Car: 2008 GTI, 12/2007 build. Red display on the dash. Original CAN
gateway ends in 530K.
Installed RNS315 out of a 2015 Jetta. This unit for sure has bluetooth.
Install went OK. Used the proper antenna adapters and what not. In VCDS,
I enabled "37 Navigation". The box came up for Navigation, but it
doesn't find the radio, no matter what. Radio does work, minus bluetooth
and MFSW controls. Didn't have the issue with CAN gateway not putting
radio to sleep, but forums say that older CAN gateways will have issues
finding RNS315. Swapped in a new CAN gateway from Amazon
<http://www.amazon.com/>. Part number is 7N0907530AJ, with a 2014 build.
Checked off the boxes on the list for all the things this car has
(screen shotted the list from original gateway, and checked off the same
boxes on the new one). The coding menu looks different than the original
gateway. Navigation menu in VCDS does find the unit, with serial number
and all. I went to go uncheck byte 3 bit 5 in Navigation (Telephone
Transceiver/Bluetooth (internal) inactive), and I keep getting the Error
31 message when I go "Do It" (Request out of range - coding rejected). I
believe this is what I need to do to get the bluetooth menu to come up
on the RNS315. If I'm wrong, let me know. I did wire up a bluetooth mic
and plugged it into the back of the radio in the correct spot in the
harness connector.
Would love to get bluetooth working. Also, I hear mixed stories about
MFSW controls working (the volume buttons and phone mute, left side).
Also, the CAN gateway and Navigation both have fault codes for not coded
correctly.
Full scan.....
harness connector.
correctly.
Full scan.....
Sunday,03,July,2016,23:28:05:59930
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
www.Ross-Tech.com <http://www.ross-tech.com/>
VIN: WVWEV71K38W072030 License Plate: NTK54F
Mileage: 107340km-66697mi Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 65
VIN: WVWEV71K38W072030 Mileage: 107340km-66697miles
56-Radio -- Status: Not registered 0001
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: VWX7Z0G63NJ8SY
Coding: 0403010A18070160
Shop #: WSC 01279 785 00200
VCID: 3663D51941AD678E94-8062
Readiness: 0000 0101
Revision: 00H11001
Coding: 0021122
VCID: 73E52C0D125F32A673-8026
Part No SW: 1K0 820 047 GF HW: 1K0 820 047 GF
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
VCID: 6ED33D79797D1F4E9C-803A
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Revision: 00H54000 Serial number: 01000007377159
Coding: A78D0F2700041500470A00000F00000000497F075C00010000 0000000000
Shop #: WSC 06429 444 54105
VCID: 71E92605684300B681-8024
Component: Wischer 170707 021 0501
Coding: 00038805
Shop #: WSC 06429
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D095FT5
Coding: 0013899
Shop #: WSC 01269 785 00200
VCID: 6CD737714F61ED5EB2-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME184F1A71I
Subsystem 3 - Serial number: 6342MSME192F6926M
Subsystem 4 - Serial number: 6352QSME33267935F
Subsystem 5 - Serial number: 6362QSME3367175DN
Subsystem 6 - Serial number: 63727SME0D130323S
Subsystem 7 - Serial number: 63827SME0D13022F/
Address 16: Steering wheel
Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BD HW: 1K0 953 549 BD
Component: J0527 036 0070
Coding: 0002022
VCID: 75E112151C2B2C965D-8020
Component: E0221 002 0010
Part No SW: 1K6 920 974 A HW: 1K6 920 974 A
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0G63NJ8SY
Coding: 0007103
Shop #: WSC 01287 785 00200
VCID: 326BE909ADC57BAEB8-8066
Part No SW: 7N0 907 530 AJ HW: 7N0 907 530 AJ
Component: J533 Gateway H51 1634
Revision: H51 Serial number: 18011400F15821
Coding: 350000
Shop #: WSC 12345 123 12345
VCID: 78FF1B21CB3951FE46-802C
00463 - Control Module for Digital Sound Package (J525)
Reset counter: 1
Mileage: 107344 km
Time: 23:22:55
Mileage: 107344 km
Time: 23:22:51
Component: IMMO VDD 1216
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1Q0 035 274 K HW: 1Q0 035 274 K
Component: RNS315-NAR H85 0501
Serial number: VWZAZ2P0626905
Coding: 000100210400060000008000
Shop #: WSC 00066 123 00118
ASAM Dataset: EV_RNS315NARV2UDS 001705
ROD: EV_RNS315NARV2UDS.rod
VCID: 326BE90965C57BAEB8-8066
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V7N 0060
1048641 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 1
Mileage: 107344 km
Time: 23:24:12
Component: Tuer-SG 006 120A
Coding: 0001077
VCID: 387FDB214BB991FE86-806C
008 - Implausible Signal
Address 44: Steering Assist
Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 00000 028 00001
VCID: 3561D2155CAB6C969D-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Coding: 1B9006885103083F2D04058FB0080A04889C00
VCID: 04077FD147F1051E5A-8050
Coding: 0001076
VCID: 3979DE2570B388F679-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74E72F111751359E6A-8020
01312 - Powertrain Data Bus
Component: RDK 0450
Coding: 0100101
End-------------------------(Elapsed Time: 01:40)--------------------------
