Audi 8K xenon retrofitting
pronet
Romania
C?ID=157414
Hello guys,
A friend of mine wants to retrofit the factory halogen to xenon headlights. I check if the 09 Centr.electric supports this retrofit but it seems not. Also, not all bites/byts were documented. I'm asking you if, using the actual central electric is possible this retrofitting. Scan below:
Friday,28,February,2014,02:29:40:56830
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WAUZZZ8K1BN021157   License Plate:
Mileage: 103970km-64603mi   Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 56 5F 62 72
VIN: WAUZZZ8K1BN021157   Mileage: 103970km/64603miles
Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 MK    HW: 03L 906 022 B
   Component: R4 2,0L EDC   H10 8441
   Revision: 11H10---
   Coding: 0104002C02072118
   Shop #: WSC 22151 143 999999
   ASAM Dataset: EV_ECM20TDI03L906022MK A01009
   ROD: EV_ECM20TDI03L906022C.rod
   VCID: 7AF007C1FD02A7CED53-802F
4987 - Cylinder 4 Glow Plug Circuit (Q13)
          P0674 00 [096] - Electrical Fault
Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
   Part No SW: 8K0 927 155 AF    HW: 0AW 927 156 H
   Component: 0AW 20TDI RdW H06 0009
   Revision: --H06---    Serial number: 0000000701
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMVL381 A02017
   ROD: EV_TCMVL381.rod
   VCID: 77F61EF5CE10BAA6AAD-8022
9827 - Clutch Pressure Adaptation
          P1741 00 [044] - Limit Reached
                    Mileage: 103467 km
                    Date: 2014.01.31
                    Time: 08:28:28
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
   Part No SW: 8K0 907 379 BF    HW: 8K0 907 379 BF
   Component: ESP8 front    H04 0030
   Coding: 170500
   Shop #: WSC 02391 823 56573
   VCID: 7EF80BD1E92A8BEEE9B-802B
   Part No SW: 8K0 907 064 CA    HW: 8K0 907 064 CA
   Component: BCM2 2.0      H04 0430
   Coding: 010100
   Shop #: WSC 02399 823 56573
   VCID: 71E220EDA874E496649-8024
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H50 0071
   Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
   Component: KLIMA 1 ZONE  H08 0180
   Revision: A1000000    Serial number: 01250820100831
   Coding: 34100000
   VCID: 7DFA0CDDE42C90F6F01-8028
   Component: BCM1 1.0      H29 0392
   Revision: 10029001    Serial number: 00000000632588
   Coding: 690040B10134BE000001000300005F5F4F1C420802000001000000
   VCID: 3C7CC1D9BFB659FE87F-8069
   Component: WWS 200810  H06 0070
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
   Component: E1 - LDS  H08 0090
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0070
   Revision: 11001001    Serial number: 51241024300227
   Coding: 100103
   VCID: 4796AE35F6700A261AD-8012
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 J    HW: 8K0 959 655 J
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GKD0K22TJ
   Coding: 30343435363030303030554A304C384B3053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 448CB939CF46213EFFF-8011
   Serial number: 6334MSME563322598
   Serial number: 6344MSME56332746A
   Serial number: 6352QSME386F0B0EY
   Serial number: 6362QSME16692802C
   Serial number: 63732SME076C2804
   Crash sensor for front airbag; passenger side:
   Serial number: 63832SME6D5F37107
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90315JI3000AU
   Coding: 000016
   VCID: 3D7ACCDDA4AC50F6B01-8068
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 930 N    HW: 8K0 920 930 N
   Component: KOMBIINSTR.   H22 0258
   Revision: 00000000    Serial number: EJC56ZP8A
   Coding: 0F37080002000008000001
   VCID: 3874DDC98B8E75DE637-806D
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E10816812D
   Coding: 00C303
   VCID: 830EFA2502C86606065-80D6
   Component: J367-BDM  H07 0170
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1401
   Coding: 011C02204000410001
   Shop #: WSC 10101 599 00000
   VCID: 53AE8A653228B686765-8006
   Revision: 00002001    Serial number: 0133106253
   Coding: 0100062000B900808120013280000000
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1401
   Coding: 011C02204C00410001
   VCID: 52A08F610D32BF8E7D3-8007
   Revision: 00000003    Serial number: 10000000596824
   VCID: 346CE9F997E691BE4FF-8061
   Part No SW: 4G0 035 053     HW: 4G0 035 053
   Component: Radio U Basic H51 0051
   Revision: AB001007    Serial number: 496I00A7550337
   Coding: 010003020100000001
   VCID: DBBEE245DAF8FEC62E5-808E
   Part No SW: 8T1 035 654 F    HW: 8T1 035 654 D
   Component: B-BNT-EU      H58 0144
   Revision: --------    Serial number: 324G/0A7515696
   Coding: 01010000030681ED01000F0E000000030000
   VCID: 3A70C7C1B58267CE953-806F
   Subsystem 1 - Part No SW: 8T0 919 604     HW: 8T0 919 604
   Component: DU6 Basic  H42 0084
   Subsystem 2 - Part No SW: 8T0 919 609     HW: 8T0 919 609
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
   Component: TSG HL        H06 1401
   Coding: 010C02204000210001
   VCID: 56A8737121DAA3AE91B-8003
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Component: TSG HR        H06 1401
dules
Slovenia - Kranj
C?ID=99478
Welcome
You'll have to replace bcm1 which controls the lights, because they will not be part of the high beam. Each car has no factory built-in extra pin. Original bcm unit you must activate the car to an authorized service center
pronet
Romania
C?ID=157414
Ok. I got it. Thanks you very much. Why I have to go to an authorized service? As far as I known the BCM is not pin protected. I assume if I have the BCM I can mounted my self, I'm correct or not?
dules
Slovenia - Kranj
C?ID=99478
bcm heave component protection and unlock only authorized service
United States
Hi dules!
pronet I agree, most of the modules in a 8K/8T/8R Audi have Component Protection so a new BCM1 controller would need to be unlocked via SVM.
-Dana
pronet
Romania
C?ID=157414
Ok. Thanks Dana. What does SVM stand for?
