.0,540.02,32.0,
,541.25,0.0,541.25,1500,541.37,0.810,541.37,2000,541.52,12.6,541.66,27.0,541.66,87.0,540.69,9.0,540.83,6.0,540.99,ON,541.12,31.0,541.12,32.0,
,542.33,0.0,542.33,1700,542.47,0.790,542.47,2200,542.62,12.8,542.75,27.0,542.75,87.0,541.79,9.0,541.91,6.0,542.05,ON,542.18,31.0,542.18,32.0,
,543.39,0.0,543.39,1800,543.51,0.800,543.51,2000,543.65,12.2,543.77,27.0,543.77,87.0,542.89,9.0,543.00,6.0,543.13,ON,543.26,31.0,543.26,32.0,
,544.40,0.0,544.40,1300,544.53,0.820,544.53,1600,544.66,12.6,544.82,27.0,544.82,87.0,543.88,9.0,543.99,6.0,544.13,ON,544.27,31.0,544.27,32.0,
,545.46,0.0,545.46,1300,545.59,0.820,545.59,1600,545.73,12.4,545.84,27.0,545.84,87.0,544.95,8.0,545.05,6.0,545.17,ON,545.30,31.0,545.30,32.0,
,546.54,0.0,546.54,1200,546.66,0.800,546.66,1500,546.81,12.4,546.94,27.0,546.94,87.0,545.98,9.0,546.10,6.0,546.24,ON,546.38,31.0,546.38,32.0,
,547.61,0.0,547.61,1200,547.73,0.810,547.73,1500,547.86,12.4,547.98,27.0,547.98,87.0,547.08,9.0,547.21,6.0,547.34,ON,547.47,31.0,547.47,32.0,
,548.65,0.0,548.65,1100,548.78,0.810,548.78,1400,548.90,11.8,549.03,27.0,549.03,87.0,548.12,8.0,548.24,6.0,548.37,ON,548.50,31.0,548.50,32.0,
,549.69,0.0,549.69,1000,549.83,0.810,549.83,1300,549.97,12.2,550.11,27.0,550.11,87.0,549.16,8.0,549.29,6.0,549.42,ON,549.54,31.0,549.54,32.0,
,550.79,0.0,550.79,1000,550.92,0.820,550.92,1400,551.06,12.2,551.21,27.0,551.21,87.0,550.25,9.0,550.38,6.0,550.51,ON,550.64,31.0,550.64,32.0,
,551.86,0.0,551.86,1400,552.01,0.820,552.01,1800,552.14,12.6,552.28,27.0,552.28,87.0,551.33,9.0,551.46,6.0,551.57,ON,551.70,31.0,551.70,32.0,
,552.96,0.0,552.96,1600,553.09,0.820,553.09,2000,553.21,12.8,553.34,27.0,553.34,87.0,552.42,9.0,552.55,6.0,552.68,ON,552.81,31.0,552.81,32.0,
,554.03,0.0,554.03,1700,554.17,0.820,554.17,2200,554.31,12.8,554.45,27.0,554.45,87.0,553.49,8.0,553.61,6.0,553.74,ON,553.87,31.0,553.87,32.0,
,555.14,0.0,555.14,1700,555.27,0.820,555.27,2200,555.40,13.2,555.52,27.0,555.52,87.0,554.59,9.0,554.72,6.0,554.85,ON,554.98,31.0,554.98,32.0,
,556.19,0.0,556.19,1800,556.32,0.820,556.32,2300,556.43,14.0,556.56,27.0,556.57,87.0,555.66,9.0,555.78,6.0,555.91,ON,556.04,31.0,556.04,32.0,
,557.23,0.0,557.23,1800,557.36,0.820,557.36,2400,557.50,13.2,557.64,27.0,557.64,87.0,556.69,9.0,556.82,6.0,556.95,ON,557.08,31.0,557.08,32.0,
,558.31,0.0,558.31,1500,558.43,0.820,558.43,1800,558.56,13.0,558.71,27.0,558.71,87.0,557.79,9.0,557.92,6.0,558.04,ON,558.17,31.0,558.17,32.0,
,559.37,0.0,559.37,1500,559.50,0.820,559.50,1900,559.64,12.8,559.79,27.0,559.79,87.0,558.85,9.0,558.98,6.0,559.10,ON,559.23,31.0,559.23,32.0,
,560.46,0.0,560.46,1500,560.59,0.820,560.59,1900,560.73,12.2,560.87,27.0,560.87,87.0,559.93,9.0,560.06,6.0,560.18,ON,560.32,31.0,560.32,32.0,
,561.53,0.0,561.53,1600,561.66,0.820,561.66,2000,561.79,12.8,561.92,27.0,561.92,87.0,561.00,9.0,561.12,6.0,561.26,ON,561.38,31.0,561.38,32.0,
,562.59,0.0,562.59,1700,562.73,0.820,562.73,2200,562.87,14.0,563.01,27.0,563.01,87.0,562.06,9.0,562.19,6.0,562.32,ON,562.44,31.0,562.44,32.0,
,563.70,0.0,563.70,1700,563.83,0.820,563.83,2300,563.97,13.0,564.10,27.0,564.10,87.0,563.16,9.0,563.28,6.0,563.42,ON,563.54,31.0,563.54,32.0,
,564.77,0.0,564.77,1400,564.90,0.820,564.90,1600,565.04,12.8,565.18,27.0,565.18,87.0,564.24,9.0,564.36,6.0,564.49,ON,564.61,31.0,564.61,32.0,
,565.87,0.0,565.87,1300,566.01,0.820,566.01,1600,566.15,12.8,566.29,27.0,566.29,87.0,565.31,9.0,565.43,6.0,565.57,ON,565.71,31.0,565.71,32.0,
,566.97,0.0,566.97,1300,567.10,0.820,567.10,1600,567.24,12.6,567.36,27.0,567.36,87.0,566.43,9.0,566.56,6.0,566.69,ON,566.83,31.0,566.83,32.0,
,568.02,0.0,568.02,1300,568.14,0.820,568.14,1600,568.27,13.4,568.41,27.0,568.41,87.0,567.49,9.0,567.62,6.0,567.75,ON,567.88,31.0,567.88,32.0,
,569.05,0.0,569.05,1300,569.21,0.820,569.21,1600,569.35,12.4,569.48,27.0,569.48,87.0,568.55,9.0,568.66,6.0,568.78,ON,568.91,31.0,568.91,32.0,
,570.16,0.0,570.16,1300,570.30,0.820,570.30,1600,570.44,12.4,570.55,27.0,570.55,87.0,569.62,9.0,569.75,6.0,569.89,ON,570.02,31.0,570.02,32.0,
,571.22,0.0,571.22,1300,571.35,0.820,571.35,1600,571.48,12.4,571.61,27.0,571.61,87.0,570.68,9.0,570.81,6.0,570.94,ON,571.07,31.0,571.07,32.0,
,572.28,0.0,572.28,1400,572.43,0.820,572.43,1800,572.57,12.0,572.71,26.5,572.71,87.0,571.75,9.0,571.88,6.0,572.01,ON,572.14,31.0,572.14,32.0,
,573.36,0.0,573.36,1300,573.50,0.820,573.50,1600,573.63,12.4,573.77,26.5,573.77,87.0,572.84,9.0,572.98,7.0,573.11,ON,573.24,31.0,573.24,32.0,
,574.41,0.0,574.41,1300,574.55,0.820,574.55,1600,574.67,12.4,574.80,26.5,574.80,87.0,573.88,9.0,574.03,6.0,574.16,ON,574.28,31.0,574.28,32.0,
,575.44,0.0,575.44,1300,575.56,0.820,575.56,1600,575.70,13.4,575.83,26.5,575.83,87.0,574.91,9.0,575.02,6.0,575.18,ON,575.31,31.0,575.31,32.0,
,576.45,0.0,576.45,1500,576.58,0.820,576.58,2000,576.70,13.6,576.84,26.5,576.84,87.0,575.94,9.0,576.05,7.0,576.19,ON,576.33,31.0,576.33,32.0,
,577.49,0.0,577.49,1700,577.62,0.820,577.62,2200,577.75,12.8,577.87,26.5,577.87,87.0,576.96,9.0,577.08,7.0,577.21,ON,577.33,31.0,577.33,32.0,
,578.56,0.0,578.56,1700,578.69,0.820,578.69,2200,578.83,13.0,578.97,26.5,578.97,87.0,578.02,9.0,578.15,7.0,578.28,ON,578.41,31.0,578.41,32.0,
,579.66,0.0,579.66,1700,579.80,0.820,579.80,2200,579.92,12.8,580.05,26.5,580.05,87.0,579.12,9.0,579.24,7.0,579.37,ON,579.50,31.0,579.50,32.0,
,580.72,0.0,580.72,1700,580.87,0.820,580.87,2200,581.00,12.8,581.14,26.5,581.14,87.0,580.19,9.0,580.33,7.0,580.45,ON,580.57,31.0,580.57,32.0,
,581.82,0.0,581.82,1700,581.95,0.820,581.95,2200,582.07,13.0,582.20,26.5,582.20,87.0,581.27,9.0,581.39,7.0,581.53,ON,581.67,31.0,581.67,32.0,
,582.86,0.0,582.86,1700,582.98,0.820,582.98,2200,583.12,12.8,583.25,26.5,583.25,87.0,582.35,9.0,582.47,7.0,582.60,ON,582.73,31.0,582.73,32.0,
,583.92,0.0,583.92,1700,584.05,0.820,584.05,2200,584.19,12.4,584.33,26.5,584.33,87.0,583.39,9.0,583.52,6.0,583.64,ON,583.77,31.0,583.77,32.0,
,585.00,0.0,585.00,1700,585.13,0.820,585.13,2200,585.26,13.0,585.40,26.5,585.40,87.0,584.49,9.0,584.60,7.0,584.74,ON,584.86,31.0,584.86,32.0,
,586.09,0.0,586.09,1700,586.22,0.820,586.22,2200,586.36,13.0,586.50,26.5,586.50,87.0,585.55,9.0,585.68,7.0,585.81,ON,585.94,31.0,585.94,32.0,
,587.17,0.0,587.17,1700,587.29,0.820,587.29,2200,587.42,13.0,587.54,26.5,587.54,87.0,586.63,9.0,586.75,7.0,586.89,ON,587.03,31.0,587.03,32.0,
,588.20,0.0,588.20,1700,588.34,0.820,588.34,2200,588.46,13.2,588.59,26.5,588.59,87.0,587.67,9.0,587.78,7.0,587.92,ON,588.06,31.0,588.06,32.0,
,589.26,0.0,589.26,1700,589.39,0.820,589.39,2200,589.53,14.0,589.67,26.5,589.67,87.0,588.72,9.0,588.85,7.0,588.98,ON,589.11,31.0,589.11,32.0,
,590.37,0.0,590.37,1700,590.49,0.820,590.49,2200,590.62,13.0,590.74,26.5,590.74,87.0,589.81,9.0,589.95,7.0,590.09,ON,590.22,31.0,590.22,32.0,
,591.42,0.0,591.42,1700,591.56,0.820,591.56,2200,591.70,13.0,591.84,26.5,591.84,87.0,590.87,9.0,591.00,7.0,591.13,ON,591.27,31.0,591.27,32.0,
,592.52,0.0,592.52,1700,592.65,0.820,592.65,2200,592.79,13.0,592.91,26.5,592.91,87.0,591.98,9.0,592.09,7.0,592.23,ON,592.37,31.0,592.37,32.0,
,593.57,0.0,593.57,1800,593.69,0.820,593.69,2300,593.82,13.0,593.95,26.5,593.95,87.0,593.05,9.0,593.17,7.0,593.30,ON,593.43,31.0,593.43,32.0,
,594.62,0.0,594.62,1400,594.76,0.820,594.76,1600,594.91,13.8,595.04,26.5,595.04,87.0,594.09,9.0,594.22,7.0,594.35,ON,594.47,31.0,594.47,32.0,
,595.73,0.0,595.73,1400,595.86,0.820,595.86,1800,595.99,12.8,596.11,26.5,596.11,87.0,595.18,9.0,595.31,7.0,595.44,ON,595.57,31.0,595.57,32.0,
,596.79,0.0,596.79,1400,596.93,0.820,596.93,1800,597.06,12.8,597.21,26.5,597.21,87.0,596.25,9.0,596.37,7.0,596.50,ON,596.63,31.0,596.63,32.0,
,597.89,0.0,597.89,1400,598.02,0.820,598.02,1800,598.15,12.6,598.27,26.5,598.27,87.0,597.34,9.0,597.46,7.0,597.60,ON,597.74,31.0,597.74,32.0,
,598.95,0.0,598.95,1400,599.09,0.820,599.09,1800,599.23,12.6,599.37,26.5,599.37,87.0,598.41,9.0,598.54,7.0,598.66,ON,598.80,31.0,598.80,32.0,
,600.04,0.0,600.04,1400,600.16,0.820,600.16,1800,600.29,12.6,600.41,26.5,600.41,87.0,599.51,9.0,599.64,7.0,599.77,ON,599.90,31.0,599.90,32.0,
,601.07,0.0,601.07,1400,601.19,0.820,601.19,1800,601.32,13.4,601.44,26.5,601.44,87.0,600.54,9.0,600.67,7.0,600.80,ON,600.93,31.0,600.93,32.0,
,602.10,0.0,602.10,1400,602.22,0.820,602.22,1800,602.35,12.4,602.47,26.5,602.47,87.0,601.58,9.0,601.70,7.0,601.83,ON,601.96,31.0,601.96,32.0,
,603.13,0.0,603.13,1300,603.25,0.820,603.25,1800,603.38,12.4,603.50,26.5,603.50,87.0,602.61,9.0,602.73,7.0,602.86,ON,602.99,31.0,602.99,32.0,
,604.16,0.0,604.16,1400,604.28,0.820,604.28,1800,604.41,12.0,604.53,26.5,604.53,87.0,603.64,9.0,603.76,7.0,603.89,ON,604.02,31.0,604.02,32.0,
,605.19,0.0,605.19,1400,605.31,0.820,605.31,1800,605.44,12.4,605.56,26.5,605.56,87.0,604.67,9.0,604.79,7.0,604.92,ON,605.05,31.0,605.05,32.0,
,606.25,0.0,606.25,1400,606.38,0.820,606.38,1800,606.52,12.2,606.66,26.5,606.66,87.0,605.70,9.0,605.82,7.0,605.96,ON,606.10,31.0,606.10,32.0,
,607.33,0.0,607.33,1400,607.45,0.820,607.45,1800,607.58,12.2,607.70,26.5,607.70,87.0,606.79,9.0,606.91,7.0,607.05,ON,607.19,31.0,607.19,32.0,
,608.36,0.0,608.36,1400,608.48,0.820,608.48,1800,608.61,13.2,608.73,26.5,608.73,87.0,607.84,9.0,607.96,7.0,608.09,ON,608.22,31.0,608.22,32.0,
,609.39,0.0,609.39,1300,609.51,0.820,609.51,1600,609.64,12.4,609.76,26.5,609.76,87.0,608.87,9.0,608.99,7.0,609.12,ON,609.25,31.0,609.25,32.0,
,610.37,0.0,610.37,1300,610.52,0.820,610.52,1600,610.65,12.4,610.78,26.5,610.78,87.0,609.89,9.0,610.00,7.0,610.12,ON,610.25,31.0,610.25,32.0,
,611.42,0.0,611.42,1300,611.58,0.820,611.58,1600,611.72,12.4,611.86,26.5,611.86,87.0,610.89,9.0,611.03,7.0,611.17,ON,611.28,31.0,611.28,32.0,
,612.52,0.0,612.52,1300,612.68,0.820,612.68,1600,612.82,12.4,612.94,26.5,612.94,87.0,611.98,9.0,612.12,7.0,612.25,ON,612.38,31.0,612.38,32.0,
,613.59,0.0,613.59,1300,613.72,0.820,613.72,1600,613.85,13.2,613.97,26.5,613.97,87.0,613.06,9.0,613.20,7.0,613.34,ON,613.45,31.0,613.45,32.0,
,614.62,0.0,614.62,1300,614.75,0.820,614.75,1600,614.87,12.4,615.00,26.5,615.00,87.0,614.08,9.0,614.23,7.0,614.37,ON,614.48,31.0,614.48,32.0,
,615.64,0.0,615.64,1400,615.78,0.820,615.78,1800,615.90,12.4,616.03,26.5,616.03,87.0,615.11,9.0,615.26,7.0,615.40,ON,615.51,31.0,615.51,32.0,
,616.67,0.0,616.67,1400,616.81,0.820,616.81,1800,616.94,12.0,617.08,26.5,617.08,87.0,616.14,9.0,616.29,7.0,616.42,ON,616.54,31.0,616.54,32.0,
,617.76,0.0,617.76,1400,617.90,0.820,617.90,1800,618.04,12.4,618.17,26.5,618.17,87.0,617.21,10.0,617.35,7.0,617.49,ON,617.61,31.0,617.61,32.0,
,618.82,0.0,618.82,1400,618.97,0.820,618.97,1800,619.10,12.4,619.23,26.5,619.23,87.0,618.30,9.0,618.44,7.0,618.57,ON,618.70,31.0,618.70,32.0,
,619.89,0.0,619.89,1400,620.05,0.820,620.05,1800,620.18,12.6,620.31,26.5,620.31,87.0,619.34,9.0,619.47,7.0,619.61,ON,619.75,31.0,619.75,32.0,
,620.98,0.0,620.98,1400,621.12,0.820,621.12,1800,621.25,13.4,621.38,26.5,621.38,87.0,620.42,9.0,620.56,7.0,620.70,ON,620.84,31.0,620.84,32.0,
,622.02,0.0,622.02,1400,622.17,0.820,622.17,1800,622.31,12.6,622.46,26.5,622.46,87.0,621.50,9.0,621.64,7.0,621.77,ON,621.90,31.0,621.90,32.0,
,623.15,0.0,623.15,1400,623.29,0.820,623.29,1600,623.41,12.6,623.54,26.5,623.54,87.0,622.58,9.0,622.73,7.0,622.87,ON,623.01,31.0,623.01,32.0,
,624.19,0.0,624.19,1300,624.34,0.820,624.34,1600,624.48,12.6,624.62,26.5,624.62,87.0,623.67,10.0,623.81,7.0,623.93,ON,624.07,31.0,624.07,32.0,
,625.29,0.0,625.29,1200,625.43,0.820,625.43,1500,625.57,12.0,625.70,26.5,625.70,87.0,624.75,9.0,624.88,7.0,625.01,ON,625.15,31.0,625.15,32.0,
,626.35,0.0,626.35,1300,626.50,0.820,626.50,1800,626.64,12.6,626.78,26.5,626.78,87.0,625.82,9.0,625.96,7.0,626.11,ON,626.23,31.0,626.23,32.0,
,627.45,0.0,627.45,1400,627.59,0.820,627.59,1800,627.71,13.4,627.84,26.5,627.84,87.0,626.91,9.0,627.05,7.0,627.18,ON,627.31,31.0,627.31,32.0,
,628.49,0.0,628.49,1500,628.64,0.820,628.64,1800,628.77,12.6,628.90,26.5,628.90,87.0,627.97,10.0,628.12,7.0,628.24,ON,628.37,31.0,628.37,32.0,
,629.54,0.0,629.54,1500,629.68,0.820,629.68,1900,629.80,12.2,629.93,26.5,629.93,87.0,629.01,10.0,629.14,7.0,629.27,ON,629.40,31.0,629.40,32.0,
,630.57,0.0,630.57,1500,630.69,0.820,630.69,1900,630.84,12.6,630.98,26.5,630.98,87.0,630.04,9.0,630.15,7.0,630.31,ON,630.44,31.0,630.44,32.0,
,631.65,0.0,631.65,1500,631.79,0.820,631.79,1800,631.93,13.6,632.08,26.5,632.08,87.0,631.11,10.0,631.23,7.0,631.38,ON,631.51,31.0,631.51,32.0,
,632.72,0.0,632.72,1400,632.86,0.820,632.86,1800,633.01,12.8,633.15,26.5,633.15,87.0,632.20,9.0,632.32,7.0,632.47,ON,632.60,31.0,632.60,32.0,
,633.82,0.0,633.82,1400,633.96,0.820,633.96,1600,634.11,12.6,634.24,26.5,634.24,87.0,633.28,9.0,633.40,7.0,633.55,ON,633.68,31.0,633.68,32.0,
,634.89,0.0,634.89,1200,635.02,0.820,635.02,1500,635.18,12.4,635.32,26.5,635.32,87.0,634.35,9.0,634.48,7.0,634.63,ON,634.77,31.0,634.77,32.0,
,635.99,0.0,635.99,1000,636.13,0.820,636.13,1100,636.28,12.2,636.41,26.5,636.41,88.0,635.45,9.0,635.57,7.0,635.73,ON,635.86,31.0,635.86,32.0,
,637.07,0.0,637.07,1100,637.20,0.820,637.20,1400,637.35,12.2,637.48,26.5,637.48,88.0,636.54,9.0,636.66,7.0,636.82,ON,636.94,31.0,636.94,32.0,
,638.12,0.0,638.12,1000,638.26,0.820,638.26,1300,638.41,12.0,638.55,26.5,638.55,88.0,637.60,10.0,637.72,7.0,637.85,ON,637.98,31.0,637.98,32.0,
,639.21,0.0,639.21,900,639.35,0.820,639.35,1000,639.51,12.0,639.64,26.5,639.64,88.0,638.67,9.0,638.80,7.0,638.94,ON,639.08,31.0,639.08,32.0,
,640.27,0.0,640.27,800,640.39,0.820,640.39,1000,640.54,12.0,640.68,26.5,640.68,88.0,639.76,10.0,639.88,7.0,640.02,ON,640.14,31.0,640.14,32.0,
,641.35,0.0,641.35,800,641.49,0.820,641.49,1000,641.63,12.0,641.75,26.5,641.75,88.0,640.81,10.0,640.93,7.0,641.08,ON,641.21,31.0,641.21,32.0,
,642.39,0.0,642.39,800,642.52,0.820,642.52,1000,642.67,12.0,642.80,26.5,642.80,88.0,641.87,9.0,641.99,7.0,642.14,ON,642.27,31.0,642.27,32.0,
,643.45,0.0,643.45,800,643.58,0.820,643.58,1000,643.72,11.8,643.84,26.5,643.84,88.0,642.91,9.0,643.04,7.0,643.19,ON,643.33,31.0,643.33,32.0,
,644.52,0.0,644.52,800,644.66,0.820,644.66,1000,644.82,12.4,644.95,26.5,644.95,88.0,643.96,10.0,644.08,7.0,644.24,ON,644.38,31.0,644.38,32.0,
,645.61,0.0,645.61,800,645.75,0.820,645.75,1000,645.89,11.8,646.03,26.5,646.03,88.0,645.07,10.0,645.19,7.0,645.35,ON,645.48,31.0,645.48,32.0,
,646.64,0.0,646.64,800,646.76,0.820,646.76,1000,646.90,12.2,647.04,26.5,647.04,88.0,646.14,9.0,646.25,7.0,646.37,ON,646.51,31.0,646.51,32.0,
,647.68,0.0,647.68,700,647.81,0.820,647.81,900,647.93,12.2,648.08,26.5,648.08,88.0,647.16,9.0,647.28,7.0,647.41,ON,647.56,31.0,647.56,32.0,
,648.75,0.0,648.75,1000,648.89,0.820,648.89,1300,649.03,12.2,649.18,26.5,649.18,88.0,648.21,10.0,648.33,7.0,648.47,ON,648.62,31.0,648.62,32.0,
,649.81,0.0,649.81,1000,649.95,0.820,649.95,1400,650.07,12.4,650.21,27.0,650.21,88.0,649.30,10.0,649.42,7.0,649.56,ON,649.70,31.0,649.70,32.0,
,650.84,0.0,650.84,1100,650.96,0.820,650.96,1400,651.09,12.6,651.23,27.0,651.23,88.0,650.33,9.0,650.45,7.0,650.57,ON,650.70,31.0,650.70,32.0,
,651.90,0.0,651.90,1200,652.02,0.820,652.02,1500,652.14,12.6,652.26,27.0,652.26,88.0,651.37,9.0,651.50,7.0,651.62,ON,651.76,31.0,651.76,32.0,
,652.89,0.0,652.89,1400,653.03,0.820,653.03,1800,653.15,13.8,653.28,27.0,653.28,88.0,652.39,10.0,652.51,7.0,652.62,ON,652.75,31.0,652.75,32.0,
,653.94,0.0,653.94,1600,654.08,0.820,654.08,2300,654.23,13.4,654.36,27.0,654.36,88.0,653.39,10.0,653.50,7.0,653.68,ON,653.81,31.0,653.81,32.0,
,655.03,0.0,655.03,1900,655.18,0.820,655.18,2000,655.31,13.4,655.43,27.0,655.43,88.0,654.49,10.0,654.61,7.0,654.76,ON,654.89,31.0,654.89,32.0,
,656.09,0.0,656.09,1500,656.21,0.820,656.21,1900,656.36,13.4,656.50,27.0,656.50,88.0,655.55,9.0,655.67,7.0,655.83,ON,655.97,31.0,655.97,32.0,
,657.17,0.0,657.17,2000,657.31,0.820,657.31,2600,657.46,13.2,657.59,27.0,657.59,88.0,656.63,10.0,656.76,7.0,656.90,ON,657.04,31.0,657.04,32.0,
,658.23,0.0,658.23,2500,658.35,0.820,658.35,3200,658.49,14.0,658.62,27.0,658.62,88.0,657.70,10.0,657.83,7.0,657.98,ON,658.10,31.0,658.10,32.0,
,659.26,0.0,659.26,1800,659.40,0.820,659.40,2300,659.56,13.8,659.70,27.0,659.70,88.0,658.75,9.0,658.87,7.0,659.01,ON,659.13,31.0,659.13,32.0,
,660.37,0.0,660.37,2000,660.51,0.820,660.51,2700,660.66,13.4,660.79,27.0,660.79,88.0,659.83,10.0,659.95,7.0,660.10,ON,660.23,31.0,660.23,32.0,
,661.43,0.0,661.43,2000,661.57,0.820,661.57,2200,661.72,13.8,661.85,27.0,661.85,88.0,660.91,10.0,661.03,7.0,661.18,ON,661.30,31.0,661.30,32.0,
,662.48,0.0,662.48,1600,662.61,0.820,662.61,2000,662.75,13.6,662.90,27.0,662.90,88.0,661.96,9.0,662.07,7.0,662.19,ON,662.34,31.0,662.34,32.0,
,663.56,0.0,663.56,1700,663.69,0.820,663.69,2200,663.82,13.4,663.97,27.0,663.97,88.0,663.03,9.0,663.15,7.0,663.29,ON,663.44,31.0,663.44,32.0,
,664.60,0.0,664.60,1700,664.74,0.820,664.74,2200,664.88,13.4,665.03,27.0,665.03,88.0,664.09,10.0,664.21,7.0,664.34,ON,664.48,31.0,664.48,32.0,
,665.67,0.0,665.67,1800,665.79,0.820,665.79,2300,665.91,13.4,666.06,27.0,666.06,88.0,665.16,10.0,665.27,7.0,665.41,ON,665.55,31.0,665.55,32.0,
,666.73,0.0,666.73,1800,666.88,0.820,666.88,2400,667.01,13.4,667.16,27.0,667.16,88.0,666.19,9.0,666.31,7.0,666.44,ON,666.59,31.0,666.59,32.0,
,667.83,0.0,667.83,1900,667.96,0.820,667.96,2400,668.08,13.4,668.23,27.0,668.23,88.0,667.28,10.0,667.41,7.0,667.54,ON,667.70,31.0,667.70,32.0,
,668.90,0.0,668.90,1500,669.04,0.820,669.04,1900,669.18,13.0,669.33,27.0,669.33,88.0,668.36,10.0,668.48,7.0,668.62,ON,668.77,31.0,668.77,32.0,
,669.97,0.0,669.97,1400,670.10,0.820,670.10,1800,670.22,12.8,670.36,26.5,670.36,88.0,669.46,9.0,669.57,7.0,669.71,ON,669.85,31.0,669.85,32.0,
,671.00,0.0,671.00,1400,671.13,0.820,671.13,1800,671.27,12.6,671.41,27.0,671.41,88.0,670.48,9.0,670.60,7.0,670.74,ON,670.88,31.0,670.88,32.0,
,672.06,0.0,672.06,1400,672.19,0.820,672.19,1800,672.31,12.8,672.46,26.5,672.46,88.0,671.53,9.0,671.65,7.0,671.78,ON,671.93,31.0,671.93,32.0,
,673.14,0.0,673.14,1400,673.27,0.820,673.27,1800,673.41,12.6,673.55,26.5,673.55,88.0,672.59,9.0,672.71,7.0,672.85,ON,673.00,31.0,673.00,32.0,
,674.20,0.0,674.20,1400,674.33,0.820,674.33,1800,674.45,12.6,674.59,26.5,674.59,88.0,673.66,9.0,673.79,7.0,673.93,ON,674.08,31.0,674.08,32.0,
,675.23,0.0,675.23,1400,675.36,0.820,675.36,1800,675.49,12.6,675.64,26.5,675.64,88.0,674.71,9.0,674.83,7.0,674.96,ON,675.11,31.0,675.11,32.0,
,676.30,0.0,676.30,1400,676.44,0.820,676.44,1800,676.58,12.6,676.73,26.5,676.73,88.0,675.75,9.0,675.86,7.0,676.01,ON,676.16,31.0,676.16,32.0,
,677.37,0.0,677.37,1500,677.50,0.820,677.50,1800,677.64,12.6,677.78,26.5,677.78,88.0,676.85,9.0,676.97,7.0,677.11,ON,677.25,31.0,677.25,32.0,
,678.43,0.0,678.43,1500,678.56,0.820,678.56,1900,678.70,12.4,678.84,26.5,678.84,88.0,677.89,9.0,678.01,7.0,678.14,ON,678.30,31.0,678.30,32.0,
,679.50,0.0,679.50,1500,679.64,0.820,679.64,1900,679.77,12.6,679.92,26.5,679.92,88.0,678.96,9.0,679.07,7.0,679.21,ON,679.37,31.0,679.37,32.0,
,680.56,0.0,680.56,1500,680.69,0.820,680.69,1900,680.81,12.6,680.96,26.5,680.96,88.0,680.04,9.0,680.16,7.0,680.30,ON,680.44,31.0,680.44,32.0,
,681.61,0.0,681.61,1500,681.73,0.820,681.73,1900,681.86,12.6,682.00,26.5,682.00,88.0,681.08,9.0,681.21,7.0,681.34,ON,681.48,31.0,681.48,32.0,
,682.66,0.0,682.66,1500,682.80,0.820,682.80,1900,682.94,12.0,683.09,26.5,683.09,89.0,682.11,9.0,682.23,7.0,682.36,ON,682.53,31.0,682.53,32.0,
,683.75,0.0,683.75,1400,683.87,0.820,683.87,1800,684.00,12.2,684.15,26.5,684.15,89.0,683.21,9.0,683.33,7.0,683.47,ON,683.62,31.0,683.62,32.0,
,684.78,0.0,684.78,1400,684.90,0.820,684.90,1800,685.03,12.4,685.17,26.5,685.17,89.0,684.28,9.0,684.39,7.0,684.51,ON,684.64,31.0,684.64,32.0,
,685.83,0.0,685.83,1300,685.96,0.820,685.96,1600,686.09,12.4,686.21,26.5,686.21,89.0,685.30,10.0,685.42,7.0,685.55,ON,685.68,31.0,685.68,32.0,
,686.87,0.0,686.87,1200,687.00,0.820,687.00,1500,687.14,12.2,687.28,27.0,687.28,89.0,686.35,9.0,686.47,7.0,686.60,ON,686.73,31.0,686.73,32.0,
,687.96,0.0,687.96,1300,688.09,0.820,688.09,1600,688.22,12.4,688.35,26.5,688.35,89.0,687.42,9.0,687.55,7.0,687.68,ON,687.81,31.0,687.81,32.0,
,689.03,0.0,689.03,1200,689.16,0.820,689.16,1500,689.29,12.4,689.41,27.0,689.41,89.0,688.50,10.0,688.63,7.0,688.76,ON,688.88,31.0,688.88,32.0,
,690.10,0.0,690.10,1000,690.23,0.820,690.23,1300,690.37,12.4,690.51,26.5,690.51,90.0,689.55,9.0,689.67,7.0,689.81,ON,689.95,31.0,689.95,32.0,
,691.17,0.0,691.17,1100,691.30,0.820,691.30,1400,691.43,13.2,691.55,27.0,691.55,90.0,690.65,10.0,690.78,7.0,690.91,ON,691.03,31.0,691.03,32.0,
,692.20,0.0,692.20,900,692.32,0.820,692.32,1100,692.46,11.8,692.57,27.0,692.57,90.0,691.69,9.0,691.80,7.0,691.93,ON,692.07,31.0,692.07,32.0,
,693.23,0.0,693.23,800,693.35,0.820,693.35,1000,693.49,11.8,693.60,26.5,693.60,90.0,692.72,9.0,692.83,7.0,692.96,ON,693.09,31.0,693.09,32.0,
,694.26,0.0,694.26,700,694.38,0.820,694.38,900,694.51,12.0,694.63,26.5,694.63,90.0,693.75,9.0,693.86,7.0,693.99,ON,694.12,31.0,694.12,32.0,
,695.29,0.0,695.29,800,695.42,0.820,695.42,1000,695.56,12.0,695.70,26.5,695.70,90.0,694.77,9.0,694.89,7.0,695.02,ON,695.15,31.0,695.15,32.0,
,696.38,0.0,696.38,800,696.52,0.820,696.52,1000,696.65,12.0,696.78,26.5,696.78,90.0,695.84,10.0,695.98,7.0,696.10,ON,696.23,31.0,696.23,32.0,
,697.45,0.0,697.45,800,697.59,0.820,697.59,1000,697.73,12.0,697.87,26.5,697.87,90.0,696.90,10.0,697.04,7.0,697.16,ON,697.30,31.0,697.30,32.0,
,698.55,0.0,698.55,800,698.68,0.820,698.68,1000,698.80,12.2,698.93,27.0,698.93,90.0,698.01,9.0,698.14,7.0,698.27,ON,698.40,31.0,698.40,32.0,
,699.60,0.0,699.60,800,699.72,0.820,699.72,1000,699.85,12.6,699.97,27.0,699.97,90.0,699.08,10.0,699.20,7.0,699.33,ON,699.46,31.0,699.46,32.0,
,700.63,0.0,700.63,800,700.75,0.820,700.75,1000,700.88,12.4,701.00,27.0,701.00,90.0,700.11,10.0,700.23,7.0,700.36,ON,700.49,31.0,700.49,32.0,
,701.66,0.0,701.66,800,701.79,0.820,701.79,1000,701.93,13.2,702.07,27.0,702.07,90.0,701.14,10.0,701.26,7.0,701.39,ON,701.52,31.0,701.52,32.0,
,702.75,0.0,702.75,800,702.88,0.820,702.88,1000,703.02,12.4,703.14,27.0,703.14,90.0,702.21,10.0,702.34,7.0,702.47,ON,702.60,31.0,702.60,32.0,
,703.82,0.0,703.82,800,703.95,0.820,703.95,1000,704.09,12.4,704.22,27.0,704.22,90.0,703.27,10.0,703.40,7.0,703.53,ON,703.66,31.0,703.66,32.0,
,704.88,0.0,704.88,800,705.01,0.820,705.01,900,705.16,12.4,705.30,27.5,705.30,90.0,704.35,10.0,704.48,7.0,704.61,ON,704.74,31.0,704.74,32.0,
,705.96,0.0,705.96,800,706.09,0.820,706.09,1000,706.21,12.4,706.36,27.5,706.36,90.0,705.44,10.0,705.57,8.0,705.69,ON,705.82,31.0,705.82,32.0,
,707.02,0.0,707.02,800,707.14,0.820,707.14,1000,707.27,12.2,707.39,27.5,707.39,90.0,706.51,10.0,706.62,7.0,706.75,ON,706.88,31.0,706.88,32.0,
,708.05,0.0,708.05,800,708.18,0.820,708.18,1000,708.32,12.2,708.47,27.5,708.47,90.0,707.53,10.0,707.65,7.0,707.78,ON,707.91,31.0,707.91,32.0,
,709.14,0.0,709.14,800,709.28,0.820,709.28,1000,709.41,12.4,709.54,28.0,709.54,90.0,708.60,10.0,708.74,8.0,708.86,ON,709.00,31.0,709.00,32.0,
,710.21,0.0,710.21,800,710.35,0.820,710.35,1000,710.49,12.2,710.63,28.0,710.63,90.0,709.68,10.0,709.80,7.0,709.94,ON,710.06,31.0,710.06,32.0,
,711.31,0.0,711.31,800,711.44,0.790,711.44,1000,711.59,13.0,711.72,28.0,711.72,90.0,710.77,10.0,710.90,7.0,711.03,ON,711.16,31.0,711.16,32.0,
,712.34,0.0,712.34,800,712.49,0.820,712.49,1000,712.62,12.2,712.75,28.0,712.75,90.0,711.85,10.0,711.97,7.0,712.09,ON,712.22,31.0,712.22,32.0,
,713.37,0.0,713.37,800,713.50,0.820,713.50,1000,713.64,12.4,713.76,28.0,713.76,90.0,712.86,10.0,713.00,7.0,713.12,ON,713.25,31.0,713.25,32.0,
,714.39,0.0,714.39,800,714.51,0.800,714.51,1000,714.64,12.2,714.79,28.0,714.79,90.0,713.88,10.0,714.00,7.0,714.12,ON,714.26,31.0,714.26,32.0,
,715.45,0.0,715.45,800,715.57,0.810,715.57,1000,715.70,12.6,715.84,28.0,715.84,90.0,714.91,10.0,715.03,7.0,715.17,ON,715.31,31.0,715.31,32.0,
,716.50,0.0,716.50,800,716.64,0.820,716.64,1000,716.78,12.4,716.94,28.5,716.94,90.0,715.96,10.0,716.08,7.0,716.21,ON,716.36,31.0,716.36,32.0,
,717.61,0.0,717.61,800,717.74,0.820,717.74,1000,717.87,12.4,718.01,28.5,718.01,90.0,717.07,10.0,717.19,7.0,717.32,ON,717.47,31.0,717.47,32.0,
,718.67,0.0,718.67,800,718.81,0.820,718.81,1000,718.95,12.6,719.10,28.5,719.10,90.0,718.13,10.0,718.25,7.0,718.37,ON,718.52,31.0,718.52,32.0,
,719.77,0.0,719.77,800,719.89,0.820,719.89,1000,720.01,12.4,720.16,28.5,720.16,90.0,719.21,10.0,719.33,7.0,719.47,ON,719.63,31.0,719.63,32.0,
,720.83,0.0,720.83,800,720.98,0.820,720.98,1000,721.11,12.4,721.26,28.5,721.26,90.0,720.30,10.0,720.41,7.0,720.55,ON,720.71,31.0,720.71,32.0,
,721.90,0.0,721.90,800,722.03,0.820,722.03,1000,722.17,12.4,722.33,28.5,722.33,90.0,721.38,10.0,721.50,7.0,721.64,ON,721.78,31.0,721.78,32.0,
,722.96,0.0,722.96,800,723.09,0.820,723.09,1000,723.21,12.6,723.36,28.5,723.36,90.0,722.45,10.0,722.56,7.0,722.70,ON,722.84,31.0,722.84,32.0,
,724.03,0.0,724.03,800,724.17,0.820,724.17,1000,724.32,12.4,724.45,28.5,724.45,90.0,723.49,10.0,723.61,7.0,723.75,ON,723.90,31.0,723.90,32.0,
,725.10,0.0,725.10,800,725.21,0.820,725.21,1000,725.34,12.6,725.48,29.0,725.48,90.0,724.56,10.0,724.69,7.0,724.82,ON,724.96,31.0,724.96,32.0,
,726.13,0.0,726.13,800,726.26,0.820,726.26,1000,726.38,12.4,726.53,28.5,726.53,90.0,725.62,10.0,725.73,7.0,725.87,ON,726.01,31.0,726.01,32.0,
,727.15,0.0,727.15,800,727.27,0.820,727.27,1000,727.40,12.0,727.52,29.0,727.52,90.0,726.66,10.0,726.76,7.0,726.88,ON,727.01,31.0,727.01,32.0,
,728.15,0.0,728.15,800,728.30,0.820,728.30,1000,728.43,12.6,728.55,29.0,728.55,90.0,727.65,10.0,727.76,7.0,727.90,ON,728.02,31.0,728.02,32.0,
,729.21,0.0,729.21,800,729.37,0.820,729.37,1000,729.51,13.4,729.65,29.0,729.65,90.0,728.67,10.0,728.81,7.0,728.94,ON,729.07,31.0,729.07,32.0,
,730.32,0.0,730.32,800,730.46,0.820,730.46,1000,730.59,12.6,730.72,29.0,730.72,90.0,729.79,10.0,729.92,7.0,730.05,ON,730.18,31.0,730.18,32.0,
,731.38,0.0,731.38,800,731.51,0.820,731.51,1000,731.64,12.4,731.77,29.0,731.77,90.0,730.85,10.0,731.00,7.0,731.12,ON,731.25,31.0,731.25,32.0,
,732.43,0.0,732.43,800,732.57,0.820,732.57,1000,732.71,12.6,732.84,29.0,732.84,90.0,731.89,10.0,732.02,7.0,732.15,ON,732.28,31.0,732.28,32.0,
,733.51,0.0,733.51,800,733.66,0.820,733.66,1000,733.79,13.4,733.91,29.0,733.91,90.0,732.97,10.0,733.11,7.0,733.24,ON,733.37,31.0,733.37,32.0,
,734.57,0.0,734.57,800,734.71,0.810,734.71,1000,734.83,12.0,734.96,29.0,734.96,90.0,734.03,9.0,734.17,7.0,734.30,ON,734.43,31.0,734.43,32.0,
,735.60,0.0,735.60,800,735.72,0.820,735.72,1000,735.87,12.6,736.02,29.0,736.02,90.0,735.07,10.0,735.19,7.0,735.34,ON,735.47,31.0,735.47,32.0,
,736.68,0.0,736.68,800,736.83,0.810,736.83,1000,736.97,12.6,737.10,29.0,737.10,90.0,736.14,10.0,736.26,7.0,736.41,ON,736.55,31.0,736.55,32.0,
,737.74,0.0,737.74,800,737.87,0.820,737.87,1000,738.02,12.6,738.14,29.0,738.14,90.0,737.21,9.0,737.35,7.0,737.49,ON,737.61,31.0,737.61,32.0,
,738.77,0.0,738.77,800,738.90,0.820,738.90,1000,739.02,12.6,739.16,29.0,739.16,90.0,738.26,10.0,738.38,7.0,738.50,ON,738.64,31.0,738.64,32.0,
,739.79,0.0,739.79,800,739.93,0.810,739.93,1000,740.05,12.6,740.17,29.0,740.17,90.0,739.27,10.0,739.38,7.0,739.52,ON,739.64,31.0,739.64,32.0,
,740.83,0.0,740.83,800,740.95,0.780,740.95,1000,741.08,12.8,741.20,29.0,741.20,90.0,740.31,9.0,740.44,7.0,740.56,ON,740.70,31.0,740.70,32.0,
,741.86,0.0,741.86,800,741.98,0.820,741.98,1000,742.11,12.8,742.24,29.0,742.24,90.0,741.34,9.0,741.47,7.0,741.59,ON,741.72,31.0,741.72,32.0,
,742.92,0.0,742.92,800,743.05,0.820,743.05,1000,743.19,13.6,743.34,29.0,743.34,90.0,742.38,10.0,742.51,7.0,742.64,ON,742.77,31.0,742.77,32.0,
,744.00,0.0,744.00,800,744.12,0.810,744.12,1000,744.25,12.8,744.38,29.0,744.38,90.0,743.47,10.0,743.60,7.0,743.73,ON,743.86,31.0,743.86,32.0,
,745.05,0.0,745.05,800,745.18,0.810,745.18,1000,745.31,13.6,745.44,29.0,745.44,90.0,744.52,9.0,744.64,7.0,744.76,ON,744.90,31.0,744.90,32.0,
,746.12,0.0,746.12,800,746.24,0.820,746.24,1000,746.39,12.8,746.52,29.0,746.52,91.0,745.57,9.0,745.71,7.0,745.84,ON,745.96,31.0,745.96,32.0,
,747.17,0.0,747.17,800,747.30,0.820,747.30,1000,747.42,12.8,747.55,29.5,747.55,91.0,746.65,10.0,746.77,7.0,746.91,ON,747.04,31.0,747.04,32.0,
,748.24,0.0,748.24,800,748.38,0.810,748.38,1000,748.53,12.8,748.66,29.5,748.66,91.0,747.68,10.0,747.80,7.0,747.94,ON,748.08,31.0,748.08,32.0,
,749.33,0.0,749.33,800,749.45,0.810,749.45,1000,749.58,12.8,749.72,29.5,749.72,91.0,748.80,9.0,748.93,7.0,749.06,ON,749.19,31.0,749.19,32.0,
,750.39,0.0,750.39,800,750.51,0.820,750.51,1000,750.64,12.8,750.76,29.5,750.76,91.0,749.87,10.0,749.99,7.0,750.12,ON,750.25,31.0,750.25,32.0,
,751.42,0.0,751.42,800,751.54,0.820,751.54,1000,751.67,13.8,751.79,29.5,751.79,91.0,750.89,10.0,751.01,7.0,751.14,ON,751.26,31.0,751.26,32.0,
,752.45,0.0,752.45,800,752.57,0.810,752.57,1000,752.70,12.8,752.82,29.5,752.82,91.0,751.93,9.0,752.05,7.0,752.18,ON,752.31,31.0,752.31,32.0,
,753.49,0.0,753.49,800,753.62,0.810,753.62,1000,753.75,12.8,753.89,29.5,753.89,91.0,752.96,9.0,753.08,7.0,753.21,ON,753.34,31.0,753.34,32.0,
,754.57,0.0,754.57,800,754.70,0.820,754.70,1000,754.84,12.8,754.96,29.5,754.96,91.0,754.03,10.0,754.16,7.0,754.29,ON,754.42,31.0,754.42,32.0,
,755.62,0.0,755.62,800,755.74,0.820,755.74,1000,755.87,13.0,755.99,29.5,755.99,91.0,755.09,10.0,755.22,7.0,755.35,ON,755.48,31.0,755.48,32.0,
,756.65,0.0,756.65,800,756.77,0.780,756.77,1000,756.90,13.8,757.02,29.5,757.02,91.0,756.13,9.0,756.25,7.0,756.38,ON,756.51,31.0,756.51,32.0,
,757.63,0.0,757.63,800,757.77,0.780,757.77,1000,757.90,13.2,758.03,29.5,758.03,91.0,757.15,9.0,757.26,7.0,757.38,ON,757.51,31.0,757.51,32.0,
,758.68,0.0,758.68,800,758.84,0.820,758.84,1000,758.97,13.0,759.11,29.5,759.11,91.0,758.15,10.0,758.28,7.0,758.41,ON,758.54,31.0,758.54,32.0,
,759.78,0.0,759.78,800,759.93,0.790,759.93,1000,760.06,13.2,760.19,29.5,760.19,91.0,759.25,10.0,759.39,7.0,759.52,ON,759.65,31.0,759.65,32.0,
,760.82,0.0,760.82,800,760.96,0.790,760.96,1000,761.09,13.2,761.21,29.5,761.21,91.0,760.30,9.0,760.44,7.0,760.57,ON,760.70,31.0,760.70,32.0,
,761.85,0.0,761.85,800,762.00,0.810,762.00,1000,762.13,12.4,762.26,29.5,762.26,91.0,761.34,9.0,761.47,7.0,761.60,ON,761.73,31.0,761.73,32.0,
,762.90,0.0,762.90,800,763.04,0.820,763.04,1000,763.16,13.0,763.29,29.5,763.29,91.0,762.37,10.0,762.52,7.0,762.65,ON,762.77,31.0,762.77,32.0,
,763.93,0.0,763.93,800,764.07,0.800,764.07,1000,764.20,13.2,764.34,29.5,764.34,91.0,763.40,10.0,763.55,7.0,763.68,ON,763.80,31.0,763.80,32.0,
,765.01,0.0,765.01,800,765.16,0.800,765.16,1000,765.29,13.0,765.42,30.0,765.42,91.0,764.47,9.0,764.61,7.0,764.74,ON,764.88,31.0,764.88,32.0,
,766.08,0.0,766.08,800,766.23,0.820,766.23,1000,766.36,13.2,766.49,29.5,766.49,91.0,765.54,9.0,765.69,7.0,765.82,ON,765.96,31.0,765.96,32.0,
,767.13,0.0,767.13,800,767.27,0.820,767.27,1000,767.40,14.0,767.54,30.0,767.54,91.0,766.60,10.0,766.75,7.0,766.88,ON,767.00,31.0,767.00,32.0,
,768.21,0.0,768.21,800,768.35,0.820,768.35,1000,768.47,13.2,768.60,30.0,768.60,91.0,767.67,10.0,767.81,7.0,767.94,ON,768.07,31.0,768.07,32.0,
,769.25,0.0,769.25,800,769.39,0.820,769.39,1000,769.52,12.6,769.64,30.0,769.64,91.0,768.73,9.0,768.87,7.0,769.00,ON,769.13,31.0,769.13,32.0,
,770.28,0.0,770.28,800,770.42,0.820,770.42,1000,770.55,13.2,770.67,30.0,770.67,91.0,769.76,10.0,769.90,7.0,770.03,ON,770.16,31.0,770.16,32.0,
,771.31,0.0,771.31,800,771.46,0.820,771.46,1000,771.59,13.2,771.71,30.0,771.71,91.0,770.79,10.0,770.93,7.0,771.06,ON,771.19,31.0,771.19,32.0,
,772.34,0.0,772.34,800,772.49,0.820,772.49,1000,772.62,13.2,772.76,30.0,772.76,91.0,771.83,9.0,771.96,7.0,772.09,ON,772.22,31.0,772.22,32.0,
,773.44,0.0,773.44,800,773.58,0.800,773.58,1000,773.71,13.2,773.83,30.0,773.83,91.0,772.90,9.0,773.04,7.0,773.17,ON,773.30,31.0,773.30,32.0,
,774.49,0.0,774.49,800,774.64,0.820,774.64,1000,774.78,13.4,774.91,30.0,774.91,91.0,773.95,10.0,774.09,7.0,774.23,ON,774.35,31.0,774.35,32.0,
,775.57,0.0,775.57,800,775.72,0.820,775.72,1000,775.85,14.0,775.99,30.0,775.99,91.0,775.03,10.0,775.17,7.0,775.31,ON,775.44,31.0,775.44,32.0,
,776.64,0.0,776.64,800,776.78,0.800,776.78,1000,776.91,13.2,777.05,30.0,777.05,91.0,776.12,9.0,776.26,7.0,776.39,ON,776.52,31.0,776.52,32.0,
,777.70,0.0,777.70,800,777.85,0.820,777.85,1000,777.99,12.8,778.14,30.0,778.14,91.0,777.18,9.0,777.32,7.0,777.45,ON,777.58,31.0,777.58,32.0,
,778.80,0.0,778.80,800,778.96,0.820,778.96,1000,779.09,13.2,779.22,30.0,779.22,91.0,778.26,10.0,778.40,7.0,778.53,ON,778.67,31.0,778.67,32.0,
,779.86,0.0,779.86,800,780.01,0.800,780.01,1000,780.14,13.4,780.26,30.0,780.26,91.0,779.33,10.0,779.48,7.0,779.61,ON,779.73,31.0,779.73,32.0,
,780.90,0.0,780.90,800,781.05,0.800,781.05,1000,781.19,13.2,781.33,30.0,781.33,91.0,780.38,9.0,780.52,7.0,780.65,ON,780.78,31.0,780.78,32.0,
,781.98,0.0,781.98,800,782.12,0.820,782.12,1000,782.25,13.2,782.37,30.0,782.37,91.0,781.46,9.0,781.60,7.0,781.73,ON,781.86,31.0,781.86,32.0,
,783.03,0.0,783.03,800,783.17,0.820,783.17,1000,783.29,13.2,783.42,30.0,783.42,91.0,782.49,10.0,782.63,7.0,782.76,ON,782.89,31.0,782.89,32.0,
,784.06,0.0,784.06,800,784.20,0.800,784.20,1000,784.32,13.2,784.45,30.0,784.45,91.0,783.53,10.0,783.68,7.0,783.81,ON,783.93,31.0,783.93,32.0,
,785.07,0.0,785.07,800,785.20,0.800,785.20,1000,785.35,13.2,785.48,30.0,785.48,91.0,784.56,9.0,784.70,7.0,784.81,ON,784.95,31.0,784.95,32.0,
,786.12,0.0,786.12,800,786.24,0.820,786.24,1000,786.37,13.0,786.52,30.0,786.52,91.0,785.59,10.0,785.70,7.0,785.83,ON,785.98,31.0,785.98,32.0,
,787.19,0.0,787.19,800,787.34,0.820,787.34,1000,787.47,13.0,787.62,30.0,787.62,91.0,786.65,10.0,786.77,7.0,786.91,ON,787.06,31.0,787.06,32.0,
,788.27,0.0,788.27,800,788.39,0.800,788.39,1000,788.54,14.0,788.67,30.5,788.67,91.0,787.75,9.0,787.86,7.0,788.00,ON,788.14,31.0,788.14,32.0,
,789.33,0.0,789.33,800,789.47,0.800,789.47,1000,789.61,13.2,789.76,30.5,789.76,91.0,788.79,9.0,788.89,7.0,789.03,ON,789.19,31.0,789.19,32.0,
,790.42,0.0,790.42,800,790.56,0.820,790.56,1000,790.70,13.2,790.86,30.5,790.86,91.0,789.88,10.0,790.00,7.0,790.14,ON,790.29,31.0,790.29,32.0,
,791.53,0.0,791.53,800,791.68,0.820,791.68,1000,791.81,13.2,791.96,30.5,791.96,91.0,790.99,10.0,791.11,7.0,791.25,ON,791.41,31.0,791.41,32.0,
,792.62,0.0,792.62,800,792.74,0.800,792.74,1000,792.87,13.2,793.01,30.5,793.01,91.0,792.08,9.0,792.20,7.0,792.34,ON,792.49,31.0,792.49,32.0,
,793.65,0.0,793.65,800,793.77,0.820,793.77,1000,793.90,13.0,794.04,30.5,794.04,91.0,793.12,9.0,793.25,7.0,793.38,ON,793.52,31.0,793.52,32.0,
,794.70,0.0,794.70,1400,794.84,0.820,794.84,1800,794.98,14.2,795.13,30.5,795.13,91.0,794.15,10.0,794.28,7.0,794.41,ON,794.56,31.0,794.56,32.0,
,795.79,0.0,795.79,1700,795.93,0.820,795.93,2200,796.05,15.2,796.19,30.5,796.19,91.0,795.25,10.0,795.37,7.0,795.51,ON,795.66,31.0,795.66,32.0,
,796.84,0.0,796.84,2100,796.97,0.820,796.97,2300,797.10,15.8,797.22,30.5,797.22,91.0,796.31,9.0,796.43,7.0,796.55,ON,796.68,31.0,796.68,32.0,
,797.88,0.0,797.88,1700,798.00,0.820,798.00,2300,798.13,16.2,798.25,30.5,798.25,91.0,797.36,9.0,797.48,7.0,797.61,ON,797.74,31.0,797.74,32.0,
,798.90,0.0,798.90,2100,799.03,0.820,799.03,2700,799.18,16.8,799.32,30.5,799.32,91.0,798.39,10.0,798.51,7.0,798.64,ON,798.77,31.0,798.77,32.0,
,799.99,0.0,799.99,1600,800.11,0.820,800.11,2000,800.24,16.6,800.37,30.0,800.37,91.0,799.46,10.0,799.59,7.0,799.72,ON,799.84,31.0,799.84,32.0,
,801.06,0.0,801.06,1700,801.20,0.790,801.20,2200,801.34,16.6,801.49,30.0,801.49,91.0,800.54,9.0,800.65,7.0,800.78,ON,800.91,31.0,800.91,32.0,
,802.15,0.0,802.15,1900,802.29,0.820,802.29,2600,802.43,16.0,802.56,30.0,802.56,91.0,801.62,9.0,801.75,7.0,801.88,ON,802.01,31.0,802.01,32.0,
,803.21,0.0,803.21,2100,803.34,0.820,803.34,2700,803.46,16.4,803.58,30.0,803.58,91.0,802.69,9.0,802.81,7.0,802.94,ON,803.07,31.0,803.07,32.0,
,804.24,0.0,804.24,1500,804.36,0.810,804.36,1900,804.49,15.8,804.61,30.0,804.61,91.0,803.71,9.0,803.84,7.0,803.97,ON,804.10,31.0,804.10,32.0,
,805.27,0.0,805.27,1500,805.39,0.810,805.39,1900,805.52,15.2,805.64,29.5,805.64,91.0,804.75,9.0,804.87,7.0,805.00,ON,805.13,31.0,805.13,32.0,
,806.30,0.0,806.30,1600,806.42,0.790,806.42,2000,806.55,15.8,806.67,29.5,806.67,91.0,805.78,9.0,805.90,7.0,806.03,ON,806.16,31.0,806.16,32.0,
,807.36,0.0,807.36,1600,807.49,0.800,807.49,2000,807.63,15.4,807.77,29.5,807.77,91.0,806.81,9.0,806.93,7.0,807.07,ON,807.21,31.0,807.21,32.0,
,808.44,0.0,808.44,1600,808.57,0.800,808.57,2000,808.69,15.2,808.82,29.5,808.82,90.0,807.91,9.0,808.05,7.0,808.17,ON,808.30,31.0,808.30,32.0,
,809.44,0.0,809.44,1700,809.59,0.800,809.59,2200,809.72,15.0,809.84,29.0,809.84,90.0,808.94,9.0,809.05,7.0,809.19,ON,809.31,31.0,809.31,32.0,
,810.48,0.0,810.48,1700,810.63,0.800,810.63,2200,810.76,14.4,810.89,29.0,810.89,90.0,809.96,9.0,810.10,7.0,810.23,ON,810.36,31.0,810.36,32.0,
,811.51,0.0,811.51,1700,811.65,0.810,811.65,2200,811.80,14.2,811.94,29.0,811.94,90.0,811.00,9.0,811.13,6.0,811.26,ON,811.39,31.0,811.39,32.0,
,812.60,0.0,812.60,1700,812.75,0.810,812.75,2200,812.88,14.0,813.01,29.0,813.01,90.0,812.07,9.0,812.21,7.0,812.34,ON,812.47,31.0,812.47,32.0,
,813.66,0.0,813.66,1700,813.80,0.790,813.80,2200,813.92,14.0,814.05,29.0,814.05,90.0,813.13,9.0,813.28,7.0,813.41,ON,813.53,31.0,813.53,32.0,
,814.69,0.0,814.69,1700,814.83,0.770,814.83,2200,814.95,13.2,815.08,29.0,815.08,90.0,814.17,8.0,814.31,6.0,814.44,ON,814.56,31.0,814.56,32.0,
,815.72,0.0,815.72,1700,815.87,0.790,815.87,2200,816.00,13.8,816.13,29.0,816.13,90.0,815.20,8.0,815.34,6.0,815.47,ON,815.59,31.0,815.59,32.0,
,816.80,0.0,816.80,1600,816.95,0.790,816.95,2000,817.08,13.6,817.22,29.0,817.22,90.0,816.27,9.0,816.40,6.0,816.53,ON,816.66,31.0,816.66,32.0,
,817.89,0.0,817.89,1600,818.03,0.820,818.03,2000,818.16,13.0,818.28,28.5,818.28,90.0,817.35,9.0,817.49,6.0,817.62,ON,817.75,31.0,817.75,32.0,
,818.89,0.0,818.89,1600,819.03,0.780,819.03,2000,819.18,12.8,819.31,28.5,819.31,90.0,818.39,9.0,818.50,6.0,818.64,ON,818.76,31.0,818.76,32.0,
,819.92,0.0,819.92,1600,820.06,0.800,820.06,2000,820.18,13.4,820.33,28.5,820.33,90.0,819.42,8.0,819.53,6.0,819.65,ON,819.79,31.0,819.79,32.0,
,820.96,0.0,820.96,1600,821.09,0.780,821.09,2000,821.21,13.4,821.34,28.5,821.34,90.0,820.45,9.0,820.56,6.0,820.68,ON,820.81,31.0,820.81,32.0,
,821.96,0.0,821.96,1700,822.11,0.780,822.11,2200,822.24,13.4,822.37,28.5,822.37,90.0,821.47,9.0,821.59,6.0,821.71,ON,821.84,31.0,821.84,32.0,
,823.01,0.0,823.01,1700,823.16,0.790,823.16,2200,823.29,12.8,823.42,28.5,823.42,90.0,822.48,8.0,822.63,6.0,822.76,ON,822.88,31.0,822.88,32.0,
,824.09,0.0,824.09,1700,824.24,0.740,824.24,2200,824.37,13.6,824.51,28.5,824.51,90.0,823.55,8.0,823.69,6.0,823.82,ON,823.95,31.0,823.95,32.0,
,825.17,0.0,825.17,1800,825.32,0.760,825.32,2300,825.44,14.4,825.57,28.5,825.57,90.0,824.64,9.0,824.78,6.0,824.91,ON,825.04,31.0,825.04,32.0,
,826.18,0.0,826.18,1500,826.30,0.790,826.30,1800,826.44,13.4,826.57,28.5,826.57,90.0,825.68,8.0,825.79,6.0,825.92,ON,826.05,31.0,826.05,32.0,
,827.25,0.0,827.25,1300,827.39,0.780,827.39,1600,827.55,13.2,827.67,28.5,827.67,90.0,826.70,8.0,826.83,6.0,826.97,ON,827.11,31.0,827.11,32.0,
,828.35,0.0,828.35,1300,828.48,0.760,828.48,1600,828.62,13.2,828.74,28.0,828.74,90.0,827.82,8.0,827.94,6.0,828.10,ON,828.23,31.0,828.23,32.0,
,829.38,0.0,829.38,1300,829.51,0.780,829.51,1600,829.65,13.2,829.77,28.0,829.77,90.0,828.86,9.0,828.98,6.0,829.13,ON,829.26,31.0,829.26,32.0,
,830.42,0.0,830.42,1300,830.56,0.780,830.56,1600,830.70,13.8,830.85,28.0,830.85,90.0,829.89,8.0,830.01,6.0,830.14,ON,830.28,31.0,830.28,32.0,
,831.52,0.0,831.52,1300,831.65,0.750,831.65,1600,831.79,12.4,831.93,28.0,831.93,90.0,830.97,9.0,831.09,6.0,831.23,ON,831.39,31.0,831.39,32.0,
,832.59,0.0,832.59,1300,832.74,0.770,832.74,1600,832.87,13.0,833.03,28.0,833.03,90.0,832.04,9.0,832.15,6.0,832.29,ON,832.45,31.0,832.45,32.0,
,833.68,0.0,833.68,1300,833.80,0.800,833.80,1600,833.93,13.0,834.08,28.0,834.08,90.0,833.15,9.0,833.28,6.0,833.41,ON,833.55,31.0,833.55,32.0,
,834.72,0.0,834.72,1300,834.85,0.800,834.85,1600,834.97,13.0,835.11,28.0,835.11,90.0,834.20,8.0,834.32,6.0,834.44,ON,834.59,31.0,834.59,32.0,
,835.75,0.0,835.75,1400,835.88,0.760,835.88,1800,836.00,13.0,836.14,28.0,836.14,90.0,835.23,8.0,835.35,6.0,835.47,ON,835.60,31.0,835.60,32.0,
,836.80,0.0,836.80,1400,836.92,0.760,836.92,1800,837.05,13.0,837.18,28.0,837.18,90.0,836.28,8.0,836.40,6.0,836.53,ON,836.66,31.0,836.66,32.0,
,837.88,0.0,837.88,1400,838.00,0.810,838.00,1800,838.13,12.8,838.27,28.0,838.27,90.0,837.32,8.0,837.45,6.0,837.58,ON,837.71,31.0,837.71,32.0,
,838.93,0.0,838.93,1400,839.06,0.810,839.06,1800,839.19,12.8,839.31,28.0,839.31,90.0,838.41,8.0,838.54,6.0,838.66,ON,838.80,31.0,838.80,32.0,
,839.96,0.0,839.96,1400,840.09,0.730,840.09,1800,840.22,12.0,840.34,28.0,840.34,90.0,839.45,8.0,839.56,6.0,839.70,ON,839.82,31.0,839.82,32.0,
,840.94,0.0,840.94,1400,841.09,0.730,841.09,1800,841.23,12.8,841.35,28.0,841.35,90.0,840.46,8.0,840.57,6.0,840.70,ON,840.82,31.0,840.82,32.0,
,841.99,0.0,841.99,1400,842.13,0.730,842.13,1800,842.25,13.6,842.38,28.0,842.38,90.0,841.46,8.0,841.61,6.0,841.74,ON,841.86,31.0,841.86,32.0,
,843.03,0.0,843.03,1400,843.18,0.730,843.18,1800,843.32,12.6,843.46,28.0,843.46,90.0,842.49,8.0,842.65,5.0,842.78,ON,842.91,31.0,842.91,32.0,
,844.13,0.0,844.13,1400,844.27,0.740,844.27,1800,844.39,12.4,844.52,28.0,844.52,90.0,843.59,8.0,843.73,6.0,843.86,ON,843.99,31.0,843.99,32.0,
,845.17,0.0,845.17,1400,845.31,0.720,845.31,1800,845.44,12.6,845.56,28.0,845.56,90.0,844.65,8.0,844.79,6.0,844.92,ON,845.05,31.0,845.05,32.0,
,846.20,0.0,846.20,1500,846.34,0.740,846.34,1900,846.47,12.6,846.59,27.5,846.59,90.0,845.68,8.0,845.82,5.0,845.95,ON,846.08,31.0,846.08,32.0,
,847.23,0.0,847.23,1500,847.38,0.740,847.38,1900,847.51,12.6,847.64,27.5,847.64,90.0,846.71,8.0,846.85,5.0,846.98,ON,847.11,31.0,847.11,32.0,
,848.28,0.0,848.28,1500,848.42,0.720,848.42,1900,848.55,12.6,848.69,27.5,848.69,90.0,847.76,8.0,847.90,6.0,848.03,ON,848.15,31.0,848.15,32.0,
,849.36,0.0,849.36,1500,849.51,0.720,849.51,1900,849.65,12.0,849.78,27.5,849.78,90.0,848.83,8.0,848.96,6.0,849.09,ON,849.22,31.0,849.22,32.0,
,850.43,0.0,850.43,1500,850.58,0.740,850.58,1900,850.72,12.6,850.86,27.5,850.86,90.0,849.90,8.0,850.04,5.0,850.18,ON,850.31,31.0,850.31,32.0,
,851.53,0.0,851.53,1500,851.67,0.740,851.67,1900,851.79,13.4,851.92,27.5,851.92,90.0,850.99,8.0,851.13,5.0,851.26,ON,851.39,31.0,851.39,32.0,
,852.58,0.0,852.58,1500,852.72,0.720,852.72,1900,852.85,13.4,852.98,27.5,852.98,91.0,852.05,8.0,852.19,5.0,852.32,ON,852.45,31.0,852.45,32.0,
,853.60,0.0,853.60,1500,853.72,0.720,853.72,1900,853.86,12.6,853.98,27.5,853.98,91.0,853.09,8.0,853.20,5.0,853.34,ON,853.48,31.0,853.48,32.0,
,854.61,0.0,854.61,1500,854.75,0.750,854.75,1900,854.87,12.6,855.01,27.5,855.01,91.0,854.10,8.0,854.22,5.0,854.34,ON,854.48,31.0,854.48,32.0,
,855.65,0.0,855.65,1500,855.78,0.730,855.78,1900,855.92,13.4,856.04,27.5,856.04,91.0,855.13,8.0,855.25,5.0,855.37,ON,855.51,31.0,855.51,32.0,
,856.70,0.0,856.70,1500,856.83,0.710,856.83,1900,856.97,12.6,857.11,27.5,857.11,91.0,856.18,8.0,856.30,5.0,856.43,ON,856.56,31.0,856.56,32.0,
,857.79,0.0,857.79,1500,857.92,0.750,857.92,1900,858.06,12.6,858.21,27.5,858.21,91.0,857.25,8.0,857.38,5.0,857.51,ON,857.64,31.0,857.64,32.0,
,858.87,0.0,858.87,1500,859.00,0.750,859.00,1900,859.14,12.6,859.28,27.5,859.28,91.0,858.35,8.0,858.48,5.0,858.60,ON,858.74,31.0,858.74,32.0,
,859.96,0.0,859.96,1400,860.09,0.730,860.09,1900,860.23,13.0,860.37,27.5,860.37,92.0,859.42,8.0,859.55,5.0,859.68,ON,859.81,31.0,859.81,32.0,
,861.02,0.0,861.02,1500,861.15,0.730,861.15,1900,861.29,13.0,861.41,27.5,861.41,92.0,860.50,8.0,860.62,5.0,860.76,ON,860.88,31.0,860.88,32.0,
,862.07,0.0,862.07,1500,862.20,0.750,862.20,1900,862.34,14.0,862.48,27.5,862.48,92.0,861.55,8.0,861.67,5.0,861.80,ON,861.93,31.0,861.93,32.0,
,863.15,0.0,863.15,1500,863.27,0.750,863.27,1900,863.40,13.4,863.54,27.5,863.54,92.0,862.62,8.0,862.75,5.0,862.88,ON,863.01,31.0,863.01,32.0,
,864.24,0.0,864.24,1500,864.37,0.740,864.37,1900,864.51,13.6,864.65,27.0,864.65,92.0,863.69,8.0,863.81,5.0,863.95,ON,864.08,31.0,864.08,32.0,
,865.33,0.0,865.33,1600,865.46,0.740,865.46,2000,865.60,13.6,865.72,27.0,865.72,92.0,864.79,8.0,864.92,5.0,865.05,ON,865.18,31.0,865.18,32.0,
,866.38,0.0,866.38,1600,866.49,0.760,866.49,2000,866.62,13.0,866.74,27.0,866.74,92.0,865.86,8.0,865.99,5.0,866.11,ON,866.24,31.0,866.24,32.0,
,867.40,0.0,867.40,1600,867.52,0.720,867.52,2000,867.65,13.6,867.77,27.0,867.77,92.0,866.88,7.0,867.01,5.0,867.14,ON,867.27,31.0,867.27,32.0,
,868.43,0.0,868.43,1400,868.55,0.740,868.55,1800,868.68,13.2,868.80,27.0,868.80,92.0,867.92,8.0,868.03,5.0,868.17,ON,868.29,31.0,868.29,32.0,
,869.49,0.0,869.49,1300,869.62,0.740,869.62,1600,869.76,13.0,869.91,27.0,869.91,92.0,868.94,8.0,869.07,5.0,869.20,ON,869.34,31.0,869.34,32.0,
,870.57,0.0,870.57,1300,870.70,0.720,870.70,1600,870.83,12.8,870.97,27.0,870.97,92.0,870.04,7.0,870.18,5.0,870.30,ON,870.44,31.0,870.44,32.0,
,871.63,0.0,871.63,1300,871.76,0.740,871.76,1600,871.90,12.0,872.04,27.0,872.04,92.0,871.11,7.0,871.23,5.0,871.36,ON,871.49,31.0,871.49,32.0,
,872.72,0.0,872.72,1300,872.85,0.760,872.85,1600,872.97,12.4,873.10,27.0,873.10,92.0,872.18,8.0,872.31,5.0,872.44,ON,872.57,31.0,872.57,32.0,
,873.77,0.0,873.77,1300,873.89,0.740,873.89,1600,874.02,12.2,874.14,27.0,874.14,92.0,873.24,8.0,873.37,5.0,873.50,ON,873.63,31.0,873.63,32.0,
,874.80,0.0,874.80,1300,874.92,0.720,874.92,1600,875.05,12.2,875.17,27.0,875.17,92.0,874.28,8.0,874.40,5.0,874.53,ON,874.66,31.0,874.66,32.0,
,875.78,0.0,875.78,1300,875.93,0.770,875.93,1600,876.06,12.2,876.19,27.0,876.19,92.0,875.30,7.0,875.41,5.0,875.53,ON,875.66,31.0,875.66,32.0,
,876.81,0.0,876.81,1300,876.96,0.770,876.96,1600,877.09,12.2,877.22,27.0,877.22,92.0,876.30,8.0,876.44,5.0,876.56,ON,876.69,31.0,876.69,32.0,
,877.86,0.0,877.86,1300,878.01,0.770,878.01,1600,878.14,13.0,878.26,27.0,878.26,92.0,877.33,8.0,877.48,5.0,877.61,ON,877.73,31.0,877.73,32.0,
,878.90,0.0,878.90,1500,879.05,0.730,879.05,1900,879.19,12.4,879.33,27.0,879.33,92.0,878.38,7.0,878.52,5.0,878.65,ON,878.78,31.0,878.78,32.0,
,879.97,0.0,879.97,1500,880.11,0.770,880.11,1900,880.25,12.0,880.39,27.0,880.39,92.0,879.46,7.0,879.60,5.0,879.73,ON,879.85,31.0,879.85,32.0,
,881.03,0.0,881.03,1500,881.18,0.770,881.18,1900,881.31,12.8,881.44,27.0,881.44,92.0,880.52,8.0,880.65,5.0,880.78,ON,880.91,31.0,880.91,32.0,
,882.08,0.0,882.08,1500,882.22,0.730,882.22,1900,882.34,12.8,882.47,27.0,882.47,92.0,881.56,8.0,881.70,5.0,881.83,ON,881.95,31.0,881.95,32.0,
,883.08,0.0,883.08,1400,883.20,0.730,883.20,1800,883.35,13.0,883.48,27.0,883.48,92.0,882.58,7.0,882.69,5.0,882.83,ON,882.95,31.0,882.95,32.0,
,884.11,0.0,884.11,1400,884.23,0.770,884.23,1800,884.37,13.2,884.50,27.0,884.50,92.0,883.60,8.0,883.72,5.0,883.86,ON,883.98,31.0,883.98,32.0,
,885.14,0.0,885.14,1400,885.26,0.730,885.26,1800,885.41,13.2,885.55,27.0,885.55,92.0,884.61,8.0,884.74,5.0,884.89,ON,885.01,31.0,885.01,32.0,
,886.22,0.0,886.22,1400,886.36,0.740,886.36,1800,886.51,13.2,886.64,27.0,886.64,92.0,885.68,8.0,885.80,5.0,885.95,ON,886.08,31.0,886.08,32.0,
,887.29,0.0,887.29,1800,887.42,0.740,887.42,2300,887.56,13.0,887.68,27.0,887.68,91.0,886.77,7.0,886.89,5.0,887.04,ON,887.17,31.0,887.17,32.0,
,888.32,0.0,888.32,1700,888.45,0.760,888.45,2200,888.61,13.6,888.75,27.0,888.75,91.0,887.80,8.0,887.92,5.0,888.07,ON,888.20,31.0,888.20,32.0,
,889.43,0.0,889.43,1700,889.56,0.760,889.56,2200,889.71,13.4,889.84,27.0,889.84,91.0,888.88,8.0,889.00,5.0,889.15,ON,889.28,31.0,889.28,32.0,
,890.48,0.0,890.48,1600,890.62,0.740,890.62,2000,890.76,13.2,890.88,27.0,890.88,91.0,889.95,7.0,890.08,5.0,890.23,ON,890.35,31.0,890.35,32.0,
,891.52,0.0,891.52,1600,891.65,0.740,891.65,1900,891.79,12.6,891.91,27.0,891.91,91.0,891.00,7.0,891.12,5.0,891.27,ON,891.40,31.0,891.40,32.0,
,892.55,0.0,892.55,1500,892.67,0.740,892.67,2000,892.82,12.4,892.96,27.0,892.96,91.0,892.03,8.0,892.15,5.0,892.30,ON,892.43,31.0,892.43,32.0,
,893.61,0.0,893.61,1600,893.75,0.740,893.75,2000,893.90,13.0,894.04,27.0,894.04,91.0,893.08,8.0,893.20,5.0,893.35,ON,893.47,31.0,893.47,32.0,
,894.68,0.0,894.68,1600,894.81,0.740,894.81,1900,894.95,13.8,895.08,27.0,895.08,91.0,894.17,7.0,894.29,5.0,894.43,ON,894.56,31.0,894.56,32.0,
,895.70,0.0,895.70,1500,895.82,0.740,895.82,1900,895.95,12.8,896.11,27.0,896.11,91.0,895.20,7.0,895.31,5.0,895.43,ON,895.57,31.0,895.57,32.0,
,896.73,0.0,896.73,1500,896.87,0.740,896.87,1900,896.99,13.6,897.12,27.0,897.12,91.0,896.23,8.0,896.34,5.0,896.46,ON,896.59,31.0,896.59,32.0,
,897.74,0.0,897.74,1500,897.88,0.740,897.88,1900,898.01,12.8,898.13,27.0,898.13,91.0,897.25,8.0,897.37,5.0,897.49,ON,897.62,31.0,897.62,32.0,
,898.79,0.0,898.79,1400,898.93,0.740,898.93,1800,899.05,12.6,899.18,27.0,899.18,91.0,898.26,7.0,898.41,5.0,898.54,ON,898.66,31.0,898.66,32.0,
,899.83,0.0,899.83,1300,899.98,0.750,899.98,1600,900.12,12.0,900.26,27.0,900.26,90.0,899.30,7.0,899.44,5.0,899.57,ON,899.70,31.0,899.70,32.0,
,900.93,0.0,900.93,1100,901.07,0.730,901.07,1400,901.19,12.0,901.32,27.0,901.32,90.0,900.39,8.0,900.53,5.0,900.66,ON,900.79,31.0,900.79,32.0,
,901.97,0.0,901.97,900,902.11,0.750,902.11,1100,902.24,12.2,902.36,27.0,902.36,90.0,901.45,8.0,901.59,5.0,901.72,ON,901.85,31.0,901.85,32.0,
,903.00,0.0,903.00,1100,903.15,0.750,903.15,1400,903.29,12.2,903.43,27.0,903.43,90.0,902.48,7.0,902.62,5.0,902.75,ON,902.88,31.0,902.88,32.0,
,904.10,0.0,904.10,1100,904.26,0.700,904.26,1400,904.39,12.2,904.52,27.0,904.52,90.0,903.56,7.0,903.70,5.0,903.83,ON,903.96,31.0,903.96,32.0,
,905.16,0.0,905.16,1300,905.32,0.750,905.32,1600,905.46,12.4,905.60,27.0,905.60,90.0,904.63,8.0,904.77,5.0,904.89,ON,905.03,31.0,905.03,32.0,
,906.26,0.0,906.26,1600,906.40,0.750,906.40,2000,906.52,12.8,906.66,27.0,906.66,90.0,905.73,7.0,905.87,5.0,906.00,ON,906.13,31.0,906.13,32.0,
,907.30,0.0,907.30,1800,907.44,0.720,907.44,2400,907.57,13.0,907.70,27.0,907.70,90.0,906.79,7.0,906.93,5.0,907.05,ON,907.18,31.0,907.18,32.0,
,908.33,0.0,908.33,2100,908.47,0.750,908.47,2800,908.60,13.0,908.72,27.0,908.72,90.0,907.82,8.0,907.95,5.0,908.08,ON,908.21,31.0,908.21,32.0,
,909.38,0.0,909.38,1700,909.52,0.720,909.52,2200,909.64,12.8,909.77,27.0,909.77,90.0,908.84,8.0,908.98,5.0,909.11,ON,909.24,31.0,909.24,32.0,
,910.41,0.0,910.41,1800,910.53,0.720,910.53,2300,910.68,12.8,910.82,27.0,910.82,90.0,909.88,7.0,909.99,5.0,910.15,ON,910.28,31.0,910.28,32.0,
,911.50,0.0,911.50,2000,911.63,0.750,911.63,2600,911.77,12.2,911.89,27.0,911.89,90.0,910.95,7.0,911.07,5.0,911.22,ON,911.35,31.0,911.35,32.0,
,912.54,0.0,912.54,1700,912.66,0.720,912.66,2200,912.82,12.6,912.94,27.0,912.94,90.0,912.02,8.0,912.13,5.0,912.29,ON,912.41,31.0,912.41,32.0,
,913.59,0.0,913.59,1700,913.70,0.720,913.70,2200,913.85,12.6,913.97,27.0,913.97,90.0,913.07,8.0,913.19,5.0,913.33,ON,913.45,31.0,913.45,32.0,
,914.59,0.0,914.59,1800,914.72,0.750,914.72,2300,914.84,12.6,914.98,27.0,914.98,90.0,914.09,7.0,914.19,5.0,914.33,ON,914.47,31.0,914.47,32.0,
,915.62,0.0,915.62,1900,915.75,0.700,915.75,2400,915.89,12.6,916.03,27.0,916.03,90.0,915.10,7.0,915.22,5.0,915.34,ON,915.47,31.0,915.47,32.0,
,916.65,0.0,916.65,2000,916.80,0.730,916.80,2600,916.93,12.2,917.06,27.0,917.06,90.0,916.17,8.0,916.28,5.0,916.40,ON,916.53,31.0,916.53,32.0,
,917.69,0.0,917.69,2100,917.84,0.740,917.84,2700,917.97,12.2,918.11,27.0,918.11,90.0,917.17,8.0,917.30,5.0,917.43,ON,917.56,31.0,917.56,32.0,
,918.78,0.0,918.78,1800,918.92,0.780,918.92,2300,919.04,12.8,919.17,27.0,919.17,90.0,918.25,8.0,918.38,5.0,918.51,ON,918.64,31.0,918.64,32.0,
,919.84,0.0,919.84,1800,919.99,0.710,919.99,2300,920.14,13.6,920.28,27.0,920.28,90.0,919.31,8.0,919.46,5.0,919.58,ON,919.71,31.0,919.71,32.0,
,920.95,0.0,920.95,1900,921.09,0.740,921.09,2400,921.22,12.8,921.34,27.0,921.34,90.0,920.40,7.0,920.54,5.0,920.67,ON,920.80,31.0,920.80,32.0,
,922.00,0.0,922.00,1900,922.14,0.780,922.14,2400,922.26,12.8,922.40,27.0,922.40,90.0,921.46,7.0,921.60,5.0,921.73,ON,921.86,31.0,921.86,32.0,
,923.03,0.0,923.03,1900,923.17,0.740,923.17,2400,923.29,12.6,923.42,27.0,923.42,90.0,922.50,7.0,922.65,5.0,922.78,ON,922.90,31.0,922.90,32.0,
,924.06,0.0,924.06,1800,924.20,0.740,924.20,2300,924.33,12.4,924.47,27.0,924.47,90.0,923.54,7.0,923.68,5.0,923.81,ON,923.93,31.0,923.93,32.0,
,925.14,0.0,925.14,1800,925.30,0.760,925.30,2300,925.42,12.4,925.56,27.0,925.56,91.0,924.60,7.0,924.75,5.0,924.87,ON,925.00,31.0,925.00,32.0,
,926.21,0.0,926.21,1900,926.35,0.740,926.35,2300,926.48,12.4,926.60,27.0,926.60,91.0,925.69,7.0,925.83,5.0,925.96,ON,926.09,31.0,926.09,32.0,
,927.24,0.0,927.24,1900,927.40,0.740,927.40,2400,927.53,12.4,927.67,27.0,927.67,91.0,926.72,7.0,926.87,5.0,926.99,ON,927.12,31.0,927.12,32.0,
,928.34,0.0,928.34,1900,928.49,0.740,928.49,2400,928.62,12.2,928.76,27.0,928.76,91.0,927.80,7.0,927.94,5.0,928.07,ON,928.20,31.0,928.20,32.0,
,929.40,0.0,929.40,1900,929.54,0.720,929.54,2400,929.66,12.2,929.79,27.0,929.79,91.0,928.87,7.0,929.01,5.0,929.15,ON,929.27,31.0,929.27,32.0,
,930.44,0.0,930.44,1900,930.59,0.750,930.59,2400,930.73,12.4,930.87,27.0,930.87,91.0,929.90,7.0,930.05,5.0,930.18,ON,930.32,31.0,930.32,32.0,
,931.55,0.0,931.55,1900,931.69,0.720,931.69,2400,931.82,12.4,931.94,27.0,931.94,91.0,931.01,7.0,931.15,4.0,931.29,ON,931.43,31.0,931.43,32.0,
,932.58,0.0,932.58,1900,932.72,0.750,932.72,2400,932.85,12.0,932.97,27.0,932.97,92.0,932.06,7.0,932.20,5.0,932.32,ON,932.46,31.0,932.46,32.0,
,933.62,0.0,933.62,1900,933.77,0.720,933.77,2400,933.89,12.4,934.01,27.0,934.01,92.0,933.10,7.0,933.23,5.0,933.36,ON,933.49,31.0,933.49,32.0,
,934.63,0.0,934.63,1900,934.77,0.730,934.77,2400,934.91,12.0,935.02,27.0,935.02,92.0,934.12,7.0,934.24,4.0,934.37,ON,934.49,31.0,934.49,32.0,
,935.66,0.0,935.66,1900,935.77,0.720,935.77,2400,935.90,13.2,936.04,27.0,936.04,92.0,935.15,7.0,935.26,4.0,935.38,ON,935.52,31.0,935.52,32.0,
,936.70,0.0,936.70,1900,936.84,0.750,936.84,2400,936.99,12.0,937.13,27.0,937.13,92.0,936.15,7.0,936.28,5.0,936.41,ON,936.56,31.0,936.56,32.0,
,937.79,0.0,937.79,1900,937.93,0.700,937.93,2400,938.07,12.4,938.23,27.0,938.23,92.0,937.25,7.0,937.37,5.0,937.52,ON,937.66,31.0,937.66,32.0,
,938.87,0.0,938.87,1900,939.00,0.700,939.00,2400,939.13,12.0,939.25,27.0,939.25,92.0,938.35,7.0,938.46,4.0,938.58,ON,938.71,31.0,938.71,32.0,
,939.91,0.0,939.91,1900,940.04,0.720,940.04,2400,940.18,12.2,940.32,27.0,940.32,92.0,939.39,7.0,939.51,4.0,939.64,ON,939.77,31.0,939.77,32.0,
,941.00,0.0,941.00,1900,941.14,0.720,941.14,2400,941.25,12.0,941.38,27.0,941.38,92.0,940.46,7.0,940.59,5.0,940.72,ON,940.85,31.0,940.85,32.0,
,942.03,0.0,942.03,1900,942.16,0.730,942.16,2400,942.28,12.2,942.41,27.0,942.41,92.0,941.51,7.0,941.64,4.0,941.77,ON,941.90,31.0,941.90,32.0,
,943.07,0.0,943.07,1900,943.21,0.700,943.21,2400,943.33,12.4,943.46,27.0,943.46,92.0,942.54,7.0,942.66,4.0,942.78,ON,942.91,31.0,942.91,32.0,
,944.11,0.0,944.11,1800,944.25,0.720,944.25,2300,944.38,12.2,944.52,27.0,944.52,92.0,943.59,7.0,943.71,4.0,943.84,ON,943.97,31.0,943.97,32.0,
,945.20,0.0,945.20,1800,945.33,0.750,945.33,2300,945.47,12.4,945.61,27.0,945.61,92.0,944.66,7.0,944.79,4.0,944.92,ON,945.06,31.0,945.06,32.0,
,946.27,0.0,946.27,1800,946.40,0.710,946.40,2300,946.52,12.2,946.65,27.0,946.65,92.0,945.74,7.0,945.86,4.0,945.98,ON,946.11,31.0,946.11,32.0,
,947.34,0.0,947.34,1800,947.46,0.700,947.46,2300,947.60,12.2,947.74,27.0,947.74,93.0,946.79,7.0,946.91,4.0,947.05,ON,947.19,31.0,947.19,32.0,
,948.44,0.0,948.44,1700,948.56,0.720,948.56,2200,948.69,12.0,948.81,27.0,948.81,93.0,947.90,7.0,948.02,4.0,948.15,ON,948.28,31.0,948.28,32.0,
,949.50,0.0,949.50,1700,949.63,0.710,949.63,2200,949.78,12.0,949.91,27.0,949.91,93.0,948.97,7.0,949.09,4.0,949.22,ON,949.35,31.0,949.35,32.0,
,950.58,0.0,950.58,1700,950.70,0.730,950.70,2200,950.83,12.2,950.95,27.0,950.95,93.0,950.05,7.0,950.18,4.0,950.31,ON,950.44,31.0,950.44,32.0,
,951.61,0.0,951.61,1700,951.73,0.690,951.73,2200,951.86,12.2,951.98,27.0,951.98,93.0,951.09,7.0,951.21,4.0,951.34,ON,951.47,31.0,951.47,32.0,
,952.64,0.0,952.64,1700,952.76,0.750,952.76,2200,952.89,12.0,953.03,27.0,953.03,93.0,952.12,7.0,952.24,4.0,952.37,ON,952.50,31.0,952.50,32.0,
,953.65,0.0,953.65,1600,953.80,0.730,953.80,2000,953.93,12.0,954.06,27.0,954.06,93.0,953.16,7.0,953.28,4.0,953.40,ON,953.53,31.0,953.53,32.0,
,954.70,0.0,954.70,1600,954.84,0.710,954.84,2000,954.97,12.0,955.11,27.5,955.11,93.0,954.17,7.0,954.30,4.0,954.44,ON,954.57,31.0,954.57,32.0,
,955.78,0.0,955.78,1600,955.93,0.750,955.93,2000,956.06,12.2,956.18,27.0,956.18,93.0,955.24,7.0,955.38,4.0,955.51,ON,955.64,31.0,955.64,32.0,
,956.82,0.0,956.82,1600,956.96,0.720,956.96,2000,957.09,12.4,957.21,27.0,957.21,93.0,956.30,7.0,956.44,4.0,956.57,ON,956.70,31.0,956.70,32.0,
,957.85,0.0,957.85,1600,957.99,0.690,957.99,2200,958.12,12.4,958.24,27.0,958.24,93.0,957.33,7.0,957.47,4.0,957.60,ON,957.73,31.0,957.73,32.0,
,958.88,0.0,958.88,1700,959.02,0.730,959.02,2200,959.15,12.6,959.27,27.5,959.27,93.0,958.36,7.0,958.50,4.0,958.63,ON,958.76,31.0,958.76,32.0,
,959.91,0.0,959.91,1700,960.06,0.690,960.06,2200,960.20,12.8,960.33,27.5,960.33,93.0,959.39,7.0,959.53,4.0,959.65,ON,959.79,31.0,959.79,32.0,
,961.00,0.0,961.00,1700,961.16,0.750,961.16,2200,961.28,12.6,961.41,27.5,961.41,93.0,960.46,6.0,960.60,4.0,960.73,ON,960.86,31.0,960.86,32.0,
,962.06,0.0,962.06,1700,962.21,0.730,962.21,2200,962.32,12.2,962.46,27.5,962.46,93.0,961.53,7.0,961.66,4.0,961.80,ON,961.93,31.0,961.93,32.0,
,963.09,0.0,963.09,1700,963.23,0.700,963.23,2200,963.35,12.8,963.49,27.5,963.49,93.0,962.57,7.0,962.72,4.0,962.84,ON,962.97,31.0,962.97,32.0,
,964.12,0.0,964.12,1700,964.26,0.690,964.26,2200,964.38,13.6,964.52,27.5,964.52,93.0,963.59,7.0,963.75,4.0,963.87,ON,963.99,31.0,963.99,32.0,
,965.17,0.0,965.17,1700,965.33,0.750,965.33,2200,965.45,12.6,965.60,27.5,965.60,93.0,964.63,7.0,964.77,4.0,964.90,ON,965.03,31.0,965.03,32.0,
,966.24,0.0,966.24,1700,966.39,0.710,966.39,2200,966.52,13.2,966.65,27.5,966.65,93.0,965.72,7.0,965.86,4.0,965.99,ON,966.12,31.0,966.12,32.0,
,967.29,0.0,967.29,1700,967.45,0.730,967.45,2200,967.59,12.2,967.73,27.5,967.73,93.0,966.76,7.0,966.91,4.0,967.04,ON,967.16,31.0,967.16,32.0,
,968.40,0.0,968.40,1700,968.56,0.720,968.56,2200,968.70,11.8,968.82,27.0,968.82,93.0,967.86,7.0,968.00,4.0,968.13,ON,968.26,31.0,968.26,32.0,
,969.50,0.0,969.50,1700,969.65,0.750,969.65,2200,969.79,12.2,969.93,27.0,969.93,93.0,968.96,7.0,969.11,4.0,969.24,ON,969.36,31.0,969.36,32.0,
,970.60,0.0,970.60,1700,970.75,0.710,970.75,2200,970.88,12.2,971.00,27.5,971.00,93.0,970.06,7.0,970.20,4.0,970.33,ON,970.46,31.0,970.46,32.0,
,971.66,0.0,971.66,1700,971.80,0.720,971.80,2200,971.92,12.2,972.05,27.5,972.05,93.0,971.12,7.0,971.26,4.0,971.39,ON,971.52,31.0,971.52,32.0,
,972.74,0.0,972.74,1600,972.89,0.750,972.89,2000,973.02,13.0,973.16,27.5,973.16,93.0,972.18,7.0,972.32,4.0,972.46,ON,972.60,31.0,972.60,32.0,
,973.80,0.0,973.80,1600,973.94,0.730,973.94,2000,974.06,12.0,974.18,27.5,974.18,93.0,973.27,7.0,973.41,4.0,973.53,ON,973.66,31.0,973.66,32.0,
,974.84,0.0,974.84,1600,974.99,0.730,974.99,2000,975.12,12.0,975.26,27.5,975.26,93.0,974.30,7.0,974.44,4.0,974.58,ON,974.72,31.0,974.72,32.0,
,975.93,0.0,975.93,1600,976.08,0.750,976.08,2000,976.22,12.8,976.33,27.5,976.33,93.0,975.39,7.0,975.53,4.0,975.66,ON,975.79,31.0,975.79,32.0,
,977.00,0.0,977.00,1500,977.13,0.750,977.13,1900,977.26,12.0,977.38,27.5,977.38,93.0,976.46,7.0,976.59,4.0,976.72,ON,976.85,31.0,976.85,32.0,
,978.04,0.0,978.04,1500,978.18,0.700,978.18,1900,978.33,12.0,978.46,27.5,978.46,93.0,977.49,7.0,977.64,4.0,977.78,ON,977.91,31.0,977.91,32.0,
,979.13,0.0,979.13,1500,979.27,0.700,979.27,1900,979.39,12.0,979.52,27.5,979.52,93.0,978.59,7.0,978.73,4.0,978.86,ON,978.99,31.0,978.99,32.0,
,980.17,0.0,980.17,1500,980.31,0.720,980.31,1800,980.44,12.0,980.58,27.5,980.58,93.0,979.65,7.0,979.79,4.0,979.92,ON,980.05,31.0,980.05,32.0,
,981.22,0.0,981.22,1400,981.36,0.730,981.36,1900,981.48,11.6,981.61,27.5,981.61,93.0,980.69,7.0,980.84,4.0,980.97,ON,981.09,31.0,981.09,32.0,
,982.25,0.0,982.25,1500,982.39,0.710,982.39,1900,982.51,12.0,982.64,27.5,982.64,93.0,981.72,7.0,981.87,4.0,982.00,ON,982.12,31.0,982.12,32.0,
,983.30,0.0,983.30,1500,983.45,0.710,983.45,1900,983.58,11.6,983.72,27.5,983.72,93.0,982.75,7.0,982.90,4.0,983.03,ON,983.16,31.0,983.16,32.0,
,984.39,0.0,984.39,1500,984.53,0.760,984.53,1900,984.65,12.0,984.78,27.5,984.78,93.0,983.85,7.0,983.99,4.0,984.12,ON,984.25,31.0,984.25,32.0,
,985.45,0.0,985.45,1600,985.59,0.740,985.59,2000,985.71,13.0,985.84,27.5,985.84,93.0,984.91,7.0,985.05,4.0,985.18,ON,985.31,31.0,985.31,32.0,
,986.48,0.0,986.48,1600,986.62,0.760,986.62,2000,986.75,12.2,986.89,27.5,986.89,93.0,985.96,7.0,986.10,4.0,986.23,ON,986.35,31.0,986.35,32.0,
,987.56,0.0,987.56,1700,987.70,0.730,987.70,2200,987.84,12.2,987.95,27.5,987.95,93.0,987.01,7.0,987.16,4.0,987.28,ON,987.43,31.0,987.43,32.0,
,988.61,0.0,988.61,1700,988.75,0.730,988.75,2200,988.87,12.4,989.00,27.5,989.00,93.0,988.08,7.0,988.21,4.0,988.35,ON,988.48,31.0,988.48,32.0,
,989.64,0.0,989.64,1800,989.78,0.730,989.78,2300,989.90,12.2,990.03,27.5,990.03,93.0,989.12,7.0,989.26,4.0,989.39,ON,989.51,31.0,989.51,32.0,
,990.72,0.0,990.72,1900,990.87,0.710,990.87,2400,991.00,12.4,991.14,27.5,991.14,92.0,990.14,7.0,990.30,4.0,990.44,ON,990.58,31.0,990.58,32.0,
,991.78,0.0,991.78,2300,991.93,0.695,991.93,2900,992.07,12.6,992.18,27.5,992.18,93.0,991.25,7.0,991.39,4.0,991.53,ON,991.65,31.0,991.65,32.0,
,992.82,0.0,992.82,2400,992.96,0.760,992.96,3200,993.09,12.0,993.21,27.5,993.21,92.0,992.30,7.0,992.44,4.0,992.57,ON,992.70,31.0,992.70,32.0,
,993.89,0.0,993.89,2000,994.04,0.710,994.04,2600,994.18,12.0,994.31,27.5,994.31,92.0,993.33,7.0,993.47,4.0,993.61,ON,993.75,31.0,993.75,32.0,
,994.97,0.0,994.97,2000,995.12,0.740,995.12,2600,995.24,12.2,995.37,27.5,995.37,92.0,994.44,7.0,994.58,4.0,994.71,ON,994.84,31.0,994.84,32.0,
,996.01,0.0,996.01,2000,996.15,0.695,996.15,2600,996.27,12.2,996.40,27.5,996.40,92.0,995.48,7.0,995.62,4.0,995.75,ON,995.88,31.0,995.88,32.0,
,997.05,0.0,997.05,2000,997.20,0.760,997.20,2600,997.34,12.2,997.48,27.5,997.48,93.0,996.53,7.0,996.67,4.0,996.80,ON,996.93,31.0,996.93,32.0,
,998.15,0.0,998.15,2000,998.30,0.740,998.30,2600,998.43,12.0,998.55,27.5,998.55,93.0,997.61,7.0,997.75,4.0,997.88,ON,998.01,31.0,998.01,32.0,
,999.19,0.0,999.19,2000,999.33,0.740,999.33,2600,999.46,11.8,999.60,27.5,999.60,93.0,998.67,7.0,998.81,4.0,998.94,ON,999.07,31.0,999.07,32.0,
,1000.24,0.0,1000.24,2000,1000.38,0.730,1000.38,2600,1000.50,12.2,1000.63,27.5,1000.63,93.0,999.71,7.0,999.86,4.0,999.99,ON,1000.11,31.0,1000.11,32.0,
,1001.27,0.0,1001.27,2000,1001.41,0.730,1001.41,2600,1001.53,12.0,1001.66,27.5,1001.66,93.0,1000.74,7.0,1000.88,4.0,1001.01,ON,1001.14,31.0,1001.14,32.0,
,1002.26,0.0,1002.26,2000,1002.38,0.710,1002.38,2600,1002.53,12.0,1002.66,27.5,1002.66,93.0,1001.76,7.0,1001.88,4.0,1002.01,ON,1002.13,31.0,1002.13,32.0,
,1003.29,0.0,1003.29,2000,1003.41,0.695,1003.41,2600,1003.56,12.2,1003.69,27.5,1003.69,93.0,1002.78,7.0,1002.90,4.0,1003.04,ON,1003.16,31.0,1003.16,32.0,
,1004.33,0.0,1004.33,2000,1004.46,0.720,1004.46,2600,1004.60,12.2,1004.73,27.5,1004.73,93.0,1003.81,7.0,1003.93,4.0,1004.08,ON,1004.21,31.0,1004.21,32.0,
,1005.40,0.0,1005.40,2000,1005.54,0.760,1005.54,2600,1005.69,11.8,1005.82,27.5,1005.82,93.0,1004.86,7.0,1004.98,4.0,1005.13,ON,1005.26,31.0,1005.26,32.0,
,1006.47,0.0,1006.47,2000,1006.60,0.710,1006.60,2600,1006.74,12.2,1006.86,27.5,1006.86,93.0,1005.95,7.0,1006.07,4.0,1006.22,ON,1006.35,31.0,1006.35,32.0,
,1007.49,0.0,1007.49,2000,1007.61,0.740,1007.61,2600,1007.74,12.4,1007.88,27.5,1007.88,93.0,1006.98,7.0,1007.10,4.0,1007.22,ON,1007.36,31.0,1007.36,32.0,
,1008.52,0.0,1008.52,2000,1008.64,0.760,1008.64,2600,1008.77,12.2,1008.93,27.5,1008.93,93.0,1007.99,7.0,1008.12,4.0,1008.25,ON,1008.39,31.0,1008.39,32.0,
,1009.60,0.0,1009.60,2000,1009.74,0.750,1009.74,2600,1009.88,12.0,1010.03,27.5,1010.03,93.0,1009.06,7.0,1009.18,4.0,1009.31,ON,1009.46,31.0,1009.46,32.0,
,1010.70,0.0,1010.70,2000,1010.83,0.720,1010.83,2600,1010.95,13.0,1011.11,27.5,1011.11,93.0,1010.15,7.0,1010.28,4.0,1010.41,ON,1010.57,31.0,1010.57,32.0,
,1011.77,0.0,1011.77,2000,1011.91,0.740,1011.91,2600,1012.05,12.2,1012.20,27.5,1012.20,93.0,1011.23,7.0,1011.35,4.0,1011.49,ON,1011.64,31.0,1011.64,32.0,
,1012.87,0.0,1012.87,2000,1013.00,0.740,1013.00,2600,1013.12,12.2,1013.27,27.5,1013.27,93.0,1012.32,7.0,1012.44,4.0,1012.58,ON,1012.74,31.0,1012.74,32.0,
,1013.94,0.0,1013.94,2000,1014.07,0.750,1014.07,2600,1014.22,12.2,1014.37,27.5,1014.37,93.0,1013.41,6.0,1013.52,4.0,1013.65,ON,1013.79,31.0,1013.79,32.0,
,1015.00,0.0,1015.00,1900,1015.13,0.720,1015.13,2400,1015.26,12.2,1015.39,27.5,1015.39,93.0,1014.49,7.0,1014.60,4.0,1014.72,ON,1014.85,31.0,1014.85,32.0,
,1016.02,0.0,1016.02,1900,1016.16,0.740,1016.16,2400,1016.28,12.2,1016.41,27.5,1016.41,93.0,1015.52,7.0,1015.63,4.0,1015.76,ON,1015.89,31.0,1015.89,32.0,
,1017.06,0.0,1017.06,1900,1017.21,0.740,1017.21,2400,1017.34,12.0,1017.47,27.5,1017.47,93.0,1016.53,7.0,1016.66,4.0,1016.79,ON,1016.92,31.0,1016.92,32.0,
,1018.11,0.0,1018.11,1900,1018.25,0.720,1018.25,2400,1018.38,12.2,1018.52,27.5,1018.52,93.0,1017.58,7.0,1017.71,4.0,1017.84,ON,1017.97,31.0,1017.97,32.0,
,1019.19,0.0,1019.19,2000,1019.34,0.720,1019.34,2600,1019.47,12.2,1019.59,27.5,1019.59,93.0,1018.65,6.0,1018.79,4.0,1018.92,ON,1019.05,31.0,1019.05,32.0,
,1020.23,0.0,1020.23,2000,1020.37,0.700,1020.37,2600,1020.50,11.8,1020.64,27.5,1020.64,93.0,1019.71,6.0,1019.85,4.0,1019.98,ON,1020.11,31.0,1020.11,32.0,
,1021.28,0.0,1021.28,2000,1021.42,0.700,1021.42,2600,1021.54,13.0,1021.67,27.5,1021.67,93.0,1020.75,6.0,1020.90,4.0,1021.03,ON,1021.15,31.0,1021.15,32.0,
,1022.31,0.0,1022.31,2000,1022.45,0.690,1022.45,2600,1022.57,12.2,1022.70,27.5,1022.70,93.0,1021.78,7.0,1021.93,4.0,1022.06,ON,1022.18,31.0,1022.18,32.0,
,1023.31,0.0,1023.31,2000,1023.45,0.740,1023.45,2600,1023.61,12.0,1023.75,27.5,1023.75,93.0,1022.81,6.0,1022.92,4.0,1023.06,ON,1023.18,31.0,1023.18,32.0,
,1024.42,0.0,1024.42,2000,1024.56,0.700,1024.56,2600,1024.70,12.2,1024.82,27.5,1024.82,95.0,1023.88,7.0,1024.00,4.0,1024.15,ON,1024.28,31.0,1024.28,32.0,
,1025.48,0.0,1025.48,2000,1025.60,0.700,1025.60,2600,1025.75,12.0,1025.89,27.5,1025.89,93.0,1024.94,6.0,1025.06,4.0,1025.21,ON,1025.34,31.0,1025.34,32.0,
,1026.51,0.0,1026.51,2000,1026.63,0.740,1026.63,2600,1026.77,12.0,1026.90,27.5,1026.90,93.0,1026.00,7.0,1026.12,4.0,1026.26,ON,1026.38,31.0,1026.38,32.0,
,1027.54,0.0,1027.54,2100,1027.66,0.700,1027.66,2700,1027.80,12.2,1027.92,27.5,1027.92,93.0,1027.03,7.0,1027.15,4.0,1027.29,ON,1027.41,31.0,1027.41,32.0,
,1028.54,0.0,1028.54,2100,1028.68,0.700,1028.68,2700,1028.81,12.0,1028.95,27.5,1028.95,92.0,1028.03,6.0,1028.15,4.0,1028.27,ON,1028.40,31.0,1028.40,32.0,
,1029.61,0.0,1029.61,2100,1029.75,0.720,1029.75,2700,1029.89,11.6,1030.05,27.5,1030.05,93.0,1029.07,6.0,1029.19,4.0,1029.32,ON,1029.47,31.0,1029.47,32.0,
,1030.70,0.0,1030.70,2100,1030.83,0.700,1030.83,2700,1030.96,12.0,1031.12,27.5,1031.12,93.0,1030.17,6.0,1030.29,4.0,1030.42,ON,1030.58,31.0,1030.58,32.0,
,1031.78,0.0,1031.78,2100,1031.92,0.720,1031.92,2700,1032.06,13.0,1032.21,27.5,1032.21,93.0,1031.23,6.0,1031.36,4.0,1031.49,ON,1031.64,31.0,1031.64,32.0,
,1032.88,0.0,1032.88,2100,1032.99,0.720,1032.99,2700,1033.12,12.0,1033.28,27.5,1033.28,93.0,1032.33,7.0,1032.45,4.0,1032.59,ON,1032.74,31.0,1032.74,32.0,
,1033.90,0.0,1033.90,2100,1034.04,0.750,1034.04,2700,1034.16,12.2,1034.29,27.5,1034.29,93.0,1033.41,7.0,1033.51,4.0,1033.63,ON,1033.76,31.0,1033.76,32.0,
,1034.96,0.0,1034.96,2200,1035.08,0.710,1035.08,2700,1035.22,12.0,1035.33,27.5,1035.33,93.0,1034.45,6.0,1034.56,4.0,1034.69,ON,1034.82,31.0,1034.82,32.0,
,1036.02,0.0,1036.02,2200,1036.15,0.730,1036.15,2800,1036.30,12.0,1036.43,27.5,1036.43,93.0,1035.47,7.0,1035.59,4.0,1035.73,ON,1035.87,31.0,1035.87,32.0,
,1037.10,0.0,1037.10,2200,1037.22,0.750,1037.22,2800,1037.35,12.0,1037.47,27.5,1037.47,93.0,1036.57,7.0,1036.70,4.0,1036.83,ON,1036.96,31.0,1036.96,32.0,
,1038.14,0.0,1038.14,2200,1038.27,0.710,1038.27,2800,1038.39,11.8,1038.52,27.5,1038.52,93.0,1037.60,6.0,1037.73,4.0,1037.86,ON,1037.99,31.0,1037.99,32.0,
,1039.18,0.0,1039.18,2100,1039.32,0.695,1039.32,2700,1039.46,13.0,1039.60,27.5,1039.60,93.0,1038.65,6.0,1038.77,4.0,1038.90,ON,1039.03,31.0,1039.03,32.0,
,1040.28,0.0,1040.28,2100,1040.40,0.710,1040.40,2700,1040.52,12.2,1040.66,27.5,1040.66,93.0,1039.74,7.0,1039.87,4.0,1040.00,ON,1040.13,31.0,1040.13,32.0,
,1041.32,0.0,1041.32,2100,1041.45,0.750,1041.45,2700,1041.57,12.0,1041.70,27.5,1041.70,93.0,1040.79,7.0,1040.91,4.0,1041.05,ON,1041.19,31.0,1041.19,32.0,
,1042.35,0.0,1042.35,2000,1042.47,0.695,1042.47,2600,1042.60,12.0,1042.72,27.5,1042.72,93.0,1041.84,6.0,1041.96,4.0,1042.09,ON,1042.21,31.0,1042.21,32.0,
,1043.38,0.0,1043.38,2000,1043.50,0.710,1043.50,2600,1043.64,13.0,1043.75,27.5,1043.75,93.0,1042.87,6.0,1042.98,4.0,1043.11,ON,1043.24,31.0,1043.24,32.0,
,1044.41,0.0,1044.41,2000,1044.54,0.730,1044.54,2600,1044.68,11.8,1044.82,27.5,1044.82,93.0,1043.89,7.0,1044.01,4.0,1044.14,ON,1044.27,31.0,1044.27,32.0,
,1045.50,0.0,1045.50,2000,1045.64,0.730,1045.64,2600,1045.75,12.2,1045.89,27.5,1045.89,93.0,1044.96,7.0,1045.10,4.0,1045.22,ON,1045.36,31.0,1045.36,32.0,
,1046.54,0.0,1046.54,2000,1046.68,0.710,1046.68,2600,1046.80,12.0,1046.93,27.5,1046.93,93.0,1046.01,6.0,1046.14,4.0,1046.27,ON,1046.39,31.0,1046.39,32.0,
,1047.53,0.0,1047.53,2000,1047.67,0.730,1047.67,2600,1047.80,12.2,1047.92,27.5,1047.92,93.0,1047.05,6.0,1047.16,4.0,1047.28,ON,1047.41,31.0,1047.41,32.0,
,1048.58,0.0,1048.58,2000,1048.74,0.730,1048.74,2600,1048.87,12.4,1049.01,27.5,1049.01,93.0,1048.04,7.0,1048.18,4.0,1048.31,ON,1048.44,31.0,1048.44,32.0,
,1049.66,0.0,1049.66,2000,1049.81,0.710,1049.81,2600,1049.94,12.2,1050.08,27.5,1050.08,93.0,1049.12,7.0,1049.27,4.0,1049.39,ON,1049.52,31.0,1049.52,32.0,
,1050.73,0.0,1050.73,2000,1050.87,0.710,1050.87,2600,1051.00,12.2,1051.12,27.5,1051.12,93.0,1050.21,6.0,1050.35,4.0,1050.48,ON,1050.61,31.0,1050.61,32.0,
,1051.76,0.0,1051.76,1900,1051.91,0.730,1051.91,2400,1052.04,12.2,1052.17,27.5,1052.17,93.0,1051.24,6.0,1051.39,4.0,1051.51,ON,1051.64,31.0,1051.64,32.0,
,1052.81,0.0,1052.81,1900,1052.96,0.730,1052.96,2400,1053.09,12.2,1053.22,27.5,1053.22,93.0,1052.28,7.0,1052.42,4.0,1052.54,ON,1052.68,31.0,1052.68,32.0,
,1053.88,0.0,1053.88,1800,1054.03,0.695,1054.03,2300,1054.17,12.0,1054.31,27.5,1054.31,93.0,1053.35,7.0,1053.49,4.0,1053.62,ON,1053.75,31.0,1053.75,32.0,
,1054.96,0.0,1054.96,1700,1055.10,0.710,1055.10,2200,1055.24,11.8,1055.37,27.5,1055.37,93.0,1054.44,6.0,1054.58,4.0,1054.71,ON,1054.83,31.0,1054.83,32.0,
,1056.00,0.0,1056.00,1600,1056.14,0.710,1056.14,2000,1056.27,12.0,1056.40,27.5,1056.40,93.0,1055.49,7.0,1055.62,4.0,1055.76,ON,1055.87,31.0,1055.87,32.0,
,1057.00,0.0,1057.00,1500,1057.12,0.750,1057.12,1900,1057.27,12.0,1057.40,27.5,1057.40,93.0,1056.51,7.0,1056.61,4.0,1056.75,ON,1056.87,31.0,1056.87,32.0,
,1058.03,0.0,1058.03,1300,1058.17,0.710,1058.17,1600,1058.31,12.0,1058.44,27.5,1058.44,93.0,1057.52,6.0,1057.64,4.0,1057.78,ON,1057.90,31.0,1057.90,32.0,
,1059.11,0.0,1059.11,1300,1059.25,0.710,1059.25,1600,1059.41,11.8,1059.53,27.5,1059.53,93.0,1058.57,6.0,1058.69,4.0,1058.84,ON,1058.97,31.0,1058.97,32.0,
,1060.19,0.0,1060.19,1300,1060.31,0.730,1060.31,1600,1060.45,11.6,1060.57,27.5,1060.57,93.0,1059.64,7.0,1059.77,4.0,1059.92,ON,1060.06,31.0,1060.06,32.0,
,1061.21,0.0,1061.21,1300,1061.34,0.750,1061.34,1600,1061.50,12.0,1061.64,27.5,1061.64,93.0,1060.70,7.0,1060.81,4.0,1060.97,ON,1061.09,31.0,1061.09,32.0,
,1062.31,0.0,1062.31,1500,1062.45,0.710,1062.45,1900,1062.60,12.0,1062.73,27.5,1062.73,93.0,1061.77,6.0,1061.89,4.0,1062.05,ON,1062.18,31.0,1062.18,32.0,
,1063.37,0.0,1063.37,1500,1063.49,0.710,1063.49,1900,1063.63,12.0,1063.76,27.5,1063.76,93.0,1062.86,6.0,1062.98,4.0,1063.12,ON,1063.24,31.0,1063.24,32.0,
,1064.40,0.0,1064.40,1500,1064.52,0.760,1064.52,1900,1064.65,12.0,1064.79,27.5,1064.79,93.0,1063.87,7.0,1063.98,4.0,1064.12,ON,1064.27,31.0,1064.27,32.0,
,1065.43,0.0,1065.43,1500,1065.55,0.760,1065.55,1900,1065.68,12.0,1065.82,27.5,1065.82,93.0,1064.90,7.0,1065.03,4.0,1065.16,ON,1065.30,31.0,1065.30,32.0,
,1066.47,0.0,1066.47,1500,1066.60,0.720,1066.60,1900,1066.73,12.2,1066.88,27.5,1066.88,93.0,1065.93,6.0,1066.06,4.0,1066.19,ON,1066.34,31.0,1066.34,32.0,
,1067.53,0.0,1067.53,1500,1067.68,0.760,1067.68,1900,1067.82,12.2,1067.97,27.5,1067.97,93.0,1067.00,7.0,1067.12,4.0,1067.26,ON,1067.41,31.0,1067.41,32.0,
,1068.60,0.0,1068.60,1500,1068.73,0.720,1068.73,1900,1068.86,12.4,1068.99,27.5,1068.99,93.0,1068.09,6.0,1068.21,4.0,1068.34,ON,1068.48,31.0,1068.48,32.0,
,1069.62,0.0,1069.62,1500,1069.77,0.740,1069.77,1900,1069.90,12.4,1070.02,27.5,1070.02,93.0,1069.12,6.0,1069.23,4.0,1069.35,ON,1069.48,31.0,1069.48,32.0,
,1070.68,0.0,1070.68,1500,1070.80,0.720,1070.80,1900,1070.93,12.6,1071.05,27.5,1071.05,93.0,1070.16,7.0,1070.28,4.0,1070.41,ON,1070.54,31.0,1070.54,32.0,
,1071.71,0.0,1071.71,1500,1071.83,0.760,1071.83,1900,1071.96,12.6,1072.08,27.5,1072.08,93.0,1071.19,6.0,1071.31,4.0,1071.44,ON,1071.57,31.0,1071.57,32.0,
,1072.77,0.0,1072.77,1500,1072.90,0.720,1072.90,1900,1073.04,12.6,1073.19,27.5,1073.19,93.0,1072.22,7.0,1072.34,4.0,1072.48,ON,1072.62,31.0,1072.62,32.0,
,1073.88,0.0,1073.88,1500,1074.01,0.720,1074.01,1900,1074.15,12.6,1074.29,27.5,1074.29,93.0,1073.32,7.0,1073.46,4.0,1073.60,ON,1073.73,31.0,1073.73,32.0,
,1074.96,0.0,1074.96,1500,1075.08,0.720,1075.08,1900,1075.21,12.0,1075.35,27.5,1075.35,93.0,1074.43,6.0,1074.56,4.0,1074.69,ON,1074.82,31.0,1074.82,32.0,
,1076.02,0.0,1076.02,1500,1076.14,0.760,1076.14,1900,1076.27,12.6,1076.39,27.5,1076.39,93.0,1075.50,7.0,1075.62,4.0,1075.75,ON,1075.88,31.0,1075.88,32.0,
,1077.02,0.0,1077.02,1600,1077.17,0.740,1077.17,2000,1077.30,13.4,1077.44,27.5,1077.44,93.0,1076.52,7.0,1076.63,4.0,1076.75,ON,1076.88,31.0,1076.88,32.0,
,1078.06,0.0,1078.06,1600,1078.21,0.760,1078.21,2000,1078.35,12.6,1078.49,27.5,1078.49,93.0,1077.55,7.0,1077.68,4.0,1077.81,ON,1077.94,31.0,1077.94,32.0,
,1079.16,0.0,1079.16,1700,1079.31,0.740,1079.31,2200,1079.45,12.6,1079.58,27.5,1079.58,93.0,1078.62,7.0,1078.76,4.0,1078.89,ON,1079.02,31.0,1079.02,32.0,
,1080.25,0.0,1080.25,1700,1080.38,0.760,1080.38,2200,1080.51,12.6,1080.66,27.5,1080.66,93.0,1079.70,7.0,1079.83,4.0,1079.98,ON,1080.11,31.0,1080.11,32.0,
,1081.33,0.0,1081.33,1800,1081.48,0.760,1081.48,2300,1081.61,12.8,1081.75,27.5,1081.75,93.0,1080.79,7.0,1080.93,4.0,1081.06,ON,1081.18,31.0,1081.18,32.0,
,1082.39,0.0,1082.39,1800,1082.53,0.720,1082.53,2300,1082.66,12.6,1082.79,27.5,1082.79,93.0,1081.88,7.0,1082.02,4.0,1082.14,ON,1082.28,31.0,1082.28,32.0,
,1083.42,0.0,1083.42,1800,1083.57,0.760,1083.57,2300,1083.70,12.6,1083.83,27.5,1083.83,93.0,1082.91,7.0,1083.04,4.0,1083.17,ON,1083.30,31.0,1083.30,32.0,
,1084.49,0.0,1084.49,1800,1084.65,0.720,1084.65,2300,1084.77,12.8,1084.91,27.5,1084.91,93.0,1083.94,7.0,1084.07,4.0,1084.21,ON,1084.36,31.0,1084.36,32.0,
,1085.56,0.0,1085.56,1800,1085.70,0.760,1085.70,2300,1085.83,12.8,1085.95,27.5,1085.95,93.0,1085.02,7.0,1085.17,4.0,1085.30,ON,1085.43,31.0,1085.43,32.0,
,1086.59,0.0,1086.59,1900,1086.74,0.760,1086.74,2300,1086.87,13.8,1087.00,27.5,1087.00,93.0,1086.07,6.0,1086.22,4.0,1086.34,ON,1086.47,31.0,1086.47,32.0,
,1087.64,0.0,1087.64,1900,1087.79,0.760,1087.79,2400,1087.92,12.8,1088.05,28.0,1088.05,93.0,1087.11,7.0,1087.26,4.0,1087.39,ON,1087.51,31.0,1087.51,32.0,
,1088.72,0.0,1088.72,1900,1088.87,0.760,1088.87,2300,1089.00,12.8,1089.14,28.0,1089.14,93.0,1088.18,7.0,1088.32,4.0,1088.45,ON,1088.58,31.0,1088.58,32.0,
,1089.76,0.0,1089.76,1600,1089.89,0.720,1089.89,2000,1090.04,12.2,1090.17,28.0,1090.17,93.0,1089.25,7.0,1089.39,4.0,1089.51,ON,1089.64,31.0,1089.64,32.0,
,1090.81,0.0,1090.81,1500,1090.95,0.760,1090.95,1900,1091.11,12.4,1091.25,28.0,1091.25,93.0,1090.28,7.0,1090.41,4.0,1090.56,ON,1090.68,31.0,1090.68,32.0,
,1091.93,0.0,1091.93,1500,1092.06,0.740,1092.06,1900,1092.21,12.4,1092.34,28.0,1092.34,93.0,1091.38,7.0,1091.50,4.0,1091.65,ON,1091.78,31.0,1091.78,32.0,
,1092.98,0.0,1092.98,1500,1093.10,0.760,1093.10,1900,1093.25,12.4,1093.38,28.0,1093.38,93.0,1092.45,7.0,1092.58,4.0,1092.73,ON,1092.85,31.0,1092.85,32.0,
,1094.04,0.0,1094.04,1500,1094.16,0.780,1094.16,1900,1094.31,12.0,1094.45,28.0,1094.45,93.0,1093.50,7.0,1093.62,4.0,1093.78,ON,1093.90,31.0,1093.90,32.0,
,1095.11,0.0,1095.11,1500,1095.26,0.740,1095.26,1900,1095.41,13.0,1095.54,28.0,1095.54,93.0,1094.58,7.0,1094.70,4.0,1094.84,ON,1094.97,31.0,1094.97,32.0,
,1096.18,0.0,1096.18,1500,1096.32,0.740,1096.32,1900,1096.45,12.2,1096.58,28.0,1096.58,93.0,1095.65,7.0,1095.77,4.0,1095.92,ON,1096.05,31.0,1096.05,32.0,
,1097.22,0.0,1097.22,1500,1097.37,0.740,1097.37,1900,1097.50,12.2,1097.66,28.0,1097.66,94.0,1096.70,7.0,1096.82,4.0,1096.93,ON,1097.08,31.0,1097.08,32.0,
,1098.31,0.0,1098.31,1500,1098.45,0.760,1098.45,1900,1098.57,12.0,1098.71,28.0,1098.71,94.0,1097.78,7.0,1097.91,4.0,1098.05,ON,1098.18,31.0,1098.18,32.0,
,1099.37,0.0,1099.37,1500,1099.49,0.740,1099.49,1900,1099.62,12.2,1099.76,28.0,1099.76,94.0,1098.83,7.0,1098.95,4.0,1099.09,ON,1099.24,31.0,1099.24,32.0,
,1100.41,0.0,1100.41,1500,1100.54,0.780,1100.54,1900,1100.66,12.2,1100.81,28.0,1100.81,94.0,1099.87,7.0,1100.00,5.0,1100.13,ON,1100.28,31.0,1100.28,32.0,
,1101.48,0.0,1101.48,1500,1101.62,0.760,1101.62,1900,1101.77,12.2,1101.91,28.0,1101.91,95.0,1100.94,7.0,1101.06,5.0,1101.20,ON,1101.35,31.0,1101.35,32.0,
,1102.54,0.0,1102.54,1500,1102.66,0.780,1102.66,1900,1102.79,13.4,1102.93,28.0,1102.93,95.0,1102.04,7.0,1102.15,4.0,1102.27,ON,1102.40,31.0,1102.40,32.0,
,1103.60,0.0,1103.60,1500,1103.72,0.770,1103.72,1900,1103.86,11.8,1103.97,28.0,1103.97,95.0,1103.08,7.0,1103.20,4.0,1103.34,ON,1103.46,31.0,1103.46,32.0,
,1104.58,0.0,1104.58,1500,1104.72,0.770,1104.72,1900,1104.85,12.2,1104.99,28.0,1104.99,95.0,1104.10,7.0,1104.21,5.0,1104.33,ON,1104.46,31.0,1104.46,32.0,
,1105.61,0.0,1105.61,1600,1105.76,0.770,1105.76,2000,1105.90,12.4,1106.04,28.0,1106.04,95.0,1105.10,7.0,1105.23,5.0,1105.36,ON,1105.49,31.0,1105.49,32.0,
,1106.71,0.0,1106.71,1600,1106.85,0.790,1106.85,2000,1106.99,12.0,1107.13,28.0,1107.13,96.0,1106.17,7.0,1106.31,4.0,1106.44,ON,1106.57,31.0,1106.57,32.0,
,1107.79,0.0,1107.79,1600,1107.93,0.750,1107.93,2000,1108.06,12.2,1108.19,28.0,1108.19,96.0,1107.25,7.0,1107.38,5.0,1107.53,ON,1107.65,31.0,1107.65,32.0,
,1108.83,0.0,1108.83,1600,1108.96,0.770,1108.96,2200,1109.10,12.2,1109.24,28.0,1109.24,96.0,1108.30,7.0,1108.44,5.0,1108.57,ON,1108.69,31.0,1108.69,32.0,
,1109.90,0.0,1109.90,1700,1110.06,0.770,1110.06,2200,1110.18,12.4,1110.32,28.0,1110.32,96.0,1109.36,7.0,1109.50,4.0,1109.63,ON,1109.76,31.0,1109.76,32.0,
,1110.98,0.0,1110.98,1700,1111.11,0.770,1111.11,2200,1111.24,12.4,1111.36,28.0,1111.36,96.0,1110.44,7.0,1110.58,4.0,1110.72,ON,1110.85,31.0,1110.85,32.0,
,1112.00,0.0,1112.00,1800,1112.15,0.770,1112.15,2300,1112.28,12.6,1112.41,28.0,1112.41,96.0,1111.48,7.0,1111.62,5.0,1111.75,ON,1111.88,31.0,1111.88,32.0,
,1113.03,0.0,1113.03,1800,1113.18,0.770,1113.18,2300,1113.32,12.6,1113.47,28.0,1113.47,96.0,1112.52,7.0,1112.65,5.0,1112.78,ON,1112.91,31.0,1112.91,32.0,
,1114.13,0.0,1114.13,1800,1114.29,0.770,1114.29,2300,1114.42,12.6,1114.55,28.0,1114.55,96.0,1113.59,7.0,1113.73,4.0,1113.86,ON,1114.00,31.0,1114.00,32.0,
,1115.24,0.0,1115.24,1800,1115.39,0.770,1115.39,2300,1115.52,12.4,1115.66,28.0,1115.66,96.0,1114.66,7.0,1114.82,4.0,1114.96,ON,1115.10,31.0,1115.10,32.0,
,1116.34,0.0,1116.34,1900,1116.47,0.770,1116.47,2400,1116.60,12.6,1116.72,28.0,1116.72,96.0,1115.77,7.0,1115.91,5.0,1116.05,ON,1116.19,31.0,1116.19,32.0,
,1117.36,0.0,1117.36,1900,1117.50,0.770,1117.50,2400,1117.62,13.4,1117.75,28.0,1117.75,97.0,1116.83,7.0,1116.98,5.0,1117.12,ON,1117.23,31.0,1117.23,32.0,
,1118.39,0.0,1118.39,1900,1118.53,0.770,1118.53,2400,1118.65,13.2,1118.78,28.0,1118.78,97.0,1117.86,7.0,1118.01,4.0,1118.14,ON,1118.26,31.0,1118.26,32.0,
,1119.39,0.0,1119.39,1900,1119.53,0.770,1119.53,2400,1119.67,12.2,1119.79,28.0,1119.79,97.0,1118.89,7.0,1119.00,4.0,1119.14,ON,1119.26,31.0,1119.26,32.0,
,1120.42,0.0,1120.42,1900,1120.54,0.770,1120.54,2400,1120.67,12.0,1120.80,28.0,1120.80,97.0,1119.91,7.0,1120.03,5.0,1120.15,ON,1120.29,31.0,1120.29,32.0,
,1121.46,0.0,1121.46,1900,1121.59,0.770,1121.59,2400,1121.72,12.4,1121.87,28.0,1121.87,97.0,1120.92,7.0,1121.05,5.0,1121.18,ON,1121.33,31.0,1121.33,32.0,
,1122.52,0.0,1122.52,1900,1122.66,0.750,1122.66,2400,1122.81,12.0,1122.95,28.0,1122.95,97.0,1121.99,7.0,1122.11,4.0,1122.24,ON,1122.38,31.0,1122.38,32.0,
,1123.60,0.0,1123.60,1900,1123.72,0.770,1123.72,2400,1123.84,12.4,1123.98,28.0,1123.98,97.0,1123.08,6.0,1123.19,4.0,1123.33,ON,1123.47,31.0,1123.47,32.0,
,1124.62,0.0,1124.62,1900,1124.75,0.770,1124.75,2400,1124.89,12.2,1125.03,28.0,1125.03,97.0,1124.10,7.0,1124.22,5.0,1124.36,ON,1124.50,31.0,1124.50,32.0,
,1125.65,0.0,1125.65,1800,1125.78,0.770,1125.78,2300,1125.92,12.4,1126.04,27.5,1126.04,97.0,1125.15,6.0,1125.25,5.0,1125.37,ON,1125.50,31.0,1125.50,32.0,
,1126.70,0.0,1126.70,1800,1126.82,0.750,1126.82,2300,1126.95,12.4,1127.07,28.0,1127.07,97.0,1126.18,7.0,1126.30,4.0,1126.43,ON,1126.56,31.0,1126.56,32.0,
,1127.73,0.0,1127.73,1800,1127.86,0.770,1127.86,2300,1128.00,12.2,1128.14,28.0,1128.14,97.0,1127.21,6.0,1127.33,4.0,1127.46,ON,1127.59,31.0,1127.59,32.0,
,1128.82,0.0,1128.82,1800,1128.95,0.770,1128.95,2300,1129.10,12.0,1129.23,27.5,1129.23,97.0,1128.29,7.0,1128.41,5.0,1128.54,ON,1128.67,31.0,1128.67,32.0,
,1129.90,0.0,1129.90,1800,1130.03,0.730,1130.03,2300,1130.17,13.2,1130.31,27.5,1130.31,97.0,1129.38,7.0,1129.50,4.0,1129.63,ON,1129.76,31.0,1129.76,32.0,
,1130.99,0.0,1130.99,1800,1131.12,0.750,1131.12,2300,1131.26,12.2,1131.38,28.0,1131.38,96.0,1130.45,7.0,1130.58,4.0,1130.71,ON,1130.84,31.0,1130.84,32.0,
,1132.06,0.0,1132.06,1800,1132.20,0.730,1132.20,2300,1132.32,12.2,1132.44,27.5,1132.44,96.0,1131.51,7.0,1131.64,4.0,1131.77,ON,1131.90,31.0,1131.90,32.0,
,1133.10,0.0,1133.10,1900,1133.23,0.730,1133.23,2400,1133.37,11.8,1133.52,28.0,1133.52,96.0,1132.58,6.0,1132.71,4.0,1132.83,ON,1132.96,31.0,1132.96,32.0,
,1134.19,0.0,1134.19,1900,1134.32,0.750,1134.32,2400,1134.44,12.4,1134.57,27.5,1134.57,96.0,1133.65,7.0,1133.78,4.0,1133.91,ON,1134.05,31.0,1134.05,32.0,
,1135.24,0.0,1135.24,1900,1135.36,0.730,1135.36,2400,1135.49,12.4,1135.62,27.5,1135.62,96.0,1134.72,7.0,1134.83,4.0,1134.96,ON,1135.10,31.0,1135.10,32.0,
,1136.29,0.0,1136.29,1800,1136.42,0.730,1136.42,2400,1136.56,12.2,1136.70,27.5,1136.70,96.0,1135.76,7.0,1135.89,4.0,1136.01,ON,1136.14,31.0,1136.14,32.0,
,1137.38,0.0,1137.38,1900,1137.51,0.730,1137.51,2400,1137.64,13.2,1137.76,27.5,1137.76,96.0,1136.84,7.0,1136.97,4.0,1137.10,ON,1137.23,31.0,1137.23,32.0,
,1138.44,0.0,1138.44,1900,1138.55,0.750,1138.55,2400,1138.68,12.0,1138.80,27.5,1138.80,96.0,1137.89,7.0,1138.01,4.0,1138.15,ON,1138.29,31.0,1138.29,32.0,
,1139.46,0.0,1139.46,1900,1139.58,0.770,1139.58,2400,1139.71,12.2,1139.83,27.5,1139.83,96.0,1138.94,7.0,1139.06,4.0,1139.20,ON,1139.32,31.0,1139.32,32.0,
,1140.53,0.0,1140.53,1900,1140.65,0.730,1140.65,2400,1140.80,12.2,1140.93,27.5,1140.93,96.0,1139.97,7.0,1140.09,4.0,1140.23,ON,1140.37,31.0,1140.37,32.0,
,1141.60,0.0,1141.60,2000,1141.72,0.750,1141.72,2600,1141.85,12.2,1141.97,27.5,1141.97,96.0,1141.07,6.0,1141.18,4.0,1141.32,ON,1141.46,31.0,1141.46,32.0,
,1142.65,0.0,1142.65,2000,1142.78,0.750,1142.78,2600,1142.91,12.4,1143.03,27.5,1143.03,96.0,1142.10,7.0,1142.23,4.0,1142.36,ON,1142.49,31.0,1142.49,32.0,
,1143.72,0.0,1143.72,2000,1143.85,0.770,1143.85,2700,1143.99,12.2,1144.13,28.0,1144.13,96.0,1143.17,7.0,1143.29,4.0,1143.43,ON,1143.57,31.0,1143.57,32.0,
,1144.80,0.0,1144.80,2100,1144.92,0.730,1144.92,2700,1145.05,12.2,1145.17,27.5,1145.17,96.0,1144.26,6.0,1144.38,4.0,1144.52,ON,1144.66,31.0,1144.66,32.0,
,1145.83,0.0,1145.83,2100,1145.95,0.750,1145.95,2700,1146.08,12.2,1146.20,27.5,1146.20,95.0,1145.31,7.0,1145.43,4.0,1145.56,ON,1145.69,31.0,1145.69,32.0,
,1146.86,0.0,1146.86,2200,1146.98,0.750,1146.98,2800,1147.11,12.4,1147.23,27.5,1147.23,95.0,1146.34,7.0,1146.46,4.0,1146.59,ON,1146.72,31.0,1146.72,32.0,
,1147.92,0.0,1147.92,2200,1148.04,0.730,1148.04,2800,1148.19,12.2,1148.34,27.5,1148.34,95.0,1147.37,7.0,1147.49,4.0,1147.63,ON,1147.77,31.0,1147.77,32.0,
,1149.01,0.0,1149.01,2200,1149.15,0.730,1149.15,2700,1149.28,12.0,1149.40,27.5,1149.40,95.0,1148.47,6.0,1148.60,4.0,1148.73,ON,1148.86,31.0,1148.86,32.0,
,1150.07,0.0,1150.07,2100,1150.21,0.750,1150.21,2700,1150.35,12.2,1150.49,27.5,1150.49,95.0,1149.54,7.0,1149.65,4.0,1149.79,ON,1149.92,31.0,1149.92,32.0,
,1151.18,0.0,1151.18,2000,1151.31,0.720,1151.31,2600,1151.45,11.8,1151.58,27.5,1151.58,95.0,1150.63,7.0,1150.76,4.0,1150.90,ON,1151.02,31.0,1151.02,32.0,
,1152.22,0.0,1152.22,2000,1152.36,0.700,1152.36,2600,1152.50,12.0,1152.63,27.5,1152.63,95.0,1151.72,6.0,1151.83,4.0,1151.96,ON,1152.08,31.0,1152.08,32.0,
,1153.30,0.0,1153.30,1900,1153.45,0.730,1153.45,2400,1153.58,13.0,1153.70,27.5,1153.70,95.0,1152.76,6.0,1152.90,4.0,1153.03,ON,1153.16,31.0,1153.16,32.0,
,1154.34,0.0,1154.34,1900,1154.48,0.750,1154.48,2300,1154.61,11.8,1154.75,27.5,1154.75,95.0,1153.82,7.0,1153.96,4.0,1154.09,ON,1154.22,31.0,1154.22,32.0,
,1155.39,0.0,1155.39,1800,1155.53,0.730,1155.53,2300,1155.65,12.2,1155.78,27.5,1155.78,95.0,1154.86,7.0,1155.01,4.0,1155.14,ON,1155.26,31.0,1155.26,32.0,
,1156.40,0.0,1156.40,1700,1156.53,0.700,1156.53,2200,1156.68,12.2,1156.81,28.0,1156.81,95.0,1155.89,6.0,1156.03,4.0,1156.15,ON,1156.28,31.0,1156.28,32.0,
,1157.42,0.0,1157.42,1700,1157.54,0.750,1157.54,2000,1157.67,12.0,1157.81,28.0,1157.81,95.0,1156.92,6.0,1157.03,4.0,1157.16,ON,1157.29,31.0,1157.29,32.0,
,1158.45,0.0,1158.45,1600,1158.57,0.750,1158.57,2000,1158.70,12.0,1158.84,27.5,1158.84,95.0,1157.93,7.0,1158.05,4.0,1158.19,ON,1158.32,31.0,1158.32,32.0,
,1159.49,0.0,1159.49,1600,1159.62,0.750,1159.62,1900,1159.75,13.0,1159.89,28.0,1159.89,95.0,1158.96,7.0,1159.08,4.0,1159.21,ON,1159.36,31.0,1159.36,32.0,
,1160.57,0.0,1160.57,1500,1160.70,0.730,1160.70,1900,1160.84,12.0,1160.99,28.0,1160.99,95.0,1160.03,6.0,1160.16,4.0,1160.30,ON,1160.45,31.0,1160.45,32.0,
,1161.63,0.0,1161.63,1500,1161.76,0.750,1161.76,1900,1161.88,12.2,1162.03,28.0,1162.03,95.0,1161.11,6.0,1161.23,4.0,1161.37,ON,1161.50,31.0,1161.50,32.0,
,1162.69,0.0,1162.69,1500,1162.83,0.750,1162.83,1900,1162.97,12.2,1163.12,28.0,1163.12,95.0,1162.15,7.0,1162.28,4.0,1162.40,ON,1162.55,31.0,1162.55,32.0,
,1163.76,0.0,1163.76,1500,1163.89,0.730,1163.89,1900,1164.03,12.2,1164.18,28.0,1164.18,95.0,1163.24,7.0,1163.37,4.0,1163.50,ON,1163.65,31.0,1163.65,32.0,
,1164.81,0.0,1164.81,1500,1164.96,0.730,1164.96,1900,1165.07,13.2,1165.22,28.0,1165.22,95.0,1164.29,6.0,1164.42,4.0,1164.54,ON,1164.68,31.0,1164.68,32.0,
,1165.89,0.0,1165.89,1500,1166.03,0.750,1166.03,1900,1166.17,12.2,1166.32,28.0,1166.32,95.0,1165.33,7.0,1165.46,4.0,1165.59,ON,1165.76,31.0,1165.76,32.0,
,1166.98,0.0,1166.98,1500,1167.10,0.750,1167.10,1900,1167.23,12.2,1167.39,28.0,1167.39,95.0,1166.44,7.0,1166.56,4.0,1166.70,ON,1166.85,31.0,1166.85,32.0,
,1168.07,0.0,1168.07,1500,1168.20,0.770,1168.20,1900,1168.35,12.4,1168.49,28.0,1168.49,94.0,1167.52,6.0,1167.64,4.0,1167.77,ON,1167.92,31.0,1167.92,32.0,
,1169.15,0.0,1169.15,1500,1169.27,0.730,1169.27,1900,1169.40,12.2,1169.54,28.0,1169.54,94.0,1168.61,7.0,1168.73,4.0,1168.88,ON,1169.02,31.0,1169.02,32.0,
,1170.18,0.0,1170.18,1500,1170.30,0.750,1170.30,1900,1170.44,13.4,1170.58,28.0,1170.58,94.0,1169.65,7.0,1169.78,4.0,1169.91,ON,1170.05,31.0,1170.05,32.0,
,1171.23,0.0,1171.23,1500,1171.37,0.750,1171.37,1900,1171.51,12.2,1171.66,28.0,1171.66,94.0,1170.70,7.0,1170.82,4.0,1170.96,ON,1171.10,31.0,1171.10,32.0,
,1172.32,0.0,1172.32,1400,1172.46,0.770,1172.46,1800,1172.60,12.2,1172.76,28.0,1172.76,94.0,1171.78,7.0,1171.90,4.0,1172.04,ON,1172.19,31.0,1172.19,32.0,
,1173.38,0.0,1173.38,1400,1173.52,0.760,1173.52,1800,1173.64,13.2,1173.77,28.0,1173.77,94.0,1172.88,7.0,1173.00,4.0,1173.11,ON,1173.24,31.0,1173.24,32.0,
,1174.39,0.0,1174.39,1400,1174.54,0.710,1174.54,1900,1174.66,12.2,1174.80,28.0,1174.80,94.0,1173.90,7.0,1174.02,4.0,1174.14,ON,1174.27,31.0,1174.27,32.0,
,1175.44,0.0,1175.44,1400,1175.57,0.750,1175.57,1800,1175.70,12.0,1175.82,28.0,1175.82,94.0,1174.91,7.0,1175.06,4.0,1175.19,ON,1175.31,31.0,1175.31,32.0,
,1176.46,0.0,1176.46,1400,1176.60,0.740,1176.60,1800,1176.73,12.2,1176.87,28.0,1176.87,94.0,1175.95,7.0,1176.09,4.0,1176.21,ON,1176.33,31.0,1176.33,32.0,
,1177.54,0.0,1177.54,1400,1177.70,0.750,1177.70,1800,1177.82,13.0,1177.97,28.0,1177.97,94.0,1177.01,7.0,1177.14,4.0,1177.27,ON,1177.40,31.0,1177.40,32.0,
,1178.61,0.0,1178.61,1400,1178.77,0.730,1178.77,1800,1178.90,12.0,1179.04,28.0,1179.04,94.0,1178.09,7.0,1178.24,4.0,1178.36,ON,1178.49,31.0,1178.49,32.0,
,1179.71,0.0,1179.71,1400,1179.86,0.750,1179.86,1800,1179.99,12.0,1180.13,28.0,1180.13,94.0,1179.17,7.0,1179.31,4.0,1179.44,ON,1179.57,31.0,1179.57,32.0,
,1180.75,0.0,1180.75,1400,1180.88,0.800,1180.88,1800,1181.03,12.0,1181.16,28.0,1181.16,94.0,1180.24,7.0,1180.38,4.0,1180.50,ON,1180.63,31.0,1180.63,32.0,
,1181.81,0.0,1181.81,1400,1181.94,0.780,1181.94,1800,1182.06,12.0,1182.21,28.0,1182.21,94.0,1181.27,7.0,1181.38,4.0,1181.52,ON,1181.68,31.0,1181.68,32.0,
,1182.85,0.0,1182.85,1400,1182.99,0.750,1182.99,1800,1183.13,12.0,1183.27,28.0,1183.27,94.0,1182.34,7.0,1182.44,4.0,1182.56,ON,1182.69,31.0,1182.69,32.0,
,1183.96,0.0,1183.96,1400,1184.09,0.750,1184.09,1800,1184.22,12.2,1184.34,28.0,1184.34,94.0,1183.42,7.0,1183.54,5.0,1183.68,ON,1183.80,31.0,1183.80,32.0,
,1185.01,0.0,1185.01,1400,1185.14,0.800,1185.14,1800,1185.26,12.2,1185.39,28.0,1185.39,94.0,1184.48,7.0,1184.60,5.0,1184.73,ON,1184.86,31.0,1184.86,32.0,
,1186.06,0.0,1186.06,1400,1186.19,0.780,1186.19,1800,1186.33,12.2,1186.47,28.0,1186.47,94.0,1185.52,7.0,1185.64,4.0,1185.77,ON,1185.90,31.0,1185.90,32.0,
,1187.15,0.0,1187.15,1400,1187.28,0.760,1187.28,1800,1187.42,12.0,1187.54,28.0,1187.54,94.0,1186.61,7.0,1186.74,4.0,1186.87,ON,1187.00,31.0,1187.00,32.0,
,1188.17,0.0,1188.17,1400,1188.30,0.770,1188.30,1800,1188.42,12.2,1188.55,28.0,1188.55,94.0,1187.67,7.0,1187.78,5.0,1187.92,ON,1188.04,31.0,1188.04,32.0,
,1189.20,0.0,1189.20,1300,1189.33,0.770,1189.33,1600,1189.45,12.0,1189.58,28.0,1189.58,94.0,1188.67,7.0,1188.82,5.0,1188.95,ON,1189.07,31.0,1189.07,32.0,
,1190.22,0.0,1190.22,1300,1190.36,0.750,1190.36,1600,1190.48,11.8,1190.61,28.0,1190.61,94.0,1189.70,7.0,1189.84,4.0,1189.95,ON,1190.09,31.0,1190.09,32.0,
,1191.25,0.0,1191.25,1300,1191.39,0.750,1191.39,1600,1191.51,12.0,1191.64,28.0,1191.64,93.0,1190.73,7.0,1190.88,4.0,1191.00,ON,1191.12,31.0,1191.12,32.0,
,1192.30,0.0,1192.30,1300,1192.45,0.800,1192.45,1600,1192.58,12.0,1192.72,27.5,1192.72,94.0,1191.75,7.0,1191.90,5.0,1192.03,ON,1192.16,31.0,1192.16,32.0,
,1193.37,0.0,1193.37,1300,1193.51,0.780,1193.51,1800,1193.64,12.0,1193.78,27.5,1193.78,93.0,1192.85,7.0,1192.99,5.0,1193.12,ON,1193.25,31.0,1193.25,32.0,
,1194.43,0.0,1194.43,1400,1194.58,0.780,1194.58,1800,1194.71,12.0,1194.85,27.5,1194.85,93.0,1193.91,7.0,1194.06,4.0,1194.18,ON,1194.31,31.0,1194.31,32.0,
,1195.46,0.0,1195.46,1400,1195.61,0.800,1195.61,1800,1195.75,12.2,1195.89,27.5,1195.89,93.0,1194.95,7.0,1195.08,4.0,1195.21,ON,1195.34,31.0,1195.34,32.0,
,1196.57,0.0,1196.57,1400,1196.71,0.800,1196.71,1800,1196.84,12.0,1196.96,27.5,1196.96,93.0,1196.02,7.0,1196.17,5.0,1196.31,ON,1196.45,31.0,1196.45,32.0,
,1197.60,0.0,1197.60,1400,1197.74,0.780,1197.74,1800,1197.87,11.8,1197.99,27.5,1197.99,93.0,1197.08,7.0,1197.22,5.0,1197.35,ON,1197.48,31.0,1197.48,32.0,
,1198.65,0.0,1198.65,1400,1198.79,0.780,1198.79,1800,1198.91,12.2,1199.04,28.0,1199.04,93.0,1198.11,7.0,1198.26,4.0,1198.38,ON,1198.51,31.0,1198.51,32.0,
,1199.73,0.0,1199.73,1400,1199.88,0.770,1199.88,1600,1200.01,12.2,1200.15,28.0,1200.15,93.0,1199.17,7.0,1199.31,5.0,1199.45,ON,1199.59,31.0,1199.59,32.0,
,1200.82,0.0,1200.82,1400,1200.96,0.800,1200.96,1800,1201.09,12.0,1201.20,28.0,1201.20,93.0,1200.28,7.0,1200.42,5.0,1200.56,ON,1200.69,31.0,1200.69,32.0,
,1201.82,0.0,1201.82,1400,1201.94,0.780,1201.94,1800,1202.07,12.0,1202.20,27.5,1202.20,93.0,1201.32,7.0,1201.43,5.0,1201.56,ON,1201.69,31.0,1201.69,32.0,
,1202.85,0.0,1202.85,1300,1202.96,0.780,1202.96,1600,1203.10,12.2,1203.23,28.0,1203.23,93.0,1202.32,7.0,1202.45,5.0,1202.60,ON,1202.72,31.0,1202.72,32.0,
,1203.88,0.0,1203.88,1300,1203.99,0.800,1203.99,1600,1204.13,12.0,1204.26,28.0,1204.26,93.0,1203.35,7.0,1203.47,5.0,1203.62,ON,1203.75,31.0,1203.75,32.0,
,1204.90,0.0,1204.90,1300,1205.02,0.770,1205.02,1600,1205.17,12.0,1205.31,28.0,1205.31,93.0,1204.37,7.0,1204.50,5.0,1204.65,ON,1204.77,31.0,1204.77,32.0,
,1205.98,0.0,1205.98,1300,1206.12,0.750,1206.12,1600,1206.27,12.0,1206.40,27.5,1206.40,93.0,1205.44,7.0,1205.56,5.0,1205.71,ON,1205.84,31.0,1205.84,32.0,
,1207.06,0.0,1207.06,1200,1207.18,0.750,1207.18,1500,1207.35,12.2,1207.47,28.0,1207.47,93.0,1206.54,7.0,1206.65,5.0,1206.80,ON,1206.93,31.0,1206.93,32.0,
,1208.15,0.0,1208.15,1200,1208.29,0.770,1208.29,1500,1208.45,12.0,1208.58,28.0,1208.58,93.0,1207.60,7.0,1207.72,5.0,1207.88,ON,1208.01,31.0,1208.01,32.0,
,1209.24,0.0,1209.24,1500,1209.38,0.800,1209.38,1900,1209.52,12.2,1209.66,28.0,1209.66,93.0,1208.70,7.0,1208.82,5.0,1208.97,ON,1209.10,31.0,1209.10,32.0,
,1210.32,0.0,1210.32,1500,1210.47,0.780,1210.47,1900,1210.61,13.2,1210.74,27.5,1210.74,93.0,1209.78,7.0,1209.90,5.0,1210.05,ON,1210.19,31.0,1210.19,32.0,
,1211.41,0.0,1211.41,1500,1211.53,0.800,1211.53,1900,1211.68,12.0,1211.82,28.0,1211.82,93.0,1210.85,7.0,1210.98,5.0,1211.13,ON,1211.27,31.0,1211.27,32.0,
,1212.49,0.0,1212.49,1400,1212.63,0.800,1212.63,1800,1212.78,12.2,1212.91,27.5,1212.91,93.0,1211.95,7.0,1212.07,5.0,1212.22,ON,1212.35,31.0,1212.35,32.0,
,1213.56,0.0,1213.56,1500,1213.69,0.770,1213.69,1800,1213.83,12.4,1213.95,27.5,1213.95,93.0,1213.05,7.0,1213.16,5.0,1213.31,ON,1213.44,31.0,1213.44,32.0,
,1214.63,0.0,1214.63,1400,1214.77,0.750,1214.77,1800,1214.92,12.2,1215.05,27.5,1215.05,93.0,1214.07,7.0,1214.19,5.0,1214.35,ON,1214.49,31.0,1214.49,32.0,
,1215.69,0.0,1215.69,1400,1215.82,0.770,1215.82,1800,1215.97,13.0,1216.11,27.5,1216.11,93.0,1215.18,7.0,1215.30,5.0,1215.44,ON,1215.57,31.0,1215.57,32.0,
,1216.75,0.0,1216.75,1400,1216.89,0.770,1216.89,1800,1217.04,12.0,1217.19,27.5,1217.19,93.0,1216.24,7.0,1216.35,5.0,1216.50,ON,1216.63,31.0,1216.63,32.0,
,1217.85,0.0,1217.85,1400,1218.00,0.750,1218.00,1800,1218.14,13.2,1218.27,27.5,1218.27,93.0,1217.31,7.0,1217.44,5.0,1217.58,ON,1217.71,31.0,1217.71,32.0,
,1218.91,0.0,1218.91,1400,1219.05,0.750,1219.05,1800,1219.19,12.2,1219.31,27.5,1219.31,93.0,1218.38,7.0,1218.52,5.0,1218.66,ON,1218.78,31.0,1218.78,32.0,
,1219.97,0.0,1219.97,1400,1220.09,0.770,1220.09,1800,1220.24,12.0,1220.38,27.5,1220.38,93.0,1219.43,7.0,1219.55,5.0,1219.71,ON,1219.84,31.0,1219.84,32.0,
,1221.05,0.0,1221.05,1400,1221.19,0.770,1221.19,1800,1221.34,13.0,1221.47,27.5,1221.47,93.0,1220.51,7.0,1220.63,5.0,1220.78,ON,1220.91,31.0,1220.91,32.0,
,1222.15,0.0,1222.15,1400,1222.26,0.750,1222.26,1800,1222.41,11.6,1222.55,27.5,1222.55,93.0,1221.61,7.0,1221.72,5.0,1221.88,ON,1222.01,31.0,1222.01,32.0,
,1223.22,0.0,1223.22,1400,1223.36,0.750,1223.36,1600,1223.51,12.0,1223.64,27.5,1223.64,93.0,1222.68,7.0,1222.80,5.0,1222.96,ON,1223.09,31.0,1223.09,32.0,
,1224.28,0.0,1224.28,1300,1224.42,0.770,1224.42,1600,1224.56,12.0,1224.68,27.5,1224.68,93.0,1223.75,7.0,1223.88,5.0,1224.03,ON,1224.15,31.0,1224.15,32.0,
,1225.34,0.0,1225.34,1300,1225.46,0.810,1225.46,1600,1225.61,11.4,1225.75,27.5,1225.75,92.0,1224.80,7.0,1224.92,5.0,1225.08,ON,1225.21,31.0,1225.21,32.0,
,1226.42,0.0,1226.42,1300,1226.54,0.790,1226.54,1600,1226.68,12.0,1226.81,27.5,1226.81,92.0,1225.88,7.0,1226.00,5.0,1226.15,ON,1226.28,31.0,1226.28,32.0,
,1227.46,0.0,1227.46,1200,1227.59,0.780,1227.59,1500,1227.73,12.8,1227.85,27.5,1227.85,92.0,1226.94,7.0,1227.06,5.0,1227.21,ON,1227.34,31.0,1227.34,32.0,
,1228.51,0.0,1228.51,1200,1228.63,0.810,1228.63,1500,1228.77,12.0,1228.90,27.5,1228.90,92.0,1227.97,7.0,1228.09,5.0,1228.23,ON,1228.37,31.0,1228.37,32.0,
,1229.53,0.0,1229.53,1100,1229.66,0.810,1229.66,1400,1229.80,11.8,1229.95,27.5,1229.95,92.0,1229.01,7.0,1229.14,5.0,1229.28,ON,1229.41,31.0,1229.41,32.0,
,1230.61,0.0,1230.61,1500,1230.75,0.810,1230.75,1900,1230.90,12.0,1231.03,27.5,1231.03,92.0,1230.07,7.0,1230.20,5.0,1230.35,ON,1230.48,31.0,1230.48,32.0,
,1231.68,0.0,1231.68,1600,1231.81,0.810,1231.81,2000,1231.93,13.2,1232.08,27.5,1232.08,92.0,1231.14,7.0,1231.25,5.0,1231.39,ON,1231.55,31.0,1231.55,32.0,
,1232.75,0.0,1232.75,1700,1232.89,0.810,1232.89,2200,1233.03,12.2,1233.18,27.5,1233.18,92.0,1232.21,7.0,1232.33,5.0,1232.46,ON,1232.61,31.0,1232.61,32.0,
,1233.85,0.0,1233.85,1700,1233.98,0.790,1233.98,2200,1234.12,13.4,1234.26,27.5,1234.26,92.0,1233.31,7.0,1233.42,5.0,1233.56,ON,1233.71,31.0,1233.71,32.0,
,1234.92,0.0,1234.92,1400,1235.06,0.810,1235.06,1600,1235.20,11.8,1235.35,27.5,1235.35,91.0,1234.39,8.0,1234.51,5.0,1234.64,ON,1234.79,31.0,1234.79,32.0,
,1236.01,0.0,1236.01,1300,1236.13,0.790,1236.13,1600,1236.26,12.0,1236.40,27.5,1236.40,91.0,1235.47,7.0,1235.59,5.0,1235.73,ON,1235.88,31.0,1235.88,32.0,
,1237.04,0.0,1237.04,1300,1237.16,0.790,1237.16,1600,1237.29,12.0,1237.43,27.0,1237.43,91.0,1236.51,7.0,1236.64,5.0,1236.77,ON,1236.91,31.0,1236.91,32.0,
,1238.07,0.0,1238.07,1200,1238.21,0.810,1238.21,1500,1238.33,12.8,1238.48,27.0,1238.48,91.0,1237.54,7.0,1237.67,5.0,1237.80,ON,1237.94,31.0,1237.94,32.0,
,1239.11,0.0,1239.11,1200,1239.24,0.810,1239.24,1500,1239.36,12.0,1239.51,27.0,1239.51,91.0,1238.60,7.0,1238.72,5.0,1238.85,ON,1238.99,31.0,1238.99,32.0,
,1240.18,0.0,1240.18,1200,1240.32,0.780,1240.32,1500,1240.46,12.0,1240.61,27.0,1240.61,91.0,1239.64,7.0,1239.76,5.0,1239.90,ON,1240.05,31.0,1240.05,32.0,
,1241.25,0.0,1241.25,1200,1241.38,0.780,1241.38,1500,1241.50,12.0,1241.64,27.0,1241.64,91.0,1240.73,7.0,1240.86,5.0,1240.99,ON,1241.13,31.0,1241.13,32.0,
,1242.28,0.0,1242.28,1200,1242.41,0.800,1242.41,1500,1242.55,12.0,1242.67,27.0,1242.67,91.0,1241.76,8.0,1241.88,5.0,1241.99,ON,1242.13,31.0,1242.13,32.0,
,1243.28,0.0,1243.28,1200,1243.42,0.800,1243.42,1500,1243.55,12.0,1243.68,27.0,1243.68,91.0,1242.79,8.0,1242.91,5.0,1243.02,ON,1243.15,31.0,1243.15,32.0,
,1244.32,0.0,1244.32,1200,1244.46,0.820,1244.46,1500,1244.58,12.0,1244.71,27.0,1244.71,90.0,1243.80,7.0,1243.94,5.0,1244.07,ON,1244.20,31.0,1244.20,32.0,
,1245.37,0.0,1245.37,1200,1245.52,0.760,1245.52,1500,1245.65,12.0,1245.80,27.0,1245.80,90.0,1244.82,8.0,1244.97,5.0,1245.11,ON,1245.24,31.0,1245.24,32.0,
,1246.46,0.0,1246.46,1200,1246.61,0.800,1246.61,1400,1246.74,12.0,1246.86,27.0,1246.86,90.0,1245.92,7.0,1246.07,5.0,1246.19,ON,1246.33,31.0,1246.33,32.0,
,1247.52,0.0,1247.52,1200,1247.66,0.780,1247.66,1600,1247.78,12.0,1247.91,27.0,1247.91,90.0,1246.98,8.0,1247.13,5.0,1247.25,ON,1247.38,31.0,1247.38,32.0,
,1248.55,0.0,1248.55,1500,1248.70,0.780,1248.70,1900,1248.83,11.8,1248.96,27.0,1248.96,90.0,1248.02,7.0,1248.17,5.0,1248.30,ON,1248.42,31.0,1248.42,32.0,
,1249.63,0.0,1249.63,1400,1249.78,0.750,1249.78,1800,1249.91,13.0,1250.03,27.0,1250.03,90.0,1249.09,7.0,1249.23,5.0,1249.36,ON,1249.49,31.0,1249.49,32.0,
,1250.69,0.0,1250.69,1400,1250.85,0.710,1250.85,1800,1250.98,12.2,1251.11,27.0,1251.11,90.0,1250.15,8.0,1250.29,5.0,1250.42,ON,1250.55,31.0,1250.55,32.0,
,1251.77,0.0,1251.77,1400,1251.92,0.750,1251.92,1800,1252.06,12.2,1252.19,27.0,1252.19,90.0,1251.24,7.0,1251.37,5.0,1251.50,ON,1251.63,31.0,1251.63,32.0,
,1252.84,0.0,1252.84,1500,1252.98,0.770,1252.98,1900,1253.11,13.2,1253.25,27.0,1253.25,90.0,1252.32,8.0,1252.46,5.0,1252.59,ON,1252.72,31.0,1252.72,32.0,
,1253.88,0.0,1253.88,1600,1254.03,0.730,1254.03,2000,1254.15,12.4,1254.28,27.0,1254.28,90.0,1253.36,7.0,1253.50,5.0,1253.62,ON,1253.75,31.0,1253.75,32.0,
,1254.92,0.0,1254.92,1700,1255.08,0.760,1255.08,2200,1255.22,12.4,1255.35,27.0,1255.35,90.0,1254.39,8.0,1254.53,5.0,1254.66,ON,1254.79,31.0,1254.79,32.0,
,1256.03,0.0,1256.03,1800,1256.18,0.730,1256.18,2300,1256.30,13.4,1256.42,27.0,1256.42,90.0,1255.49,7.0,1255.63,5.0,1255.76,ON,1255.89,31.0,1255.89,32.0,
,1257.08,0.0,1257.08,1800,1257.22,0.770,1257.22,2300,1257.34,12.6,1257.48,27.0,1257.48,90.0,1256.55,7.0,1256.69,5.0,1256.82,ON,1256.95,31.0,1256.95,32.0,
,1258.11,0.0,1258.11,1400,1258.25,0.730,1258.25,1800,1258.37,12.4,1258.50,27.0,1258.50,90.0,1257.59,7.0,1257.74,5.0,1257.86,ON,1257.98,31.0,1257.98,32.0,
,1259.16,0.0,1259.16,1400,1259.31,0.730,1259.31,1800,1259.44,12.2,1259.59,27.0,1259.59,90.0,1258.61,7.0,1258.76,5.0,1258.89,ON,1259.02,31.0,1259.02,32.0,
,1260.25,0.0,1260.25,1400,1260.41,0.730,1260.41,1800,1260.54,12.4,1260.67,27.0,1260.67,90.0,1259.71,7.0,1259.86,5.0,1260.00,ON,1260.12,31.0,1260.12,32.0,
,1261.29,0.0,1261.29,1500,1261.44,0.730,1261.44,1900,1261.57,12.4,1261.70,27.0,1261.70,90.0,1260.78,7.0,1260.91,5.0,1261.04,ON,1261.17,31.0,1261.17,32.0,
,1262.32,0.0,1262.32,1500,1262.48,0.710,1262.48,1900,1262.61,12.2,1262.75,27.0,1262.75,90.0,1261.81,7.0,1261.94,5.0,1262.07,ON,1262.20,31.0,1262.20,32.0,
,1263.42,0.0,1263.42,1500,1263.57,0.730,1263.57,1900,1263.70,13.2,1263.82,27.0,1263.82,90.0,1262.88,7.0,1263.02,5.0,1263.15,ON,1263.28,31.0,1263.28,32.0,
,1264.46,0.0,1264.46,1500,1264.60,0.710,1264.60,2000,1264.73,12.2,1264.85,27.0,1264.85,90.0,1263.94,7.0,1264.08,5.0,1264.21,ON,1264.34,31.0,1264.34,32.0,
,1265.49,0.0,1265.49,1600,1265.63,0.740,1265.63,2000,1265.76,12.2,1265.88,27.0,1265.88,90.0,1264.97,7.0,1265.11,5.0,1265.24,ON,1265.37,31.0,1265.37,32.0,
,1266.52,0.0,1266.52,1600,1266.66,0.770,1266.66,1900,1266.79,11.8,1266.91,27.0,1266.91,90.0,1266.00,7.0,1266.14,5.0,1266.27,ON,1266.40,31.0,1266.40,32.0,
,1267.55,0.0,1267.55,1500,1267.70,0.710,1267.70,1900,1267.84,12.0,1267.98,27.0,1267.98,90.0,1267.03,7.0,1267.17,5.0,1267.30,ON,1267.43,31.0,1267.43,32.0,
,1268.65,0.0,1268.65,1500,1268.80,0.710,1268.80,1900,1268.93,12.2,1269.05,27.0,1269.05,90.0,1268.11,7.0,1268.25,5.0,1268.38,ON,1268.51,31.0,1268.51,32.0,
,1269.71,0.0,1269.71,1500,1269.85,0.730,1269.85,1900,1269.99,12.0,1270.12,27.0,1270.12,90.0,1269.18,7.0,1269.30,5.0,1269.44,ON,1269.57,31.0,1269.57,32.0,
,1270.78,0.0,1270.78,1400,1270.93,0.710,1270.93,1800,1271.06,12.0,1271.21,27.0,1271.21,90.0,1270.25,7.0,1270.39,5.0,1270.52,ON,1270.64,31.0,1270.64,32.0,
,1271.85,0.0,1271.85,1200,1271.99,0.740,1271.99,1500,1272.12,12.0,1272.24,27.0,1272.24,90.0,1271.34,7.0,1271.47,5.0,1271.60,ON,1271.73,31.0,1271.73,32.0,
,1272.88,0.0,1272.88,1100,1273.02,0.710,1273.02,1400,1273.15,11.8,1273.27,27.0,1273.27,90.0,1272.37,7.0,1272.50,5.0,1272.63,ON,1272.76,31.0,1272.76,32.0,
,1273.91,0.0,1273.91,1300,1274.05,0.710,1274.05,1500,1274.18,11.4,1274.32,27.0,1274.32,90.0,1273.39,7.0,1273.53,5.0,1273.66,ON,1273.79,31.0,1273.79,32.0,
,1274.94,0.0,1274.94,1100,1275.09,0.770,1275.09,1400,1275.23,11.8,1275.37,27.0,1275.37,90.0,1274.43,7.0,1274.56,5.0,1274.69,ON,1274.82,31.0,1274.82,32.0,
,1276.04,0.0,1276.04,900,1276.19,0.740,1276.19,1300,1276.32,11.6,1276.46,27.0,1276.46,90.0,1275.50,7.0,1275.64,5.0,1275.77,ON,1275.90,31.0,1275.90,32.0,
,1277.11,0.0,1277.11,900,1277.26,0.740,1277.26,1000,1277.39,11.6,1277.53,27.0,1277.53,90.0,1276.59,7.0,1276.74,5.0,1276.86,ON,1276.99,31.0,1276.99,32.0,
,1278.21,0.0,1278.21,800,1278.36,0.770,1278.36,1000,1278.49,12.2,1278.63,27.0,1278.63,90.0,1277.65,7.0,1277.80,5.0,1277.93,ON,1278.07,31.0,1278.07,32.0,
,1279.28,0.0,1279.28,800,1279.43,0.790,1279.43,1000,1279.56,11.6,1279.69,27.0,1279.69,90.0,1278.76,7.0,1278.90,5.0,1279.03,ON,1279.16,31.0,1279.16,32.0,
,1280.33,0.0,1280.33,800,1280.47,0.790,1280.47,1000,1280.60,11.8,1280.74,27.0,1280.74,90.0,1279.80,7.0,1279.93,5.0,1280.06,ON,1280.19,31.0,1280.19,32.0,
,1281.41,0.0,1281.41,1300,1281.56,0.790,1281.56,1600,1281.70,13.0,1281.83,27.5,1281.83,90.0,1280.88,7.0,1281.01,5.0,1281.14,ON,1281.27,31.0,1281.27,32.0,
,1282.47,0.0,1282.47,1500,1282.63,0.790,1282.63,1900,1282.77,12.6,1282.91,27.5,1282.91,90.0,1281.96,7.0,1282.10,5.0,1282.23,ON,1282.36,31.0,1282.36,32.0,
,1283.57,0.0,1283.57,1900,1283.72,0.810,1283.72,2400,1283.85,13.0,1284.00,27.5,1284.00,90.0,1283.04,7.0,1283.18,5.0,1283.31,ON,1283.43,31.0,1283.43,32.0,
,1284.64,0.0,1284.64,1300,1284.80,0.780,1284.80,1800,1284.92,12.8,1285.06,28.0,1285.06,90.0,1284.12,8.0,1284.27,5.0,1284.39,ON,1284.53,31.0,1284.53,32.0,
,1285.74,0.0,1285.74,1600,1285.89,0.730,1285.89,2000,1286.02,13.0,1286.14,28.0,1286.14,90.0,1285.19,8.0,1285.33,5.0,1285.46,ON,1285.60,31.0,1285.60,32.0,
,1286.80,0.0,1286.80,1900,1286.94,0.780,1286.94,2400,1287.06,13.2,1287.19,28.0,1287.19,90.0,1286.26,7.0,1286.40,5.0,1286.53,ON,1286.66,31.0,1286.66,32.0,
,1287.83,0.0,1287.83,1800,1287.99,0.790,1287.99,2200,1288.13,13.0,1288.27,28.0,1288.27,90.0,1287.30,7.0,1287.45,5.0,1287.58,ON,1287.70,31.0,1287.70,32.0,
,1288.95,0.0,1288.95,1400,1289.09,0.740,1289.09,1800,1289.23,13.6,1289.36,28.0,1289.36,90.0,1288.40,7.0,1288.54,5.0,1288.68,ON,1288.80,31.0,1288.80,32.0,
,1290.01,0.0,1290.01,1500,1290.16,0.820,1290.16,1900,1290.29,12.8,1290.42,27.5,1290.42,90.0,1289.48,8.0,1289.61,5.0,1289.74,ON,1289.87,31.0,1289.87,32.0,
,1291.05,0.0,1291.05,1600,1291.20,0.800,1291.20,2000,1291.33,12.8,1291.47,27.5,1291.47,90.0,1290.53,8.0,1290.66,5.0,1290.79,ON,1290.92,31.0,1290.92,32.0,
,1292.14,0.0,1292.14,1700,1292.28,0.770,1292.28,2200,1292.40,12.8,1292.53,27.5,1292.53,90.0,1291.60,7.0,1291.74,5.0,1291.87,ON,1292.00,31.0,1292.00,32.0,
,1293.18,0.0,1293.18,1700,1293.33,0.740,1293.33,2200,1293.46,13.8,1293.59,27.5,1293.59,90.0,1292.66,7.0,1292.80,5.0,1292.93,ON,1293.06,31.0,1293.06,32.0,
,1294.21,0.0,1294.21,1800,1294.34,0.770,1294.34,2300,1294.48,13.0,1294.60,27.5,1294.60,90.0,1293.70,7.0,1293.84,5.0,1293.96,ON,1294.09,31.0,1294.09,32.0,
,1295.23,0.0,1295.23,1800,1295.35,0.770,1295.35,2300,1295.48,13.0,1295.64,27.5,1295.64,90.0,1294.72,7.0,1294.84,5.0,1294.96,ON,1295.10,31.0,1295.10,32.0,
,1296.27,0.0,1296.27,1800,1296.40,0.770,1296.40,2300,1296.52,12.6,1296.64,27.5,1296.64,90.0,1295.76,7.0,1295.87,5.0,1295.99,ON,1296.12,31.0,1296.12,32.0,
,1297.31,0.0,1297.31,1800,1297.44,0.770,1297.44,2300,1297.59,14.0,1297.72,27.5,1297.72,90.0,1296.77,7.0,1296.90,5.0,1297.02,ON,1297.15,31.0,1297.15,32.0,
,1298.40,0.0,1298.40,1800,1298.53,0.740,1298.53,2300,1298.67,12.4,1298.79,27.5,1298.79,90.0,1297.86,7.0,1297.99,5.0,1298.12,ON,1298.25,31.0,1298.25,32.0,
,1299.45,0.0,1299.45,1800,1299.57,0.760,1299.57,2300,1299.70,12.8,1299.82,27.5,1299.82,90.0,1298.93,7.0,1299.06,5.0,1299.18,ON,1299.31,31.0,1299.31,32.0,
,1300.48,0.0,1300.48,1800,1300.60,0.730,1300.60,2300,1300.73,12.8,1300.85,27.5,1300.85,90.0,1299.96,7.0,1300.08,5.0,1300.21,ON,1300.34,31.0,1300.34,32.0,
,1301.51,0.0,1301.51,1800,1301.63,0.730,1301.63,2300,1301.76,12.6,1301.88,27.5,1301.88,90.0,1300.99,7.0,1301.11,5.0,1301.24,ON,1301.37,31.0,1301.37,32.0,
,1302.54,0.0,1302.54,1800,1302.66,0.760,1302.66,2300,1302.79,12.8,1302.92,27.5,1302.92,90.0,1302.02,7.0,1302.14,5.0,1302.27,ON,1302.40,31.0,1302.40,32.0,
,1303.60,0.0,1303.60,1800,1303.73,0.740,1303.73,2300,1303.87,12.8,1303.99,27.5,1303.99,90.0,1303.06,7.0,1303.19,5.0,1303.32,ON,1303.45,31.0,1303.45,32.0,
,1304.65,0.0,1304.65,1800,1304.79,0.780,1304.79,2300,1304.91,13.8,1305.04,27.0,1305.04,90.0,1304.12,7.0,1304.25,5.0,1304.38,ON,1304.51,31.0,1304.51,32.0,
,1305.71,0.0,1305.71,1800,1305.84,0.710,1305.84,2300,1305.96,12.4,1306.08,27.0,1306.08,90.0,1305.19,7.0,1305.32,5.0,1305.44,ON,1305.57,31.0,1305.57,32.0,
,1306.74,0.0,1306.74,1900,1306.86,0.720,1306.86,2400,1306.99,12.4,1307.13,27.0,1307.13,90.0,1306.22,6.0,1306.34,4.0,1306.47,ON,1306.60,31.0,1306.60,32.0,
,1307.79,0.0,1307.79,1900,1307.93,0.695,1307.93,2400,1308.07,13.8,1308.22,27.0,1308.22,90.0,1307.26,7.0,1307.40,5.0,1307.52,ON,1307.64,31.0,1307.64,32.0,
,1308.89,0.0,1308.89,1900,1309.02,0.695,1309.02,2400,1309.15,12.8,1309.28,27.0,1309.28,90.0,1308.35,7.0,1308.46,5.0,1308.60,ON,1308.74,31.0,1308.74,32.0,
,1309.96,0.0,1309.96,1500,1310.09,0.730,1310.09,1800,1310.23,12.6,1310.37,27.0,1310.37,90.0,1309.41,7.0,1309.54,4.0,1309.68,ON,1309.81,31.0,1309.81,32.0,
,1311.04,0.0,1311.04,1200,1311.16,0.740,1311.16,1500,1311.30,12.2,1311.44,27.0,1311.44,90.0,1310.52,6.0,1310.65,4.0,1310.78,ON,1310.90,32.0,1310.90,32.0,
,1312.13,0.0,1312.13,1100,1312.26,0.740,1312.26,1400,1312.40,12.2,1312.54,27.0,1312.54,90.0,1311.60,7.0,1311.72,4.0,1311.84,ON,1311.97,31.0,1311.97,32.0,
,1313.21,0.0,1313.21,1100,1313.33,0.740,1313.33,1500,1313.46,12.0,1313.58,27.0,1313.58,90.0,1312.68,7.0,1312.81,4.0,1312.94,ON,1313.07,31.0,1313.07,32.0,
,1314.24,0.0,1314.24,1100,1314.36,0.730,1314.36,1500,1314.49,13.0,1314.63,27.0,1314.63,90.0,1313.71,6.0,1313.84,4.0,1313.97,ON,1314.10,31.0,1314.10,32.0,
,1315.29,0.0,1315.29,1300,1315.42,0.730,1315.42,1600,1315.55,11.8,1315.67,27.0,1315.67,90.0,1314.76,7.0,1314.88,4.0,1315.00,ON,1315.13,31.0,1315.13,32.0,
,1316.33,0.0,1316.33,1100,1316.45,0.710,1316.45,1400,1316.58,12.0,1316.70,27.0,1316.70,90.0,1315.81,7.0,1315.93,4.0,1316.06,ON,1316.19,31.0,1316.19,32.0,
,1317.39,0.0,1317.39,1000,1317.52,0.760,1317.52,1300,1317.64,12.0,1317.77,27.0,1317.77,90.0,1316.84,7.0,1316.96,4.0,1317.10,ON,1317.24,31.0,1317.24,32.0,
,1318.45,0.0,1318.45,1400,1318.59,0.695,1318.59,1900,1318.72,12.0,1318.85,27.0,1318.85,90.0,1317.91,7.0,1318.04,4.0,1318.17,ON,1318.30,31.0,1318.30,32.0,
,1319.50,0.0,1319.50,1400,1319.62,0.695,1319.62,1800,1319.75,12.4,1319.88,27.0,1319.88,90.0,1318.98,7.0,1319.11,4.0,1319.23,ON,1319.36,31.0,1319.36,32.0,
,1320.53,0.0,1320.53,1500,1320.66,0.750,1320.66,1900,1320.78,12.4,1320.90,27.0,1320.90,90.0,1320.01,7.0,1320.14,4.0,1320.26,ON,1320.39,31.0,1320.39,32.0,
,1321.56,0.0,1321.56,1600,1321.68,0.695,1321.68,2200,1321.81,12.0,1321.93,27.0,1321.93,90.0,1321.04,7.0,1321.16,4.0,1321.29,ON,1321.42,31.0,1321.42,32.0,
,1322.58,0.0,1322.58,1800,1322.71,0.760,1322.71,2300,1322.85,12.6,1323.00,27.0,1323.00,90.0,1322.07,7.0,1322.19,4.0,1322.32,ON,1322.45,31.0,1322.45,32.0,
,1323.69,0.0,1323.69,1900,1323.81,0.770,1323.81,2400,1323.94,12.8,1324.07,27.0,1324.07,90.0,1323.14,7.0,1323.28,4.0,1323.42,ON,1323.54,31.0,1323.54,32.0,
,1324.72,0.0,1324.72,1300,1324.84,0.730,1324.84,1500,1324.97,12.4,1325.10,27.0,1325.10,90.0,1324.21,6.0,1324.32,5.0,1324.45,ON,1324.58,31.0,1324.58,32.0,
,1325.77,0.0,1325.77,1300,1325.91,0.710,1325.91,1600,1326.05,12.2,1326.19,27.0,1326.19,90.0,1325.25,7.0,1325.37,4.0,1325.50,ON,1325.62,31.0,1325.62,32.0,
,1326.86,0.0,1326.86,1300,1327.00,0.730,1327.00,1600,1327.15,12.0,1327.26,27.0,1327.26,91.0,1326.33,6.0,1326.46,4.0,1326.59,ON,1326.72,31.0,1326.72,32.0,
,1327.95,0.0,1327.95,1300,1328.08,0.750,1328.08,1600,1328.23,12.2,1328.36,27.0,1328.36,91.0,1327.40,7.0,1327.52,5.0,1327.65,ON,1327.78,31.0,1327.78,32.0,
,1329.04,0.0,1329.04,1300,1329.17,0.700,1329.17,1600,1329.29,12.2,1329.42,27.0,1329.42,91.0,1328.50,7.0,1328.63,5.0,1328.76,ON,1328.89,31.0,1328.89,32.0,
,1330.08,0.0,1330.08,1400,1330.21,0.750,1330.21,1800,1330.34,12.0,1330.46,27.0,1330.46,91.0,1329.55,7.0,1329.67,4.0,1329.81,ON,1329.93,31.0,1329.93,32.0,
,1331.12,0.0,1331.12,1300,1331.24,0.770,1331.24,1500,1331.37,12.0,1331.49,27.0,1331.49,91.0,1330.60,6.0,1330.72,4.0,1330.85,ON,1330.98,31.0,1330.98,32.0,
,1332.15,0.0,1332.15,1200,1332.27,0.720,1332.27,1500,1332.40,12.0,1332.52,27.0,1332.52,91.0,1331.63,7.0,1331.75,4.0,1331.88,ON,1332.01,31.0,1332.01,32.0,
,1333.21,0.0,1333.21,1100,1333.34,0.720,1333.34,1300,1333.48,12.0,1333.62,27.0,1333.62,91.0,1332.66,7.0,1332.78,5.0,1332.92,ON,1333.06,31.0,1333.06,32.0,
,1334.26,0.0,1334.26,800,1334.40,0.720,1334.40,1000,1334.54,11.2,1334.66,27.0,1334.66,91.0,1333.76,7.0,1333.87,4.0,1334.01,ON,1334.13,31.0,1334.13,32.0,
,1335.30,0.0,1335.30,800,1335.44,0.750,1335.44,1000,1335.57,11.8,1335.69,27.0,1335.69,91.0,1334.78,7.0,1334.92,4.0,1335.05,ON,1335.18,31.0,1335.18,32.0,
,1336.33,0.0,1336.33,800,1336.46,0.695,1336.46,1000,1336.59,12.4,1336.71,27.0,1336.71,91.0,1335.81,7.0,1335.95,5.0,1336.08,ON,1336.21,31.0,1336.21,32.0,
,1337.35,0.0,1337.35,1200,1337.50,0.750,1337.50,1600,1337.64,12.0,1337.78,27.0,1337.78,91.0,1336.84,7.0,1336.98,5.0,1337.11,ON,1337.24,31.0,1337.24,32.0,
,1338.45,0.0,1338.45,1600,1338.59,0.750,1338.59,2200,1338.71,13.4,1338.85,27.0,1338.85,91.0,1337.92,7.0,1338.05,4.0,1338.19,ON,1338.31,31.0,1338.31,32.0,
,1339.49,0.0,1339.49,1500,1339.64,0.695,1339.64,1800,1339.76,12.6,1339.88,27.0,1339.88,91.0,1338.97,7.0,1339.11,4.0,1339.24,ON,1339.38,31.0,1339.38,32.0,
,1340.52,0.0,1340.52,1500,1340.67,0.750,1340.67,1900,1340.80,12.6,1340.94,27.0,1340.94,91.0,1340.00,7.0,1340.14,5.0,1340.27,ON,1340.41,31.0,1340.41,32.0,
,1341.55,0.0,1341.55,1800,1341.70,0.740,1341.70,2300,1341.83,12.8,1341.97,27.0,1341.97,91.0,1341.04,7.0,1341.17,5.0,1341.30,ON,1341.43,31.0,1341.43,32.0,
,1342.58,0.0,1342.58,2000,1342.72,0.750,1342.72,2600,1342.85,13.0,1342.97,27.0,1342.97,91.0,1342.07,7.0,1342.20,5.0,1342.33,ON,1342.46,31.0,1342.46,32.0,
,1343.61,0.0,1343.61,1500,1343.76,0.750,1343.76,1900,1343.90,12.6,1344.04,27.0,1344.04,91.0,1343.09,7.0,1343.23,5.0,1343.36,ON,1343.49,31.0,1343.49,32.0,
,1344.71,0.0,1344.71,1400,1344.87,0.750,1344.87,1800,1345.00,12.6,1345.13,27.0,1345.13,91.0,1344.17,7.0,1344.32,5.0,1344.44,ON,1344.57,31.0,1344.57,32.0,
,1345.77,0.0,1345.77,1400,1345.92,0.770,1345.92,1800,1346.05,12.4,1346.18,27.0,1346.18,91.0,1345.24,7.0,1345.39,5.0,1345.52,ON,1345.64,31.0,1345.64,32.0,
,1346.85,0.0,1346.85,1200,1347.00,0.750,1347.00,1500,1347.13,12.4,1347.27,27.0,1347.27,91.0,1346.31,7.0,1346.45,5.0,1346.58,ON,1346.71,31.0,1346.71,32.0,
,1347.91,0.0,1347.91,1000,1348.06,0.695,1348.06,1300,1348.19,11.8,1348.33,27.0,1348.33,91.0,1347.38,7.0,1347.52,5.0,1347.64,ON,1347.77,31.0,1347.77,32.0,
,1348.95,0.0,1348.95,800,1349.10,0.690,1349.10,1000,1349.23,11.8,1349.36,27.0,1349.36,91.0,1348.44,7.0,1348.57,5.0,1348.70,ON,1348.83,31.0,1348.83,32.0,
,1349.98,0.0,1349.98,800,1350.12,0.690,1350.12,1000,1350.26,11.8,1350.40,27.0,1350.40,91.0,1349.47,7.0,1349.60,4.0,1349.73,ON,1349.86,31.0,1349.86,32.0,
,1351.08,0.0,1351.08,1000,1351.22,0.690,1351.22,1300,1351.36,12.6,1351.49,27.0,1351.49,91.0,1350.54,7.0,1350.68,4.0,1350.81,ON,1350.94,31.0,1350.94,32.0,
,1352.14,0.0,1352.14,1100,1352.29,0.740,1352.29,1400,1352.42,12.0,1352.55,27.0,1352.55,91.0,1351.61,7.0,1351.74,5.0,1351.88,ON,1352.00,31.0,1352.00,32.0,
,1353.19,0.0,1353.19,1100,1353.33,0.740,1353.33,1300,1353.46,12.0,1353.60,27.0,1353.60,91.0,1352.66,7.0,1352.82,5.0,1352.94,ON,1353.06,31.0,1353.06,32.0,
,1354.27,0.0,1354.27,1100,1354.42,0.690,1354.42,1400,1354.55,12.2,1354.70,27.0,1354.70,91.0,1353.73,7.0,1353.87,5.0,1354.00,ON,1354.13,31.0,1354.13,32.0,
,1355.34,0.0,1355.34,1300,1355.49,0.760,1355.49,1600,1355.62,12.0,1355.76,27.0,1355.76,91.0,1354.82,7.0,1354.96,5.0,1355.09,ON,1355.23,31.0,1355.23,32.0,
,1356.37,0.0,1356.37,1400,1356.52,0.700,1356.52,1800,1356.66,12.6,1356.81,27.0,1356.81,91.0,1355.86,7.0,1355.99,5.0,1356.12,ON,1356.26,31.0,1356.26,32.0,
,1357.48,0.0,1357.48,1000,1357.62,0.760,1357.62,1300,1357.75,12.4,1357.87,27.0,1357.87,92.0,1356.93,7.0,1357.08,5.0,1357.22,ON,1357.36,31.0,1357.36,32.0,
,1358.51,0.0,1358.51,1000,1358.65,0.690,1358.65,1300,1358.78,12.2,1358.92,27.0,1358.92,92.0,1357.99,7.0,1358.13,5.0,1358.26,ON,1358.39,31.0,1358.39,32.0,
,1359.56,0.0,1359.56,1200,1359.70,0.760,1359.70,1500,1359.82,12.2,1359.95,27.0,1359.95,92.0,1359.03,7.0,1359.18,5.0,1359.31,ON,1359.43,31.0,1359.43,32.0,
,1360.59,0.0,1360.59,1200,1360.74,0.730,1360.74,1500,1360.87,13.0,1361.00,27.0,1361.00,92.0,1360.06,7.0,1360.21,5.0,1360.34,ON,1360.46,31.0,1360.46,32.0,
,1361.67,0.0,1361.67,800,1361.82,0.760,1361.82,1100,1361.95,12.0,1362.09,27.0,1362.09,92.0,1361.13,8.0,1361.27,5.0,1361.40,ON,1361.53,31.0,1361.53,32.0,
,1362.74,0.0,1362.74,800,1362.89,0.800,1362.89,1000,1363.02,11.4,1363.14,27.0,1363.14,92.0,1362.22,7.0,1362.36,5.0,1362.49,ON,1362.62,31.0,1362.62,32.0,
,1363.77,0.0,1363.77,900,1363.92,0.760,1363.92,1300,1364.05,12.0,1364.17,27.0,1364.17,92.0,1363.26,7.0,1363.38,5.0,1363.52,ON,1363.65,31.0,1363.65,32.0,
,1364.84,0.0,1364.84,1000,1364.98,0.760,1364.98,1300,1365.12,12.0,1365.25,27.0,1365.25,92.0,1364.29,7.0,1364.41,5.0,1364.55,ON,1364.69,31.0,1364.69,32.0,
,1365.92,0.0,1365.92,1200,1366.06,0.730,1366.06,1500,1366.18,12.2,1366.31,27.0,1366.31,92.0,1365.39,7.0,1365.54,5.0,1365.67,ON,1365.79,31.0,1365.79,32.0,
,1366.96,0.0,1366.96,1300,1367.11,0.770,1367.11,1600,1367.25,13.4,1367.39,27.0,1367.39,92.0,1366.42,8.0,1366.57,5.0,1366.70,ON,1366.82,31.0,1366.82,32.0,
,1368.06,0.0,1368.06,1400,1368.21,0.760,1368.21,1800,1368.34,12.6,1368.46,27.0,1368.46,92.0,1367.52,7.0,1367.66,5.0,1367.79,ON,1367.92,31.0,1367.92,32.0,
,1369.12,0.0,1369.12,1500,1369.26,0.760,1369.26,1900,1369.38,12.8,1369.52,27.0,1369.52,92.0,1368.58,7.0,1368.72,5.0,1368.85,ON,1368.98,31.0,1368.98,32.0,
,1370.15,0.0,1370.15,1300,1370.29,0.800,1370.29,1600,1370.42,12.4,1370.55,27.0,1370.55,92.0,1369.62,8.0,1369.77,5.0,1369.90,ON,1370.02,31.0,1370.02,32.0,
,1371.23,0.0,1371.23,900,1371.39,0.730,1371.39,1000,1371.52,12.2,1371.65,27.0,1371.65,92.0,1370.67,8.0,1370.81,5.0,1370.95,ON,1371.09,31.0,1371.09,32.0,
,1372.30,0.0,1372.30,700,1372.45,0.730,1372.45,900,1372.58,12.0,1372.71,27.0,1372.71,92.0,1371.78,7.0,1371.92,5.0,1372.05,ON,1372.18,31.0,1372.18,32.0,
,1373.33,0.0,1373.33,800,1373.48,0.760,1373.48,1000,1373.62,12.0,1373.76,27.0,1373.76,92.0,1372.82,7.0,1372.95,5.0,1373.08,ON,1373.21,31.0,1373.21,32.0,
,1374.43,0.0,1374.43,1100,1374.59,0.810,1374.59,1400,1374.72,12.2,1374.85,27.0,1374.85,92.0,1373.89,8.0,1374.03,5.0,1374.16,ON,1374.29,31.0,1374.29,32.0,
,1375.49,0.0,1375.49,1300,1375.63,0.770,1375.63,1600,1375.75,12.4,1375.88,27.0,1375.88,92.0,1374.96,8.0,1375.11,5.0,1375.24,ON,1375.36,31.0,1375.36,32.0,
,1376.52,0.0,1376.52,1300,1376.68,0.770,1376.68,1600,1376.82,12.6,1376.96,27.0,1376.96,92.0,1375.99,7.0,1376.13,5.0,1376.27,ON,1376.39,31.0,1376.39,32.0,
,1377.63,0.0,1377.63,1300,1377.78,0.810,1377.78,1600,1377.91,13.0,1378.04,27.0,1378.04,92.0,1377.08,7.0,1377.22,5.0,1377.35,ON,1377.48,31.0,1377.48,32.0,
,1378.68,0.0,1378.68,1300,1378.82,0.750,1378.82,1600,1378.94,12.4,1379.07,27.0,1379.07,92.0,1378.15,8.0,1378.29,5.0,1378.41,ON,1378.54,31.0,1378.54,32.0,
,1379.71,0.0,1379.71,1200,1379.85,0.710,1379.85,1400,1379.97,12.8,1380.10,27.5,1380.10,92.0,1379.19,7.0,1379.33,5.0,1379.46,ON,1379.58,31.0,1379.58,32.0,
,1380.74,0.0,1380.74,900,1380.88,0.710,1380.88,1100,1381.01,12.4,1381.15,27.5,1381.15,92.0,1380.22,7.0,1380.36,5.0,1380.49,ON,1380.61,31.0,1380.61,32.0,
,1381.82,0.0,1381.82,900,1381.97,0.750,1381.97,1000,1382.10,12.4,1382.24,27.5,1382.24,92.0,1381.28,7.0,1381.42,5.0,1381.55,ON,1381.68,31.0,1381.68,32.0,
,1382.89,0.0,1382.89,900,1383.03,0.780,1383.03,1100,1383.16,13.2,1383.28,27.5,1383.28,92.0,1382.37,8.0,1382.51,5.0,1382.64,ON,1382.77,31.0,1382.77,32.0,
,1383.92,0.0,1383.92,1100,1384.07,0.710,1384.07,1400,1384.20,12.0,1384.33,27.5,1384.33,92.0,1383.40,7.0,1383.54,5.0,1383.67,ON,1383.80,31.0,1383.80,32.0,
,1384.95,0.0,1384.95,800,1385.10,0.770,1385.10,1000,1385.24,12.4,1385.38,27.5,1385.38,92.0,1384.44,7.0,1384.57,5.0,1384.70,ON,1384.83,31.0,1384.83,32.0,
,1386.05,0.0,1386.05,800,1386.21,0.810,1386.21,1000,1386.34,12.2,1386.47,27.5,1386.47,92.0,1385.51,7.0,1385.65,5.0,1385.78,ON,1385.91,31.0,1385.91,32.0,
,1387.11,0.0,1387.11,800,1387.25,0.810,1387.25,1000,1387.37,11.8,1387.50,27.5,1387.50,92.0,1386.58,8.0,1386.73,5.0,1386.86,ON,1386.98,31.0,1386.98,32.0,
,1388.15,0.0,1388.15,800,1388.30,0.740,1388.30,1000,1388.44,12.0,1388.58,27.5,1388.58,92.0,1387.63,7.0,1387.77,5.0,1387.90,ON,1388.03,31.0,1388.03,32.0,
,1389.25,0.0,1389.25,800,1389.41,0.750,1389.41,1000,1389.54,12.0,1389.67,27.5,1389.67,92.0,1388.71,7.0,1388.85,5.0,1388.98,ON,1389.11,31.0,1389.11,32.0,
,1390.31,0.0,1390.31,800,1390.45,0.760,1390.45,1000,1390.57,12.0,1390.69,27.5,1390.69,92.0,1389.78,8.0,1389.91,5.0,1390.04,ON,1390.17,31.0,1390.17,32.0,
,1391.33,0.0,1391.33,800,1391.45,0.820,1391.45,1000,1391.59,12.0,1391.72,27.5,1391.72,92.0,1390.81,8.0,1390.92,5.0,1391.08,ON,1391.21,31.0,1391.21,32.0,
,1392.36,0.0,1392.36,800,1392.48,0.740,1392.48,1000,1392.63,12.2,1392.77,27.5,1392.77,92.0,1391.84,7.0,1391.96,5.0,1392.11,ON,1392.23,31.0,1392.23,32.0,
,1393.45,0.0,1393.45,800,1393.58,0.790,1393.58,1000,1393.74,12.4,1393.87,28.0,1393.87,93.0,1392.91,7.0,1393.02,5.0,1393.17,ON,1393.30,31.0,1393.30,32.0,
,1394.51,0.0,1394.51,800,1394.64,0.760,1394.64,1000,1394.79,12.2,1394.92,28.0,1394.92,92.0,1393.99,8.0,1394.11,5.0,1394.26,ON,1394.39,31.0,1394.39,32.0,
,1395.54,0.0,1395.54,800,1395.67,0.760,1395.67,1000,1395.80,13.2,1395.95,28.5,1395.95,93.0,1395.03,7.0,1395.14,5.0,1395.27,ON,1395.40,31.0,1395.40,32.0,
,1396.61,0.0,1396.61,800,1396.75,0.760,1396.75,1000,1396.89,12.4,1397.04,28.5,1397.04,93.0,1396.07,8.0,1396.19,5.0,1396.33,ON,1396.48,31.0,1396.48,32.0,
,1397.70,0.0,1397.70,800,1397.82,0.760,1397.82,1000,1397.95,12.4,1398.09,28.5,1398.09,93.0,1397.16,8.0,1397.28,5.0,1397.42,ON,1397.57,31.0,1397.57,32.0,
,1398.73,0.0,1398.73,800,1398.85,0.760,1398.85,1000,1398.98,13.4,1399.14,29.0,1399.14,93.0,1398.20,8.0,1398.33,5.0,1398.46,ON,1398.60,31.0,1398.60,32.0,
I logged a shorter drive this morning, and noted the delay, gave up early and toggled the ac switch. in this case, I increased the temperature control after a while, and the current reading is reduced for a while (indicating the system needed less volume from the pump) the pressure did not come down..... In this case, I also included compressor load, and noted it increased roughly with the high side pressure reading, but not in lock step. (answering part of my query on what exactly the compressor load represents)
Thursday,7,July,2016,08:16:29:51928-VCID:7CD9275F3F21BFDE22-8028,VCDS Version: Release 15.7.4 (x64),Data version: 20160216,,,,,,,,,,,,,,,,,,,
1K0 820 047 HS,ADVMB,Climatic PQ35 142 1111,,,,,,,,,,,,,,,,,,,,,,,
,,G001,F0,G001,F1,G002,F1,G002,F2,G002,F3,G003,F0,G003,F1,G004,F0,G004,F3,G005,F0,G006,F0,G007,F0
Marker,TIME,Group 1 - Field 0,TIME,Group 1 - Field 1,TIME,Group 2 - Field 1,TIME,Group 2 - Field 2,TIME,Group 2 - Field 3,TIME,Group 3 - Field 0,TIME,Group 3 - Field 1,TIME,Group 4 - Field 0,TIME,Group 4 - Field 3,TIME,Group 5 - Field 0,TIME,Group 6 - Field 0,TIME,Group 7 - Field 0,
,STAMP,Compressor - Shut-Off Code,STAMP,Engine Speed,STAMP,Compressor - Current (specified),STAMP,Compressor - Speed,STAMP,Compressor Load,STAMP,Coolant - Pressure,STAMP,Radiator Fan - Activation (actual),STAMP,Outside Temp. - (unfiltered),STAMP,Coolant - Temperature,STAMP,Outlet Blower - Temperature,STAMP,Evaporator - Temperature,STAMP,Fan/Blower - Status,
,,,, /min,, A,, /min,, Nm,, bar,, %,,øC,,øC,,øC,,øC,,,
,0,7,0,800,0.12,0,0.12,0,0.12,0,0.27,6.6,0.27,9.6,0.4,27,0.4,30,0.52,26,0.64,24,0.78,OFF,
,0.91,7,0.91,800,1.04,0,1.04,0,1.04,0,1.17,6.6,1.17,9.6,1.31,27,1.31,30,1.43,26,1.55,24,1.68,OFF,
,1.82,7,1.82,800,1.96,0,1.96,0,1.96,0,2.11,6.8,2.11,9.6,2.25,27,2.25,30,2.38,26,2.51,24,2.64,OFF,
,2.79,6,2.79,800,2.92,0,2.92,0,2.92,0,3.05,7.8,3.05,9.6,3.17,27,3.17,30,3.29,27,3.43,24,3.57,ON,
,3.7,6,3.7,800,3.82,0,3.82,0,3.82,0,3.97,6.8,3.97,9.6,4.09,27,4.09,30,4.21,27,4.34,24,4.45,ON,
,4.61,0,4.61,800,4.73,0.82,4.73,1000,4.73,2.4,4.86,6.8,4.86,9.6,4.98,27,4.98,30,5.13,26,5.26,24,5.39,ON,
,5.52,0,5.52,800,5.67,0.82,5.67,1000,5.67,2.9,5.8,7.4,5.8,9.6,5.94,27,5.94,30,6.05,27,6.19,24,6.33,ON,
,6.47,0,6.47,800,6.61,0.82,6.61,1000,6.61,3.2,6.77,7.6,6.77,9.6,6.91,27,6.91,30,7.02,27,7.15,24,7.29,ON,
,7.42,0,7.42,800,7.54,0.82,7.54,1000,7.54,3.3,7.67,7.6,7.67,9.6,7.81,27,7.81,30,7.93,26,8.04,24,8.17,ON,
,8.29,0,8.29,800,8.44,0.82,8.44,1000,8.44,3.5,8.57,8.2,8.57,14,8.7,27,8.7,30,8.81,26,8.94,24,9.07,ON,
,9.2,0,9.2,800,9.32,0.82,9.32,1000,9.32,3.6,9.47,8.4,9.47,17.2,9.61,27,9.61,31,9.74,26,9.86,24,10.01,ON,
,10.14,0,10.14,800,10.28,0.82,10.28,1000,10.28,3.6,10.42,8.4,10.42,20,10.57,27,10.57,31,10.69,26,10.81,24,10.95,ON,
,11.09,0,11.09,800,11.21,0.82,11.21,1000,11.21,3.7,11.34,8.4,11.34,22,11.46,27,11.46,31,11.59,26,11.72,24,11.85,ON,
,11.98,0,11.98,800,12.14,0.82,12.14,1000,12.14,4.6,12.27,8.8,12.27,23.6,12.4,27,12.4,31,12.51,26,12.64,24,12.77,ON,
,12.9,0,12.9,800,13.02,0.82,13.02,1000,13.02,3.9,13.17,8.8,13.17,25.6,13.31,27,13.31,31,13.44,26,13.56,24,13.71,ON,
,13.84,0,13.84,800,13.98,0.82,13.98,1000,13.98,3.9,14.12,8.8,14.12,26.8,14.28,27,14.28,30,14.4,26,14.51,24,14.63,ON,
,14.76,0,14.76,800,14.91,0.82,14.91,1000,14.91,4.8,15.04,9,15.04,28.4,15.16,27,15.16,31,15.28,25,15.42,23,15.55,ON,
,15.68,0,15.68,800,15.8,0.82,15.8,1000,15.8,3.9,15.93,9,15.93,29.2,16.07,27,16.07,31,16.18,25,16.31,23,16.46,ON,
,16.59,0,16.59,800,16.71,0.82,16.71,1000,16.71,4,16.84,8.8,16.84,30.4,16.98,27,16.98,31,17.1,25,17.21,23,17.35,ON,
,17.46,0,17.46,800,17.62,0.82,17.62,1000,17.62,4,17.74,9,17.74,31.2,17.87,27,17.87,31,17.98,25,18.11,23,18.24,ON,
,18.37,0,18.37,800,18.49,0.82,18.49,1000,18.49,4,18.64,8.8,18.64,31.6,18.77,27.5,18.77,31,18.89,25,19.01,23,19.16,ON,
,19.27,0,19.27,800,19.4,0.82,19.4,1000,19.4,3.9,19.52,8.6,19.52,32.4,19.68,27,19.68,31,19.79,25,19.91,23,20.02,ON,
,20.15,0,20.15,800,20.29,0.82,20.29,1000,20.29,3.9,20.41,8.6,20.41,32.8,20.54,27,20.54,31,20.65,25,20.8,23,20.93,ON,
,21.06,0,21.06,800,21.19,0.82,21.19,1000,21.19,3.7,21.34,8.4,21.34,32.8,21.48,27.5,21.48,31,21.61,25,21.73,23,21.88,ON,
,22.01,0,22.01,800,22.15,0.82,22.15,1000,22.15,3.5,22.29,8.4,22.29,32.8,22.44,27,22.44,31,22.56,25,22.68,23,22.82,ON,
,22.96,0,22.96,800,23.08,0.82,23.08,1000,23.08,3.6,23.21,9.2,23.21,32.8,23.35,27.5,23.35,32,23.5,25,23.62,23,23.75,ON,
,23.88,0,23.88,800,24.02,0.82,24.02,1000,24.02,3.3,24.14,8.4,24.14,32.8,24.27,27.5,24.27,32,24.38,25,24.49,23,24.63,ON,
,24.75,0,24.75,800,24.88,0.82,24.88,1000,24.88,3.6,25,9.4,25,32.8,25.15,27.5,25.15,32,25.27,25,25.39,23,25.52,ON,
,25.66,0,25.66,800,25.78,0.82,25.78,1000,25.78,3.6,25.91,8.4,25.91,32.8,26.03,27.5,26.03,32,26.17,25,26.29,23,26.43,ON,
,26.56,0,26.56,800,26.71,0.82,26.71,1000,26.71,3.3,26.85,8,26.85,33.2,26.99,27,26.99,32,27.12,25,27.26,22,27.39,ON,
,27.52,0,27.52,800,27.66,0.82,27.66,1000,27.66,3.6,27.82,8.2,27.82,33.2,27.95,27.5,27.95,32,28.07,24,28.19,22,28.33,ON,
,28.45,0,28.45,800,28.58,0.82,28.58,1000,28.58,3.5,28.7,8,28.7,33.2,28.85,27.5,28.85,32,28.97,25,29.08,22,29.19,ON,
,29.33,0,29.33,1100,29.46,0.82,29.46,1400,29.46,3.2,29.59,8.2,29.59,33.2,29.72,27.5,29.72,32,29.85,25,29.99,22,30.11,ON,
,30.24,0,30.24,1000,30.36,0.82,30.36,1100,30.36,3.4,30.5,8.2,30.5,33.2,30.63,27.5,30.63,32,30.75,25,30.88,22,31.02,ON,
,31.14,0,31.14,800,31.27,0.82,31.27,1000,31.27,3.5,31.39,8,31.39,32.8,31.54,27.5,31.54,32,31.67,25,31.77,22,31.89,ON,
,32.02,0,32.02,800,32.16,0.82,32.16,1000,32.16,3.3,32.28,8,32.28,32.8,32.41,27.5,32.41,33,32.52,24,32.64,22,32.77,ON,
,32.9,0,32.9,800,33.02,0.82,33.02,1000,33.02,3.3,33.16,8,33.16,32.8,33.32,27.5,33.32,33,33.44,25,33.55,22,33.67,ON,
,33.8,0,33.8,800,33.94,0.82,33.94,1000,33.94,3.5,34.06,8,34.06,32.8,34.19,27.5,34.19,33,34.3,25,34.44,22,34.58,ON,
,34.7,0,34.7,1000,34.83,0.82,34.83,1300,34.83,3.8,34.97,8,34.97,32.8,35.09,27.5,35.09,33,35.21,24,35.33,22,35.45,ON,
,35.59,0,35.59,900,35.72,0.82,35.72,1100,35.72,4.1,35.84,8,35.84,32.8,35.97,27.5,35.97,33,36.1,24,36.22,22,36.34,ON,
,36.47,0,36.47,900,36.62,0.82,36.62,1100,36.62,3.3,36.75,8,36.75,32.8,36.87,27.5,36.87,33,36.99,24,37.13,22,37.26,ON,
,37.39,0,37.39,900,37.51,0.82,37.51,1100,37.51,3.3,37.66,8,37.66,32.8,37.79,27.5,37.79,33,37.91,25,38.03,22,38.17,ON,
,38.29,0,38.29,800,38.42,0.82,38.42,1000,38.42,3.5,38.54,8,38.54,32.8,38.68,27.5,38.68,33,38.8,25,38.92,22,39.06,ON,
,39.2,0,39.2,800,39.32,0.82,39.32,1000,39.32,3.2,39.45,8,39.45,32.8,39.57,27.5,39.57,33,39.71,25,39.83,22,39.96,ON,
,40.09,0,40.09,800,40.24,0.82,40.24,1000,40.24,3.2,40.37,8,40.37,32.8,40.5,27.5,40.5,33,40.63,25,40.77,22,40.9,ON,
,41.03,0,41.03,800,41.17,0.82,41.17,1000,41.17,3.3,41.32,7.8,41.32,32.8,41.45,27.5,41.45,33,41.58,24,41.7,22,41.84,ON,
,41.96,0,41.96,900,42.09,0.82,42.09,1000,42.09,3.3,42.23,7.6,42.23,32.8,42.39,27.5,42.39,33,42.51,24,42.62,22,42.74,ON,
,42.87,0,42.87,1100,43.01,0.82,43.01,1400,43.01,3,43.13,8,43.13,32.8,43.26,27.5,43.26,33,43.37,24,43.51,22,43.62,ON,
,43.75,0,43.75,1100,43.88,0.82,43.88,1400,43.88,3,44,8,44,32.8,44.15,27.5,44.15,34,44.26,24,44.39,22,44.52,ON,
,44.66,0,44.66,1400,44.78,0.82,44.78,1800,44.78,2.7,44.9,8,44.9,32.8,45.03,27.5,45.03,34,45.16,24,45.28,22,45.41,ON,
,45.54,0,45.54,1700,45.69,0.82,45.69,2200,45.69,2.3,45.82,8,45.82,32.8,45.95,27.5,45.95,34,46.06,24,46.19,22,46.32,ON,
,46.45,0,46.45,2000,46.57,0.82,46.57,2400,46.57,2,46.72,8,46.72,32.8,46.85,27.5,46.85,34,46.97,25,47.09,22,47.23,ON,
,47.35,0,47.35,1400,47.48,0.82,47.48,1800,47.48,2.7,47.6,8,47.6,32.8,47.75,27.5,47.75,34,47.87,25,47.99,22,48.12,ON,
,48.26,0,48.26,1500,48.38,0.82,48.38,1900,48.38,2.6,48.51,8,48.51,32.8,48.63,27.5,48.63,34,48.77,25,48.89,22,49.02,ON,
,49.15,0,49.15,1700,49.3,0.82,49.3,2200,49.3,2.7,49.41,8,49.41,32.8,49.54,27.5,49.54,35,49.65,24,49.76,22,49.9,ON,
,50.02,0,50.02,1900,50.15,0.82,50.15,2400,50.15,2.3,50.27,8,50.27,32.8,50.41,27.5,50.41,35,50.53,24,50.65,22,50.79,ON,
,50.93,0,50.93,1900,51.05,0.82,51.05,2400,51.05,2,51.18,8,51.18,32.8,51.3,27.5,51.3,35,51.44,25,51.56,22,51.69,ON,
,51.82,0,51.82,1700,51.96,0.82,51.96,2200,51.96,2.1,52.08,8,52.08,32.8,52.21,27.5,52.21,35,52.32,25,52.47,22,52.6,ON,
,52.72,0,52.72,1400,52.85,0.82,52.85,1800,52.85,2.4,52.99,8,52.99,32.8,53.11,27.5,53.11,35,53.23,24,53.35,22,53.47,ON,
,53.61,0,53.61,1200,53.74,0.82,53.74,1500,53.74,2.9,53.86,8,53.86,32.8,53.99,27.5,53.99,35,54.12,24,54.24,22,54.36,ON,
,54.49,0,54.49,1100,54.61,0.82,54.61,1400,54.61,3,54.75,8,54.75,32.8,54.88,27.5,54.88,35,54.99,24,55.12,22,55.27,ON,
,55.41,0,55.41,1200,55.53,0.82,55.53,1500,55.53,2.9,55.66,8,55.66,32.8,55.8,27.5,55.8,36,55.91,25,56.02,22,56.14,ON,
,56.27,0,56.27,1300,56.41,0.82,56.41,1600,56.41,2.8,56.53,8,56.53,32.8,56.66,27.5,56.66,36,56.77,25,56.91,22,57.02,ON,
,57.16,0,57.16,1300,57.28,0.82,57.28,1600,57.28,2.7,57.41,7.8,57.41,32.8,57.56,27.5,57.56,36,57.68,24,57.79,22,57.91,ON,
,58.04,0,58.04,1500,58.18,0.82,58.18,1900,58.18,2.6,58.31,8,58.31,32.8,58.44,27.5,58.44,36,58.57,24,58.71,22,58.83,ON,
,58.96,0,58.96,1700,59.08,0.82,59.08,2200,59.08,2.3,59.22,8,59.22,32.8,59.35,27.5,59.35,36,59.47,24,59.6,22,59.74,ON,
,59.86,0,59.86,1800,59.99,0.82,59.99,2400,59.99,2,60.11,8,60.11,32.8,60.25,27.5,60.25,36,60.37,25,60.49,22,60.62,ON,
,60.76,0,60.76,2000,60.89,0.82,60.89,2600,60.89,1.6,61.02,8,61.02,32.8,61.14,27.5,61.14,36,61.27,24,61.4,22,61.53,ON,
,61.66,0,61.66,2100,61.8,0.82,61.8,2700,61.8,1.3,61.92,8,61.92,32.8,62.05,27.5,62.05,36,62.16,24,62.27,22,62.41,ON,
,62.53,0,62.53,2100,62.66,0.82,62.66,2700,62.66,1.7,62.79,8,62.79,32.8,62.92,27.5,62.92,36,63.04,24,63.16,22,63.3,ON,
,63.44,0,63.44,1700,63.56,0.82,63.56,2000,63.56,2.5,63.69,8.8,63.69,32.8,63.81,27.5,63.81,36,63.94,25,64.05,22,64.17,ON,
,64.3,0,64.3,1400,64.42,0.82,64.42,1800,64.42,2.5,64.56,8.6,64.56,32.8,64.69,27.5,64.69,36,64.8,25,64.93,22,65.08,ON,
,65.22,0,65.22,1400,65.34,0.82,65.34,1800,65.34,2.7,65.47,8.8,65.47,32.8,65.61,27.5,65.61,37,65.72,24,65.85,22,65.98,ON,
,66.13,0,66.13,1400,66.26,0.82,66.26,1900,66.26,2.6,66.39,7.6,66.39,32.8,66.51,27.5,66.51,37,66.65,24,66.77,22,66.9,ON,
,67.03,0,67.03,1500,67.17,0.82,67.17,1900,67.17,2.6,67.29,7.6,67.29,32.8,67.42,27.5,67.42,37,67.53,25,67.64,22,67.8,ON,
,67.93,0,67.93,1600,68.06,0.82,68.06,2000,68.06,2.5,68.18,8,68.18,32.8,68.33,27.5,68.33,37,68.46,25,68.58,22,68.72,ON,
,68.87,0,68.87,1700,69,0.82,69,2200,69,2.3,69.14,8,69.14,32.8,69.28,27.5,69.28,38,69.41,24,69.53,22,69.67,ON,
,69.81,0,69.81,1700,69.95,0.82,69.95,2200,69.95,2.3,70.07,8.8,70.07,32.8,70.2,27.5,70.2,38,70.31,24,70.42,22,70.56,ON,
,70.7,0,70.7,1700,70.82,0.82,70.82,2200,70.82,2.3,70.95,8,70.95,32.8,71.11,27.5,71.11,38,71.24,24,71.36,22,71.48,ON,
,71.63,0,71.63,1700,71.78,0.82,71.78,2200,71.78,2.3,71.92,8,71.92,32.8,72.06,27.5,72.06,38,72.2,25,72.33,22,72.45,ON,
,72.59,0,72.59,1600,72.73,0.82,72.73,2000,72.73,2.4,72.87,8,72.87,32.8,73.01,27.5,73.01,38,73.14,25,73.27,22,73.4,ON,
,73.53,0,73.53,1600,73.65,0.82,73.65,2000,73.65,2.3,73.81,8,73.81,32.8,73.94,27.5,73.94,38,74.08,24,74.19,22,74.34,ON,
,74.47,0,74.47,1600,74.61,0.82,74.61,2000,74.61,2.5,74.75,8,74.75,32.8,74.9,27.5,74.9,39,75.03,24,75.16,22,75.3,ON,
,75.45,0,75.45,1600,75.57,0.82,75.57,2000,75.57,3,75.7,8,75.7,32.8,75.82,27.5,75.82,39,75.96,25,76.08,22,76.21,ON,
,76.34,0,76.34,1700,76.48,0.82,76.48,2200,76.48,2.3,76.6,8,76.6,32.8,76.73,27.5,76.73,39,76.85,25,76.99,22,77.13,ON,
,77.26,0,77.26,1700,77.39,0.82,77.39,2200,77.39,2.3,77.54,8,77.54,32.8,77.67,27.5,77.67,39,77.8,24,77.92,22,78.07,ON,
,78.2,0,78.2,1700,78.34,0.82,78.34,2200,78.34,2.3,78.48,8,78.48,32.8,78.62,27.5,78.62,39,78.73,24,78.86,22,78.99,ON,
,79.14,0,79.14,1700,79.27,0.82,79.27,2200,79.27,2.3,79.4,8,79.4,32.8,79.52,27.5,79.52,39,79.66,25,79.78,22,79.91,ON,
,80.04,0,80.04,1700,80.18,0.82,80.18,2200,80.18,2.3,80.3,8,80.3,32.8,80.43,27.5,80.43,39,80.54,25,80.65,22,80.79,ON,
,80.91,0,80.91,1700,81.04,0.82,81.04,2200,81.04,2.3,81.16,8,81.16,32.8,81.3,27.5,81.3,39,81.42,24,81.54,22,81.68,ON,
,81.84,0,81.84,1700,81.97,0.82,81.97,2200,81.97,2.3,82.1,8,82.1,32.8,82.22,27.5,82.22,40,82.36,24,82.48,22,82.62,ON,
,82.76,0,82.76,1700,82.91,0.82,82.91,2200,82.91,2.3,83.04,8,83.04,32.8,83.18,27.5,83.18,40,83.31,25,83.45,22,83.58,ON,
,83.71,0,83.71,1700,83.83,0.82,83.83,2200,83.83,2.1,83.97,8,83.97,32.8,84.1,27.5,84.1,40,84.21,25,84.34,22,84.49,ON,
,84.6,0,84.6,1700,84.74,0.82,84.74,2000,84.74,2.3,84.86,7.8,84.86,32.8,85,27.5,85,41,85.12,25,85.24,22,85.38,ON,
,85.54,0,85.54,1500,85.66,0.82,85.66,2000,85.66,2.5,85.79,8,85.79,32.8,85.91,27.5,85.91,41,86.06,24,86.18,22,86.32,ON,
,86.46,0,86.46,1500,86.61,0.82,86.61,1900,86.61,2.4,86.73,8,86.73,32.8,86.87,27.5,86.87,41,87,24,87.14,22,87.27,ON,
,87.4,0,87.4,1400,87.55,0.82,87.55,1800,87.55,2.7,87.69,8,87.69,32.8,87.82,27.5,87.82,41,87.93,25,88.04,22,88.18,ON,
,88.34,0,88.34,1400,88.47,0.82,88.47,1800,88.47,2.7,88.6,8,88.6,32.8,88.72,27.5,88.72,41,88.86,25,88.98,22,89.11,ON,
,89.24,0,89.24,1400,89.38,0.82,89.38,1800,89.38,2.4,89.5,8,89.5,32.8,89.63,27.5,89.63,42,89.74,25,89.85,22,89.99,ON,
,90.12,0,90.12,1300,90.25,0.82,90.25,1600,90.25,3.6,90.39,8,90.39,32.8,90.54,27.5,90.54,42,90.67,24,90.79,22,90.93,ON,
,91.08,0,91.08,1200,91.21,0.82,91.21,1500,91.21,2.9,91.33,8,91.33,32.8,91.46,27.5,91.46,42,91.6,25,91.73,22,91.86,ON,
,91.99,0,91.99,1100,92.13,0.82,92.13,1400,92.13,3,92.25,8,92.25,32.8,92.38,27.5,92.38,42,92.49,24,92.63,22,92.77,ON,
,92.91,0,92.91,1100,93.03,0.82,93.03,1400,93.03,3.7,93.17,8.2,93.17,32.8,93.3,27.5,93.3,42,93.41,25,93.54,22,93.69,ON,
,93.81,0,93.81,1100,93.94,0.82,93.94,1400,93.94,2.9,94.06,9.2,94.06,32.8,94.21,27.5,94.21,42,94.33,24,94.44,22,94.56,ON,
,94.69,0,94.69,1100,94.84,0.82,94.84,1400,94.84,3.2,94.97,8,94.97,32.8,95.09,27.5,95.09,42,95.21,25,95.35,22,95.48,ON,
,95.61,0,95.61,1100,95.73,0.82,95.73,1400,95.73,3.2,95.87,8.2,95.87,32.8,96,27.5,96,42,96.11,25,96.22,22,96.39,ON,
,96.51,0,96.51,1000,96.64,0.82,96.64,1300,96.64,3.2,96.76,8.2,96.76,32.8,96.9,27.5,96.9,42,97.02,25,97.14,22,97.26,ON,
,97.39,0,97.39,900,97.53,0.82,97.53,1100,97.53,3.4,97.66,8.2,97.66,32.8,97.79,27.5,97.79,42,97.91,25,98.04,22,98.18,ON,
,98.31,0,98.31,800,98.44,0.82,98.44,1000,98.44,3.5,98.59,8.2,98.59,32.8,98.72,27.5,98.72,42,98.85,25,98.97,22,99.11,ON,
,99.24,0,99.24,800,99.36,0.82,99.36,1000,99.36,3.5,99.49,8.2,99.49,32.8,99.65,27.5,99.65,42,99.77,25,99.89,22,100.03,ON,
,100.17,0,100.17,800,100.3,0.82,100.3,1000,100.3,4.3,100.42,8.4,100.42,32.8,100.55,27.5,100.55,43,100.69,25,100.81,22,100.95,ON,
,101.08,0,101.08,900,101.22,0.82,101.22,1300,101.22,3.5,101.34,9.6,101.34,32.8,101.47,27.5,101.47,43,101.58,25,101.73,22,101.86,ON,
,101.99,0,101.99,1100,102.11,0.82,102.11,1400,102.11,3.4,102.25,8.6,102.25,33.2,102.37,27.5,102.37,43,102.49,25,102.61,22,102.73,ON,
,102.89,0,102.89,1200,103.01,0.82,103.01,1500,103.01,3.4,103.14,8.4,103.14,33.2,103.26,27.5,103.26,43,103.4,25,103.52,22,103.65,ON,
,103.78,0,103.78,1300,103.92,0.82,103.92,1800,103.92,3.3,104.04,8.8,104.04,33.6,104.17,27.5,104.17,43,104.28,25,104.4,22,104.53,ON,
,104.66,0,104.66,1500,104.78,0.82,104.78,1900,104.78,3.2,104.91,9.2,104.91,33.6,105.04,27.5,105.04,43,105.17,25,105.28,22,105.4,ON,
,105.53,0,105.53,1700,105.69,0.82,105.69,2200,105.69,2.7,105.82,9.2,105.82,34,105.96,27.5,105.96,44,106.06,25,106.21,22,106.34,ON,
,106.47,0,106.47,2000,106.59,0.82,106.59,2600,106.59,2,106.74,9,106.74,34.4,106.85,27.5,106.85,44,106.97,25,107.09,22,107.21,ON,
,107.35,0,107.35,2000,107.48,0.82,107.48,2300,107.48,2.5,107.62,8.4,107.62,34.4,107.74,27.5,107.74,44,107.88,25,108,21,108.13,ON,
,108.26,0,108.26,1500,108.4,0.82,108.4,1900,108.4,2.9,108.52,8.8,108.52,34.4,108.65,27.5,108.65,44,108.76,25,108.91,21,109.04,ON,
,109.16,0,109.16,1600,109.29,0.82,109.29,2000,109.29,3.1,109.43,8.8,109.43,34.4,109.56,27.5,109.56,44,109.69,24,109.81,21,109.96,ON,
,110.09,0,110.09,1700,110.23,0.82,110.23,2200,110.23,2.5,110.37,8.8,110.37,34.4,110.51,27.5,110.51,44,110.62,24,110.75,21,110.88,ON,
,111.02,0,111.02,1800,111.15,0.82,111.15,2300,111.15,2.5,111.27,8.8,111.27,34.4,111.4,27.5,111.4,44,111.54,25,111.67,21,111.8,ON,
,111.93,0,111.93,1900,112.08,0.82,112.08,2400,112.08,2.1,112.22,9.6,112.22,34.4,112.35,27.5,112.35,45,112.47,25,112.61,21,112.75,ON,
,112.88,0,112.88,2000,113.01,0.82,113.01,2600,113.01,1.8,113.16,8.8,113.16,34.4,113.28,27.5,113.28,45,113.42,24,113.54,21,113.68,ON,
,113.82,0,113.82,1500,113.95,0.82,113.95,1900,113.95,3.1,114.07,8.8,114.07,34.4,114.22,27.5,114.22,45,114.34,24,114.46,21,114.6,ON,
,114.74,0,114.74,1300,114.88,0.82,114.88,1600,114.88,3.4,115.01,9,115.01,34.4,115.13,27.5,115.13,45,115.27,24,115.39,21,115.52,ON,
,115.65,0,115.65,1300,115.79,0.82,115.79,1600,115.79,3.4,115.91,9,115.91,34.8,116.04,27.5,116.04,45,116.15,24,116.26,21,116.4,ON,
,116.54,0,116.54,1200,116.66,0.82,116.66,1400,116.66,3.7,116.79,8.8,116.79,34.8,116.95,27.5,116.95,45,117.08,24,117.2,20,117.34,ON,
,117.49,0,117.49,1000,117.62,0.82,117.62,1300,117.62,3.8,117.76,9,117.76,34.8,117.9,27.5,117.9,45,118.04,24,118.18,21,118.3,ON,
,118.44,0,118.44,1000,118.59,0.82,118.59,1300,118.59,3.8,118.73,9.2,118.73,35.2,118.86,27.5,118.86,45,118.98,24,119.12,21,119.26,ON,
,119.4,0,119.4,900,119.54,0.82,119.54,1000,119.54,4.7,119.69,9.2,119.69,35.2,119.82,27.5,119.82,45,119.95,24,120.07,20,120.22,ON,
,120.35,0,120.35,900,120.47,0.82,120.47,1100,120.47,4.1,120.6,9.2,120.6,35.6,120.75,28,120.75,45,120.87,24,120.99,20,121.11,ON,
,121.24,0,121.24,1000,121.4,0.82,121.4,1300,121.4,3.9,121.54,9.2,121.54,35.6,121.66,28,121.66,45,121.78,24,121.92,20,122.05,ON,
,122.17,0,122.17,1100,122.3,0.82,122.3,1500,122.3,3.5,122.44,9.4,122.44,35.6,122.56,27.5,122.56,45,122.68,24,122.8,20,122.92,ON,
,123.07,0,123.07,1400,123.2,0.82,123.2,1900,123.2,3.6,123.33,9.6,123.33,36,123.45,27.5,123.45,46,123.59,23,123.71,20,123.84,ON,
,123.97,0,123.97,1700,124.11,0.82,124.11,2300,124.11,3.2,124.24,9.6,124.24,36.4,124.38,27.5,124.38,46,124.51,23,124.65,20,124.78,ON,
,124.91,0,124.91,1900,125.05,0.82,125.05,2600,125.05,2.8,125.2,9.6,125.2,36.8,125.33,28,125.33,46,125.47,23,125.6,20,125.76,ON,
,125.89,0,125.89,1800,126.01,0.82,126.01,2200,126.01,2.9,126.14,9.4,126.14,37.2,126.28,27.5,126.28,46,126.4,23,126.52,20,126.65,ON,
,126.8,0,126.8,1500,126.93,0.82,126.93,1900,126.93,3.9,127.07,9.6,127.07,37.2,127.22,27.5,127.22,46,127.37,23,127.49,19,127.62,ON,
,127.74,0,127.74,1700,127.88,0.82,127.88,2200,127.88,3.2,128,9.4,128,37.6,128.14,27.5,128.14,47,128.27,23,128.4,19,128.53,ON,
,128.66,0,128.66,1800,128.78,0.82,128.78,2300,128.78,3.3,128.92,10,128.92,38,129.05,28,129.05,47,129.16,23,129.29,19,129.44,ON,
,129.56,0,129.56,2000,129.69,0.82,129.69,2600,129.69,2.4,129.82,10,129.82,38.4,129.97,28,129.97,47,130.08,22,130.19,19,130.33,ON,
,130.45,0,130.45,2000,130.6,0.82,130.6,2300,130.6,3.1,130.74,10,130.74,38.8,130.88,28,130.88,47,131.01,22,131.15,19,131.28,ON,
,131.41,0,131.41,1400,131.55,0.82,131.55,1800,131.55,3.9,131.71,10,131.71,39.2,131.83,28,131.83,47,131.95,22,132.07,19,132.23,ON,
,132.34,0,132.34,1300,132.48,0.82,132.48,1600,132.48,4.1,132.59,10,132.59,39.6,132.73,28,132.73,47,132.85,22,132.98,19,133.11,ON,
,133.26,0,133.26,1300,133.37,0.82,133.37,1600,133.37,4.1,133.5,10,133.5,39.6,133.64,28,133.64,48,133.77,22,133.89,19,134.02,ON,
,134.14,0,134.14,1200,134.26,0.82,134.26,1400,134.26,4.6,134.41,10.4,134.41,40,134.55,28,134.55,48,134.66,21,134.79,19,134.94,ON,
,135.07,0,135.07,1000,135.2,0.82,135.2,1300,135.2,4.7,135.33,10.4,135.33,40.4,135.47,28,135.47,48,135.61,22,135.74,18,135.88,ON,
,136.03,0,136.03,1000,136.15,0.82,136.15,1300,136.15,4.9,136.28,10.6,136.28,40.8,136.42,28,136.42,48,136.56,22,136.69,18,136.82,ON,
,136.95,0,136.95,1000,137.09,0.82,137.09,1400,137.09,4.6,137.21,11.8,137.21,41.2,137.34,28,137.34,48,137.45,21,137.6,18,137.73,ON,
,137.85,0,137.85,1000,137.98,0.82,137.98,1300,137.98,5.1,138.12,10.4,138.12,42,138.24,28,138.24,48,138.36,21,138.48,18,138.64,ON,
,138.77,0,138.77,1000,138.9,0.82,138.9,1300,138.9,5.1,139.02,11,139.02,42.4,139.17,28,139.17,48,139.3,21,139.42,18,139.56,ON,
,139.7,0,139.7,1100,139.83,0.82,139.84,1400,139.84,5.1,139.98,11.2,139.98,43.2,140.12,28,140.12,48,140.26,20,140.39,18,140.52,ON,
,140.65,0,140.65,1200,140.78,0.82,140.78,1500,140.78,5.5,140.91,11.6,140.91,44,141.05,28,141.05,48,141.17,20,141.31,18,141.44,ON,
,141.57,0,141.57,1400,141.68,0.82,141.68,1800,141.68,4.7,141.84,12,141.84,44.4,141.96,28,141.96,48,142.09,20,142.21,18,142.35,ON,
,142.47,0,142.47,1500,142.6,0.82,142.6,1900,142.6,4.6,142.71,11.8,142.71,45.2,142.86,28,142.86,48,142.99,20,143.12,18,143.25,ON,
,143.41,0,143.41,1600,143.53,0.82,143.53,2000,143.53,4.4,143.68,12,143.68,46,143.81,28,143.81,49,143.94,20,144.06,17,144.2,ON,
,144.34,0,144.34,1700,144.49,0.82,144.49,2200,144.49,4,144.62,11.4,144.62,46.4,144.74,28,144.74,49,144.86,20,145,17,145.13,ON,
,145.26,0,145.26,1800,145.38,0.82,145.38,2300,145.38,3.7,145.53,12,145.53,47.2,145.66,28,145.66,49,145.78,20,145.9,17,146.04,ON,
,146.16,0,146.16,1900,146.29,0.82,146.29,2400,146.29,3.5,146.41,12,146.41,47.6,146.56,28,146.56,49,146.69,19,146.81,17,146.94,ON,
,147.09,0,147.09,1900,147.23,0.82,147.23,2400,147.23,3.3,147.37,12,147.37,48,147.51,28,147.51,50,147.65,20,147.76,16,147.9,ON,
,148.02,0,148.02,1800,148.15,0.82,148.15,2000,148.15,4.5,148.3,12.8,148.3,48.4,148.43,28,148.43,50,148.54,19,148.67,16,148.82,ON,
,148.94,0,148.94,1400,149.07,0.82,149.07,1800,149.07,4.9,149.19,12,149.19,48.8,149.33,28,149.33,50,149.45,19,149.57,16,149.69,ON,
,149.82,0,149.82,1400,149.96,0.82,149.96,1900,149.96,4.6,150.08,11.8,150.08,48.8,150.21,28,150.21,50,150.32,19,150.46,16,150.6,ON,
,150.72,0,150.72,1500,150.85,0.82,150.85,1900,150.85,4.9,150.99,11.8,150.99,48.8,151.11,28,151.11,50,151.23,19,151.35,16,151.5,ON,
,151.63,0,151.63,1500,151.75,0.82,151.75,1900,151.75,4.3,151.88,12.4,151.88,48.8,152.02,28,152.02,50,152.13,19,152.26,16,152.39,ON,
,152.53,0,152.53,1500,152.66,0.82,152.66,1900,152.66,4.5,152.78,11.4,152.78,48.8,152.91,28,152.91,51,153.06,19,153.18,15,153.31,ON,
,153.44,0,153.44,1500,153.58,0.82,153.58,1900,153.58,4.6,153.7,11.8,153.7,48.8,153.83,28,153.83,51,153.94,18,154.09,15,154.22,ON,
,154.34,0,154.34,1500,154.47,0.82,154.47,1900,154.47,4.6,154.61,11.8,154.61,48.8,154.74,28,154.74,51,154.87,18,154.99,15,155.14,ON,
,155.27,0,155.27,1500,155.41,0.82,155.41,1800,155.41,4.6,155.54,11.8,155.54,48.8,155.69,28,155.69,51,155.81,17,155.94,15,156.07,ON,
,156.23,0,156.23,1500,156.36,0.82,156.36,1900,156.36,4.6,156.49,11.8,156.49,48.8,156.61,28,156.61,51,156.74,17,156.85,14,156.99,ON,
,157.13,0,157.13,1400,157.27,0.82,157.27,1800,157.27,4.7,157.39,11.8,157.39,48.8,157.52,28,157.52,51,157.63,18,157.74,14,157.88,ON,
,158,0,158,1300,158.13,0.82,158.13,1600,158.13,5.1,158.25,11.6,158.25,48.8,158.4,28,158.4,51,158.52,17,158.65,14,158.78,ON,
,158.93,0,158.93,1100,159.06,0.82,159.06,1400,159.06,5.4,159.19,11.6,159.19,48.8,159.31,28,159.31,51,159.45,17,159.57,14,159.7,ON,
,159.83,0,159.83,900,159.97,0.82,159.97,1100,159.97,5.7,160.09,11.4,160.09,48.8,160.22,28,160.22,51,160.33,17,160.45,14,160.6,ON,
,160.74,0,160.74,900,160.88,0.82,160.88,1100,160.88,5.7,161.02,12.2,161.02,48.4,161.17,28,161.17,51,161.29,17,161.41,14,161.55,ON,
,161.7,0,161.7,800,161.83,0.82,161.83,1000,161.83,5.9,161.95,11.4,161.95,48.4,162.08,28,162.08,51,162.21,17,162.33,14,162.47,ON,
,162.61,0,162.61,800,162.75,0.82,162.75,1000,162.75,5.9,162.88,11.4,162.88,48,163,28,163,52,163.11,16,163.26,13,163.39,ON,
,163.51,0,163.51,1100,163.64,0.82,163.64,1500,163.64,5.1,163.78,11.6,163.78,48,163.9,28,163.9,52,164.02,17,164.14,13,164.26,ON,
,164.41,0,164.41,1600,164.54,0.82,164.54,2200,164.54,4,164.67,12,164.67,48,164.79,28,164.79,52,164.93,17,165.05,13,165.18,ON,
,165.31,0,165.31,2200,165.45,0.82,165.45,2800,165.45,2.2,165.57,12.4,165.57,48.4,165.7,28,165.7,52,165.81,16,165.96,13,166.09,ON,
,166.21,0,166.21,2400,166.34,0.82,166.34,3100,166.34,1.6,166.48,12.4,166.48,49.2,166.6,28,166.6,52,166.72,16,166.84,13,166.96,ON,
,167.11,0,167.11,1700,167.24,0.82,167.24,2200,167.24,4.1,167.37,12.4,167.37,49.6,167.48,28,167.48,52,167.63,16,167.75,13,167.89,ON,
,168.03,0,168.03,2100,168.18,0.82,168.18,2700,168.18,2.6,168.31,12.2,168.31,50,168.44,28,168.44,53,168.59,16,168.71,13,168.84,ON,
,168.98,0,168.98,2100,169.09,0.81,169.09,2400,169.09,3.5,169.23,12,169.23,50.4,169.37,28,169.37,53,169.47,16,169.6,13,169.75,ON,
,169.87,0,169.87,1700,170,0.82,170,2200,170,4,170.12,12,170.12,50.4,170.27,28,170.27,53,170.4,16,170.52,13,170.65,ON,
,170.8,0,170.8,1800,170.94,0.82,170.94,2300,170.94,3.7,171.07,12,171.07,50.4,171.18,28,171.18,53,171.32,15,171.45,12,171.57,ON,
,171.71,0,171.71,1900,171.84,0.81,171.84,2400,171.84,3.4,171.97,12,171.97,50.4,172.11,28,172.11,53,172.25,15,172.38,12,172.52,ON,
,172.65,0,172.65,1900,172.79,0.82,172.79,2400,172.79,3.5,172.93,12,172.93,50.4,173.06,28,173.06,53,173.19,15,173.31,12,173.45,ON,
,173.57,0,173.57,1600,173.7,0.8,173.7,1800,173.7,4.7,173.83,12,173.83,50,173.98,28,173.98,53,174.09,15,174.2,12,174.33,ON,
,174.45,0,174.45,1300,174.6,0.78,174.6,1600,174.6,5.4,174.71,11.8,174.71,50,174.84,28,174.84,54,174.97,15,175.12,12,175.24,ON,
,175.38,0,175.38,1200,175.49,0.78,175.49,1500,175.49,4.9,175.63,11.2,175.63,50,175.76,28,175.76,54,175.88,15,176,12,176.16,ON,
,176.27,0,176.27,1200,176.4,0.79,176.4,1400,176.4,5.3,176.52,11.6,176.52,49.6,176.66,28,176.66,54,176.78,15,176.92,12,177.04,ON,
,177.18,0,177.18,1100,177.3,0.79,177.3,1400,177.3,5.4,177.43,11.6,177.43,49.6,177.55,28,177.55,54,177.69,15,177.81,11,177.95,ON,
,178.07,0,178.07,1000,178.21,0.77,178.21,1300,178.21,5.7,178.33,11.8,178.33,49.2,178.46,28,178.46,54,178.57,15,178.72,11,178.85,ON,
,178.97,0,178.97,1100,179.1,0.77,179.1,1400,179.1,5.5,179.24,11.2,179.24,48.8,179.37,28,179.37,54,179.51,15,179.62,11,179.77,ON,
,179.9,0,179.9,1100,180.04,0.78,180.04,1400,180.04,5.6,180.18,12,180.18,49.2,180.34,28,180.34,54,180.46,15,180.59,11,180.72,ON,
,180.87,0,180.87,900,181,0.78,181,1100,181,6,181.13,11.8,181.13,49.2,181.25,28,181.25,54,181.38,14,181.51,11,181.64,ON,
,181.77,0,181.77,900,181.9,0.76,181.9,1100,181.9,6,182.02,11.8,182.02,49.2,182.15,28,182.15,54,182.27,14,182.38,11,182.54,ON,
,182.67,0,182.67,800,182.79,0.76,182.79,1000,182.79,6,182.92,11.8,182.92,49.2,183.07,28,183.07,54,183.19,14,183.3,11,183.45,ON,
,183.59,0,183.59,700,183.73,0.76,183.73,900,183.73,6,183.87,11,183.87,48.8,184.01,28,184.01,54,184.15,15,184.28,11,184.41,ON,
,184.54,0,184.54,700,184.69,0.77,184.69,1000,184.69,6,184.82,12.4,184.82,48.4,184.94,28,184.94,54,185.06,15,185.2,11,185.33,ON,
,185.46,0,185.46,800,185.58,0.73,185.58,1000,185.58,6,185.73,11.6,185.73,48.4,185.86,28,185.86,54,185.98,14,186.1,10,186.24,ON,
,186.36,0,186.36,800,186.49,0.73,186.49,1000,186.49,6.5,186.61,12.2,186.61,48.4,186.76,28,186.76,55,186.88,14,186.99,10,187.11,ON,
,187.24,0,187.24,800,187.4,0.73,187.4,1000,187.4,6,187.54,11.6,187.54,48.4,187.68,28,187.68,55,187.81,14,187.95,10,188.09,ON,
,188.21,0,188.21,800,188.35,0.74,188.35,1000,188.35,5.9,188.5,11,188.5,48,188.64,28,188.64,55,188.74,14,188.88,10,189.02,ON,
,189.15,0,189.15,800,189.27,0.74,189.27,1000,189.27,6.5,189.41,12.2,189.41,48,189.55,28,189.55,55,189.68,14,189.8,10,189.95,ON,
,190.1,0,190.1,800,190.24,0.72,190.24,1000,190.24,6,190.38,11.6,190.38,48,190.52,28,190.52,56,190.66,14,190.79,10,190.92,ON,
,191.05,0,191.05,800,191.2,0.72,191.2,1000,191.2,6.2,191.33,11.8,191.33,47.6,191.45,28,191.45,56,191.57,14,191.71,10,191.84,ON,
,191.97,0,191.97,800,192.09,0.75,192.09,1000,192.09,6.2,192.23,11.8,192.23,47.6,192.36,28.5,192.36,56,192.47,14,192.58,10,192.72,ON,
,192.86,0,192.86,800,192.98,0.75,192.98,1000,192.98,6.4,193.11,12,193.11,47.6,193.25,28.5,193.25,56,193.38,14,193.5,10,193.62,ON,
,193.75,0,193.75,800,193.87,0.73,193.87,1000,193.87,6.4,194.01,12,194.01,48,194.14,28.5,194.14,56,194.25,14,194.38,10,194.53,ON,
,194.65,0,194.65,800,194.78,0.73,194.78,1000,194.78,6.4,194.9,12,194.9,48.4,195.05,28.5,195.05,56,195.18,14,195.3,10,195.44,ON,
,195.58,0,195.58,800,195.71,0.73,195.71,1000,195.71,6.4,195.86,12,195.86,48.4,196,28.5,196,56,196.14,14,196.27,10,196.4,ON,
,196.52,0,196.52,800,196.66,0.74,196.66,1000,196.66,6.4,196.78,12,196.78,48.4,196.91,28.5,196.91,56,197.03,14,197.16,10,197.31,ON,
,197.45,0,197.45,800,197.56,0.72,197.56,1000,197.56,6.4,197.71,12,197.71,48.8,197.84,28.5,197.84,57,197.98,14,198.08,10,198.25,ON,
,198.38,0,198.38,800,198.53,0.72,198.53,1000,198.53,6.4,198.66,12,198.66,49.2,198.81,28.5,198.81,57,198.93,14,199.05,10,199.19,ON,
,199.34,0,199.34,1400,199.47,0.74,199.47,1600,199.47,5.3,199.61,12.4,199.61,49.2,199.73,28.5,199.73,57,199.86,14,199.99,10,200.12,ON,
,200.25,0,200.25,1500,200.41,0.75,200.41,1900,200.41,4.9,200.54,12,200.54,49.6,200.67,28.5,200.67,57,200.78,14,200.91,10,201.04,ON,
,201.17,0,201.17,1700,201.29,0.75,201.29,2200,201.29,4.2,201.44,12.6,201.44,50,201.58,28.5,201.58,57,201.71,14,201.83,10,201.98,ON,
,202.11,0,202.11,1300,202.25,0.73,202.25,1600,202.25,5.6,202.39,12.8,202.39,50.4,202.54,28.5,202.54,57,202.67,14,202.78,10,202.92,ON,
,203.06,0,203.06,1500,203.21,0.73,203.21,2000,203.21,4.8,203.34,12.6,203.34,50.8,203.46,28.5,203.46,57,203.6,13,203.72,10,203.85,ON,
,203.99,0,203.99,1800,204.14,0.74,204.14,2400,204.14,3.8,204.28,12.4,204.28,51.2,204.42,28.5,204.42,57,204.55,13,204.69,10,204.82,ON,
,204.95,0,204.95,2100,205.09,0.74,205.09,2700,205.09,2.9,205.24,13.4,205.24,51.6,205.37,28.5,205.37,57,205.5,14,205.62,9,205.76,ON,
,205.88,0,205.88,1600,206.01,0.72,206.01,1900,206.01,5.2,206.13,13.4,206.13,52.4,206.28,28.5,206.28,57,206.4,13,206.53,9,206.66,ON,
,206.81,0,206.81,1500,206.95,0.72,206.95,1900,206.95,5.2,207.09,13.4,207.09,52.8,207.23,28.5,207.23,57,207.37,13,207.5,9,207.63,ON,
,207.76,0,207.76,1600,207.91,0.73,207.91,2000,207.91,5.4,208.04,13.4,208.04,53.2,208.16,28.5,208.16,57,208.28,13,208.42,9,208.55,ON,
,208.68,0,208.68,1600,208.82,0.73,208.82,2000,208.82,5.1,208.96,12.8,208.96,53.6,209.08,28.5,209.08,57,209.2,13,209.32,9,209.48,ON,
,209.62,0,209.62,1500,209.75,0.71,209.75,1900,209.75,5.2,209.89,12.8,209.89,54,210.05,28.5,210.05,57,210.17,13,210.29,9,210.43,ON,
,210.58,0,210.58,1500,210.71,0.71,210.71,1900,210.71,5.2,210.84,13.4,210.84,54.4,210.96,28.5,210.96,57,211.09,13,211.24,9,211.35,ON,
,211.49,0,211.49,1500,211.65,0.71,211.65,1900,211.65,5.3,211.79,13.4,211.79,54.8,211.92,28.5,211.92,57,212.05,13,212.19,9,212.32,ON,
,212.45,0,212.45,1500,212.59,0.72,212.59,1900,212.59,5.2,212.74,13.2,212.74,54.8,212.87,28.5,212.87,57,212.98,13,213.11,9,213.26,ON,
,213.38,0,213.38,1400,213.51,0.7,213.51,1800,213.51,5.4,213.65,13.2,213.65,54.8,213.79,28.5,213.79,58,213.9,12,214.01,9,214.15,ON,
,214.27,0,214.27,1300,214.41,0.7,214.41,1600,214.41,5.8,214.54,12.6,214.54,55.2,214.68,28.5,214.68,58,214.81,12,214.95,9,215.08,ON,
,215.21,0,215.21,1300,215.33,0.7,215.33,1600,215.33,5.8,215.48,13,215.48,54.8,215.62,28.5,215.62,58,215.75,12,215.87,9,216.02,ON,
,216.15,0,216.15,1300,216.29,0.71,216.29,1600,216.29,5.8,216.43,12.8,216.43,55.2,216.58,28.5,216.58,58,216.71,12,216.84,9,216.98,ON,
,217.13,0,217.13,1300,217.25,0.71,217.25,1600,217.25,5.8,217.38,13.8,217.38,55.2,217.5,28.5,217.5,58,217.63,12,217.75,8,217.88,ON,
,218,0,218,1300,218.13,0.695,218.13,1600,218.13,5.7,218.3,12.8,218.3,54.8,218.42,28.5,218.42,58,218.54,12,218.66,8,218.8,ON,
,218.92,0,218.92,1300,219.06,0.695,219.06,1600,219.06,5.7,219.19,12.8,219.19,54.8,219.34,28.5,219.34,58,219.46,12,219.59,8,219.72,ON,
,219.86,0,219.86,1400,219.99,0.7,219.99,1800,219.99,5.3,220.13,13,220.13,54.8,220.27,28.5,220.27,58,220.41,12,220.54,8,220.67,ON,
,220.8,0,220.8,1500,220.94,0.7,220.94,1900,220.94,5.1,221.06,12.4,221.06,54.8,221.19,28.5,221.19,58,221.3,12,221.44,8,221.58,ON,
,221.72,0,221.72,1600,221.86,0.69,221.86,1900,221.86,4.9,222,13,222,54.8,222.12,28.5,222.12,58,222.24,12,222.36,8,222.48,ON,
,222.63,0,222.63,1400,222.75,0.69,222.75,1800,222.75,5.3,222.88,12.8,222.88,54.8,223,28.5,223,59,223.15,12,223.27,8,223.4,ON,
,223.53,0,223.53,1100,223.67,0.69,223.67,1300,223.67,6,223.8,12.6,223.8,54.4,223.93,28.5,223.93,59,224.07,11,224.2,8,224.33,ON,
,224.46,0,224.46,800,224.6,0.695,224.6,1100,224.6,6.5,224.76,12.4,224.76,54,224.88,28.5,224.88,59,224.99,11,225.12,8,225.27,ON,
,225.39,0,225.39,700,225.53,0.685,225.53,900,225.53,6.5,225.64,12,225.64,54,225.78,28.5,225.78,59,225.9,12,226.02,8,226.15,ON,
,226.27,0,226.27,800,226.42,0.685,226.42,1000,226.42,6.4,226.55,12,226.55,53.2,226.69,28.5,226.69,59,226.8,12,226.95,8,227.09,ON,
,227.2,0,227.2,800,227.33,0.685,227.33,1000,227.33,7,227.47,12.8,227.47,52.8,227.59,28.5,227.59,59,227.71,12,227.83,8,227.95,ON,
,228.09,0,228.09,800,228.22,0.69,228.22,1000,228.22,6.4,228.34,12,228.34,52.4,228.47,28.5,228.47,59,228.6,12,228.72,8,228.86,ON,
,228.98,0,228.98,800,229.13,0.69,229.13,1000,229.13,6.4,229.26,11.8,229.26,52.4,229.39,28.5,229.39,59,229.5,11,229.65,8,229.78,ON,
,229.9,0,229.9,800,230.03,0.69,230.03,1000,230.03,6.4,230.17,12.2,230.17,52,230.3,28.5,230.3,59,230.43,11,230.55,7,230.7,ON,
,230.83,0,230.83,800,230.97,0.68,230.97,1000,230.97,7,231.11,12,231.11,51.6,231.25,28.5,231.25,60,231.38,11,231.51,8,231.64,ON,
,231.8,0,231.8,800,231.93,0.695,231.93,1000,231.93,6.4,232.06,12.2,232.06,51.6,232.19,29,232.19,60,232.33,11,232.45,8,232.59,ON,
,232.71,0,232.71,800,232.86,0.695,232.86,1000,232.86,6.5,233,12.2,233,51.2,233.14,29,233.14,60,233.27,11,233.41,7,233.54,ON,
,233.67,0,233.67,800,233.81,0.685,233.81,1000,233.81,6.2,233.95,12,233.95,51.2,234.07,29,234.07,60,234.19,12,234.31,7,234.46,ON,
,234.59,0,234.59,800,234.71,0.685,234.71,1000,234.71,6.4,234.84,13,234.84,51.2,234.98,29,234.98,60,235.11,11,235.23,8,235.35,ON,
,235.49,0,235.49,800,235.62,0.695,235.62,1000,235.62,7.3,235.74,12.2,235.74,51.2,235.87,29,235.87,60,236,12,236.12,8,236.23,ON,
,236.37,0,236.37,800,236.49,0.7,236.49,1000,236.49,6.5,236.63,12.2,236.63,51.2,236.76,29,236.76,60,236.89,12,237.01,8,237.15,ON,
,237.28,0,237.28,800,237.4,0.69,237.4,1000,237.4,6.4,237.53,11.8,237.53,51.2,237.68,29,237.68,60,237.79,11,237.92,7,238.05,ON,
,238.18,0,238.18,800,238.31,0.69,238.31,1000,238.31,6.5,238.43,12.2,238.43,51.2,238.56,29,238.56,60,238.7,11,238.82,7,238.94,ON,
,239.08,0,239.08,800,239.22,0.69,239.22,1000,239.22,6.5,239.35,12.2,239.35,51.2,239.48,29,239.48,60,239.59,11,239.72,8,239.85,ON,
,239.98,0,239.98,800,240.11,0.71,240.11,1000,240.11,7.2,240.26,12.8,240.26,51.2,240.39,29,240.39,60,240.52,12,240.64,8,240.8,ON,
,240.93,0,240.93,800,241.06,0.71,241.06,1000,241.06,6.4,241.2,13,241.2,51.2,241.34,29,241.34,60,241.47,11,241.59,7,241.73,ON,
,241.89,0,241.89,800,242.02,0.695,242.02,1000,242.02,6.5,242.16,12.2,242.16,51.2,242.27,29,242.27,60,242.41,11,242.53,7,242.66,ON,
,242.79,0,242.79,800,242.93,0.695,242.93,1000,242.93,6.4,243.05,13,243.05,51.2,243.18,29,243.18,60,243.29,12,243.4,8,243.55,ON,
,243.68,0,243.68,800,243.8,0.71,243.8,1000,243.8,6.4,243.93,12.2,243.93,51.2,244.07,29,244.07,60,244.18,12,244.29,8,244.41,ON,
,244.54,0,244.54,800,244.68,0.72,244.68,1000,244.68,6.4,244.8,12.2,244.8,51.2,244.93,29,244.93,60,245.05,12,245.19,7,245.32,ON,
,245.44,0,245.44,800,245.58,0.7,245.58,1000,245.58,6.4,245.73,12,245.73,51.2,245.87,29,245.87,60,246,12,246.12,7,246.27,ON,
,246.4,0,246.4,800,246.54,0.7,246.54,1000,246.54,6,246.68,12.2,246.68,51.2,246.83,29,246.83,61,246.95,12,247.07,7,247.21,ON,
,247.35,0,247.35,800,247.47,0.7,247.47,1000,247.47,6.5,247.6,11.8,247.6,51.2,247.72,29,247.72,61,247.85,11,247.98,7,248.11,ON,
,248.24,0,248.24,800,248.39,0.71,248.39,1000,248.39,6.7,248.52,11.8,248.52,51.2,248.64,29,248.64,61,248.76,11,248.9,7,249.03,ON,
,249.16,0,249.16,800,249.3,0.71,249.3,1000,249.3,6.5,249.44,11.8,249.44,51.2,249.55,29,249.55,61,249.68,12,249.8,7,249.92,ON,
,250.07,0,250.07,800,250.2,0.71,250.2,1000,250.2,6.5,250.33,11.8,250.33,51.2,250.45,29,250.45,61,250.59,12,250.71,7,250.85,ON,
,250.99,0,250.99,800,251.14,0.71,251.14,1000,251.14,6.5,251.27,11.8,251.27,51.2,251.4,29,251.4,61,251.55,11,251.68,7,251.81,ON,
,251.95,0,251.95,800,252.09,0.72,252.09,1000,252.09,6.4,252.24,12.2,252.24,51.2,252.37,29,252.37,61,252.5,11,252.62,7,252.77,ON,
,252.9,0,252.9,800,253.04,0.72,253.04,1000,253.04,6.4,253.18,12.2,253.18,51.2,253.33,29,253.33,61,253.45,11,253.57,7,253.71,ON,
,253.87,0,253.87,800,253.99,0.72,253.99,1000,253.99,7.3,254.14,12.2,254.14,51.2,254.25,29,254.25,61,254.39,12,254.51,7,254.65,ON,
,254.77,0,254.77,800,254.91,0.72,254.91,1000,254.91,7.3,255.04,12.2,255.04,51.2,255.19,29,255.19,61,255.31,11,255.46,7,255.6,ON,
,255.74,0,255.74,800,255.88,0.73,255.88,1000,255.88,6.2,256.03,12.2,256.03,51.2,256.16,29,256.16,62,256.27,11,256.4,7,256.55,ON,
,256.67,0,256.67,800,256.8,0.73,256.8,1000,256.8,6.4,256.92,12.2,256.92,51.2,257.07,29,257.07,62,257.19,12,257.3,7,257.42,ON,
,257.55,0,257.55,800,257.69,0.73,257.69,1000,257.69,6.5,257.83,12.2,257.83,51.2,257.97,29,257.97,62,258.08,12,258.21,7,258.34,ON,
,258.47,0,258.47,800,258.59,0.73,258.59,1000,258.59,6.4,258.74,12.2,258.74,51.2,258.87,29,258.87,62,258.99,11,259.11,7,259.25,ON,
,259.37,0,259.37,800,259.5,0.73,259.5,1000,259.5,6.5,259.62,12,259.62,51.2,259.77,29,259.77,62,259.89,12,260,7,260.13,ON,
,260.28,0,260.28,800,260.4,0.74,260.4,1000,260.4,6.5,260.53,13.2,260.53,51.2,260.65,29,260.65,62,260.79,12,260.91,7,261.04,ON,
,261.18,0,261.18,800,261.33,0.74,261.33,1000,261.33,6.5,261.47,12,261.47,51.6,261.61,29,261.61,62,261.74,12,261.88,7,262.01,ON,
,262.14,0,262.14,800,262.26,0.74,262.26,1000,262.26,6.5,262.4,11.8,262.4,51.2,262.53,29.5,262.53,62,262.66,12,262.78,7,262.93,ON,
,263.06,0,263.06,800,263.18,0.74,263.18,1000,263.18,6.7,263.31,12.4,263.31,51.6,263.45,29.5,263.45,62,263.56,11,263.69,7,263.83,ON,
,263.98,0,263.98,800,264.1,0.75,264.1,1000,264.1,6.7,264.22,11.8,264.22,51.6,264.35,29.5,264.35,62,264.49,12,264.61,7,264.74,ON,
,264.86,0,264.86,800,265,0.75,265,1000,265,6.5,265.12,12.2,265.12,51.6,265.26,29.5,265.26,62,265.37,11,265.52,7,265.65,ON,
,265.76,0,265.76,800,265.89,0.75,265.89,1000,265.89,6.2,266.03,12.2,266.03,51.6,266.15,29.5,266.15,62,266.28,12,266.4,7,266.52,ON,
,266.66,0,266.66,800,266.79,0.75,266.79,1000,266.79,6.7,266.92,12,266.92,51.6,267.04,29.5,267.04,62,267.19,11,267.3,7,267.43,ON,
,267.56,0,267.56,800,267.7,0.75,267.7,1000,267.7,6.4,267.83,12.2,267.83,52,267.97,29.5,267.97,62,268.1,11,268.24,7,268.37,ON,
,268.5,0,268.5,800,268.64,0.76,268.64,1000,268.64,6.7,268.78,12.4,268.78,52,268.9,29.5,268.9,62,269.02,12,269.14,7,269.29,ON,
,269.42,0,269.42,800,269.56,0.76,269.56,1000,269.56,6.7,269.68,12.4,269.68,52,269.82,29.5,269.82,62,269.94,12,270.06,7,270.2,ON,
,270.34,0,270.34,800,270.46,0.76,270.46,1000,270.46,7.3,270.59,12.4,270.59,52,270.71,29.5,270.71,62,270.84,11,270.97,7,271.1,ON,
,271.23,0,271.23,800,271.37,0.76,271.37,1000,271.37,6.5,271.49,12.4,271.49,52,271.62,29.5,271.62,62,271.73,11,271.84,8,271.99,ON,
,272.12,0,272.12,800,272.24,0.79,272.24,1000,272.24,6.8,272.37,12.6,272.37,52,272.53,29.5,272.53,62,272.65,11,272.78,8,272.91,ON,
,273.06,0,273.06,800,273.2,0.79,273.2,1000,273.2,6.7,273.34,13.4,273.34,52,273.48,29.5,273.48,63,273.62,11,273.75,7,273.88,ON,
,274.01,0,274.01,800,274.15,0.77,274.15,1000,274.15,6.7,274.27,12.4,274.27,52,274.4,29.5,274.4,63,274.53,11,274.67,7,274.8,ON,
,274.93,0,274.93,800,275.05,0.77,275.05,1000,275.05,6.7,275.19,12,275.19,52,275.32,29.5,275.32,63,275.44,11,275.56,8,275.71,ON,
,275.83,0,275.83,800,275.96,0.8,275.96,1000,275.96,6.8,276.08,12.4,276.08,52,276.23,29.5,276.23,63,276.35,11,276.49,8,276.61,ON,
,276.76,0,276.76,800,276.9,0.8,276.9,1000,276.9,6.7,277.04,12.6,277.04,52,277.18,29.5,277.18,63,277.32,11,277.45,7,277.58,ON,
,277.71,0,277.71,800,277.85,0.78,277.85,1000,277.85,6.8,277.97,12.6,277.97,52.4,278.1,29.5,278.1,63,278.23,11,278.37,7,278.5,ON,
,278.62,0,278.62,800,278.74,0.78,278.74,1000,278.74,6.8,278.88,13.4,278.88,52.4,279.01,29.5,279.01,63,279.13,11,279.26,8,279.41,ON,
,279.53,0,279.53,800,279.65,0.8,279.65,1000,279.65,6.8,279.77,12.6,279.77,52.4,279.91,29.5,279.91,63,280.04,11,280.15,8,280.29,ON,
,280.43,0,280.43,800,280.55,0.81,280.55,1000,280.55,6.8,280.68,12.6,280.68,52.4,280.8,29.5,280.8,63,280.93,11,281.04,7,281.18,ON,
,281.32,0,281.32,800,281.47,0.79,281.47,1000,281.47,6.8,281.6,12.6,281.6,52.4,281.73,29.5,281.73,63,281.86,11,282,7,282.13,ON,
,282.26,0,282.26,800,282.4,0.79,282.4,1000,282.4,6.4,282.55,12.4,282.55,52.4,282.68,30,282.68,63,282.81,11,282.93,7,283.08,ON,
,283.21,0,283.21,800,283.35,0.79,283.35,1000,283.35,6.8,283.47,12.6,283.47,52.4,283.62,30,283.62,63,283.74,11,283.85,8,283.97,ON,
,284.1,0,284.1,800,284.25,0.82,284.25,1000,284.25,7.5,284.38,12.6,284.38,52.4,284.5,30,284.5,63,284.62,11,284.76,8,284.89,ON,
,285.02,0,285.02,800,285.14,0.82,285.14,1000,285.14,7.5,285.28,12.6,285.28,52.4,285.41,30,285.41,63,285.52,11,285.65,7,285.8,ON,
,285.92,0,285.92,800,286.05,0.8,286.05,1000,286.05,6.8,286.17,12.6,286.17,52.4,286.32,30,286.32,63,286.44,11,286.55,7,286.69,ON,
,286.83,0,286.83,800,286.95,0.8,286.95,1000,286.95,6.8,287.08,13.4,287.08,52.4,287.2,30,287.2,63,287.34,11,287.46,8,287.59,ON,
,287.72,0,287.72,800,287.86,0.82,287.86,1000,287.86,6.7,287.98,13.4,287.98,52.4,288.11,30,288.11,63,288.22,11,288.33,8,288.5,ON,
,288.63,0,288.63,800,288.77,0.82,288.77,1000,288.77,6.7,288.91,12,288.91,52.4,289.06,30,289.06,63,289.18,11,289.3,7,289.44,ON,
,289.59,0,289.59,800,289.72,0.8,289.72,1000,289.72,6.4,289.86,12.4,289.86,52.4,289.98,30,289.98,63,290.11,11,290.24,7,290.37,ON,
,290.5,0,290.5,800,290.66,0.8,290.66,1000,290.66,6.8,290.79,12.6,290.8,52.4,290.92,30,290.92,63,291.03,11,291.16,7,291.29,ON,
,291.42,0,291.42,800,291.54,0.8,291.54,1000,291.54,6.8,291.68,12.4,291.68,52.4,291.83,30,291.83,63,291.96,11,292.09,8,292.23,ON,
,292.37,0,292.37,1500,292.5,0.82,292.5,2000,292.5,4.9,292.64,12.6,292.64,52.4,292.78,30,292.78,63,292.9,11,293.02,8,293.14,ON,
,293.27,0,293.27,1800,293.42,0.8,293.42,2300,293.42,4.2,293.55,13.4,293.56,52.8,293.69,30,293.69,63,293.8,11,293.93,7,294.06,ON,
,294.19,0,294.19,2100,294.31,0.8,294.31,2800,294.31,2.9,294.46,13.6,294.46,53.6,294.59,30,294.59,63,294.71,11,294.83,7,294.98,ON,
,295.11,0,295.11,1800,295.23,0.8,295.23,2300,295.23,4.3,295.36,14.2,295.36,54,295.5,30,295.5,63,295.61,11,295.74,8,295.87,ON,
,296.03,0,296.03,2000,296.15,0.82,296.15,2700,296.15,2.9,296.28,13.6,296.28,54.8,296.4,30,296.4,63,296.55,11,296.66,8,296.8,ON,
,296.94,0,296.94,2400,297.09,0.82,297.09,3100,297.09,1.8,297.22,13.8,297.22,55.2,297.36,30,297.36,63,297.49,11,297.63,7,297.76,ON,
,297.89,0,297.89,1800,298.01,0.8,298.01,2300,298.01,4.3,298.15,13.8,298.15,55.6,298.28,30,298.28,63,298.41,11,298.53,7,298.69,ON,
,298.82,0,298.82,1800,298.95,0.8,298.95,2400,298.95,3.9,299.07,13.6,299.07,56,299.22,30,299.22,63,299.36,10,299.47,7,299.61,ON,
,299.76,0,299.76,2000,299.89,0.81,299.89,2600,299.89,3.3,300.03,13.6,300.03,56,300.17,30,300.17,63,300.3,10,300.42,7,300.56,ON,
,300.7,0,300.7,2200,300.85,0.81,300.85,2800,300.85,2.6,300.98,13.6,300.98,56.4,301.1,30,301.1,63,301.22,10,301.36,7,301.49,ON,
,301.62,0,301.62,2300,301.74,0.79,301.74,2900,301.74,2.3,301.88,13.6,301.88,56.8,302.01,30,302.01,63,302.12,11,302.24,7,302.37,ON,
,302.52,0,302.52,1700,302.65,0.79,302.65,2200,302.65,4.5,302.77,13.4,302.77,56.8,302.9,30,302.9,64,303.04,10,303.15,7,303.28,ON,
,303.41,0,303.41,1700,303.57,0.81,303.57,2200,303.57,4.5,303.7,13.4,303.7,56.8,303.84,29.5,303.84,64,303.97,10,304.11,7,304.24,ON,
,304.37,0,304.37,1800,304.51,0.82,304.51,2300,304.51,4.2,304.66,12.8,304.66,56.8,304.79,29.5,304.79,64,304.92,10,305.04,7,305.17,ON,
,305.29,0,305.29,1800,305.43,0.8,305.43,2300,305.43,4.1,305.55,12.8,305.55,56.8,305.69,29.5,305.69,64,305.81,10,305.93,7,306.04,ON,
,306.17,0,306.17,1800,306.32,0.8,306.32,2300,306.32,4,306.44,13.4,306.44,56.8,306.57,29.5,306.57,64,306.7,10,306.83,7,306.96,ON,
,307.09,0,307.09,1800,307.21,0.8,307.21,2300,307.21,4.2,307.35,13.4,307.35,56.4,307.48,29.5,307.48,64,307.6,10,307.73,7,307.87,ON,
,307.99,0,307.99,1800,308.12,0.81,308.12,2300,308.12,4.1,308.24,13,308.24,56.4,308.39,29.5,308.39,64,308.52,10,308.64,7,308.77,ON,
,308.92,0,308.92,1900,309.06,0.81,309.06,2400,309.06,3.8,309.2,13.2,309.2,56.4,309.34,29.5,309.34,65,309.49,10,309.61,7,309.74,ON,
,309.87,0,309.87,1900,310.03,0.79,310.03,2400,310.03,3.6,310.15,14,310.15,56.4,310.28,29.5,310.28,65,310.39,10,310.53,7,310.66,ON,
,310.8,0,310.8,1900,310.91,0.79,310.91,2400,310.91,3.8,311.07,12.6,311.07,56,311.19,29.5,311.19,65,311.32,10,311.43,7,311.6,ON,
,311.72,0,311.72,1900,311.86,0.82,311.86,2400,311.86,3.8,311.99,13,311.99,56,312.14,29.5,312.14,65,312.26,9,312.39,7,312.52,ON,
,312.66,0,312.66,1900,312.79,0.82,312.79,2400,312.79,4,312.93,13.2,312.93,55.6,313.07,29.5,313.07,65,313.22,10,313.34,7,313.47,ON,
,313.6,0,313.6,1900,313.76,0.8,313.76,2400,313.76,3.8,313.9,13.2,313.9,55.6,314.04,29.5,314.04,65,314.18,10,314.31,7,314.45,ON,
,314.57,0,314.57,1800,314.71,0.8,314.71,2300,314.71,4.1,314.85,13,314.85,55.6,314.98,29.5,314.98,66,315.1,9,315.24,7,315.4,ON,
,315.53,0,315.53,1800,315.66,0.8,315.66,2300,315.66,4.1,315.78,12.8,315.78,55.2,315.93,29.5,315.93,66,316.05,10,316.16,7,316.3,ON,
,316.44,0,316.44,1800,316.56,0.81,316.56,2300,316.56,4.3,316.69,13.6,316.69,55.2,316.81,29.5,316.81,66,316.95,10,317.07,7,317.2,ON,
,317.33,0,317.33,1800,317.47,0.79,317.47,2300,317.47,4.1,317.59,13,317.59,55.2,317.72,29.5,317.72,66,317.84,9,317.98,6,318.11,ON,
,318.23,0,318.23,1900,318.37,0.79,318.37,2400,318.37,3.5,318.52,13,318.52,55.2,318.66,29.5,318.66,66,318.79,9,318.91,6,319.06,ON,
,319.19,0,319.19,1900,319.33,0.81,319.33,2400,319.33,3.8,319.47,13.8,319.47,55.2,319.63,29.5,319.63,66,319.75,9,319.86,7,319.97,ON,
,320.11,0,320.11,1800,320.27,0.82,320.27,2300,320.27,4,320.4,13,320.4,55.2,320.53,29.5,320.53,67,320.64,9,320.76,7,320.89,ON,
,321.02,0,321.02,1800,321.15,0.82,321.15,2300,321.15,4,321.29,13,321.29,55.2,321.43,29.5,321.43,67,321.56,9,321.68,6,321.83,ON,
,321.96,0,321.96,1800,322.1,0.8,322.1,2300,322.1,4.3,322.25,13,322.25,55.2,322.39,29.5,322.39,67,322.52,9,322.65,6,322.78,ON,
,322.92,0,322.92,1800,323.05,0.78,323.05,2300,323.05,4.1,323.17,13,323.17,55.2,323.3,29.5,323.3,68,323.43,9,323.55,6,323.67,ON,
,323.81,0,323.81,1800,323.92,0.81,323.92,2300,323.92,4,324.07,13,324.07,55.2,324.19,29.5,324.19,68,324.33,9,324.46,6,324.62,ON,
,324.75,0,324.75,1800,324.88,0.81,324.88,2300,324.88,3.9,325.02,13,325.02,55.2,325.17,29,325.17,68,325.29,9,325.41,6,325.55,ON,
,325.69,0,325.69,1700,325.83,0.79,325.83,2200,325.83,4.3,325.97,13.8,325.97,55.2,326.09,29,326.09,69,326.23,9,326.35,6,326.48,ON,
,326.61,0,326.61,1700,326.75,0.79,326.75,2200,326.75,4.1,326.87,12.8,326.87,55.2,327,29,327,69,327.11,9,327.25,6,327.39,ON,
,327.53,0,327.53,1700,327.65,0.81,327.65,2200,327.65,4.3,327.8,12.8,327.8,54.8,327.93,29,327.93,69,328.05,9,328.18,6,328.33,ON,
,328.47,0,328.47,1700,328.61,0.82,328.61,2200,328.61,4.3,328.76,12.4,328.76,54.8,328.9,29,328.9,69,329.02,9,329.14,6,329.29,ON,
,329.43,0,329.43,1700,329.56,0.8,329.56,2200,329.56,4.3,329.7,12.8,329.7,54.8,329.82,29,329.82,69,329.96,8,330.08,6,330.21,ON,
,330.34,0,330.34,1700,330.5,0.8,330.5,2200,330.5,4.3,330.64,12.2,330.64,54.4,330.78,29,330.78,69,330.91,8,331.05,6,331.18,ON,
,331.31,0,331.31,1700,331.45,0.8,331.45,2200,331.45,4.3,331.6,12.8,331.6,54.4,331.73,29,331.73,69,331.87,9,331.98,6,332.12,ON,
,332.24,0,332.24,1700,332.37,0.81,332.37,2200,332.37,4.3,332.49,12.2,332.49,54.4,332.64,29,332.64,70,332.76,9,332.89,6,333.01,ON,
,333.16,0,333.16,1600,333.31,0.81,333.31,2000,333.31,4.8,333.45,12.8,333.45,54,333.59,29,333.59,70,333.73,8,333.85,6,333.98,ON,
,334.11,0,334.11,1600,334.26,0.79,334.26,1900,334.26,5,334.39,12,334.39,54,334.51,29,334.51,70,334.64,8,334.77,6,334.9,ON,
,335.03,0,335.03,1500,335.15,0.79,335.15,1800,335.15,5.3,335.29,12.6,335.29,54,335.42,29,335.42,70,335.54,9,335.66,6,335.81,ON,
,335.93,0,335.93,1300,336.06,0.82,336.06,1600,336.06,5.6,336.18,12.6,336.18,53.6,336.32,29,336.32,70,336.44,9,336.56,6,336.7,ON,
,336.84,0,336.84,1200,336.96,0.82,336.96,1500,336.96,5.5,337.09,12,337.09,53.6,337.21,29,337.21,71,337.34,8,337.47,6,337.6,ON,
,337.73,0,337.73,1000,337.88,0.8,337.88,1300,337.88,6.1,338.01,12.2,338.01,53.2,338.13,29,338.13,71,338.25,8,338.39,6,338.53,ON,
,338.67,0,338.67,1100,338.81,0.8,338.81,1400,338.81,5.8,338.96,12,338.96,53.2,339.09,29,339.09,71,339.22,9,339.35,6,339.49,ON,
,339.62,0,339.62,800,339.76,0.82,339.76,1000,339.76,6.4,339.88,12,339.88,52.8,340.03,29,340.03,71,340.15,9,340.28,6,340.41,ON,
,340.56,0,340.56,800,340.7,0.82,340.7,1000,340.7,6.4,340.82,12,340.82,52.4,340.94,29,340.94,71,341.08,9,341.21,6,341.33,ON,
,341.47,0,341.47,800,341.6,0.8,341.6,1000,341.6,6.4,341.73,12,341.73,52,341.87,29,341.87,72,342.01,8,342.15,6,342.29,ON,
,342.43,0,342.43,800,342.57,0.8,342.57,1000,342.57,6.4,342.73,12,342.73,51.6,342.87,29,342.87,72,343,9,343.12,6,343.27,ON,
,343.4,0,343.4,800,343.54,0.82,343.54,1000,343.54,6.4,343.68,12.8,343.68,51.6,343.83,29,343.83,72,343.95,9,344.07,6,344.21,ON,
,344.35,0,344.35,800,344.49,0.82,344.49,1000,344.49,6.2,344.63,12.2,344.63,51.6,344.75,29,344.75,72,344.89,9,345.01,6,345.14,ON,
,345.27,0,345.27,800,345.42,0.82,345.42,1000,345.42,6.5,345.55,12.2,345.55,51.6,345.68,29.5,345.68,72,345.81,9,345.95,6,346.08,ON,
,346.21,0,346.21,800,346.35,0.82,346.35,1000,346.35,6.5,346.5,12.4,346.5,51.6,346.63,29.5,346.63,72,346.76,9,346.88,6,347.01,ON,
,347.14,0,347.14,800,347.27,0.82,347.27,1000,347.27,6.8,347.41,12.4,347.41,51.6,347.57,29.5,347.57,72,347.7,9,347.81,6,347.94,ON,
,348.09,0,348.09,800,348.24,0.82,348.24,1000,348.24,6.8,348.38,12.2,348.38,51.6,348.52,29.5,348.52,72,348.66,9,348.79,6,348.91,ON,
,349.04,0,349.04,800,349.19,0.82,349.19,1000,349.19,6.7,349.32,12.6,349.32,51.6,349.44,29.5,349.44,72,349.56,9,349.7,6,349.83,ON,
,349.96,0,349.96,800,350.08,0.82,350.08,1000,350.08,6.8,350.22,12.6,350.22,52,350.35,29.5,350.35,72,350.48,9,350.6,6,350.75,ON,
,350.88,0,350.88,800,351,0.82,351,1000,351,7.5,351.13,13.6,351.13,52,351.27,29.5,351.27,72,351.38,9,351.51,6,351.64,ON,
,351.79,0,351.79,800,351.92,0.82,351.92,1000,351.92,6.4,352.05,12.6,352.05,52,352.18,29.5,352.18,72,352.32,9,352.45,6,352.58,ON,
,352.71,0,352.71,800,352.86,0.82,352.86,1000,352.86,6.8,352.99,12.6,352.99,52,353.13,30,353.13,72,353.26,9,353.4,6,353.53,ON,
,353.66,0,353.66,800,353.8,0.82,353.8,1000,353.8,6.8,353.94,12.6,353.94,52,354.06,30,354.06,72,354.18,10,354.3,6,354.46,ON,
,354.59,0,354.59,800,354.73,0.82,354.73,1000,354.73,6.8,354.84,12.6,354.84,52.4,354.98,30,354.98,72,355.1,9,355.22,6,355.34,ON,
,355.47,0,355.47,800,355.63,0.82,355.63,1000,355.63,6.8,355.77,12.6,355.77,52.4,355.91,30,355.91,72,356.05,9,356.19,6,356.33,ON,
,356.47,0,356.47,800,356.61,0.82,356.61,1000,356.61,7.5,356.76,13.6,356.76,52.4,356.89,30,356.89,73,357,9,357.13,6,357.28,ON,
,357.4,0,357.4,800,357.53,0.82,357.53,1000,357.53,6.4,357.65,12.6,357.65,52.4,357.8,30,357.8,73,357.93,10,358.05,6,358.19,ON,
,358.34,0,358.34,800,358.47,0.82,358.47,1000,358.47,6.8,358.61,12.6,358.61,52.4,358.75,30.5,358.75,73,358.89,10,359,6,359.14,ON,
,359.28,0,359.28,800,359.42,0.82,359.42,1000,359.42,6.8,359.54,12.6,359.54,52.4,359.67,30.5,359.67,73,359.78,9,359.92,7,360.04,ON,
,360.16,0,360.16,800,360.29,0.82,360.29,1000,360.29,7.5,360.42,12.6,360.42,52.4,360.58,30.5,360.58,73,360.7,9,360.83,7,360.96,ON,
,361.1,0,361.1,800,361.24,0.82,361.24,1000,361.24,6.4,361.39,12.6,361.39,52.4,361.52,30.5,361.52,73,361.67,10,361.8,6,361.92,ON,
,362.05,0,362.05,800,362.19,0.82,362.19,1000,362.19,6.4,362.31,12.6,362.31,52.4,362.44,30.5,362.44,73,362.58,10,362.72,6,362.84,ON,
,362.97,0,362.97,800,363.09,0.82,363.09,1000,363.09,6.7,363.23,12.6,363.23,52.4,363.36,30.5,363.36,73,363.49,9,363.61,7,363.76,ON,
,363.89,0,363.89,800,364.01,0.82,364.01,1000,364.01,6.7,364.14,12.4,364.14,52.4,364.3,30.5,364.3,73,364.42,9,364.55,7,364.69,ON,
,364.84,0,364.84,800,364.97,0.82,364.97,1000,364.97,6.7,365.12,12.6,365.12,52.4,365.25,30.5,365.25,73,365.4,10,365.52,6,365.66,ON,
,365.78,0,365.78,800,365.94,0.82,365.94,1000,365.94,6.7,366.08,12,366.08,52.8,366.21,30.5,366.21,74,366.33,10,366.47,6,366.6,ON,
,366.73,0,366.73,800,366.85,0.82,366.85,1000,366.85,6.8,367,13.4,367,52.8,367.14,31,367.14,74,367.27,9,367.39,7,367.54,ON,
,367.67,0,367.67,800,367.81,0.82,367.81,1000,367.81,6.7,367.95,12.6,367.95,52.8,368.09,31,368.09,74,368.2,10,368.33,7,368.46,ON,
,368.61,0,368.61,800,368.74,0.82,368.74,1000,368.74,6.8,368.87,12.4,368.87,52.8,368.99,31,368.99,74,369.13,10,369.25,7,369.38,ON,
,369.51,0,369.51,800,369.65,0.82,369.65,1000,369.65,6.8,369.77,12.6,369.77,52.4,369.9,31,369.9,74,370.01,10,370.12,7,370.27,ON,
,370.4,0,370.4,800,370.54,0.82,370.54,1000,370.54,6.8,370.68,12.4,370.68,52.4,370.82,31,370.82,74,370.93,9,371.04,7,371.18,ON,
,371.3,0,371.3,800,371.45,0.82,371.45,1000,371.45,6.7,371.58,12.4,371.58,52.4,371.71,31,371.71,74,371.82,10,371.95,7,372.08,ON,
,372.21,0,372.21,800,372.33,0.82,372.33,1000,372.33,6.8,372.48,12.4,372.48,52.4,372.62,31,372.62,74,372.75,10,372.87,7,373.02,ON,
,373.15,0,373.15,900,373.29,0.82,373.29,1300,373.29,6.2,373.43,12.6,373.43,52.4,373.58,31,373.58,74,373.7,10,373.82,7,373.96,ON,
,374.1,0,374.1,1200,374.22,0.82,374.22,1500,374.22,6,374.35,12.8,374.35,52.8,374.49,31,374.49,74,374.61,10,374.74,7,374.85,ON,
,374.99,0,374.99,1300,375.11,0.82,375.11,1600,375.11,5.8,375.26,14,375.26,52.8,375.39,31,375.39,74,375.51,10,375.62,7,375.76,ON,
,375.88,0,375.88,1500,376.01,0.82,376.01,2000,376.01,5.3,376.13,12.8,376.13,53.6,376.28,31,376.28,74,376.42,10,376.53,7,376.66,ON,
,376.81,0,376.81,1800,376.95,0.82,376.95,2400,376.95,4.3,377.1,14.2,377.1,54,377.23,31,377.23,74,377.38,10,377.5,7,377.63,ON,
,377.76,0,377.76,1400,377.91,0.82,377.91,1800,377.91,5.7,378.04,13.4,378.04,54.4,378.17,31,378.17,74,378.28,9,378.42,7,378.55,ON,
,378.68,0,378.68,1600,378.8,0.82,378.8,2000,378.8,5.2,378.96,13.8,378.96,54.8,379.08,31,379.08,74,379.2,10,379.32,7,379.47,ON,
,379.6,0,379.6,1800,379.72,0.82,379.72,2300,379.72,4.3,379.85,13.8,379.85,55.2,379.99,31,379.99,74,380.1,10,380.23,7,380.36,ON,
,380.52,0,380.52,1900,380.64,0.82,380.64,2400,380.64,4.1,380.77,14.6,380.77,55.6,380.9,31,380.9,74,381.04,10,381.17,7,381.3,ON,
,381.43,0,381.43,1900,381.58,0.82,381.58,2400,381.58,4.1,381.71,14,381.71,56.4,381.85,31,381.85,74,381.98,9,382.12,7,382.25,ON,
,382.38,0,382.38,1400,382.52,0.82,382.52,1800,382.52,5.9,382.66,13.6,382.66,57.2,382.78,31,382.78,75,382.9,9,383.02,7,383.17,ON,
,383.3,0,383.3,1300,383.42,0.82,383.42,1600,383.42,6.4,383.55,14,383.55,57.6,383.69,31,383.69,75,383.8,10,383.91,7,384.05,ON,
,384.21,0,384.21,1300,384.34,0.82,384.34,1600,384.34,6.3,384.47,14,384.47,58,384.59,31,384.59,75,384.73,10,384.85,7,384.98,ON,
,385.11,0,385.11,1400,385.25,0.82,385.25,1800,385.25,5.8,385.38,14,385.38,58,385.52,31,385.52,75,385.65,9,385.79,7,385.92,ON,
,386.05,0,386.05,1600,386.19,0.82,386.19,2000,386.19,5.2,386.34,13.4,386.34,58,386.48,31,386.48,75,386.6,9,386.72,7,386.88,ON,
,387.01,0,387.01,1700,387.14,0.82,387.14,2200,387.14,4.7,387.26,14,387.26,58.4,387.39,30.5,387.39,75,387.52,9,387.64,7,387.76,ON,
,387.92,0,387.92,1900,388.04,0.82,388.04,2400,388.04,4.1,388.17,14,388.17,58.4,388.29,30.5,388.29,75,388.43,9,388.54,7,388.69,ON,
,388.83,0,388.83,2000,388.98,0.82,388.98,2600,388.98,3.4,389.11,14,389.11,58.8,389.25,30.5,389.25,75,389.37,9,389.51,6,389.64,ON,
,389.77,0,389.77,2000,389.89,0.82,389.89,2400,389.89,4,390.03,13.8,390.03,59.2,390.16,30.5,390.16,75,390.29,9,390.41,6,390.55,ON,
,390.67,0,390.67,1500,390.8,0.82,390.8,2000,390.8,5.7,390.92,14,390.92,59.2,391.06,30.5,391.06,75,391.18,9,391.3,7,391.44,ON,
,391.58,0,391.58,1700,391.7,0.82,391.7,2200,391.7,4.3,391.83,12.8,391.83,58.8,391.95,30.5,391.95,75,392.08,9,392.21,7,392.34,ON,
,392.47,0,392.47,1700,392.61,0.82,392.61,2200,392.61,4.5,392.73,13.4,392.73,58.4,392.86,30.5,392.86,75,392.97,9,393.12,6,393.25,ON,
,393.37,0,393.37,1800,393.5,0.82,393.5,2300,393.5,4.3,393.64,13.4,393.64,58,393.76,30.5,393.76,75,393.88,9,394,6,394.16,ON,
,394.29,0,394.29,1900,394.42,0.82,394.42,2400,394.42,3.9,394.54,13.4,394.54,57.6,394.69,30.5,394.69,75,394.82,8,394.94,6,395.08,ON,
,395.23,0,395.23,1900,395.36,0.82,395.36,2400,395.36,3.9,395.5,13.4,395.5,57.2,395.64,30,395.64,75,395.78,9,395.91,6,396.04,ON,
,396.17,0,396.17,1900,396.31,0.82,396.31,2400,396.31,3.9,396.43,13.2,396.43,57.2,396.56,30,396.56,75,396.69,9,396.83,6,396.96,ON,
,397.1,0,397.1,1900,397.21,0.82,397.21,2400,397.21,3.9,397.36,13.4,397.36,57.2,397.49,30,397.49,75,397.62,8,397.73,6,397.87,ON,
,397.99,0,397.99,1900,398.12,0.82,398.12,2400,398.12,3.9,398.24,13.4,398.24,56.8,398.39,30,398.39,75,398.52,8,398.65,6,398.78,ON,
,398.93,0,398.93,1900,399.06,0.82,399.06,2400,399.06,3.9,399.18,14,399.18,56.8,399.31,30,399.31,75,399.45,9,399.58,6,399.71,ON,
,399.84,0,399.84,1900,400,0.82,400,2400,400,3.9,400.13,13.4,400.13,56.8,400.26,30,400.26,75,400.37,9,400.53,6,400.66,ON,
,400.79,0,400.79,1900,400.91,0.82,400.91,2400,400.91,3.9,401.06,13.4,401.06,56.8,401.19,30,401.19,75,401.31,8,401.44,6,401.59,ON,
,401.73,0,401.73,1900,401.86,0.82,401.86,2400,401.86,3.9,402,13.4,402,56.8,402.15,30,402.15,76,402.28,8,402.4,6,402.54,ON,
,402.69,0,402.69,1900,402.82,0.82,402.82,2400,402.82,3.9,402.95,13.4,402.95,56.4,403.08,30,403.08,76,403.21,9,403.34,6,403.46,ON,
,403.59,0,403.59,1900,403.73,0.82,403.73,2400,403.73,3.8,403.86,13.4,403.86,56.4,403.98,30,403.98,76,404.11,9,404.2,6,404.36,ON,
,404.49,0,404.49,1900,404.62,0.82,404.62,2400,404.62,3.9,404.75,13.4,404.75,56.8,404.89,30,404.89,76,405.02,8,405.14,6,405.28,ON,
,405.44,0,405.44,1900,405.56,0.82,405.56,2400,405.56,3.9,405.71,13.4,405.71,56.8,405.84,30,405.84,77,405.98,9,406.09,6,406.22,ON,
,406.35,0,406.35,1900,406.5,0.8,406.5,2400,406.5,3.9,406.63,14.2,406.63,56.8,406.76,30,406.76,77,406.87,8,407.01,6,407.13,ON,
,407.27,0,407.27,1900,407.4,0.82,407.4,2400,407.4,3.9,407.55,13.6,407.55,56.8,407.68,30,407.68,77,407.79,8,407.92,6,408.07,ON,
,408.19,0,408.19,1900,408.32,0.82,408.32,2400,408.32,4.1,408.44,14,408.44,56.8,408.59,30,408.59,78,408.72,8,408.84,6,408.98,ON,
,409.13,0,409.13,1900,409.26,0.8,409.26,2400,409.26,3.9,409.4,13.4,409.4,56.8,409.54,30,409.54,78,409.68,8,409.81,6,409.94,ON,
,410.07,0,410.07,1900,410.23,0.8,410.23,2400,410.23,3.9,410.36,13.4,410.36,56.8,410.49,30,410.49,78,410.6,8,410.75,6,410.89,ON,
,411,0,411,1900,411.14,0.8,411.14,2400,411.14,3.9,411.27,12.8,411.27,56.8,411.39,30,411.39,78,411.51,8,411.63,6,411.75,ON,
,411.89,0,411.89,1900,412.02,0.81,412.02,2400,412.02,3.9,412.14,13.4,412.14,56.8,412.27,30,412.27,78,412.4,8,412.52,6,412.64,ON,
,412.77,0,412.77,1900,412.93,0.81,412.93,2400,412.93,4.1,413.07,13,413.07,56.8,413.21,30,413.21,78,413.34,8,413.48,6,413.61,ON,
,413.74,0,413.74,1900,413.88,0.81,413.88,2400,413.88,3.9,414.04,13.4,414.04,57.2,414.17,30,414.17,78,414.29,8,414.41,6,414.55,ON,
,414.67,0,414.67,1900,414.81,0.81,414.81,2400,414.81,3.9,414.94,13.4,414.94,56.8,415.1,30,415.1,79,415.22,8,415.33,6,415.44,ON,
,415.6,0,415.6,1900,415.72,0.81,415.72,2400,415.72,3.8,415.86,13.4,415.86,56.8,415.98,29.5,415.98,79,416.13,8,416.26,6,416.38,ON,
,416.51,0,416.51,1900,416.66,0.82,416.66,2400,416.66,3.8,416.79,13.4,416.79,56.8,416.93,30,416.93,80,417.06,8,417.2,6,417.34,ON,
,417.46,0,417.46,1900,417.58,0.82,417.58,2400,417.58,3.9,417.72,13.4,417.72,56.8,417.85,30,417.85,80,417.96,8,418.09,6,418.24,ON,
,418.38,0,418.38,1900,418.5,0.8,418.5,2400,418.5,3.8,418.63,13.2,418.63,56.4,418.77,29.5,418.77,80,418.88,7,419.01,6,419.14,ON,
,419.29,0,419.29,1900,419.42,0.82,419.42,2400,419.42,3.8,419.55,13.2,419.55,56.4,419.67,29.5,419.67,80,419.81,8,419.93,6,420.06,ON,
,420.19,0,420.19,1800,420.33,0.82,420.33,2400,420.33,4.2,420.45,13.2,420.45,56.4,420.58,29.5,420.58,81,420.69,7,420.84,6,420.97,ON,
,421.09,0,421.09,1800,421.22,0.8,421.22,2300,421.22,4.1,421.36,14,421.36,56.4,421.48,29.5,421.48,81,421.6,8,421.72,5,421.84,ON,
,421.99,0,421.99,1800,422.13,0.8,422.13,2200,422.13,4.1,422.27,13.2,422.27,56.4,422.41,29.5,422.41,81,422.55,7,422.68,5,422.81,ON,
,422.94,0,422.94,1700,423.1,0.8,423.1,2200,423.1,4.5,423.22,12.6,423.22,56,423.37,29.5,423.37,81,423.49,8,423.63,5,423.76,ON,
,423.9,0,423.9,1600,424.03,0.81,424.03,2000,424.03,5,424.18,13.2,424.18,56,424.31,29.5,424.31,81,424.43,8,424.55,5,424.7,ON,
,424.83,0,424.83,1600,424.97,0.81,424.97,2000,424.97,5,425.11,13,425.11,56,425.26,29.5,425.26,81,425.38,7,425.5,5,425.64,ON,
,425.78,0,425.78,1500,425.9,0.81,425.9,1900,425.9,5.1,426.03,13,426.03,55.6,426.17,29.5,426.17,82,426.32,7,426.44,5,426.57,ON,
,426.7,0,426.7,1500,426.84,0.81,426.84,1900,426.84,4.9,426.97,13,426.97,55.6,427.11,29.5,427.11,82,427.24,8,427.38,5,427.51,ON,
,427.64,0,427.64,1400,427.78,0.81,427.78,1800,427.78,5.5,427.93,13,427.93,55.6,428.07,29.5,428.07,82,428.19,8,428.32,5,428.46,ON,
,428.59,0,428.59,1300,428.73,0.82,428.73,1600,428.73,5.4,428.85,12.8,428.85,55.6,428.99,29.5,428.99,82,429.12,7,429.23,5,429.37,ON,
,429.51,0,429.51,1200,429.63,0.82,429.63,1500,429.63,5.9,429.75,12.8,429.75,55.2,429.88,29.5,429.88,82,430.03,7,430.15,5,430.27,ON,
,430.41,0,430.41,1200,430.56,0.8,430.56,1400,430.56,6.7,430.7,13.8,430.7,55.2,430.83,29.5,430.83,82,430.96,8,431.1,5,431.23,ON,
,431.36,0,431.36,1000,431.5,0.82,431.5,1300,431.5,6.2,431.67,12.6,431.67,54.8,431.79,29.5,431.79,82,431.91,8,432.03,5,432.17,ON,
,432.29,0,432.29,1000,432.42,0.82,432.42,1300,432.42,6.1,432.56,12,432.56,54.4,432.72,29.5,432.72,83,432.85,8,432.98,5,433.11,ON,
,433.27,0,433.27,1000,433.4,0.8,433.4,1300,433.4,5.8,433.53,12.4,433.53,54,433.67,29.5,433.67,83,433.81,7,433.92,5,434.06,ON,
1,434.18,0,434.18,800,434.31,0.8,434.31,1000,434.31,6.7,434.46,13.2,434.46,54,434.59,29.5,434.59,83,434.72,7,434.84,5,434.98,ON,
,435.1,0,435.1,800,435.23,0.82,435.23,1000,435.23,7.3,435.35,12.4,435.35,53.6,435.49,29.5,435.49,83,435.61,8,435.73,5,435.87,ON,
,436.01,0,436.01,700,436.13,0.655,436.13,900,436.13,6.5,436.26,12.2,436.26,53.6,436.38,29.5,436.38,83,436.52,8,436.64,5,436.77,ON,
,436.91,0,436.91,800,437.06,0.29,437.06,1000,437.06,7.2,437.2,13.2,437.2,53.2,437.34,29.5,437.34,83,437.47,8,437.61,5,437.74,ON,
,437.87,0,437.87,800,438.01,0.58,438.01,1000,438.01,6.5,438.16,12.2,438.16,52.8,438.29,29.5,438.29,83,438.4,8,438.53,5,438.68,ON,
,438.8,0,438.8,900,438.93,0.58,438.93,1000,438.93,6.7,439.05,12,439.05,52.4,439.19,29.5,439.19,83,439.31,8,439.43,5,439.57,ON,
,439.73,0,439.73,800,439.87,0.59,439.87,1000,439.87,6.5,440.01,12.4,440.01,52.4,440.15,29.5,440.15,83,440.29,9,440.42,5,440.55,ON,
,440.68,0,440.68,800,440.83,0.59,440.83,1000,440.83,6.7,440.96,13.2,440.96,52.4,441.08,30,441.08,83,441.2,9,441.34,5,441.47,ON,
,441.6,0,441.6,800,441.74,0.595,441.74,1000,441.74,6.8,441.89,12.4,441.89,52.4,442.02,29.5,442.02,83,442.13,10,442.24,5,442.38,ON,
,442.52,0,442.52,800,442.64,0.595,442.64,1000,442.64,6.7,442.76,12.4,442.76,52.4,442.88,30,442.88,83,443.02,11,443.14,6,443.27,ON,
,443.4,0,443.4,800,443.55,0.605,443.55,1000,443.55,6.7,443.67,12.4,443.67,52.8,443.79,30,443.79,83,443.91,11,444.05,6,444.19,ON,
,444.32,0,444.32,800,444.44,0.605,444.44,1000,444.44,6.7,444.59,12.6,444.59,52.8,444.73,30,444.73,83,444.86,12,444.98,6,445.13,ON,
,445.26,0,445.26,800,445.4,0.59,445.4,1000,445.4,6.7,445.54,12.6,445.54,52.4,445.7,30,445.7,83,445.82,12,445.93,6,446.05,ON,
,446.18,0,446.18,800,446.32,0.59,446.32,1000,446.32,7.5,446.44,12.6,446.44,52.4,446.57,30,446.57,83,446.68,12,446.82,6,446.94,ON,
,447.07,0,447.07,800,447.19,0.6,447.19,1000,447.19,6.7,447.32,12.4,447.32,52.8,447.47,30,447.47,83,447.59,13,447.71,6,447.85,ON,
,447.99,0,447.99,800,448.11,0.6,448.11,1000,448.11,6.4,448.24,12.4,448.24,52.8,448.38,30,448.38,83,448.51,13,448.63,6,448.75,ON,
,448.88,0,448.88,800,449,0.6,449,1000,449,7.5,449.14,12,449.14,52.8,449.27,30,449.27,83,449.38,13,449.51,6,449.66,ON,
,449.78,0,449.78,800,449.91,0.6,449.91,1000,449.91,6.7,450.03,12.6,450.03,52.4,450.18,30.5,450.18,83,450.3,13,450.43,6,450.56,ON,
,450.71,0,450.71,800,450.85,0.59,450.85,1000,450.85,6.5,450.99,12.4,450.99,52.4,451.13,30.5,451.13,83,451.27,13,451.4,6,451.53,ON,
,451.66,0,451.66,800,451.81,0.6,451.81,1000,451.81,6.4,451.94,12.4,451.94,52.4,452.06,30.5,452.06,83,452.18,13,452.32,6,452.45,ON,
,452.58,0,452.58,800,452.72,0.6,452.72,1000,452.72,6.8,452.86,12.6,452.86,52.4,452.98,30.5,452.98,83,453.1,13,453.22,6,453.38,ON,
,453.52,0,453.52,800,453.64,0.6,453.64,1000,453.64,7.5,453.76,12.4,453.76,52.4,453.91,30.5,453.91,83,454.05,13,454.18,6,454.32,ON,
,454.47,0,454.47,800,454.61,0.6,454.61,1000,454.61,6.7,454.75,12.4,454.75,52.4,454.87,30.5,454.87,83,455,13,455.13,6,455.26,ON,
,455.39,0,455.39,800,455.55,0.595,455.55,1000,455.55,6.7,455.68,12.4,455.68,52.4,455.8,30.5,455.8,84,455.92,14,456.04,6,456.19,ON,
,456.33,0,456.33,800,456.47,0.595,456.47,1000,456.47,6.7,456.62,12,456.62,52.4,456.74,30.5,456.74,84,456.88,14,456.99,6,457.14,ON,
,457.27,0,457.27,800,457.42,0.585,457.42,1000,457.42,6.4,457.55,12,457.55,52.4,457.7,30.5,457.7,84,457.8,13,457.92,6,458.05,ON,
,458.18,0,458.18,800,458.31,0.585,458.31,1000,458.31,6.7,458.44,12.6,458.44,52.4,458.57,30.5,458.57,84,458.68,13,458.82,6,458.96,ON,
,459.08,0,459.08,800,459.2,0.595,459.2,1000,459.2,6.7,459.34,12.2,459.34,52.4,459.47,30.5,459.47,84,459.58,14,459.71,6,459.86,ON,
,459.98,0,459.98,800,460.11,0.595,460.11,1000,460.11,7.5,460.23,12.2,460.23,52.4,460.37,30.5,460.37,84,460.49,14,460.61,6,460.75,ON,
,460.89,0,460.89,800,461.01,0.595,461.01,1000,461.01,6.8,461.14,12.4,461.14,52.4,461.26,30.5,461.26,84,461.4,13,461.52,6,461.65,ON,
,461.78,0,461.78,800,461.92,0.595,461.92,1000,461.92,6.7,462.04,12.4,462.04,52,462.17,30.5,462.17,84,462.28,13,462.43,6,462.56,ON,
,462.7,0,462.7,800,462.82,0.595,462.82,1100,462.82,6.5,462.97,12.6,462.97,52,463.11,30.5,463.11,84,463.24,14,463.36,7,463.51,ON,
,463.65,0,463.65,1500,463.78,0.605,463.78,1900,463.78,4.8,463.93,13,463.93,52.4,464.06,30.5,464.06,84,464.18,14,464.3,7,464.44,ON,
,464.58,0,464.58,1700,464.72,0.605,464.72,2300,464.72,4.2,464.85,13.4,464.85,52.8,464.98,30.5,464.98,84,465.11,13,465.23,6,465.35,ON,
,465.49,0,465.49,2100,465.6,0.58,465.6,2700,465.6,2.9,465.74,13.4,465.74,53.6,465.87,30.5,465.87,84,465.99,13,466.09,6,466.23,ON,
,466.39,0,466.39,1500,466.54,0.58,466.54,1900,466.54,5.2,466.66,12.6,466.66,54,466.8,30.5,466.8,84,466.94,14,467.06,7,467.2,ON,
,467.34,0,467.34,1800,467.49,0.59,467.49,2300,467.49,4.1,467.62,12.8,467.62,54,467.74,30.5,467.74,84,467.86,14,468,7,468.13,ON,
,468.26,0,468.26,2100,468.4,0.595,468.4,2700,468.4,2.9,468.56,13.4,468.56,54.4,468.7,30.5,468.7,84,468.83,14,468.95,7,469.1,ON,
,469.23,0,469.23,1600,469.37,0.585,469.37,2000,469.37,5,469.51,13.2,469.51,54.8,469.67,30.5,469.67,84,469.79,13,469.92,6,470.05,ON,
,470.2,0,470.2,1600,470.33,0.585,470.33,2000,470.33,5,470.46,13.2,470.46,54.8,470.57,30,470.57,84,470.7,13,470.81,6,470.94,ON,
,471.06,0,471.06,1700,471.23,0.585,471.23,2200,471.23,4.4,471.36,13.2,471.36,55.2,471.49,30,471.49,84,471.61,14,471.75,7,471.88,ON,
,472.01,0,472.01,1800,472.13,0.595,472.13,2400,472.13,3.7,472.29,13,472.29,55.2,472.42,30,472.42,84,472.55,14,472.67,7,472.82,ON,
,472.95,0,472.95,1900,473.09,0.595,473.09,2400,473.09,4.1,473.23,12.8,473.23,55.2,473.38,30,473.38,84,473.5,14,473.62,6,473.74,ON,
,473.87,0,473.87,2000,474.01,0.585,474.01,2600,474.01,3.3,474.13,13.4,474.13,55.6,474.26,30,474.26,84,474.39,13,474.53,6,474.66,ON,
,474.79,0,474.79,1400,474.92,0.57,474.92,1800,474.92,5.6,475.07,13.2,475.07,56,475.19,30,475.19,84,475.31,14,475.43,6,475.59,ON,
,475.73,0,475.73,1400,475.88,0.58,475.88,1800,475.88,5.5,476.01,13.4,476.01,56,476.17,30,476.17,84,476.29,14,476.42,7,476.55,ON,
,476.69,0,476.69,1500,476.82,0.58,476.82,1900,476.82,5,476.94,12.8,476.94,56,477.07,30,477.07,84,477.22,14,477.34,6,477.47,ON,
,477.6,0,477.6,1500,477.74,0.57,477.74,1900,477.74,5.6,477.86,14,477.86,56,477.99,30,477.99,84,478.1,13,478.24,6,478.38,ON,
,478.5,0,478.5,1500,478.63,0.57,478.63,1900,478.63,5.2,478.78,13.2,478.78,56,478.91,30,478.91,84,479.02,14,479.13,6,479.26,ON,
,479.39,0,479.39,1500,479.53,0.57,479.53,1900,479.53,5,479.66,12.6,479.66,56,479.79,30,479.79,84,479.93,14,480.05,6,480.18,ON,
,480.31,0,480.31,1500,480.46,0.57,480.46,1900,480.46,5.6,480.6,13.2,480.6,56,480.74,30,480.74,84,480.87,14,481.01,6,481.14,ON,
,481.27,0,481.27,1500,481.41,0.57,481.41,2000,481.41,5,481.56,13,481.56,55.6,481.69,30,481.69,84,481.8,13,481.93,6,482.08,ON,
,482.2,0,482.2,1600,482.33,0.57,482.33,2000,482.33,5,482.45,13.2,482.45,55.6,482.59,30,482.59,84,482.71,13,482.83,6,482.95,ON,
,483.08,0,483.08,1600,483.24,0.57,483.24,2000,483.24,4.9,483.37,13,483.37,56,483.5,30,483.5,84,483.61,14,483.73,6,483.87,ON,
,484,0,484,1600,484.14,0.57,484.14,2000,484.14,5,484.28,13,484.28,56,484.4,30,484.4,84,484.52,14,484.64,6,484.75,ON,
,484.9,0,484.9,1500,485.04,0.555,485.04,1900,485.04,5,485.17,12.8,485.17,56,485.28,30,485.28,84,485.43,13,485.54,6,485.67,ON,
,485.8,0,485.8,1500,485.94,0.555,485.94,1900,485.94,5,486.07,12.8,486.07,56,486.21,30,486.21,84,486.35,13,486.48,6,486.61,ON,
,486.74,0,486.74,1500,486.88,0.555,486.88,1900,486.88,5,487.03,12.8,487.03,56,487.16,30,487.16,84,487.28,14,487.4,6,487.55,ON,
,487.67,0,487.67,1500,487.8,0.565,487.8,1900,487.8,5,487.92,12.8,487.92,55.6,488.07,30,488.07,84,488.19,14,488.32,7,488.45,ON,
,488.59,0,488.59,1600,488.72,0.565,488.72,2000,488.72,4.8,488.85,12.8,488.85,55.6,488.97,30,488.97,84,489.1,14,489.22,6,489.36,ON,
,489.48,0,489.48,1600,489.63,0.555,489.63,2000,489.63,4.8,489.77,12.6,489.77,55.2,489.92,30,489.92,84,490.04,14,490.19,6,490.31,ON,
,490.45,0,490.45,1600,490.58,0.555,490.58,2000,490.58,4.7,490.73,12.8,490.73,55.2,490.86,30,490.86,84,490.97,14,491.1,6,491.25,ON,
,491.39,0,491.39,1600,491.51,0.565,491.51,2000,491.51,4.7,491.64,12.6,491.64,55.2,491.78,30,491.78,84,491.89,14,492,7,492.14,ON,
,492.3,0,492.3,1500,492.43,0.565,492.43,1900,492.43,4.9,492.56,12.6,492.56,54.8,492.68,30,492.68,84,492.82,14,492.94,6,493.08,ON,
,493.22,0,493.22,1500,493.37,0.555,493.37,1900,493.37,4.9,493.5,12.6,493.5,54.8,493.64,30,493.64,84,493.77,14,493.91,6,494.04,ON,
,494.17,0,494.17,1500,494.31,0.555,494.31,1900,494.31,4.9,494.46,12.6,494.46,54.8,494.59,30,494.59,84,494.7,14,494.81,6,494.93,ON,
,495.07,0,495.07,1500,495.2,0.54,495.2,1900,495.2,4.9,495.34,12.6,495.34,54.4,495.46,30,495.46,84,495.6,14,495.72,6,495.85,ON,
,495.98,0,495.98,1600,496.14,0.54,496.14,2000,496.14,4.7,496.27,12.6,496.27,54.4,496.4,30,496.4,84,496.52,14,496.66,7,496.79,ON,
,496.92,0,496.92,1600,497.06,0.55,497.06,2000,497.06,4.7,497.21,12.6,497.21,54.4,497.33,30,497.33,84,497.46,14,497.58,6,497.73,ON,
,497.87,0,497.87,1600,498.01,0.54,498.01,2000,498.01,4.7,498.15,12.8,498.15,54.4,498.28,30,498.28,84,498.39,14,498.5,6,498.64,ON,
,498.79,0,498.79,1600,498.92,0.54,498.92,2000,498.92,4.8,499.04,12.6,499.04,54,499.17,30,499.17,85,499.3,14,499.42,7,499.55,ON,
,499.68,0,499.68,1600,499.83,0.55,499.83,2000,499.83,4.7,499.97,12.8,499.97,54,500.11,30,500.11,85,500.24,14,500.38,7,500.51,ON,
,500.64,0,500.64,1700,500.78,0.55,500.78,2200,500.78,4.3,500.93,12.8,500.93,54,501.06,30,501.06,85,501.19,14,501.32,6,501.45,ON,
,501.57,0,501.57,1700,501.7,0.54,501.7,2200,501.7,4.6,501.82,13.8,501.82,54,501.96,30,501.96,85,502.08,14,502.2,6,502.34,ON,
,502.48,0,502.48,1700,502.61,0.54,502.61,2200,502.61,4.3,502.73,12.8,502.73,54.4,502.85,30,502.85,85,502.98,14,503.11,7,503.24,ON,
,503.37,0,503.37,1300,503.51,0.55,503.51,1600,503.51,5.2,503.63,12.4,503.63,54,503.76,30,503.76,85,503.87,14,504.02,7,504.15,ON,
,504.29,0,504.29,1400,504.41,0.55,504.41,1800,504.41,5.6,504.56,13.4,504.56,54,504.7,30,504.7,85,504.83,14,504.95,6,505.1,ON,
,505.24,0,505.24,1400,505.37,0.525,505.37,1800,505.37,5.1,505.52,13.2,505.52,53.6,505.66,30,505.66,85,505.79,14,505.92,6,506.05,ON,
,506.19,0,506.19,1400,506.32,0.525,506.32,1800,506.32,5.1,506.44,12.2,506.44,53.6,506.58,30,506.58,85,506.72,14,506.84,6,506.98,ON,
,507.11,0,507.11,1400,507.26,0.535,507.26,1900,507.26,5.1,507.4,12.4,507.4,53.2,507.54,30,507.54,85,507.67,15,507.81,7,507.94,ON,
,508.07,0,508.07,1500,508.21,0.535,508.21,1900,508.21,4.9,508.36,12.4,508.36,53.2,508.49,30,508.49,85,508.63,15,508.74,7,508.89,ON,
,509.02,0,509.02,1500,509.14,0.535,509.14,1900,509.14,4.9,509.27,12.6,509.27,53.2,509.41,30,509.41,85,509.52,14,509.65,6,509.78,ON,
,509.93,0,509.93,1500,510.07,0.525,510.07,1900,510.07,4.9,510.22,12.2,510.22,53.2,510.35,30,510.35,85,510.49,14,510.62,6,510.74,ON,
,510.87,0,510.87,1600,511.01,0.525,511.01,2000,511.01,4.5,511.14,12,511.14,52.8,511.27,29.5,511.27,85,511.4,15,511.54,7,511.66,ON,
,511.79,0,511.79,1600,511.92,0.535,511.92,2000,511.92,5,512.05,12.4,512.05,52.8,512.18,29.5,512.18,85,512.3,15,512.43,7,512.57,ON,
,512.69,0,512.69,1600,512.82,0.535,512.82,2000,512.82,4.7,512.94,12.4,512.94,52.8,513.08,29.5,513.08,85,513.21,14,513.32,7,513.46,ON,
,513.6,0,513.6,1600,513.72,0.525,513.72,2000,513.72,4.7,513.85,12.4,513.85,52.8,513.97,29.5,513.97,85,514.12,14,514.24,6,514.36,ON,
,514.49,0,514.49,1600,514.64,0.525,514.64,2000,514.64,4.7,514.77,12.4,514.77,52.8,514.89,29.5,514.89,85,515.01,14,515.15,7,515.29,ON,
,515.43,0,515.43,1600,515.57,0.52,515.57,2000,515.57,4.6,515.72,12.2,515.72,52.8,515.85,29.5,515.85,85,515.98,15,516.1,7,516.25,ON,
,516.38,0,516.38,1600,516.5,0.52,516.5,2000,516.5,4.6,516.63,12.2,516.63,52.4,516.78,29.5,516.78,85,516.9,14,517.02,7,517.14,ON,
,517.27,0,517.27,1600,517.41,0.52,517.41,2000,517.41,4.5,517.55,12,517.55,52.4,517.67,29.5,517.67,85,517.79,14,517.93,7,518.06,ON,
,518.19,0,518.19,1500,518.31,0.52,518.31,1900,518.31,4.4,518.46,11.8,518.46,52,518.59,29.5,518.59,85,518.71,14,518.84,7,518.99,ON,
,519.13,0,519.13,1500,519.28,0.52,519.28,1900,519.28,4.7,519.41,11.4,519.41,51.6,519.57,29.5,519.57,85,519.68,15,519.81,7,519.94,ON,
,520.1,0,520.1,1500,520.23,0.515,520.23,1900,520.23,4.7,520.36,11.6,520.36,51.2,520.48,29.5,520.48,85,520.62,15,520.74,7,520.87,ON,
,521,0,521,1500,521.15,0.515,521.15,1900,521.15,4.7,521.28,12,521.28,51.2,521.4,29.5,521.4,85,521.52,14,521.66,7,521.79,ON,
,521.92,0,521.92,1500,522.05,0.515,522.05,1900,522.05,4.7,522.2,12,522.2,51.2,522.33,29.5,522.33,86,522.46,14,522.58,7,522.73,ON,
,522.86,0,522.86,1500,523,0.515,523,1900,523,4.6,523.12,12,523.12,51.2,523.26,29.5,523.26,85,523.38,15,523.5,7,523.64,ON,
,523.78,0,523.79,1500,523.92,0.515,523.92,1900,523.92,4.7,524.04,12,524.04,50.8,524.17,29.5,524.17,86,524.32,15,524.44,7,524.57,ON,
,524.7,0,524.7,1500,524.84,0.525,524.84,1900,524.84,4.7,524.96,11.4,524.96,50.4,525.09,29.5,525.09,86,525.2,15,525.35,7,525.48,ON,
,525.6,0,525.6,1500,525.72,0.5,525.72,1900,525.72,4.7,525.86,12.8,525.86,50.4,525.98,29.5,525.98,86,526.11,14,526.23,7,526.38,ON,
,526.51,0,526.51,1500,526.64,0.5,526.64,1900,526.64,4.5,526.76,12,526.76,50.4,526.91,29.5,526.91,86,527.04,15,527.17,7,527.3,ON,
,527.45,0,527.45,1500,527.58,0.51,527.58,1900,527.58,4.7,527.72,12,527.72,50.4,527.87,29.5,527.87,86,527.99,15,528.12,7,528.25,ON,
,528.38,0,528.38,1500,528.51,0.51,528.51,1900,528.51,4.5,528.65,11.6,528.65,50.4,528.76,29.5,528.76,86,528.88,15,529.02,7,529.16,ON,
,529.28,0,529.28,1500,529.41,0.5,529.41,1900,529.41,4.7,529.54,12,529.54,50.4,529.67,29.5,529.67,86,529.78,15,529.91,7,530.06,ON,
,530.19,0,530.19,1500,530.31,0.5,530.31,1900,530.31,4.7,530.43,12,530.43,50.4,530.58,29.5,530.58,86,530.71,15,530.81,7,530.93,ON,
,531.06,0,531.06,1500,531.22,0.51,531.22,1900,531.22,4.7,531.35,12,531.35,50.4,531.48,29.5,531.48,86,531.59,15,531.74,7,531.87,ON,
,531.99,0,531.99,1500,532.12,0.51,532.12,1900,532.12,4.7,532.26,12,532.26,50.4,532.38,29.5,532.38,86,532.5,15,532.62,7,532.74,ON,
,532.89,0,532.89,1500,533.03,0.51,533.03,1900,533.03,4.7,533.17,12,533.17,50.4,533.32,29.5,533.32,86,533.45,15,533.59,7,533.71,ON,
,533.84,0,533.84,1500,533.99,0.51,533.99,1900,533.99,4.7,534.13,12,534.13,50.4,534.26,29.5,534.26,86,534.38,15,534.51,7,534.64,ON,
,534.77,0,534.77,1500,534.91,0.495,534.91,1900,534.91,4.7,535.06,12,535.06,50.4,535.19,29.5,535.19,86,535.31,15,535.43,7,535.57,ON,
,535.69,0,535.69,1500,535.82,0.495,535.82,1900,535.82,4.6,535.95,12,535.95,50.8,536.1,29.5,536.1,86,536.22,15,536.34,7,536.48,ON,
,536.63,0,536.63,1500,536.76,0.49,536.76,1900,536.76,4.7,536.9,12,536.9,50.4,537.04,29.5,537.04,86,537.18,15,537.31,7,537.44,ON,
,537.57,0,537.57,1500,537.73,0.49,537.73,1900,537.73,4.7,537.86,12,537.86,50.4,537.99,29.5,537.99,86,538.1,15,538.25,7,538.37,ON,
,538.5,0,538.5,1500,538.63,0.49,538.63,1900,538.63,4.6,538.77,12,538.77,50.4,538.89,29.5,538.89,86,539.01,15,539.13,7,539.25,ON,
,539.38,0,539.38,1400,539.51,0.49,539.51,1800,539.52,4.9,539.64,12,539.64,50.4,539.77,29.5,539.77,86,539.92,16,540.03,7,540.16,ON,
,540.29,0,540.29,1400,540.43,0.5,540.43,1800,540.43,4.9,540.56,12,540.56,50,540.7,29.5,540.7,86,540.84,16,540.97,7,541.11,ON,
,541.23,0,541.23,1400,541.37,0.49,541.37,1800,541.37,4.9,541.51,12,541.51,50,541.64,29.5,541.64,86,541.75,15,541.88,7,542.02,ON,
,542.16,0,542.16,1400,542.29,0.49,542.29,1800,542.29,4.9,542.42,12,542.42,49.6,542.56,29.5,542.56,86,542.69,15,542.81,7,542.95,ON,
,543.1,0,543.1,1400,543.22,0.5,543.22,1800,543.22,4.9,543.35,12,543.35,49.6,543.48,29.5,543.48,86,543.62,16,543.75,7,543.88,ON,
,544.01,0,544.01,1400,544.16,0.5,544.16,1800,544.16,4.9,544.29,12,544.29,49.6,544.43,29.5,544.43,86,544.56,16,544.7,7,544.83,ON,
,544.96,0,544.96,1300,545.1,0.485,545.1,1800,545.1,5.2,545.25,12,545.25,49.6,545.38,29.5,545.38,87,545.49,15,545.6,7,545.72,ON,
,545.86,0,545.86,1300,545.99,0.485,545.99,1600,545.99,5.2,546.13,12,546.13,49.2,546.27,29.5,546.27,87,546.4,15,546.52,7,546.64,ON,
,546.77,0,546.77,1400,546.89,0.485,546.89,1800,546.89,4.9,547.04,12,547.04,49.2,547.17,29.5,547.17,87,547.29,16,547.42,7,547.57,ON,
,547.71,0,547.71,1400,547.85,0.485,547.85,1800,547.85,4.9,547.99,12,547.99,49.2,548.15,29.5,548.15,87,548.26,16,548.38,7,548.52,ON,
,548.67,0,548.67,1400,548.8,0.48,548.8,1800,548.8,4.9,548.95,11.6,548.95,49.2,549.08,29.5,549.08,87,549.21,15,549.33,7,549.46,ON,
,549.59,0,549.59,1400,549.75,0.48,549.75,1800,549.75,4.7,549.88,12,549.88,49.6,550.02,29.5,550.02,87,550.15,15,550.29,7,550.42,ON,
,550.55,0,550.55,1400,550.69,0.48,550.69,1800,550.69,5.4,550.84,12.2,550.84,49.6,550.97,29.5,550.97,87,551.1,16,551.22,8,551.36,ON,
,551.47,0,551.47,1400,551.61,0.49,551.61,1800,551.61,4.9,551.73,12,551.73,49.6,551.87,29.5,551.87,87,551.99,16,552.11,8,552.25,ON,
,552.39,0,552.39,1400,552.51,0.49,552.51,1800,552.51,4.7,552.64,11.6,552.64,49.6,552.78,29.5,552.78,87,552.91,16,553.03,7,553.17,ON,
,553.29,0,553.29,1400,553.43,0.48,553.43,1800,553.43,4.9,553.56,12,553.56,49.6,553.69,29.5,553.69,87,553.81,16,553.96,7,554.08,ON,
2,554.21,0,554.21,1400,554.35,0.48,554.35,1800,554.35,4.9,554.5,12,554.5,49.6,554.64,29.5,554.64,87,554.74,15,554.87,7,555.02,ON,
,555.17,0,555.17,1400,555.3,0.465,555.3,1800,555.3,4.9,555.43,12,555.43,49.6,555.58,29.5,555.58,87,555.69,16,555.82,8,555.96,ON,
,556.11,0,556.11,1400,556.23,0.82,556.23,1800,556.23,4.9,556.36,11.8,556.36,49.6,556.48,29.5,556.48,87,556.62,15,556.74,8,556.87,ON,
,557,0,557,1400,557.14,0.82,557.14,1800,557.14,4.6,557.26,12,557.26,49.6,557.39,29.5,557.39,87,557.51,16,557.65,7,557.78,ON,
,557.9,0,557.9,1400,558.04,0.82,558.04,1800,558.04,5.2,558.19,12.6,558.19,49.6,558.33,29.5,558.33,87,558.46,16,558.58,7,558.73,ON,
,558.86,0,558.86,1400,559,0.82,559,1800,559,4.9,559.14,11.8,559.14,49.2,559.28,29.5,559.28,87,559.39,15,559.52,7,559.65,ON,
,559.8,0,559.8,1400,559.93,0.82,559.93,1800,559.93,4.8,560.06,11.8,560.06,49.2,560.18,29.5,560.18,87,560.32,15,560.44,8,560.57,ON,
,560.7,0,560.7,1400,560.84,0.82,560.84,1800,560.84,4.7,560.97,12.8,560.97,49.2,561.1,30,561.1,87,561.22,15,561.36,7,561.5,ON,
,561.65,0,561.65,1400,561.78,0.82,561.78,1800,561.78,5.3,561.93,13,561.93,49.2,562.06,30,562.06,87,562.2,15,562.33,7,562.48,ON,
,562.6,0,562.6,1400,562.73,0.82,562.73,1800,562.73,4.9,562.85,12,562.85,49.6,563,30,563,87,563.12,15,563.23,8,563.35,ON,
,563.48,0,563.48,1400,563.62,0.82,563.62,1800,563.62,4.9,563.74,12.2,563.74,50,563.87,30,563.87,87,563.98,14,564.12,8,564.24,ON,
,564.37,0,564.37,1400,564.49,0.82,564.49,1800,564.49,5.1,564.62,12.4,564.62,50,564.76,30,564.76,88,564.87,15,565,7,565.13,ON,
,565.27,0,565.27,1400,565.4,0.82,565.4,1800,565.4,5.1,565.52,12.4,565.52,50,565.65,30,565.65,88,565.78,15,565.9,7,566.04,ON,
,566.18,0,566.18,1400,566.31,0.82,566.31,1800,566.31,5.1,566.43,13.4,566.43,50.4,566.56,30,566.56,88,566.68,14,566.83,7,566.96,ON,
,567.08,0,567.08,1300,567.2,0.82,567.2,1600,567.2,5.1,567.34,12.4,567.34,50.8,567.46,30,567.46,88,567.59,14,567.71,8,567.86,ON,
,568,0,568,1400,568.14,0.82,568.14,1600,568.14,5.3,568.28,12.4,568.28,50.8,568.44,30,568.44,88,568.56,14,568.69,8,568.81,ON,
,568.97,0,568.97,1300,569.1,0.82,569.1,1600,569.1,5.4,569.23,12.2,569.23,50.8,569.35,29.5,569.35,88,569.49,14,569.61,7,569.74,ON,
,569.87,0,569.87,1300,570.02,0.82,570.02,1600,570.02,5.4,570.15,13.2,570.15,50.8,570.27,29.5,570.27,88,570.39,14,570.53,7,570.67,ON,
,570.81,0,570.81,1300,570.95,0.82,570.95,1600,570.95,5.9,571.1,13.2,571.1,51.2,571.23,29.5,571.23,88,571.36,14,571.48,7,571.63,ON,
,571.76,0,571.76,1300,571.9,0.82,571.9,1600,571.9,5.3,572.02,12.4,572.02,51.2,572.16,29.5,572.16,88,572.28,14,572.4,7,572.54,ON,
,572.68,0,572.68,1200,572.8,0.82,572.8,1500,572.8,5.6,572.93,12.4,572.93,51.2,573.05,29.5,573.05,88,573.18,13,573.29,7,573.43,ON,
,573.55,0,573.55,1200,573.68,0.82,573.68,1500,573.68,5.6,573.82,12.4,573.82,51.6,573.96,29.5,573.96,89,574.07,13,574.18,7,574.3,ON,
,574.44,0,574.44,1200,574.57,0.82,574.57,1500,574.57,5.5,574.71,12.4,574.71,51.6,574.85,29.5,574.85,89,575,13,575.12,7,575.25,ON,
,575.38,0,575.38,1400,575.52,0.82,575.52,1600,575.52,5.2,575.65,12.6,575.65,51.6,575.78,29.5,575.78,89,575.9,13,576.04,7,576.18,ON,
,576.32,0,576.32,1300,576.46,0.82,576.46,1600,576.46,5.7,576.61,13.6,576.61,52,576.74,29.5,576.74,89,576.87,13,577,7,577.14,ON,
,577.28,0,577.28,1300,577.41,0.82,577.41,1600,577.41,5.3,577.54,12.8,577.54,52.4,577.69,29.5,577.69,89,577.8,13,577.91,7,578.03,ON,
,578.16,0,578.16,1300,578.3,0.82,578.3,1600,578.3,6.3,578.42,12.8,578.42,52.4,578.55,29.5,578.55,89,578.68,13,578.82,7,578.96,ON,
,579.11,0,579.11,1300,579.24,0.82,579.24,1500,579.24,5.9,579.39,13,579.39,52.8,579.52,29.5,579.52,89,579.65,13,579.77,7,579.91,ON,
,580.04,0,580.04,1200,580.16,0.82,580.16,1500,580.16,5.9,580.3,12.8,580.3,53.2,580.45,29.5,580.45,89,580.57,13,580.69,7,580.83,ON,
,580.97,0,580.97,1100,581.1,0.82,581.1,1300,581.1,5.6,581.22,12.6,581.22,53.2,581.35,29.5,581.35,89,581.48,12,581.6,7,581.72,ON,
,581.85,0,581.85,900,582.01,0.82,582.01,1300,582.01,6.6,582.15,12.4,582.15,52.8,582.27,29.5,582.27,89,582.38,12,582.51,7,582.64,ON,
,582.77,0,582.77,1200,582.89,0.82,582.89,1500,582.89,5.5,583.04,12.6,583.04,52.8,583.18,29.5,583.18,89,583.31,13,583.43,7,583.58,ON,
,583.71,0,583.71,1300,583.85,0.82,583.85,1600,583.85,5.7,583.99,12.6,583.99,52.8,584.14,29.5,584.14,89,584.27,13,584.38,7,584.52,ON,
,584.67,0,584.67,1400,584.81,0.82,584.81,1800,584.81,5.2,584.94,12.8,584.94,52.8,585.07,29.5,585.07,89,585.21,12,585.34,7,585.47,ON,
,585.59,0,585.59,1600,585.74,0.82,585.74,2000,585.74,4.9,585.88,13,585.88,53.2,586.02,29.5,586.02,89,586.15,12,586.29,7,586.42,ON,
,586.55,0,586.55,1700,586.69,0.82,586.69,2200,586.69,4.3,586.83,13.8,586.83,53.6,586.95,29.5,586.95,89,587.07,12,587.19,7,587.34,ON,
,587.47,0,587.47,1800,587.59,0.82,587.59,2400,587.59,3.8,587.72,13.2,587.72,54,587.86,29.5,587.86,89,587.97,12,588.1,7,588.23,ON,
,588.37,0,588.37,1600,588.5,0.82,588.5,1900,588.5,5.1,588.62,13,588.62,54.4,588.75,29.5,588.75,89,588.88,12,589,7,589.14,ON,
,589.28,0,589.28,1400,589.42,0.82,589.42,1800,589.42,5.7,589.55,12.8,589.55,54.4,589.68,29.5,589.68,89,589.8,12,589.94,7,590.07,ON,
,590.2,0,590.2,1400,590.33,0.82,590.33,1800,590.33,5.3,590.48,12.8,590.48,54.4,590.61,29.5,590.61,89,590.74,11,590.86,7,591.01,ON,
,591.14,0,591.14,1500,591.28,0.82,591.28,1900,591.28,4.9,591.42,13,591.42,54,591.57,29.5,591.57,89,591.69,12,591.82,7,591.95,ON,
,592.09,0,592.09,1500,592.21,0.82,592.21,1900,592.21,5,592.34,13.6,592.34,54.4,592.45,29.5,592.45,89,592.6,12,592.71,7,592.85,ON,
,592.98,0,592.98,1500,593.12,0.82,593.12,1900,593.12,5.4,593.24,12.8,593.24,54,593.37,29.5,593.37,89,593.48,11,593.59,7,593.73,ON,
,593.87,0,593.87,1500,594.01,0.82,594.01,1900,594.01,5,594.13,12.6,594.13,54,594.27,29.5,594.27,89,594.4,11,594.51,7,594.62,ON,
,594.75,0,594.75,1500,594.89,0.82,594.89,1900,594.89,5,595.01,12.8,595.01,53.6,595.14,29.5,595.14,89,595.26,11,595.4,7,595.53,ON,
,595.65,0,595.65,1500,595.78,0.82,595.78,1900,595.78,5.4,595.92,12.8,595.92,53.6,596.04,29.5,596.04,89,596.16,11,596.28,7,596.44,ON,
,596.57,0,596.57,1500,596.7,0.82,596.7,2000,596.7,5,596.83,13.8,596.83,53.6,596.98,29.5,596.98,89,597.1,11,597.22,7,597.36,ON,
,597.51,0,597.51,1600,597.64,0.82,597.64,2000,597.64,4.8,597.76,13,597.76,53.6,597.89,29.5,597.89,89,598.03,11,598.16,7,598.3,ON,
,598.42,0,598.42,1600,598.56,0.82,598.56,2000,598.56,4.8,598.68,12.8,598.68,53.6,598.81,29.5,598.81,89,598.92,11,599.06,7,599.2,ON,
,599.34,0,599.34,1600,599.48,0.82,599.48,2000,599.48,4.9,599.63,13.8,599.63,54,599.74,29.5,599.74,88,599.87,11,599.98,7,600.14,ON,
,600.28,0,600.28,1600,600.42,0.82,600.42,2000,600.42,5.2,600.56,12.8,600.56,54,600.71,29.5,600.71,88,600.83,11,600.95,7,601.09,ON,
,601.24,0,601.24,1600,601.37,0.82,601.37,2000,601.37,4.9,601.51,12.8,601.51,54,601.63,29.5,601.63,88,601.77,11,601.89,6,602.02,ON,
,602.15,0,602.15,1600,602.31,0.82,602.31,2000,602.31,4.9,602.44,12.2,602.44,54.4,602.57,29.5,602.57,88,602.68,10,602.81,7,602.94,ON,
,603.07,0,603.07,1700,603.19,0.82,603.19,2200,603.19,4.3,603.34,13.8,603.34,54.4,603.48,29.5,603.48,88,603.61,11,603.73,7,603.88,ON,
,604.01,0,604.01,1700,604.15,0.82,604.15,2200,604.15,4.3,604.29,12.8,604.29,54.4,604.43,29.5,604.43,88,604.54,11,604.67,7,604.81,ON,
,604.94,0,604.94,1700,605.07,0.82,605.07,2200,605.07,4.3,605.21,12.8,605.21,54,605.36,29.5,605.36,88,605.5,10,605.62,6,605.75,ON,
,605.88,0,605.88,1700,606.02,0.82,606.02,2200,606.02,4.3,606.14,12.2,606.14,54,606.27,29.5,606.27,88,606.38,10,606.53,6,606.66,ON,
,606.78,0,606.78,1400,606.92,0.82,606.92,1800,606.92,5.3,607.07,12.6,607.07,54,607.21,29,607.21,88,607.34,10,607.45,6,607.6,ON,
,607.73,0,607.73,1300,607.87,0.82,607.87,1600,607.87,5.4,608,13.4,608,54,608.14,29,608.14,88,608.25,11,608.37,6,608.51,ON,
,608.65,0,608.65,1300,608.77,0.82,608.77,1600,608.77,5.4,608.9,12.2,608.9,53.6,609.04,29,609.04,88,609.19,10,609.31,6,609.44,ON,
,609.57,0,609.57,1300,609.71,0.82,609.71,1600,609.71,5.4,609.83,12.2,609.83,53.6,609.96,29,609.96,88,610.08,10,610.21,6,610.33,ON,
,610.46,0,610.46,1300,610.58,0.82,610.58,1600,610.58,5.2,610.71,12.4,610.71,53.2,610.85,29,610.85,87,610.96,10,611.09,6,611.22,ON,
,611.36,0,611.36,1300,611.49,0.82,611.49,1600,611.49,5.8,611.61,12,611.61,53.2,611.74,29,611.74,87,611.87,10,611.99,6,612.11,ON,
,612.24,0,612.24,1400,612.39,0.82,612.39,1600,612.39,5.3,612.52,12.4,612.52,52.8,612.64,29,612.64,87,612.76,10,612.9,6,613.03,ON,
,613.16,0,613.16,1400,613.28,0.82,613.28,1800,613.28,5.2,613.43,12.4,613.43,52.8,613.57,29,613.57,87,613.7,10,613.82,6,613.97,ON,
,614.1,0,614.1,1400,614.24,0.82,614.24,1800,614.24,5.1,614.36,12.2,614.36,52.4,614.5,29,614.5,87,614.62,10,614.74,6,614.88,ON,
,615.03,0,615.03,1400,615.16,0.82,615.16,1800,615.16,5.5,615.28,13.2,615.28,52.4,615.41,29,615.41,87,615.54,10,615.66,6,615.8,ON,
,615.92,0,615.92,1400,616.06,0.82,616.06,1800,616.06,5,616.19,12.2,616.19,52.4,616.31,29,616.31,87,616.43,10,616.57,6,616.7,ON,
,616.83,0,616.83,1300,616.95,0.82,616.95,1800,616.95,5,617.1,12.2,617.1,52,617.23,29,617.23,87,617.35,10,617.47,6,617.61,ON,
,617.73,0,617.73,1700,617.86,0.82,617.86,2200,617.86,4.1,617.98,12.4,617.98,52,618.12,29,618.12,87,618.24,10,618.36,6,618.48,ON,
,618.63,0,618.63,1700,618.76,0.82,618.76,2200,618.76,4.2,618.89,12.6,618.89,52,619.01,29,619.01,87,619.15,10,619.27,6,619.4,ON,
,619.53,0,619.53,1700,619.67,0.82,619.67,2200,619.67,4.2,619.79,13.4,619.79,52,619.92,29,619.92,87,620.04,10,620.19,6,620.32,ON,
,620.46,0,620.46,1800,620.6,0.82,620.6,2300,620.6,4.3,620.76,13.6,620.76,52,620.89,29,620.89,87,621.02,10,621.14,6,621.28,ON,
,621.41,0,621.41,1800,621.54,0.82,621.54,2300,621.54,4,621.67,12.8,621.67,52.4,621.82,29,621.82,87,621.94,10,622.06,6,622.19,ON,
,622.33,0,622.33,1800,622.45,0.82,622.45,2300,622.45,4,622.58,12.8,622.58,52.8,622.7,29,622.7,87,622.85,10,622.96,6,623.09,ON,
,623.22,0,623.22,1500,623.36,0.82,623.36,1900,623.36,4.9,623.48,12.6,623.48,52.8,623.61,29,623.61,87,623.73,9,623.87,6,624,ON,
,624.12,0,624.12,1400,624.25,0.82,624.25,1800,624.25,4.9,624.39,12.2,624.39,52.8,624.51,29,624.51,87,624.63,9,624.75,6,624.87,ON,
,625.02,0,625.02,1400,625.15,0.82,625.15,1800,625.15,5.1,625.28,13.2,625.28,52.8,625.4,29,625.4,87,625.54,10,625.66,6,625.79,ON,
,625.92,0,625.92,1400,626.06,0.82,626.06,1800,626.06,5.1,626.19,12.4,626.19,52.4,626.33,29,626.33,87,626.46,10,626.6,6,626.73,ON,
,626.86,0,626.86,1300,627,0.82,627,1600,627,5.3,627.15,12.4,627.15,52.4,627.28,29,627.28,87,627.4,10,627.52,6,627.67,ON,
,627.79,0,627.79,1300,627.92,0.82,627.92,1600,627.92,5.3,628.04,13.2,628.04,52.4,628.18,29,628.18,87,628.3,10,628.42,6,628.56,ON,
,628.7,0,628.7,1300,628.84,0.82,628.84,1600,628.84,5.3,628.96,12.4,628.96,52.4,629.09,29,629.09,87,629.22,10,629.34,6,629.48,ON,
,629.6,0,629.6,1300,629.75,0.82,629.75,1600,629.75,5.4,629.89,12.4,629.89,52,630.03,29,630.03,87,630.16,10,630.3,6,630.43,ON,
,630.57,0,630.57,1300,630.7,0.82,630.7,1600,630.7,5.2,630.85,12,630.85,52,630.98,29,630.98,87,631.09,9,631.22,6,631.37,ON,
,631.49,0,631.49,1300,631.62,0.82,631.62,1600,631.62,5.9,631.76,13.2,631.76,52,631.91,29,631.91,87,632.03,9,632.15,6,632.27,ON,
,632.4,0,632.4,1300,632.54,0.82,632.54,1600,632.54,5.4,632.66,12.4,632.66,52,632.79,29,632.79,87,632.9,9,633.04,6,633.17,ON,
,633.3,0,633.3,1400,633.44,0.82,633.44,1800,633.44,5,633.59,12.4,633.59,52,633.73,29,633.73,87,633.86,10,633.98,6,634.13,ON,
,634.25,0,634.25,1400,634.39,0.82,634.39,1800,634.39,4.9,634.54,12.6,634.54,52,634.69,29,634.69,87,634.81,10,634.93,6,635.06,ON,
,635.2,0,635.2,1500,635.32,0.82,635.32,1900,635.32,5.3,635.45,13.4,635.45,52,635.57,29,635.57,87,635.71,9,635.83,6,635.96,ON,
,636.09,0,636.09,1500,636.23,0.82,636.23,1900,636.23,4.9,636.35,12.4,636.35,52.4,636.48,29,636.48,87,636.59,9,636.74,6,636.87,ON,
,636.99,0,636.99,1500,637.12,0.82,637.12,1900,637.12,5.3,637.26,13.4,637.26,52.4,637.38,29,637.38,87,637.5,9,637.62,5,637.77,ON,
,637.9,0,637.9,1500,638.02,0.8,638.02,1900,638.02,4.9,638.15,12.4,638.15,52.4,638.29,29,638.29,87,638.4,9,638.51,5,638.65,ON,
,638.77,0,638.77,1500,638.91,0.8,638.91,1900,638.91,4.9,639.04,12.4,639.04,52.4,639.16,29,639.16,87,639.28,9,639.42,6,639.55,ON,
,639.68,0,639.68,1500,639.8,0.82,639.8,1900,639.8,4.9,639.95,12.4,639.95,52.8,640.08,29,640.08,88,640.2,9,640.32,6,640.46,ON,
,640.58,0,640.58,1500,640.71,0.82,640.71,1900,640.71,4.9,640.83,13.4,640.83,52.4,640.99,29,640.99,88,641.11,9,641.23,5,641.36,ON,
,641.51,0,641.51,1500,641.65,0.8,641.65,1900,641.65,4.9,641.79,12.2,641.79,52.4,641.93,29,641.93,88,642.07,9,642.2,5,642.33,ON,
,642.46,0,642.46,1500,642.6,0.8,642.6,1900,642.6,4.9,642.72,12.4,642.72,52.4,642.85,29,642.85,88,642.98,9,643.12,6,643.25,ON,
,643.38,0,643.38,1500,643.5,0.82,643.5,1900,643.5,4.7,643.65,12,643.65,52.4,643.78,29,643.78,88,643.9,9,644.02,6,644.18,ON,
,644.32,0,644.32,1500,644.46,0.82,644.46,1900,644.46,5.2,644.61,12.4,644.61,52.4,644.75,29,644.75,88,644.87,9,644.99,5,645.13,ON,
,645.28,0,645.28,1500,645.41,0.8,645.41,1900,645.41,4.9,645.53,12.2,645.53,52.4,645.66,29,645.66,88,645.79,9,645.91,5,646.05,ON,
,646.19,0,646.19,1500,646.33,0.8,646.33,1800,646.33,4.9,646.45,12.4,646.45,52.4,646.58,29,646.58,88,646.69,9,646.8,5,646.97,ON,
,647.09,0,647.09,1400,647.22,0.82,647.22,1800,647.22,4.9,647.34,12.2,647.34,52.4,647.49,29,647.49,88,647.62,9,647.74,6,647.87,ON,
,648.02,0,648.02,1400,648.16,0.82,648.16,1800,648.16,5.1,648.3,12.4,648.3,52.4,648.44,29,648.44,88,648.57,9,648.7,6,648.83,ON,
,648.96,0,648.96,1400,649.13,0.8,649.13,1800,649.13,5.5,649.26,13.4,649.26,52.4,649.38,29,649.38,88,649.5,9,649.64,5,649.78,ON,
,649.89,0,649.89,1400,650.03,0.8,650.03,1800,650.03,5.1,650.16,12.4,650.16,52.4,650.28,29,650.28,88,650.4,9,650.52,5,650.64,ON,
,650.78,0,650.78,1400,650.91,0.8,650.91,1800,650.91,5,651.05,12.2,651.05,52,651.17,29,651.17,88,651.31,9,651.43,6,651.56,ON,
,651.69,0,651.69,1300,651.83,0.82,651.83,1600,651.83,5.3,651.96,12.2,651.96,52.4,652.1,29,652.1,88,652.23,8,652.38,6,652.5,ON,
,652.63,0,652.63,1300,652.77,0.82,652.77,1600,652.77,5.3,652.93,12.2,652.93,52,653.06,29,653.06,88,653.18,9,653.3,5,653.47,ON,
,653.59,0,653.59,1200,653.72,0.8,653.72,1500,653.72,5.5,653.84,12.2,653.84,52,653.98,29,653.98,88,654.1,9,654.22,5,654.36,ON,
,654.5,0,654.5,1300,654.62,0.8,654.62,1500,654.62,5.3,654.75,12.2,654.75,52,654.87,29,654.87,88,655.02,9,655.15,6,655.28,ON,
,655.41,0,655.41,1300,655.56,0.82,655.56,1600,655.56,5.3,655.69,12.4,655.69,51.6,655.83,29,655.83,88,655.96,9,656.1,6,656.23,ON,
,656.36,0,656.36,1200,656.48,0.82,656.48,1600,656.48,5.1,656.62,12,656.62,51.6,656.75,29,656.75,88,656.86,9,656.99,5,657.14,ON,
,657.28,0,657.28,1200,657.42,0.8,657.42,1500,657.42,5.5,657.54,12.2,657.54,51.6,657.69,29,657.69,88,657.82,9,657.94,5,658.07,ON,
,658.22,0,658.22,1200,658.36,0.8,658.36,1500,658.36,5.4,658.5,12.2,658.5,51.6,658.65,29,658.65,88,658.78,9,658.91,6,659.04,ON,
,659.17,0,659.17,1200,659.32,0.82,659.32,1400,659.32,5.8,659.45,12.2,659.45,51.6,659.57,29,659.57,88,659.69,9,659.83,6,659.96,ON,
,660.09,0,660.09,1200,660.23,0.82,660.23,1600,660.23,6,660.36,11.8,660.36,51.6,660.48,29,660.48,88,660.61,9,660.73,6,660.85,ON,
,661.01,0,661.01,1400,661.13,0.82,661.13,1800,661.13,5.1,661.26,12.4,661.26,51.6,661.4,29,661.4,88,661.53,8,661.65,6,661.76,ON,
,661.89,0,661.89,1300,662.03,0.82,662.03,1600,662.03,5.4,662.16,12.4,662.16,51.6,662.29,29,662.29,88,662.4,9,662.55,6,662.69,ON,
,662.83,0,662.83,1200,662.97,0.82,662.97,1600,662.97,5.2,663.12,12.4,663.12,51.6,663.25,29,663.25,88,663.39,9,663.5,6,663.65,ON,
,663.78,0,663.78,1300,663.92,0.82,663.92,1600,663.92,5.4,664.04,12.4,664.04,51.6,664.19,29,664.19,88,664.32,9,664.44,6,664.57,ON,
,664.72,0,664.72,1300,664.87,0.82,664.87,1600,664.87,6,665,12.4,665,51.6,665.15,29,665.15,88,665.28,9,665.41,6,665.54,ON,
,665.67,0,665.67,1300,665.83,0.82,665.83,1600,665.83,5.4,665.96,12.4,665.96,52,666.09,29,666.09,88,666.22,8,666.36,6,666.49,ON,
,666.62,0,666.62,1300,666.74,0.82,666.74,1600,666.74,6,666.89,12.4,666.89,52,667.03,29,667.03,88,667.16,9,667.28,6,667.43,ON,
,667.56,0,667.56,1200,667.7,0.82,667.7,1500,667.7,6.1,667.84,13.2,667.84,52,667.98,29,667.98,88,668.09,8,668.23,6,668.35,ON,
,668.49,0,668.49,1200,668.62,0.82,668.62,1500,668.62,5.5,668.77,12.2,668.77,52,668.88,29,668.88,88,669.02,9,669.14,6,669.28,ON,
,669.4,0,669.4,1200,669.57,0.82,669.57,1500,669.57,5.6,669.69,12,669.69,52,669.82,29,669.82,88,669.93,9,670.06,6,670.19,ON,
,670.33,0,670.33,1200,670.44,0.82,670.44,1500,670.44,5.5,670.59,12.2,670.59,51.6,670.72,29,670.72,88,670.85,9,670.97,6,671.12,ON,
,671.26,0,671.26,1200,671.4,0.82,671.4,1500,671.4,5.5,671.54,12.2,671.54,51.6,671.69,29,671.69,88,671.81,8,671.93,6,672.05,ON,
,672.18,0,672.18,1100,672.33,0.82,672.33,1400,672.33,5.8,672.46,12.2,672.46,51.6,672.6,29,672.6,88,672.71,8,672.85,6,672.97,ON,
,673.1,0,673.1,1100,673.22,0.82,673.22,1400,673.22,5.6,673.35,12,673.35,51.6,673.51,29,673.51,88,673.63,9,673.76,6,673.89,ON,
,674.04,0,674.04,1000,674.17,0.82,674.17,1300,674.17,5.9,674.32,12,674.32,51.2,674.46,29,674.46,88,674.6,9,674.74,6,674.85,ON,
,674.99,0,674.99,900,675.12,0.82,675.12,1100,675.12,6.2,675.25,11.6,675.25,51.2,675.38,29,675.38,88,675.52,9,675.65,6,675.78,ON,
,675.9,0,675.9,1100,676.03,0.82,676.03,1400,676.03,5.6,676.16,12,676.16,51.2,676.3,29,676.3,88,676.41,9,676.54,6,676.69,ON,
,676.83,0,676.83,1000,676.96,0.82,676.96,1100,676.96,6.2,677.1,12,677.1,51.2,677.24,29,677.24,88,677.36,9,677.48,6,677.62,ON,
,677.77,0,677.77,800,677.9,0.82,677.9,1000,677.9,6.2,678.02,12,678.02,50.8,678.15,29,678.15,88,678.29,9,678.42,6,678.55,ON,
,678.68,0,678.68,800,678.83,0.82,678.83,1000,678.83,6.4,678.96,12,678.96,50.8,679.1,29,679.1,88,679.21,9,679.35,6,679.47,ON,
,679.6,0,679.6,700,679.72,0.82,679.72,1000,679.72,6.4,679.85,11.6,679.85,50.4,680,29,680,88,680.12,9,680.24,6,680.38,ON,
,680.54,0,680.54,800,680.68,0.82,680.68,1000,680.68,6.4,680.82,12,680.82,50.4,680.96,29,680.96,88,681.1,9,681.24,6,681.36,ON,
,681.5,0,681.5,800,681.64,0.82,681.64,1000,681.64,6.4,681.78,12,681.78,50.4,681.91,29,681.91,88,682.04,9,682.18,6,682.32,ON,
,682.45,0,682.45,800,682.58,0.82,682.58,1000,682.58,6.5,682.72,12,682.72,50.4,682.84,29,682.84,88,682.96,9,683.08,6,683.2,ON,
,683.36,0,683.36,800,683.48,0.82,683.48,1000,683.48,6,683.61,11.8,683.61,50.4,683.73,29,683.73,88,683.87,9,683.99,6,684.12,ON,
,684.25,0,684.25,800,684.4,0.82,684.4,1000,684.4,6.4,684.53,13,684.53,50.4,684.66,29,684.66,88,684.79,9,684.93,6,685.06,ON,
,685.19,0,685.19,800,685.33,0.82,685.33,1000,685.33,6.4,685.47,12.2,685.47,50.4,685.61,29,685.61,88,685.74,9,685.86,6,686.01,ON,
,686.14,0,686.14,800,686.26,0.82,686.26,1000,686.26,6.5,686.39,12,686.39,50.8,686.53,29,686.53,88,686.64,9,686.77,6,686.9,ON,
,687.04,0,687.04,800,687.17,0.82,687.17,1000,687.17,6.7,687.29,12.4,687.29,50.8,687.42,29,687.42,88,687.55,9,687.67,6,687.79,ON,
,687.92,0,687.92,800,688.03,0.82,688.03,1000,688.03,6.7,688.18,12.4,688.18,51.2,688.3,29.5,688.3,88,688.42,9,688.55,6,688.7,ON,
,688.83,0,688.83,800,688.96,0.82,688.96,1000,688.96,6.7,689.08,12.4,689.08,51.2,689.22,29.5,689.22,88,689.34,9,689.45,6,689.57,ON,
,689.7,0,689.7,800,689.87,0.82,689.87,1000,689.87,6.4,689.99,12,689.99,51.6,690.11,29.5,690.11,88,690.23,10,690.36,6,690.49,ON,
,690.63,0,690.63,800,690.77,0.82,690.77,1000,690.77,6.7,690.92,12.6,690.92,51.6,691.05,29.5,691.05,88,691.18,9,691.3,6,691.45,ON,
,691.58,0,691.58,800,691.7,0.82,691.7,1000,691.7,6.4,691.83,12.4,691.83,51.6,691.98,29.5,691.98,88,692.1,10,692.22,6,692.36,ON,
,692.5,0,692.5,800,692.62,0.82,692.62,1000,692.62,7.5,692.75,12.4,692.75,51.6,692.87,29.5,692.87,88,693,9,693.13,6,693.26,ON,
,693.39,0,693.39,1200,693.55,0.82,693.55,1500,693.55,6.3,693.68,13.6,693.68,52,693.81,29.5,693.81,88,693.92,9,694.07,6,694.2,ON,
,694.32,0,694.32,1200,694.45,0.82,694.45,1500,694.45,5.9,694.59,12.8,694.59,52,694.71,29.5,694.71,88,694.83,10,694.95,6,695.07,ON,
,695.22,0,695.22,1300,695.36,0.82,695.36,1600,695.36,6.3,695.5,13.8,695.5,52.8,695.64,29.5,695.64,88,695.78,10,695.91,7,696.05,ON,
,696.17,0,696.17,900,696.32,0.82,696.32,1000,696.32,6.8,696.45,12.8,696.45,52.8,696.6,29.5,696.6,88,696.72,10,696.87,6,696.99,ON,
,697.12,0,697.12,900,697.24,0.82,697.24,1100,697.24,6.6,697.4,12.6,697.4,52.8,697.53,29.5,697.53,88,697.66,9,697.78,6,697.93,ON,
,698.06,0,698.06,900,698.2,0.82,698.2,1100,698.2,6.6,698.34,12.6,698.34,52.8,698.49,29.5,698.49,88,698.61,9,698.73,6,698.87,ON,
,699.03,0,699.03,1000,699.16,0.82,699.16,1300,699.16,5.8,699.29,12.6,699.29,52.8,699.42,29.5,699.42,88,699.54,10,699.65,7,699.77,ON,
,699.9,0,699.9,1200,700.04,0.82,700.04,1500,700.04,6.4,700.18,12.8,700.18,52.8,700.3,29.5,700.3,88,700.42,10,700.54,7,700.66,ON,
,700.8,0,700.8,1700,700.93,0.82,700.93,2300,700.93,4.3,701.05,13.2,701.05,52.8,701.18,29.5,701.18,88,701.31,10,701.43,6,701.55,ON,
,701.68,0,701.68,2100,701.83,0.82,701.83,2600,701.83,2.7,701.96,13.4,701.96,52.8,702.08,29.5,702.08,88,702.2,9,702.33,6,702.46,ON,
,702.6,0,702.6,1400,702.72,0.82,702.72,1900,702.72,5.9,702.85,13.2,702.85,53.2,702.99,29.5,702.99,88,703.1,10,703.22,7,703.37,ON,
,703.5,0,703.5,1500,703.62,0.82,703.62,1900,703.62,5.3,703.74,13.4,703.74,54,703.89,29.5,703.89,88,704.03,10,704.15,7,704.29,ON,
,704.43,0,704.43,1500,704.56,0.82,704.56,1900,704.56,5.3,704.7,13.4,704.7,54.4,704.84,29.5,704.84,88,704.99,9,705.11,6,705.24,ON,
,705.37,0,705.37,1500,705.51,0.82,705.51,1900,705.51,5.3,705.63,13.6,705.63,54.4,705.76,29.5,705.76,88,705.87,9,706.01,6,706.15,ON,
,706.29,0,706.29,1500,706.44,0.82,706.44,1900,706.44,5.4,706.57,13.6,706.57,55.2,706.69,29.5,706.69,88,706.81,9,706.94,6,707.09,ON,
,707.24,0,707.24,1500,707.37,0.82,707.37,1900,707.37,5.4,707.52,14.2,707.52,55.6,707.66,29.5,707.66,88,707.78,10,707.9,7,708.04,ON,
,708.2,0,708.2,1500,708.33,0.82,708.33,1900,708.33,5.8,708.46,13.6,708.46,55.6,708.58,29.5,708.58,88,708.72,9,708.84,6,708.97,ON,
,709.1,0,709.1,1600,709.24,0.82,709.24,2200,709.24,4.6,709.36,13.8,709.36,56.4,709.49,29.5,709.49,88,709.6,9,709.71,6,709.88,ON,
,710,0,710,1900,710.13,0.82,710.13,2400,710.13,4.2,710.25,13.8,710.25,56.4,710.39,29.5,710.39,88,710.51,9,710.63,6,710.75,ON,
,710.91,0,710.91,2200,711.03,0.82,711.03,2800,711.03,2.7,711.16,14,711.16,56.8,711.28,29.5,711.28,88,711.43,9,711.56,6,711.69,ON,
,711.82,0,711.82,1700,711.97,0.82,711.97,2200,711.97,4.7,712.1,14,712.1,57.6,712.24,29.5,712.24,88,712.35,9,712.49,6,712.63,ON,
,712.77,0,712.77,1700,712.91,0.82,712.91,2300,712.91,4.4,713.07,14,713.07,58,713.2,29.5,713.2,88,713.32,9,713.45,6,713.58,ON,
,713.7,0,713.7,2000,713.83,0.82,713.83,2600,713.83,3.7,713.95,14,713.95,58.4,714.1,29.5,714.1,88,714.23,9,714.33,6,714.47,ON,
,714.6,0,714.6,1900,714.73,0.82,714.73,2200,714.73,4.7,714.86,13.4,714.86,58.8,714.98,29.5,714.98,88,715.12,9,715.24,6,715.37,ON,
,715.5,0,715.5,1500,715.66,0.82,715.66,1900,715.66,5.5,715.8,13.8,715.8,58.8,715.94,29.5,715.94,88,716.08,9,716.2,6,716.34,ON,
,716.47,0,716.47,1600,716.61,0.82,716.61,2000,716.61,5.2,716.76,13.6,716.76,58.8,716.9,29.5,716.9,88,717.02,9,717.14,6,717.29,ON,
,717.43,0,717.43,1600,717.57,0.82,717.57,2000,717.57,5.1,717.71,13.6,717.71,58.8,717.87,29.5,717.87,88,717.99,9,718.1,6,718.24,ON,
,718.39,0,718.39,1600,718.52,0.82,718.52,2000,718.52,5.4,718.67,14,718.67,58.4,718.78,29.5,718.78,88,718.92,9,719.04,6,719.17,ON,
,719.3,0,719.3,1700,719.44,0.82,719.44,2200,719.44,4.5,719.56,13.4,719.56,58,719.7,29.5,719.7,88,719.8,9,719.95,6,720.08,ON,
,720.2,0,720.2,1700,720.33,0.82,720.33,2200,720.33,4.2,720.47,13.2,720.47,58,720.59,29.5,720.59,88,720.71,9,720.83,6,720.99,ON,
,721.12,0,721.12,1600,721.26,0.82,721.26,2000,721.26,5.3,721.37,13.2,721.37,57.6,721.52,29.5,721.52,88,721.65,8,721.78,6,721.91,ON,
,722.07,0,722.07,1600,722.19,0.82,722.19,2000,722.19,4.9,722.34,13,722.34,57.2,722.47,29.5,722.47,88,722.6,8,722.72,6,722.86,ON,
,723,0,723,1600,723.16,0.82,723.16,2000,723.16,5,723.29,13.2,723.29,57.2,723.42,29.5,723.42,88,723.53,9,723.66,6,723.79,ON,
,723.92,0,723.92,1600,724.04,0.82,724.04,2000,724.04,4.9,724.19,13,724.19,56.8,724.33,29.5,724.33,88,724.46,9,724.58,6,724.73,ON,
,724.86,0,724.86,1500,725,0.82,725,1900,725,5.1,725.14,12.8,725.14,56.8,725.29,29.5,725.29,88,725.41,8,725.53,6,725.67,ON,
,725.82,0,725.82,1500,725.95,0.82,725.95,1900,725.95,5,726.07,13,726.07,56.4,726.2,29.5,726.2,88,726.33,8,726.45,6,726.57,ON,
,726.7,0,726.7,1400,726.82,0.82,726.82,1800,726.82,5.3,726.96,13,726.96,56.4,727.09,29.5,727.09,88,727.2,9,727.33,6,727.48,ON,
,727.6,0,727.6,1400,727.73,0.82,727.73,1800,727.73,5.3,727.85,13,727.85,56,727.99,29.5,727.99,88,728.11,9,728.23,6,728.37,ON,
,728.5,0,728.5,1300,728.62,0.82,728.62,1600,728.62,5.8,728.76,12.8,728.76,55.6,728.88,29.5,728.88,88,729.01,8,729.14,5,729.27,ON,
,729.39,0,729.39,1200,729.54,0.8,729.54,1500,729.54,5.9,729.66,12.6,729.66,55.6,729.79,29.5,729.79,88,729.9,8,730.05,5,730.18,ON,
,730.31,0,730.31,1200,730.43,0.8,730.43,1500,730.43,5.8,730.58,12.6,730.58,55.6,730.72,29.5,730.72,88,730.87,8,730.97,6,731.12,ON,
,731.25,0,731.25,1200,731.4,0.82,731.4,1500,731.4,5.8,731.54,12.6,731.54,55.2,731.7,29.5,731.7,88,731.83,9,731.94,6,732.07,ON,
,732.23,0,732.23,1100,732.36,0.82,732.36,1400,732.36,6,732.5,12.4,732.5,55.2,732.64,29.5,732.64,88,732.79,8,732.91,5,733.04,ON,
,733.17,0,733.17,1100,733.32,0.8,733.32,1400,733.32,5.9,733.45,12.4,733.45,54.8,733.57,29.5,733.57,88,733.69,8,733.83,5,733.96,ON,
,734.09,0,734.09,1100,734.21,0.8,734.21,1400,734.21,6,734.35,12.4,734.35,54.8,734.48,29.5,734.48,88,734.59,8,734.72,5,734.87,ON,
,734.99,0,734.99,1100,735.12,0.82,735.12,1400,735.12,5.9,735.24,12.6,735.24,54.8,735.38,29.5,735.38,88,735.5,9,735.62,6,735.76,ON,
,735.9,0,735.9,1000,736.04,0.82,736.04,1300,736.04,6.1,736.16,12,736.16,54.4,736.29,29.5,736.29,88,736.42,9,736.54,6,736.66,ON,
,736.79,0,736.79,1000,736.95,0.8,736.95,1300,736.95,6.8,737.09,12.6,737.09,54.4,737.23,29.5,737.23,88,737.36,8,737.5,5,737.64,ON,
,737.76,0,737.76,1100,737.91,0.8,737.91,1400,737.91,6,738.05,12.6,738.05,54,738.19,29.5,738.19,88,738.31,8,738.44,5,738.58,ON,
,738.71,0,738.71,1200,738.83,0.8,738.83,1500,738.83,6.4,738.97,13.6,738.97,53.6,739.12,29.5,739.12,88,739.24,9,739.35,5,739.48,ON,
,739.63,0,739.63,1000,739.75,0.82,739.75,1300,739.75,6.4,739.88,12.6,739.88,53.6,740.01,29.5,740.01,88,740.15,9,740.28,6,740.41,ON,
,740.54,0,740.54,1000,740.69,0.82,740.69,1100,740.69,6.5,740.82,12.8,740.82,53.6,740.96,29.5,740.96,88,741.09,8,741.23,5,741.36,ON,
,741.49,0,741.49,800,741.61,0.81,741.61,1000,741.61,6.7,741.75,12.4,741.75,53.6,741.88,29.5,741.88,89,742.01,8,742.13,5,742.28,ON,
,742.41,0,742.41,800,742.53,0.81,742.53,1000,742.53,6.5,742.66,12.4,742.66,53.6,742.8,29.5,742.8,89,742.91,9,743.04,6,743.16,ON,
,743.3,0,743.3,800,743.43,0.82,743.43,1000,743.43,7.3,743.55,12.2,743.55,53.2,743.69,29.5,743.69,89,743.82,9,743.94,6,744.06,ON,
,744.19,0,744.19,800,744.3,0.82,744.3,1000,744.3,6.5,744.44,11.8,744.44,53.2,744.58,29.5,744.58,88,744.69,9,744.82,5,744.96,ON,
,745.08,0,745.08,700,745.21,0.81,745.21,1000,745.21,6.5,745.34,13,745.34,52.8,745.48,29.5,745.48,89,745.61,8,745.73,5,745.86,ON,
sometimes there is no delay (like after a short stop for fuel on a trip, or parked for a couple hours) but it is becoming more consistent.
