J393 central locking
senna1
C?ID=231631
Hi All.
Vw caddy van 2008 sdi,, Bst, if replacing the j393 centrol locking control unit does it have to be coded, i have the front doors working ok,, just now to get the rear does to operate, the j393 was replaced with a spare we had,, in my elsa win it quotes coding, if replaced, if so can you explain the procedure, with vcds
Gone But Not Forgotten
I'm getting the sneaky suspicion that people will want to see an auto-scan in code tags.
Procedure:
[Select]
[46-Central Conv.]
[Coding]
Enter the correct value.
You did scan the vehicle prior to replacing the module, right?
senna1
C?ID=231631
No uwe.
I have my hands full with this vehicle, it was bought from a breakers yard, with parts of the loom chopped, the main part was on the passengers side by the sill they chopped through every wire in the sill section, parts missing such as the j393, the rest of the loom small things like the headlight connectors missing, wiper motor connector etc, so doing one thing at a time, such as lights, indicators hazards, The problem i have is some of the wires have two of the same colour, so checking from the j519 to the j393 out to the rear doors central locking, wiper motor, heated screen,
senna1
C?ID=231631
The j393 must be the correct one we have put in as the central locking works,,and with the others we have nothing, just now to get the rear doors to work,
senna1
C?ID=231631
Vehicle is now all done.
