Friday,07,October,2016,20:28:49:50930
-- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: WVWFV71K37W166153 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWFV71K37W166153 Mileage: 333160km-207016miles
03- Brakes -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH15--- Serial number: VWZ7Z0G8013765
Coding: 0403010A1C070160
Shop #: 01279 067 57207
VCID: 2B7BF8198AC3C21A25-807E
13 Faults Found:
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Mileage: 333157 km
Temperature: 24.0°C
Temperature: 34.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.954 V
004952 - Cylinder 2 Ignition Circuit
P1358 - 004 - Open Circuit - Intermittent
Mileage: 333157 km
Time: 01:22:45
RPM: 214 /min
Load: 62.7 %
Temperature: 24.0°C
Temperature: 34.0°C
Voltage: 11.049 V
004961 - Cylinder 3 Ignition Circuit
P1361 - 004 - Open Circuit - Intermittent
Mileage: 333157 km
Time: 01:22:46
RPM: 214 /min
Load: 53.3 %
Temperature: 24.0°C
Temperature: 34.0°C
Voltage: 10.922 V
004964 - Cylinder 4 Ignition Circuit
P1364 - 004 - Open Circuit - Intermittent
Mileage: 333157 km
Time: 01:22:46
RPM: 214 /min
Load: 53.3 %
Temperature: 24.0°C
Temperature: 34.0°C
Voltage: 10.922 V
P0300 - 008 - - MIL ON
Fault Status: 11101000
Mileage: 333157 km
Time: 04:18:51
RPM: 1227 /min
Load: 47.0 %
Temperature: 25.0°C
Temperature: 24.0°C
Voltage: 14.224 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - MIL ON
Mileage: 333157 km
Time: 04:19:14
RPM: 1185 /min
Load: 44.7 %
Temperature: 32.0°C
Temperature: 24.0°C
Voltage: 13.970 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected - Intermittent - MIL ON
Fault Status: 10101000
Mileage: 333157 km
Time: 04:19:14
RPM: 1185 /min
Load: 44.7 %
Temperature: 32.0°C
Temperature: 24.0°C
Voltage: 13.970 V
000770 - Cylinder 2
P0302 - 008 - Misfire Detected - MIL ON
Mileage: 333157 km
Time: 04:19:14
RPM: 1185 /min
Load: 44.7 %
Temperature: 32.0°C
Temperature: 24.0°C
Voltage: 13.970 V
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Mileage: 333157 km
Time: 04:19:57
RPM: 1398 /min
Load: 19.6 %
Temperature: 40.0°C
Temperature: 24.0°C
Voltage: 14.224 V
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 - 002 - Incorrect Correlation - MIL ON
Fault Status: 11100010
Mileage: 333157 km
Time: 05:03:05
RPM: 1065 /min
Load: 45.5 %
Temperature: 43.0°C
Temperature: 27.0°C
Voltage: 13.970 V
008825 - Leak in Air Intake System
P2279 - 002 -
Fault Status: 01100010
Mileage: 333157 km
Time: 05:04:19
RPM: 829 /min
Load: 22.0 %
Temperature: 54.0°C
Temperature: 28.0°C
Voltage: 13.970 V
004506 - Fuel Pressure Sensor (G247)
P119A - 001 - Malfunction
Fault Status: 01100001
Mileage: 333157 km
Time: 05:06:02
RPM: 748 /min
Load: 17.6 %
Temperature: 62.0°C
Temperature: 30.0°C
Voltage: 13.970 V
008196 - Intake Manifold Flap; Bank 1
P2004 - 008 - Stuck Open - MIL ON
Mileage: 333158 km
Time: 05:11:31
RPM: 251 /min
Temperature: 81.0°C
Temperature: 30.0°C
Voltage: 12.954 V
Readiness: 0010 0101
Part No SW: 02E 300 043 Q HW: 02E 927 770 AE
Component: GSG 070 1306
Revision: 04607000 Serial number: 00000612040951
Shop #: 01279 785 00200
VCID: 2265153DFD09035296-8076
Address 03: Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73CB20791273DADAAD-8026
013 - Check Memory - Intermittent
Part No: 1K0 820 047 GS
Component: Climatic PQ35 120 0606
Shop #: 00000 000 00000
VCID: 7BDB08593A23929AF5-802E
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006559540
Coding: 178D8F214004150047140000001400000028770B5C0001
Shop #: 22580 444 57677
VCID: 6CF93B054F4D05226C-8038
Component: Wischer 201206 020 0501
Coding: 00038805
Shop #: 22580
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 H HW: 8E0 035 593 H
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7F0024301
VCID: 2E7DF10DB9D1B73202-807A
Reset counter: 253
Mileage: 333157 km
Time: 04:18:46
02788 - Internal Communications Error
Fault Frequency: 43
Reset counter: 0
Mileage: 333160 km
Time: 08:24:30
Bin. Bits: 00000000
Bin. Bits: 00000001
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 5L AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D07R6RE
Coding: 0013644
Shop #: 01269 785 00200
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME151A07522
Subsystem 3 - Serial number: 6342MSME156A6B6EV
Subsystem 4 - Serial number: 6352QSME1C76133DN
Subsystem 5 - Serial number: 6362QSME1E183E4D-
Subsystem 6 - Serial number: 63727SME0B640C2E9
Subsystem 7 - Serial number: 63827SME0B771B200
01587 - Igniter 2 for Airbag; Drivers Side (N250)
001 - Upper Limit Exceeded - Intermittent - MIL ON
00591 - Seat Belt Switch; Driver (E24)
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 636 0070
Coding: 0012122
VCID: 77D31469060BB6FA91-8022
Component: E0221 002 0010
Part No SW: 1K6 920 973 A HW: 1K6 920 973 A
Revision: V0003000 Serial number: VWZ7Z0G8013765
Coding: 0007207
Shop #: 22580 444 53700
VCID: 3147EA71A8EFA8CA1F-8064
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 070107F1001226
Coding: 7F8F03600F000000
VCID: 2F43EC09BEDBBE3A09-807A
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T1QSF03
VCID: 7DDF064124379CAACB-8028
Component: IMMO VDD 1610
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0983
Coding: 0001077
VCID: 3851D7554B95798258-806C
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: 00000 028 00001
VCID: 3449E36557FD9DE274-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 052 0218
Revision: 00052000 Serial number: 00000000000000
Coding: 139006885103281B0904058FB0080A04889C00
Shop #: 22580 444 999999
VCID: 042973A547DDED6284-8050
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
VCID: 3957D251709F608AA7-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74C92365177DDDE2B4-8020
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio PM6 017 0023
Revision: 00017000 Serial number: VWZ5Z7F2121101
Coding: 0040401
VCID: 24691325E71D0D62E4-8070
Component: 0440
Coding: 0100101
End-------------------------(Elapsed Time: 01:11)--------------------------
