- Nov 10, 2014
- 1,518
- 2,260
- New Zealand
- C?ID=230482
Hi everybody!
I've been asking Uncle Google, but I have a limited time opportunity!
I'd like to know the Steering Rack interchangability between some of the MK5 Golf based cars, and their Audi cousins. Rack Part numbers DO interchange between brands, but I don' know WHICH factors may introduce problems.
I can get another Touran (2005, BLR engine, Japanese Domestic model) VERY cheap, and I do want another one!
This one has a steering rack fault, and I'm hoping the rack from my A3 8P parts car is interchangable! Please?
I've also considered swapping the A3 rack into the existing Touran, which is getting the R32 conversion (slowly!) I suspect the A3 has a quicker ratio.
I have NO info from the available Touran, other than it's VIN: WVGZZZ1TZ5W185288
I suspect that if the two scans below suggest compatibility, I should be fine as the 2 Touran racks would probably be compatible.
Any help is greatly appareciated - I've been hunting for broken Tourans, with Trans faults, but this is probably even better, if it works out!
Our Existing Touran:
The A3 parts car:
Tuesday,09,December,2014,16:38:19:42165
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WVGZZZ1TZ6W129773 License Plate: DMS886
Mileage: 120000km-74564mi Repair Order:
Chassis Type: 1T (1K0)
VIN: WVGZZZ1TZ6W129773 Mileage: 120000km-74564miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 06F 906 056 EM HW: Hardware No
Component: MED9.5.10 G00 8229
Revision: --H03--- Serial number: VWZ7Z0F3307625
Coding: 0000075
Shop #: WSC 01324 785 00200
VCID: 78FFC7DA0B77FEE157B-802D
Readiness: 0000 0101
Part No: 09G 927 750 CS
Component: AQ 250 6F 0847
Coding: 0000072
VCID: 0407A32A47BFAA014B3-8051
01045 - Tiptronic Switch (F189)
Address 03: ABS Brakes Labels: 1K0-614-517-MK60-F.lbl
Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Component: ESP FRONT MK60-AT 0102
Revision: 00H13001
Coding: 0021190
VCID: 68DF979A5BD76E61C7B-803D
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 BD
Component: ClimatronicPQ35 090 0808
VCID: 6ADBED9245DB5C71D1F-803F
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005382893
Coding: 008D0F210004100000120C000000000000097B075C
VCID: 2A5B2D92855B9C7111F-807F
Subsystem 1 - Part No: 1T0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW358 012 0401
Coding: 00063445
Shop #: WSC 01324
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0H4NRK
Coding: 0012338
VCID: 35610EEE5CE5C3898CD-8060
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0010042
VCID: 76E3C9E201638891457-8023
Part No: 1T0 920 862 E
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0000001
Shop #: WSC 00010 824 70462
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800106127113D
Coding: 3F3F0340078003
Component: IMMO VDD 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2302
Coding: 0000692
VCID: 366309E241E3C891857-8063
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 346733EA579FDA81BB3-8061
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 00C802087F2D8405485FC61010CC
Shop #: WSC 00010 824 05318
VCID: 79F9C2DE307DE7E9285-802C
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Subsystem 6 - Part No: 1K0 951 605 C
Subsystem 7 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000692
VCID: 377D04E646E931999E1-8062
Part No: 1K0 035 186 P
Component: Radio GR0 015 0019
Revision: 0001503S Serial number: VWZ2Z2F3751220
Coding: 0040400
VCID: 336530F65291DDB9A29-8066
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2428
Coding: 0000144
VCID: 326B35F2AD8BD4B1A9F-8067
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
End-------------------------(Elapsed Time: 01:44)--------------------------
The A3 parts car:
Sunday,14,December,2014,13:47:26:42165
VIN: WAUZZZ8P94A155758 License Plate: A3
Mileage: 150140km-93292mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 47 52 55 56
VIN: WAUZZZ8P94A155758 Mileage: 150140km-93292miles
47-Sound System -- Status: Cannot be reached 1100
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 CB HW: Bas isX 3
Component: MOTRONIC ME7.1.1 8088
Revision: 00000000 Serial number: AUX7Z0D2FNJ0DI
Coding: 0000178
Shop #: WSC 12345 210 01865
VCID: 4D91460ED475AB49D4D-8018
9 Faults Found:
18554 - Accelerator Position Sensor (G79)
P2122 - 002 - Signal too Low - Intermittent
18559 - Accelerator Position Sensor 2 (G185)
P2127 - 002 - Signal too Low - Intermittent
28836 - No Communications with HVAC Control Module (J301)
U0164 - 008 - - Intermittent
16497 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High
19475 - Valve for Exhaust Flap 1 (N321)
P3019 - 004 - Open Circuit - Intermittent
18080 - Coolant Fan Control 1
P1672 - 004 - Open or Short to Ground - Intermittent
16414 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 - 004 - Malfunction / Open Circuit - Intermittent
16434 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
P0050 - 004 - Malfunction / Open Circuit - Intermittent
16486 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low - Intermittent
Readiness: 0110 1101
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 046 D HW: 02E 927 770 AD
Component: GSG DSG 0632
Revision: 04202624 Serial number: 00000912010414
Shop #: WSC 04940 001 00001
VCID: 183FE75A2B371EE1B7B-804D
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent
28775 - No Communication with Gear Selector Module
U0103 - 000 - - Intermittent
00194 - Ignition Key Removal Lock
18270 - Powertrain Data Bus
P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
18082 - Powertrain Data Bus
P1674 - 000 - Implausible Message from Instrument Cluster - Intermittent
18288 - Powertrain Data Bus
P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No: 1K0 907 379 E
Component: ESP ALLRAD MK60 0103
Coding: 0021122
Shop #: WSC 06435 000 00000
01312 - Powertrain Data Bus
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 037768 Serial number: 8P0820043D
VCID: 2D51268EB4B58B49F4D-8078
01810 - Actuating Motor for Temperature Flap; Right (V159)
Fault Status: 00100011
Fault Frequency: 73
Reset counter: 120
Mileage: 137629 km
Date: 2014.02.06
Time: 17:55:05
Voltage: 13.80 V
Temperature: 32.0°C
(no units): 26.0
(no units): 49.0
Temperature: 23.0°C
Reset counter: 104
Mileage: 149087 km
Date: 2014.08.29
Time: 13:29:25
Voltage: 8.20 V
Fault Status: 01101000
Reset counter: 84
Mileage: 150146 km
Date: 2014.09.11
Time: 03:48:28
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 D HW: 8P0 907 279 D*
Component: Bordnetz-SG 1.0 H30 0701
Revision: 00030000 Serial number: 00000000661583
Coding: A38E5F01A0141000000000000000000000
VCID: 3E7311C269D300D15D7-806B
Subsystem 1 - Component: Fehler Lin-Slave 01
10 Faults Found:
02071 - Local Databus
010 - Open or Short to Plus
01800 - Light Switch (E1)
02397 - Parking Light Rear Right (M2)
02396 - Parking Light Rear Left (M4)
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0410603
VCID: 4385603602316D39329-8016
01218 - Side Airbag Igniter; Passenger Side (N200)
01217 - Side Airbag Igniter; Driver Side (N199)
00591 - Seat Belt Switch; Driver (E24)
00592 - Seat Belt Switch; Passenger (E25)
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 HW: 8P0 953 549
Component: Lenksäulenmodul H11 0020
Coding: 0011112
VCID: 7BF5D8D63A41D5F93A9-802E
Component: Lenkradmodul H03 0040
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 G HW: 8P0 920 930 G
Component: KOMBIINSTR. VDO H25 0140
Revision: D09 Serial number: 2242DD09024698
Coding: 0000001
Shop #: WSC 12345 012 00123
Coding: 0000001
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 25001042210752
Coding: FF0F0342070101
VCID: 285FD79A9B57AE6107B-807D
Reset counter: 84
Mileage: 150146 km
Date: 2014.09.11
Time: 04:21:33
Address 22: AWD Labels: None
VCID: 55A1AE6EBCA5E3896CD-8000
No Faults Found
Revision: D09 Serial number: AUX7Z0D2FNJ0DI
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
Part No: 8P0 959 801
Component: Tuersteuerger. H10 0010
Coding: 0000048
Part No: 1K2 909 144 F
Component: EPS_ZFLS Kl.10 1301
VCID: 2F6D3C86BEB9F959C61-807A
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 A
Component: KSG H02 0040
Coding: 008800186D288505485A016000
Shop #: WSC 07130 981 60707
VCID: 3A7B1DD275FB2CF161F-806F
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Address 47: Sound System
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
Part No: 8P0 959 802
Coding: 0000048
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 A
Component: Dynamische LWR H01 0010
Coding: 0000001
VCID: 387F07DA4BF73EE197B-806D
Fault Status: 11100101
Reset counter: 84
Mileage: 150152 km
Date: 2014.09.11
Time: 04:21:28
Fault Status: 11101010
Reset counter: 84
Mileage: 150152 km
Date: 2014.09.11
Time: 04:21:28
Reset counter: 84
Mileage: 150152 km
Date: 2014.09.11
Time: 04:21:28
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 B HW: 8P0 035 186 B
Component: concert II JP H53 0060
Revision: 07S Serial number: AUZ2Z3C1008064
Coding: 0001001
VCID: 31693AFEA88DEFA9D05-8064
End-------------------------(Elapsed Time: 02:57)--------------------------
Wednesday,17,December,2014,17:17:38:42165
Coding: 0000178
Coding: 0021122
8 Faults Found:
00493 - ESP-Sensor Unit (G419)
01486 - System Function Test Activated
014 - Defective
Fault Frequency: 73
Reset counter: 120
Mileage: 137629 km
Date: 2014.02.06
Time: 17:55:05
Voltage: 13.80 V
Temperature: 32.0°C
(no units): 26.0
(no units): 49.0
Temperature: 23.0°C
Reset counter: 104
Mileage: 149087 km
Date: 2014.08.29
Time: 13:29:25
Voltage: 8.20 V
Reset counter: 124
Mileage: 150146 km
Reset counter: 84
Mileage: 150146 km
Date: 2014.09.13
Time: 00:15:29
10 Faults Found:
02104 - Light Detection Sensor (G399)
01835 - Bulb for Side-Blinkers; Right (M19)
01834 - Bulb for Side-Blinkers; Left (M18)
01495 - Bulb for High-Beams; Left (M30)
Coding: 0410603
Coding: 0011112
02413 - Switch for Selector Lever Position P Lock (F319)
Coding: 0000001
Shop #: WSC 08447 016 263172
Fault Frequency: 29
Reset counter: 84
Mileage: 150146 km
Date: 2014.09.11
Time: 04:21:33
Fault Status: 00101110
Reset counter: 124
Time Indication: 15
Address 22: AWD
Coding: 0000048
Coding: 0000048
Coding: 0000001
Reset counter: 84
Mileage: 150152 km
Date: 2014.09.11
Time: 04:21:28
Reset counter: 84
Mileage: 150152 km
Date: 2014.09.11
Time: 04:21:28
Reset counter: 84
Mileage: 150152 km
Date: 2014.09.11
Time: 04:21:28
Fault Frequency: 0
Mileage: 1048568 km
Coding: 0001001
Reset counter: 124
Date: 2014.09.13
Time: 02:05:10
Bin. Bits: 10
End-------------------------(Elapsed Time: 01:53)--------------------------
