Golf7 with MIB2 and Fender move to Dynaudio. Long coding help
PepeVr6
Dallas, TX USA
C?ID=47704
My first post here! after ~9 years of using VCDS! Now to the point:
I have a 2016 Golf R NA version. It comes with MIB2 and Fender Audio System.
I am not happy with the Fender overall performance and I am exploring the option to retrofit a Dynaudio Excite system which is the standard one in EU and ROW. Based on my findings so far the PN of the Dynaudio Amplifier for the MIB2 platform is the same part number as the Fender one found in my car: 5Q0 035 456, the speakers of course are different but can be purchased later.
Just for the sake of proof of concept, since the amplifier seems to be the same, I want to configure the audio settings on Information Electronics (5F) long code as Dynaudio. Assuming the HW/DSP is the same and that the “Dynaudio features” (equalization parameters, DSP functions, etc) should be loaded into the AMP and appear in the Audio Settings menu in the MIB2 display.
I am using VCDS 15.7.4 and my 2016 NA Golf R (with Discover Media and Fender Sound System with subwoofer) long code for 5F Information Electronics is 027300020000000051220002001808001F0207F401200105C6
So far the only information I found here and in other forums about audio system settings are:
1. Bytes 04/07 (Sound System Channels): My code for Fender is “0000”. As you can see the long code help doesn’t provide relevant information.
2. Byte 11 Sound System. My code for Fender is “02”. As you can see the long code help doesn’t provide relevant information.
Are there dependencies on the Country settings? Any Golf R with MIB2 and Dynaudio in ROW can share their codes? I also checked the excel with various countries comparison but it looks the same as mine (Fender) on the relevant bytes.
Pointers are appreciated.
^^^^^^^^^^^^^^^^ don't have MIBII, but here's the hex02 option for byte11
PepeVr6
Dallas, TX USA
C?ID=47704
I need the long code for a 4 doors Golf7 with Dynaudio and MIB2, most likely a 2016, in order to compare. Also support from Ross Tech staff on the rifht values for Dynaudio MIB2 setup will be nice. :thumbs:
^^^ Pepe: Have you looked in Jeff's "Reference scan" section of this forum? If you can't find the exact car that you want, you might be able to find a MQB platform vehicle with a similar pedigree!
PepeVr6
Dallas, TX USA
C?ID=47704
DV52, thanks for the suggestion Mate! :)
I found the MIBII comparison excel file.That one is not very clear, The "German" R has Canada country code and the German "Morde" Golf has a different HW and even though is a supposedly Dynaudio (based on the Startup_Screen_Sticker_HMI field) has the same code as the Fender.So it's very tricky.
I didn't try the reference scans yet , but I assume is also tricky.
Pepe: Of course the primary question does need to be asked - I haven't asked it because you appear to have a good understanding of the mk7's audio equipment (it's certainly better than mine). But are you sure that the high-end system on both sides of the Atlantic are that different?
PepeVr6
Dallas, TX USA
C?ID=47704
Good question Don. Based on my findings, the Audio Amp has the same PN for both systems, Fender and Dynaudio, therefore it should be the same hardware.With that assumption I just want to "enable" the advanced features that the dynaudio system shows in the Audio Menu, with better acoustic parameters and focus digital signal processing. At the end of the day I want check the project feasibility enabling and using these advanced features. Is my opinion that both systems have the same HW but the "Fender" setup is de-featured. Makes sense?
ASR
C?ID=270252
Subscribed to this, very interesting!!
quailallstar
Ormond Beach, FL
C?ID=53119
Subscribed as well because I'm looking to do the same thing. Going to remove the Dynaudio speakers off my MK6 Golf TDI in hopes of them working with the MK7 Fender system in the Golf Wagon. Has there been any progress in re-coding the Fender amp into a Dynaudio one? I can post an auto scan of my vehicle too if it helps figure out the coding.
Danilo78
Italy
C?ID=216246
Hi to all guys
I maked upgrade from MIB1 to MIB2
My Golf is GTD MY2015 with dynaudio installed on factory
Amplifier unit must be changed from 5G0 035 456 (for MIB1) to 5Q0 035 456 (for MIB2)
5Q0 amplifier was new with coding 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 (14 bytes)
5G0 amplifier coding 12 00 00 00 8A AA 00 8A (8 bityes)
I writed first 8 bites on 5Q0 from 5G0 for works. It works but not fine
I have central subwoofer speaker error
Somebody can help me please?
^^^ ^^ Danilo: Hello - Jef (of RT fame) posted an auto-scan report from a 2016 Golf Estate, 1.8T CXBB (not sure which country) in the reference scan thread on this forum which had the following details:
   Component: MIB2_lite_amp H20 0130
   Revision: 00000001    Serial number: VWZ8Z1FBA01355K
   Coding: 2200000000AAAAAA000000000000
   Shop #: WSC 01383 790 50316
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: ED9DCAE33C790554F4-80B8
Might be worth trying the code-string
D-Dub
C?ID=272151
My sister bought a 2017 gti autobahn over the holiday, but I haven't had a chance to scan it with hex-net yet.
It has auto cruise control, blind spot indicators, discover (not sure if pro) with fender audio and subwoofer, and has apple/android car play, navigation etc.
I'll post up the auto-scan as soon as I can, but it may be a week or more since she is ~3 hours away.
Danilo78
Italy
C?ID=216246
Thank you so much DV52
I will try your coding 😉
Danilo78
Italy
C?ID=216246
I cannot try new coding....
I'm out of my city for work now....
I back to home next week
Danilo78
Italy
C?ID=216246
No good your coding string
radio in mute and dtc -> coding error :cry:
FROM POST #10
Hi to all guys
I made an upgrade from MIB1 to MIB2
Danilo: I'm entirely reading "between-the-lines", but you say in post #10 that you "upgraded from MIB1 to MIB2" , and you also say (above) that "radio in mute". Just linking-the-dots, do you have a Component Protection DTC on the 5F module ?
Might be worthwhile returning the code-string on the 5F module to its original value and then posting-up an auto-scan so we can see what's happening!
Danilo78
Italy
C?ID=216246
Now I reinstalled mib1 because not possible adaptation of mib2 by vw dealer.
I did try to use new license for mib2 but by odis online not possible....
Now I did send mib2 to my friend for cracked it.
Actually I have mib1 with mib2 amplifier.
It works, but I have central sibwoofer open circuit on dtc.
Do you need autoscan with this configuration?
This is autoscan with MIB2 installed
Tuesday,06,December,2016,09:59:20:05573
VCDS Version: 16.8.4.2
VIN: WVWZZZAUZFW******   License Plate:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 3C 42 44 47 52 55
          5F A5 A9 C0
VIN: WVWZZZAUZFW******   Mileage: 49309km-30639miles
Address 01: Engine (J623-CUNA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EQ    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 8360
   Revision: 81H22---
   Coding: 091D0032036405083000
   ASAM Dataset: EV_ECM20TDI01104L906021EQ 002011
   ROD: EV_ECM20TDI01104L906021ER.rod
   VCID: 78F42609C3C68E82F1-802C
   Part No SW: 0D9 300 041 Q    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4504
   Revision: 05853104    Serial number: TFK01504011518
   ROD: EV_TCMDQ250021.rod
   VCID: 2648387159F2C87293-8072
   Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
   Component: ESC           H42 0711
   Revision: 00000000    Serial number: 60935000002968
   Coding: 01FA6BA13423096F077A0608C1C8A980D62C90E0608395F5186250FAC289
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 499293CDE8ACC70A5E-801C
   Revision: 00021000    Serial number: 0365830359
   Coding: 030C0C
   VCID: 3A70FC01BD4A5C92C7-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020114202400011105000200101000
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6AD00C418D6A2C1277-803E
   Air quality sensor:
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011510602060
   Coding: 00111E66C24122FB0BA44080B11C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 00044EE99B16C642C9-8054
   Component: WWS    150403  043 0551
   Serial number:         150410040138
   Component: RLHS  037 0059
   Serial number: S3Y15M04D20H00M25S18
   Coding: 1EA8DD
   Serial number: 000000000ZY150750Y1C
   Serial number: 00000000000062141643
   Sun Roof:
   Component: J245 PS73.403  H03 0004
   Serial number: 0000FST0008DFNN00000
   Coding: 181901
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0047
   Revision: --------    Serial number: 39431510500062
   Coding: 0031165051
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 428084E1D59A14529F-8016
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 24031503273603
   Coding: 001C1700FE0739
   VCID: 3874E60983464E8231-806C
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H16 0115
   Serial number: 24031541350375
   ROD: EV_DRCONTITEMIC.rod
   VCID: 76E82831C9D2F8F2E3-8022
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR0DSP8I
   VCID: 7F06CD15E6E8B9BAB0-802A
   Belt Pretensioner left:
   Serial number: 34169667B19041510022
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169668B17041570842
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 204 15
   Serial number: 35767000000007B8B31Q
   Subsystem 4 - Part No SW: -----------    HW: 480 001 304 15
   Serial number: 35867000000AAB70141U
   Subsystem 5 - Part No SW: -----------    HW: 480 400 904 15
   Serial number: 3516502AD1A87850B26H
   Subsystem 6 - Part No SW: -----------    HW: 480 400 904 15
   Serial number: 3526502AB1A878517117
   Subsystem 7 - Part No SW: -----------    HW: 480 400 904 15
   Serial number: 3556502C9194131463A3
   Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 15041504400949
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 7BFE3905F2F0A59A9C-802E
   Part No SW: 5G1 920 757     HW: 5G1 920 757
   Component: KOMBI         301 4310
   Coding: 07AD09187F9C000800887A0B5400000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   VCID: 6BDE09458290351A0C-803E
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0003390353
   Coding: 030100040F087300FF00027E9D0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72E01421A5BAE4D2CF-8026
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150000730720045153
   Coding: 2DFFFF
   Serial number: 2520616303
   Revision: 00000000    Serial number: 15000091730001
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 346CD2399F2EAAE21D-8060
Address 3C: Lane Change (J1086)       Labels: None
   Part No SW: 5Q0 907 686 A    HW: 5Q0 907 686 A
   Component: HRE_Master    H11 0066
   Serial number: 0364164866
   Coding: 02011103
   ASAM Dataset: EV_HREntryHella 001024
   ROD: EV_HREntryHella.rod
   VCID: 3B7EF905B270659ADC-806E
   Lane Change Assistant 2:
   Serial number: 230315BCM00796
   Coding: 003F1220D000048000001000
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
   Serial number: 00000000000005805248
   Coding: 110000
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 9303
   VCID: 3776E5358E5841FA38-8062
   Revision: 00000001    Serial number: VWZ8Z1GBA02AEXN
   Coding: 120000008AAA008A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001002
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 6DDA075DBC843B2A12-8038
   Serial number: 020415BD205411
   Coding: 003F1020DE00048000801000
   VCID: 41828BEDD09C0F4A86-8014
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
   Serial number: 00000000000005921294
   Coding: 090000
   Coding: 029203104F010200
   VCID: 40848EE9DB96064289-8014
   Subsystem 1 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 900000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-HGH2.clb
   Part No SW: 3G0 035 021 C    HW: 3G0 035 021
   Component: MU-H-TND-EU   H50 0343
   Serial number: A680J0FB000738
   Coding: 027300010000000011111202000800101F0202F4010001009F
   VCID: 18340689E3866E8211-804C
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU301E7E
   Subsystem 2 - Part No SW: V03 959 800 QN    HW: -----------
   Component: ECE 2016  --- 0134
   Compact Disc Database:
   Component: Gracenote2  --- 1012
6696 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [009] - No Communication
                    Reset counter: 34
                    Mileage: 49309 km
                    Date: 2016.12.06
                    Time: 09:37:02
                    Voltage terminal 30: 13.5 V
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 34
                    Mileage: 49309 km
                    Date: 2016.12.06
                    Time: 09:36:37
                    BAP-BAP_Function_ID: 02
7171 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 34
                    Mileage: 49309 km
                    Date: 2016.12.06
                    Time: 09:36:37
7172 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 34
                    Mileage: 49309 km
                    Date: 2016.12.06
                    Time: 09:36:37
7179 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 34
                    Mileage: 49309 km
                    Date: 2016.12.06
                    Time: 09:36:37
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 10000341309
   Coding: 0101020001020303020400010100000100
   ROD: EV_MFKBoschAU370.rod
2555904 - Databus
                    Reset counter: 34
                    Mileage: 49309 km
                    Date: 2016.12.06
                    Time: 09:36:33
                    Control Module temperature: 37 °C
                    Outside air temperature: 10.5 °C
                    Vehicle speed: 0.00 km/h
                    Voltage terminal 15: 13.3 V
                    System run time: 1036.6 s
   Component: SAS-GEN 2     H06 0014
   Serial number: 150311200428
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 5G0 907 160     HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0006
   Serial number: 150324201384
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS_VW12.rod
   VCID: 63CE61656A407D5AB4-8036
End-------------------------(Elapsed Time: 05:51)--------------------------
Danilo78
Italy
C?ID=216246
Do you need more autoscan @DV52?
