RNS315 MK5 issue. MFSW and Bluetooth not working
9900rpm
C?ID=83902
Car: 2008 GTI, 12/2007 build. Red display on the dash. Original CAN
gateway ends in 530K.
Installed RNS315 out of a 2015 Jetta. This unit for sure has bluetooth.
Install went OK. Used the proper antenna adapters and what not. In VCDS,
I enabled "37 Navigation". The box came up for Navigation, but it
doesn't find the radio, no matter what. Radio does work, minus bluetooth
and MFSW controls. Didn't have the issue with CAN gateway not putting
radio to sleep, but forums say that older CAN gateways will have issues
finding RNS315. Swapped in a new CAN gateway from Amazon
<http://www.amazon.com/>. Part number is 7N0907530AJ, with a 2014 build.
Checked off the boxes on the list for all the things this car has
(screen shotted the list from original gateway, and checked off the same
boxes on the new one). The coding menu looks different than the original
gateway. Navigation menu in VCDS does find the unit, with serial number
and all. I went to go uncheck byte 3 bit 5 in Navigation (Telephone
Transceiver/Bluetooth (internal) inactive), and I keep getting the Error
31 message when I go "Do It" (Request out of range - coding rejected). I
believe this is what I need to do to get the bluetooth menu to come up
on the RNS315. If I'm wrong, let me know. I did wire up a bluetooth mic
and plugged it into the back of the radio in the correct spot in the
harness connector.
Would love to get bluetooth working. Also, I hear mixed stories about
MFSW controls working (the volume buttons and phone mute, left side).
Also, the CAN gateway and Navigation both have fault codes for not coded
correctly.
Full scan.....
Sunday,03,July,2016,23:28:05:59930
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
[url]www.Ross-Tech.com[/url] <http://www.ross-tech.com/>
VIN: WVWEV71K38W072030 License Plate: NTK54F
Mileage: 107340km-66697mi Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 65
VIN: WVWEV71K38W072030 Mileage: 107340km-66697miles
56-Radio -- Status: Not registered 0001
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: VWX7Z0G63NJ8SY
Coding: 0403010A18070160
Shop #: WSC 01279 785 00200
VCID: 3663D51941AD678E94-8062
Readiness: 0000 0101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73E52C0D125F32A673-8026
Part No SW: 1K0 820 047 GF HW: 1K0 820 047 GF
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
VCID: 6ED33D79797D1F4E9C-803A
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007377159
Coding: A78D0F2700041500470A00000F00000000497F075C00010000 0000000000
Shop #: WSC 06429 444 54105
VCID: 71E92605684300B681-8024
Component: Wischer 170707 021 0501
Coding: 00038805
Shop #: WSC 06429
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D095FT5
Coding: 0013899
Shop #: WSC 01269 785 00200
VCID: 6CD737714F61ED5EB2-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME184F1A71I
Subsystem 3 - Serial number: 6342MSME192F6926M
Subsystem 4 - Serial number: 6352QSME33267935F
Subsystem 5 - Serial number: 6362QSME3367175DN
Subsystem 6 - Serial number: 63727SME0D130323S
Subsystem 7 - Serial number: 63827SME0D13022F/
Address 16: Steering wheel
Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BD HW: 1K0 953 549 BD
Component: J0527 036 0070
Coding: 0002022
VCID: 75E112151C2B2C965D-8020
Component: E0221 002 0010
Part No SW: 1K6 920 974 A HW: 1K6 920 974 A
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0G63NJ8SY
Coding: 0007103
Shop #: WSC 01287 785 00200
VCID: 326BE909ADC57BAEB8-8066
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AJ HW: 7N0 907 530 AJ
Component: J533 Gateway H51 1634
Revision: H51 Serial number: 18011400F15821
Coding: 350000
VCID: 78FF1B21CB3951FE46-802C
Reset counter: 1
Mileage: 107344 km
Time: 23:22:55
Mileage: 107344 km
Time: 23:22:51
Component: IMMO VDD 1216
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1Q0 035 274 K HW: 1Q0 035 274 K
Component: RNS315-NAR H85 0501
Serial number: VWZAZ2P0626905
Coding: 000100210400060000008000
Shop #: WSC 00066 123 00118
ROD: EV_RNS315NARV2UDS.rod
VCID: 326BE90965C57BAEB8-8066
Component: NAR_V7N 0060
1048641 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 1
Mileage: 107344 km
Time: 23:24:12
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 120A
Coding: 0001077
VCID: 387FDB214BB991FE86-806C
Address 44: Steering Assist
Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 00000 028 00001
VCID: 3561D2155CAB6C969D-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 1B9006885103083F2D04058FB0080A04889C00
VCID: 04077FD147F1051E5A-8050
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
VCID: 3979DE2570B388F679-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74E72F111751359E6A-8020
01312 - Powertrain Data Bus
Component: RDK 0450
Coding: 0100101
End-------------------------(Elapsed Time: 01:40)--------------------------
Svtweb
C?ID=11754
RNS-315 only speaks BAP. So, you need to upgrade to MK6 Steering wheel and steering wheel electronics to get MFSW to work. To get display on dash, you need to change to White-pixel cluster. Much more involved.
9900rpm
C?ID=83902
There was a dude in the TDI forums that got the left side MFSW controls to work (volume and phone answer). I know that the right side will not work, as the red cluster is DDP or something while RNS315 is BAP only. This is less of an issue than the no bluetooth issue. Any ideas on that?
Svtweb
C?ID=11754
Bluetooth and the other functions are done via coding. If your radio is not coded correctly, you will not get any sound and bluetooth will not operate. Your gateway is coded for Digital sound package, but you do not have that in your car. If you do, make sure that it is connected and fuse is good.
smiffy403
tadley hampshire, UK
C?ID=253985
You have some of the same codes im suffering from after fitting an rns315 dab in my caddy but I'm none the wiser on how to sort them so hopefully you can sort it and I can gain some info from your post &#55357;&#56397; Sorry it's not a helpful reply !
Spacewalker
Poland
C?ID=159607
Most important here is a Cluster , which "transfer" MFSW buttons to radio and with proper cluster radio will recognize buttons
you can also use Mk5 (8 buttons) MFSW with White dot cluster , no need Mk6 (12 buttons)
start from cluster swap first
all other parts are ok to run with UDS cluster
golfi_vend
Tartu, Estonia
C?ID=195131
Passat B6, with 3c8920880G cluster, 8-mfsw and rns315. Volume buttons do not work in this case.
With RNS510, they work.
I think the problem is the radio not recognizing the commands from 8-mfsw as the rns315 never came with 8-mfsw(correct me if wrong).
9900rpm
C?ID=83902
Which fuse am I checking for? The radio (navigation) itself works, just no bluetooth. I know bluetooth is built in to the RNS315, and I'm having trouble enabling it. I keep getting that "Error:31" thing, coding rejected.
Having the digital sound package enabled or disabled makes no difference. Tried it both ways.
9900rpm
C?ID=83902
I'm wondering how the other person got the MK5 left side MFSW buttons (mainly volume) to work. I know the right side (menu) will never work, unless I swap a few more parts, including white dot cluster.
langers2k
C?ID=224085
I thought the RNS-310 didn't have Bluetooth and the RNS-315 did.
The RNS-310 never has bluetooth built in.
The RNS-315 comes both with and without bluetooth. If the MAC is all zeroes, then it doesn't have bluetooth I'm afraid.
Svtweb
C?ID=11754
Must be a European thing. In the US, all RNS-315's have Bluetooth. Some do not have it active, but coding activates it.
golfi_vend
Tartu, Estonia
C?ID=195131
What does Europe do with SAT radio, like the current rns315?
Your unit has sat-radio, so US. And no MAC in sticker, so no BT.
langers2k
C?ID=224085
Even in the US not all RNS-315 have bluetooth, the one golfi_vend posted being a perfect example.
Here is a http://forums.ross-tech.com/showthread.php?170-mk6-xenon-retrofit&p=33410&viewfull=1#post33410 a scan from a 2015 Jetta with an identical RNS-315 to the one you're installing (1Q0035274K RNS315-NAR H85 0501) and you can see it has a separate BT module (5N0035729E).
The easiest way to prove the unit has bluetooth is to post a picture of the sticker with the mac address...
Should look similar to this:
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
As mention above that unit does not have BT built in. I think revision D is last one with built in BT.
To get most buttons to work , you need to update Steering module to CH.
Also Best way to get all functions working with RNS315 is to update MK6 cluster , MK5 MFSW can be used with out any problem.
I did this on my car about year ago with MK6 MFSW and all buttons work:
http://forums.ross-tech.com/showthr...K6-Color-premium-cluster-MK6-MFSW-and-RNS-315
Svtweb
C?ID=11754
OK.. Now it paints a better picture. The vehicle there is a 2015, and has the option of Car-Net.
Address 75: Telematics (J949) Labels: None
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0156
Serial number: 000003554140530
Coding: 02630102C24232007F1606000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_OCULow 002009
ROD: EV_OCULow_SE12.rod
VCID: 142DC2F2FF55979873-8041
That must be why they have a BT-Less RNS-315 and an external BT unit. So that Car-Net will operate.
9900rpm
C?ID=83902
Ok, makes a lot of sense now. I went back to check the sticker on my unit, and it does have all 0's for the MAC address. It came out of a 2015 Jetta, which uses the external BT module.
Guess I'm going to have to decide if I want to add a module or live without BT.
Thanks everyone.
