Hi Guys,
I'm new to the forum so please forgive me if I say or do anything stupid.
I have a 2015 Tiguan with MIB STD2 PQ+/NAV head unit. The standard retrofit reverse camera used in RNS units will not work with this setup. I bought a RL3 interface from NAVLINKZ designed for this head unit.
http://www.navlinkz.de/Interfaces/I...und-High.html?listtype=search&searchparam=rl3
Fitting was straight forward considering all instructions are in German, thanks to google translate!
My problem is the instructions for programing with VCDS say access module 10 park/assist enter security access code go to coding and enable bit 4 RVC . Then access module 5F information system and coding enable bit 4 RVC.
Accessing module 5F was no problem but I was hoping that accessing module 10 security I would get a suggestion for the code by hovering over the box.
Alas no. Do any of you experts know the necessary security code to access this modules coding options.
I have pasted a complete scan if required as I'm not allowed attachments just yet.
Many thanks in anticipation.
Regards
Regards
Wednesday,11,May,2016,19:36:26:21664
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: WVGZZZ5NZGW046623 License Plate:
Mileage: 11830km-7350mi Repair Order:
Chassis Type: 5N (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 4C 4F 52 53 55
5F 61 62 72
VIN: WVGZZZ5NZGW046623 Mileage: 11830km-7350miles
Address 01: Engine (J623-CUWA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 016 DS HW: 04L 907 309 K
Component: R4 2,0L EDC H20 1844
Revision: 8AH20---
Coding: 01250032042701082000
ASAM Dataset: EV_ECM20TDI01104L906016DS 001004
ROD: EV_ECM20TDI01104L906016DS_VW36.rod
VCID: 7DF18EE3ECA5CED615-8028
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0BH 300 012 Q HW: 0BH 927 711 G
Component: DSG DQ500-7A H11 5204
Revision: 00H11V01
ROD: EV_TCMDQ500021_SE36.rod
VCID: 316962D3607DFAB6C1-8064
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 BN HW: 5N0 614 109 BN
Component: J104 C6 450M VDC7 0021
Revision: --H07--- Serial number: 00000008997037
Coding: 0056647
VCID: 78FF9FF70B87EBFE46-802C
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 1K8 907 044 AC HW: 1K8 907 044 AC
Component: Climatronic H05 0304
Revision: 00001K03
Coding: 001000C003
VCID: 70EFA7D7ABF7B3BE8E-8024
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 T HW: 5K0 937 086 T
Component: BCM PQ35 M 122 0183
Revision: BC122001
Coding: 4E180A3FE033E1C0408800C0340009644BD5AB08636D8520E48487000041
VCID: 45812603CCF546160D-8010
Subsystem 1 - Part No SW: 5N2 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 29091 013 0204
Coding: 009795
Component: RLS 300915 05 54 0403
Coding: 02304D
Subsystem 3 - Part No: 5C0 951 171
Component: Sensor, DWA 0 005 0502
Address 10: Park/Steer Assist (J791) Labels: None
Part No SW: 1K8 919 475 B HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0479
Revision: -------- Serial number: 39431527303066
Coding: 0131060051
ASAM Dataset: EV_EPHVA2CVW364GP00 001010
ROD: EV_EPHVA2CVW364GP00_SE36.rod
VCID: 39795AF3B80D32F679-806C
1113875 - Parking Aid Indicator Lamp
B10FF 13 [008] - Open Circuit
Reset counter: 210
1113619 - Parallel Parking Assistance Indicator Lamp
B10FE 13 [008] - Open Circuit
Reset counter: 210
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__20E VW10 HI 3018
Revision: 32022000 Serial number: 003L7PJNTS1R
Coding: 0012357
VCID: 7CF783E73FBFC7DE22-8028
Subsystem 1 - Serial number: 6332MTS619032595
Subsystem 2 - Serial number: 6342MTS668792535
Subsystem 3 - Serial number: 6351HTS6QDNTSDKR
Subsystem 4 - Serial number: 6361HTS6KBBUSDKR
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 FL HW: 5K0 953 569 BD
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20150924301284
Coding: 188A140000
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 7BF580FBF2B1C0E62B-802E
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0885815
Coding: 820000
Part No SW: 5N0 920 983 K HW: 5N0 920 983 K
Component: KOMBI H04 1008
Coding: 111F010000
VCID: 3D714EE3AC250ED655-8068
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7N0 907 530 BB HW: 7N0 907 530 AM
Component: J533 Gateway H55 1663
Revision: H55 Serial number: 010915F1000207
Coding: 356033
VCID: 71E9A2D3A8FDBAB681-8024
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0AY 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7531
Serial number: HA1-00014.08.15
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_AU21.rod
VCID: 52AB0D5F05BBE1AE98-8006
Component: IMMO H04 1008
VCID: 6ADBB5BF8D2B496EC0-803E
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 5N0 959 701 F HW: 3C0 959 793 B
Component: TUER-SG FT 002 0504
Revision: 13110009 Serial number: 0010081848
Coding: 0202BC
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 387F5FF783072BFE86-806C
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 704 F HW: 3C0 959 795 C
Component: J389__TSG-HR 010 1505
Serial number: 00000009558983
Coding: 000090
66560 - Motor for Mirror Adjustment
B11F4 01 [008] - Electrical Failure
Reset counter: 226
Mileage: 11616 km
Date: 2016.05.05
Time: 13:17:18
Part No: 5N0 909 144 R
Component: EPS_ZFLS Kl. 203 3501
Revision: 00H22000
Shop #: WSC 01324 785 00200
VCID: 408F371713D7633E3E-8014
Address 4C: Tire Pressure II
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1663
Coding: 050B0500
VCID: 6FEDA4ABBEC9AC4697-803A
Subsystem 1 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H04 0090
Subsystem 2 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H04 0090
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 5N0 959 702 F HW: 3C0 959 792 B
Component: TUER-SG BT 002 0504
Revision: 15110009 Serial number: 0010080091
Coding: 0202BC
ROD: EV_TSGBPQ35BRFVW46X.rod
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 703 F HW: 3C0 959 794 C
Component: J388__TSG-HL 010 1505
Serial number: 00000009570064
Coding: 000090
Part No SW: 3AA 907 801 J HW: 3AA 907 801 J
Component: J540 EPB4 VW-63206 0012
Revision: H19 Serial number: 00000000863441
Coding: 0026167
VCID: 387F5FF74B072BFE86-806C
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H05 0111
Coding: 049E00000B000200
ROD: EV_HeadlRegulVWAFSPt_SE36.rod
VCID: 377D5CCB8E1924868F-8062
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 140000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 140000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 C HW: 5C0 035 680 C
Component: MU-S-ND-ER H22 0245
Serial number: VWZAZ2R8855446
Coding: 02130601FF00000011111101008808001F0106C600200100CF
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 21499293309D4A3651-8074
Engine Control Module 2:
Subsystem 1 - Part No SW: 3G0 919 866 H HW: -----------
Component: ECE 2015/16 --- 0430
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AM
Component: Batt.regelung H55 1663
Coding: 030F1873
Component: J367-BDM H07 0180
End-------------------------(Elapsed Time: 03:57)--------------------------
