07 GTI Won't Start. Turns over and fires a couple times
GTIF
San Diego USA
C?ID=281154
Hi, new to the forum and to computer controlled VWs. Background: I bought this 2007 GTI not running. PO said it just quit at a light and that was it. It sat for 9 months with no battery. I bought a battery and I started doing research and checking things. I replaced the spark plugs, crank sensor, cam sensor, and HPFP cam follower. Ran compression test, checked good. 130ish on all 4 (207K miles). Changed oil, new filter, checked for spark and fuel pressure, checked fuses, cleaned the MAF. No obvious cracks in intake tubes. Engine cranks and fires a couple times then nothing, just keeps cranking. Same results with starter fluid. OBDII codes wouldn't read so I bought a VCDS from Ross-Tech. The output tells me MAF, intake leak, or bad injectors (or all 3!). I will check the MAF with my multi meter tonight. Any thoughts?
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWFV71K37W16XXXX   Mileage: 333150km-207009miles
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 H    HW: 8P0 907 115 B
   Revision: 5BH15---    Serial number: VWZ7Z0G8013765
   Coding: 0403010A1C070160
   Shop #: WSC 01279 067 57207
   VCID: 2B7BF8198AC3C266FB-807E
               P0300 - 008 -  - Intermittent
                    Fault Status: 00111000
                    Mileage: 332939 km
                    Time: 19:57:33
                    RPM: 889 /min
                    Load: 25.5 %
                    Temperature: 86.0°C
                    Temperature: 65.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.081 V
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 -  - Intermittent
                    Fault Status: 00110100
                    Mileage: 333058 km
                    Time: 05:03:23
                    RPM: 1050 /min
                    Load: 15.3 %
                    Speed: 6.0 km/h
                    Temperature: 78.0°C
                    Temperature: 57.0°C
                    Voltage: 12.954 V
008825 - Leak in Air Intake System
               P2279 - 002 -  - Intermittent
                    Fault Status: 00110010
                    Mileage: 333058 km
                    Time: 05:03:36
                    RPM: 895 /min
                    Load: 15.7 %
                    Temperature: 78.0°C
                    Temperature: 58.0°C
                    Voltage: 12.954 V
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage - Intermittent
                    Mileage: 333157 km
                    Temperature: 27.0°C
                    Temperature: 28.0°C
                    Voltage: 12.192 V
Readiness: 0110 0101
   Part No SW: 02E 300 043 Q    HW: 02E 927 770 AE
   Component: GSG DSG         070 1306
   Revision: 04607000    Serial number: 00000612040951
   Shop #: WSC 01279 785 00200
   VCID: 2265153DFD09032E48-8076
18243 - Pressure Control Valve 5 (N233)
            P1835 - 000 - Short to Plus - Intermittent
                    Fault Frequency: 255
                    Reset counter: 8
                    Mileage: 308178 km
19143 - Unexpected / Implausible Mechanical Gear Disengagement
            P2711 - 005 -  - Intermittent
                    Fault Status: 00100101
                    Reset counter: 37
                    Mileage: 312318 km
   Revision: 00H11001
   Coding: 0021122
   VCID: 73CB20791273DAA673-8026
   Part No: 1K0 820 047 GS
   Component: Climatic PQ35   120 0606
   VCID: 7BDB08593A2392E62B-802E
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006559540
   Coding: 178D8F214004150047140000001400000028770B5C0001
   Shop #: WSC 22580 444 57677
   VCID: 6CF93B054F4D055EB2-8038
   Component: Wischer 201206 020  0501
   Coding: 00038805
   Shop #: WSC 22580
                    Reset counter: 38
                    Mileage: 333157 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 8.90 V
   Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7F0024301
   VCID: 2E7DF10DB9D1B74EDC-807A
                    Reset counter: 38
                    Mileage: 333157 km
                    Time: 06:17:28
                    Voltage: 8.30 V
                    Reset counter: 38
                    Mileage: 333157 km
                    Time: 00:03:47
                    Voltage: 8.40 V
            000 -  -
                    Reset counter: 216
                    Mileage: 105914 km
                    Time: 13:42:53
02788 - Internal Communications Error
            000 -  -
                    Reset counter: 253
                    Mileage: 333157 km
                    Time: 19:11:35
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
01304 - Radio
                    Reset counter: 38
                    Mileage: 333157 km
                    Time: 00:01:34
   Component: 5L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D07R6RE
   Coding: 0013644
   Shop #: WSC 01269 785 00200
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME151A07522
   Subsystem 3 - Serial number: 6342MSME156A6B6EV
   Subsystem 4 - Serial number: 6352QSME1C76133DN
   Subsystem 5 - Serial number: 6362QSME1E183E4D-
   Subsystem 6 - Serial number: 63727SME0B640C2E9
   Subsystem 7 - Serial number: 63827SME0B771B200
00591 - Seat Belt Switch; Driver (E24)
            010 - Open or Short to Plus - Intermittent - MIL ON
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
            003 - Mechanical Failure - Intermittent - MIL ON
            008 - Implausible Signal - Intermittent - MIL ON
            002 - Lower Limit Exceeded - Intermittent - MIL ON
01587 - Igniter 2 for Airbag; Drivers Side (N250)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           636 0070
   Coding: 0012122
   VCID: 77D31469060BB6864F-8022
   Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
   Revision: V0003000    Serial number: VWZ7Z0G8013765
   Coding: 0007207
   Shop #: WSC 22580 444 53700
   VCID: 3147EA71A8EFA8B6C1-8064
9 Faults Found:
                    Reset counter: 38
                    Mileage: 333157 km
                    Time: 00:03:21
00771 - Fuel Level Sensor (G)
                    Fault Status: 00101010
                    Fault Frequency: 9
                    Reset counter: 38
                    Mileage: 332184 km
                    Time: 06:09:43
                    Reset counter: 38
                    Mileage: 333157 km
                    Time: 00:04:17
                    Reset counter: 38
                    Reset counter: 38
                    Reset counter: 38
                    Reset counter: 38
                    Reset counter: 38
                    Fault Frequency: 9
                    Reset counter: 38
                    Mileage: 332184 km
                    Time: 06:09:43
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 070107F1001226
   Coding: 7F8F03600F000000
   VCID: 2F43EC09BEDBBE46D7-807A
                    Reset counter: 37
                    Mileage: 333157 km
                    Time: 00:04:17
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T1QSF03
   VCID: 7DDF064124379CD615-8028
   Component: IMMO            VDD 1610
01176 - Key
   Component: Tuer-SG         005 0983
   Coding: 0001077
   VCID: 3851D7554B9579FE86-806C
01552 - Motor for Central Locking; Drivers Door (V56); Lock
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 3449E36557FD9D9EAA-8060
                    Mileage: 333150 km
                    Temperature: 17.0°C
                    Voltage: 6.00 V
                    Voltage: 5.80 V
            000 -  -
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Component:    KSG PQ35 RDK 052 0218
   Coding: 139006885103281B0904058FB0080A04889C00
   Shop #: WSC 22580 444 999999
   VCID: 042973A547DDED1E5A-8050
            000 -  -  - Intermittent
                    Fault Frequency: 61
                    Reset counter: 38
                    Mileage: 330689 km
                    Time: 04:39:02
                    Reset counter: 38
                    Mileage: 333157 km
                    Time: 00:04:16
   Coding: 0001076
   VCID: 3957D251709F60F679-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74C92365177DDD9E6A-8020
00070 - Starting Battery Voltage
   Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
   Component: Radio PM6       017 0023
   Revision: 00017000    Serial number: VWZ5Z7F2121101
   Coding: 0040401
   VCID: 24691325E71D0D1E3A-8070
                    Reset counter: 37
                    Mileage: 333157 km
                    Time: 09:00:23
   Component:    RDK              0440
   Coding: 0100101
End-------------------------(Elapsed Time: 01:16)--------------------------
Gavra
Melbourne/Belgrade
C?ID=240855
Put new fuel,fuel filter and when it start give some revs up and keep it there for 3-5min. After erase DTC and run again with new auto-scan .
Jef
HQ
130 PSI compression seems a bit low to me, generally we'd like to see +160 PSI. Having said that, I'd expect the engine to still run.
Pull the plugs up, crank... any fuel poofing out?
NostraJackAss
Add oil to cylinders and see if compression comes up.
Check fuel PSI and volume delivery from HPP and to it.
Check or soak/clean fuel injectors and check spray pattern if possible.
Check intake and PCV for leaks as well as a stuck N80 dumping fuel resulting in washing cylinders/rings.
GTIF
San Diego USA
C?ID=281154
All good advice. Thanks. Now to decide which to do first. Before putting in new plugs, I pulled the old ones after trying to start and checked color and condition. One was wet, two were a little moist, and one was pretty dry. All were a dark brown color, typical of burning oil. I did not see any "poof" of fuel out the coil holes when turning it over to check the plugs, but I wasn't really looking for it either. I picked up a new fuel filter today.
GTIF
San Diego USA
C?ID=281154
I decided to empty the fuel tank first. My siphon pump tube won't go down the fuel filler tube enough. Is there another easy way to drain the tank? Is 9 month old gas already bad enough to make the engine not start? It doesn't smell like old gas. :confused:
NostraJackAss
Run fuel output hose at sender to fuel collection tank and run the pump manually. Add your own additional hose to extend from lift pump.
GTIF
San Diego USA
C?ID=281154
Sounds simple enough. When you say manually, you mean run a 12v lead directly to the tank pump? I tested the MAF yesterday by putting my multimeter on ohms across the connector pins and got no readings. Should they be open or show resistance?
Emptied the gas tank. New filter and fresh 91 octane and no change. I'll start looking at the PCV and N80 and checking out the injectors by listening for pulse, then if necessary, pulling them and cleaning them.
GTIF
San Diego USA
C?ID=281154
I pulled the PCV and it flows both ways freely. I assume it should shut on one direction. I'm going to get a spark tester (OTC 6589) and check the coils again. Maybe they're weak but showed spark. Can't get to it for a couple weeks though.
ivagp
C?ID=95551
dont strain ur brain. ur compression is way to lo. when u checked comp was the battery charged if not charge battery and retest. like jack said add oil just a few drops should do. if you put to much oil u can damage the engine
GTIF
San Diego USA
C?ID=281154
OK, I'm back from my 100 mile mountain bike race in Oregon. Finished 2nd in my class. Woohoo! I replaced the bad PCV and tried starting, not much better than before. I pulled the plugs and the small hose from the PCV to simulate WOT and ran the compression test again. 1-4 got 160, 165, 156, 156, so compression looks good.
What's the best test of the MAF without the engine running? I tried continuity across the pins and got nothing. Should I test for voltage with KOEO?
I could smell fuel when I was running the compression test, but the new plugs don't all have a uniform appearance. #1 and 2 were a normal brown color, #4 was a little too clean, and #3 was pretty dark and sooty. I have an injector tester coming, so I'll go there next.
GTIF
San Diego USA
C?ID=281154
I'm really stumped. I sent the injectors for cleaning and testing and it turns out they were all good. Before and after tests were nearly identical. While I had them out I cleaned the intake valves and runners and throttle body. I tested the coils again, this time with a spark tester, and it showed pretty good spark on all 4. Reassembled and I'm still getting nothing, not even a pop. I even tried some starting fluid down the intake tube, but with the distance from that the cylinders, it may have been pointless.
How can I test the HPFP? If the LPFP works, will the engine have enough fuel pressure to start? The fuel pressure relief valve squirts fuel.
Anything I haven't tried that I should? I ordered a new evap purge valve - just in case, but I don't like shooting in the dark.
Thanks in advance for any helpful suggestions.
NostraJackAss
Is the exhaust plugged with bananas or CAT plugged............. is intake clear for air way?
You have compression?
Engine in time?
GTIF
San Diego USA
C?ID=281154
I have good compression.
Haven't checked for clogged cat yet.
If the valve timing was off, wouldn't there be interference between pistons and valves? I'll see what I can do to check that.
Thanks.
GTIF
San Diego USA
C?ID=281154
I felt a pulse at the exhaust while cranking so I think it's clear. Then I pulled the plugs and cranked for several seconds to check for fuel. The plugs came out bone dry and there is no hint of fuel smell after cranking. What controls the injectors? Maybe they're not firing. After sitting an hour or overnight it will fire a couple times like some fuel seeped into a cylinder over time.
NostraJackAss
The ECU and consumer supply current paths as per RTFB observed in WD.
Have you checked all fuses in this car, ignition switch, and all terminal relays + ground points?
GTIF
San Diego USA
C?ID=281154
OK, I got the Bentley and did RTFB and followed WD. Great book; says for troubleshooting use VAS 5051/5052, which I don't have and can't afford. I pulled all the related relays and checked them, as well as fuses. They all work. I disconnected the battery to pull some of the relays inside under the dash and now my auto-up/down windows stopped working. :banghead: I have a feeling it could be the ECU. How can I test that?
South Molton, UK
After disconnecting the battery you need to reset the one-touch windows by running them up and holding the switch for several seconds, then running them down and holding the switch for several seconds.
