I have a VW Crafter 2010 2.5 TDI with AdBlue fault on the dash. Probably the AdBlue just ran out, but after filling it's still there.There is no good support in Measuring Blocks and/or Adaptation.
Does anyone have any info on which Measuring Blocks should I look, and where can I reset SCR/AdBlue stuff?
Controller Maps: https://cloud.txt.si/index.php/s/iTgNcFPigzcOKZj
Thanks in advance
Tuesday,28,June,2016,07:43:57:09308
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WV1ZZZ2EZB6012704 License Plate: CRAFTER-ADBLUE
Chassis Type: 2E (2E - VW Crafter (LT3 / 2006 >))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (CEC) Labels: Redir Fail!
Part No SW: 076 906 022 P HW: 076 906 022 G
Component: R5 2,5L EDC A020SG 9022
Revision: 24H37--- Serial number: VWXDZ0J1026241
Coding: 0003072
Shop #: WSC 07128 298 81854
VCID: 204FE394F0E7BF3E5E-5106
Readiness: 0 3 0 0 1
Address 91: LT3 Engine Labels: Redir Fail!
Coding: 0003072
VCID: 204FE394F3E7BF3E5E-8074
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 905 865 AD HW: 906 545 580 8
Component: IMMO 0805 0815
Revision: 00805000 Serial number: VWXDZ0J1026241
VCID: 6DD1CAA074B5A256A5-8038
Address 94: LT3 Airbag Labels: None
Part No HW: 9064461442
Shop #: WSC 00117 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3332.rod (*)
VCID: 55A1824034250A967D-8000
8 Faults Found:
9003 - Supply voltage: Lower limit not reached
Test Complete - Stored
9195 - CAN info: Signal "Left-hand drive (LHD)/Right-hand drive (RHD)" not received
9193 - CAN info: Signal "Country-specific Special Equipment" not received
9196 - CAN info: Signal "Body" not received
9197 - CAN info: Signal "Engine" not received
9194 - CAN info: Signal "Model Series" not received
9181 - CAN info: Signal "Terminal Status" not received
9600 - Airbag control module (J234): Internal malfunction
Address 95: LT3 ESP Labels: None
Part No SW: 9069022800 HW: 0004460153
ASAM Dataset: 3 4101
ROD: CRFT_ESP_3_4101.rod (*)
VCID: 04078F048F3F431E5A-8050
Address 96: LT3 Instruments Labels: None
Part No SW: 9069026400 HW: 9069011800
ASAM Dataset: 32 787
ROD: CRFT_KOMBI_32_787.rod (*)
Address 99: LT3 Ign. Switch Labels: None
Part No HW: 9065455808
ASAM Dataset: 67 257
ROD: CRFT_EZS_67_257.rod (*)
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 0805 0815
Revision: 00805000 Serial number: 12345678901234
Address 9B: LT3 Driver Door Labels: None
Part No HW: 9068205626
ASAM Dataset: 33 260
ROD: CRFT_FTUHR_33_260.rod
900A - Driver's heated mirror: Short to Plus
Test Complete - Active/Stored
Address 9C: LT3 HVAC Labels: None
Part No SW: 2514450200 HW: 9068300885
ASAM Dataset: 21 2
ROD: CRFT_KLIMA_21_2.rod (*)
VCID: 77FDE8C8CEE918864F-8022
Address B4: LT3 Central Elec. Labels: None
Part No SW: 9069027500 HW: 9069011400
ASAM Dataset: 33 548
ROD: CRFT_EZE_33_548.rod (*)
VCID: 0603950CB903710E44-8052
901D - License plate lights/side-marker lights: Open circuit
9042 - Front Interior Light (W1): Short to Plus
9001 - Bulb for Left Parking Lamp (M1): Short to Plus
90B5 - Control module: Faulty
Address B6: LT3 Steering Wheel Labels: None
Part No SW: 9065402345 HW: 9065402345
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
End-------------------------(Elapsed Time: 02:48)--------------------------
Thanks in advance
