My Electronic Parking Brake failed
Pyper70
Greece or Los Angeles
C?ID=251291
It used to happen once a week....this morning after 6 months of dealing with it...It took me 10 minutes to disengage the brake. I finally got a VCDS of the log and here it is..
It's a 2008 Passat with a 1.4L 6-spd
I ordered a new button and it should be here this week but something tells me the problem is deeper than that...please ignore the other codes...like HVAC..I know the motors on the v159 need to be replaced. The parking lights burned out and although I have them, I haven't had the time to replace them
#44 Steering assist is a new one...Don't know what that is about
Mileage: 111990km-69587mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ9P035411   Mileage: 111990km-69587miles
Address 01: Engine (CAX)       Labels: 03C-906-022-CAX.clb
   Part No SW: 03C 906 022 AJ    HW: 03C 906 022 J
   Component: MED17.5.20      G   2341
   Revision: D5H06---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00028 028 00001
   VCID: 64E95AADA777CA1EEF-8030
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000786105156
   Coding: 0000307
   VCID: 2B7BF1918A294566EE-807E
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 CR    HW: 3C0 907 044 CR
   Component: ClimatronicPQ46 132 0811
   Revision: 00132023    Serial number: 00000000000000
   VCID: 73CB29F112995DA666-8026
01810 - Actuating Motor for Temperature Flap; Right (V159)
            000 -  -  - Intermittent
                    Fault Frequency: 71
                    Reset counter: 138
                    Mileage: 110726 km
                    Time: 14:41:01
   Revision: 00H54000    Serial number: 00000004936026
   Coding: 01840F0700041A00470A00000F00000000095D415C000100000000000000
   VCID: 334BE9F152191DA6A6-8066
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 100708 003  0205
   Coding: 00046997
   Shop #: WSC 00028
                    Fault Status: 01101100
                    Fault Frequency: 72
                    Reset counter: 99
                    Mileage: 107120 km
                    Voltage: 13.35 V
                    Fault Frequency: 21
                    Reset counter: 99
                    Mileage: 105086 km
                    Voltage: 13.45 V
                    Fault Frequency: 9
                    Reset counter: 99
                    Mileage: 105086 km
                    Voltage: 13.50 V
   Component: J234__005 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPHY5WW+
   Coding: 0012341
   VCID: 3B5BC1D17A49D5E67E-806E
   Subsystem 1 - Serial number: 6333FTS640602468
   Subsystem 2 - Serial number: 6343FTS651052478
   Subsystem 3 - Serial number: 6353ETS6KKJUUVNR
   Subsystem 4 - Serial number: 6363ETS6O8JUUVNJ
   Part No SW: 3C0 953 549 AB    HW: 3C0 953 549 AB
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C5953507AN
   Coding: 0000011
   VCID: 6CF9328D4FA7825EA7-8038
   Part No SW: 3C0 920 853 H    HW: 3C0 920 853 H
   Component: KOMBIINSTRUMENT VD1 1222
   Revision: V0003000    Serial number: 00000000000000
   Coding: 0005105
   Shop #: WSC 00460 207 45725
   VCID: 29770B9980D557761C-807C
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 H    HW: 3C0 907 951
   Component: J533__Gateway   H13 0142
   Revision:   H13       Serial number: 2600P08826010F
   Coding: F9807F064002021002
   VCID: 266D00A591CB780E31-8072
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Shop #: WSC 06402 785 00200
   VCID: 3957DBD97075E7F66C-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 P
   Component: RNS-MID       H04 5274
   Revision: AB001001    Serial number: VWZ6Z749331161
   Coding: 04000440040000800000
   Shop #: WSC 43770 133 92736
   VCID: 3753DDE18661F1869A-8062
   Component: EU West V12  8195
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1517
   Revision: 72009005    Serial number: 00000772488818
   Coding: 0000181
   VCID: 6FC325817EB1794682-803A
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.080 0401
   Revision: 1AH02234    Serial number: 00081640492602
   Coding: 0000258
   VCID: 364DD0E5416B088E81-8062
01288 - Terminal 30; Steering Assist
                    Fault Status: 00101011
                    Fault Priority: 9
                    Reset counter: 138
                    (no units): 2.0
                    Voltage: 12.60 V
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 042 0472
   Coding: 18910A0001860E7630049C1C70084F0B607CA1
   Shop #: WSC 08224 211 56823
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1517
   Revision: 72009005    Serial number: 00000769088822
   Coding: 0000180
   VCID: 70C126FD638F66BE9B-8024
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000126943
   Coding: 0000057
   VCID: 28710E9D9BDF6E7E03-807C
                    Fault Status: 00101100
                    Fault Frequency: 107
                    Reset counter: 139
                    Mileage: 109779 km
                    Voltage: 12.80 V
                    Count: 10
                    Hex Value: 0x1271
                    Hex Value: 0x0001
                    Hex Value: 0x1010
02434 - Supply Voltage for Control Module for Left Channel
            009 - Open or Short to Ground - MIL ON
                    Fault Status: 11101001
                    Reset counter: 99
                    Mileage: 111994 km
                    Voltage: 12.60 V
                    Count: 16
                    Hex Value: 0x12F0
                    Hex Value: 0x0001
                    Hex Value: 0x0101
02435 - Supply Voltage for Control Module for Right Channel
                    Reset counter: 99
                    Mileage: 111994 km
                    Voltage: 12.60 V
                    Count: 17
                    Hex Value: 0x12F0
                    Hex Value: 0x0001
                    Hex Value: 0x0101
16366 - Control Module - Internal Malfunction; CPU 2
            014 - Defective - MIL ON
                    Fault Status: 11101110
                    Fault Frequency: 12
                    Reset counter: 99
                    Mileage: 109779 km
                    Voltage: 12.80 V
                    Count: 41
                    Hex Value: 0x1271
                    Hex Value: 0x0001
                    Hex Value: 0x1010
16352 - Control Module - Electrical Error
                    Fault Frequency: 198
                    Reset counter: 99
                    Mileage: 107083 km
                    Voltage: 13.20 V
                    Count: 42
                    Hex Value: 0x12E8
                    Hex Value: 0x8001
                    Hex Value: 0x0101
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0308
   Revision: 41004101    Serial number: 00000000595392
   Coding: 0000144
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0308
   Revision: 41004101    Serial number: 00000000607707
   Coding: 0000144
   VCID: 71C723F968856FB694-8024
End-------------------------(Elapsed Time: 01:22)--------------------------
Based on those faults, I would think you need a new EPB module. But given the code in 44, maybe investigate power and grounds first.
Pyper70
C?ID=251291
I have never even taken off my steering wheel....where would I even check for a loose ground or power cables? Maybe something near the fusebox?
golfi_vend
Tartu, Estonia
C?ID=195131
Any fault like this is a indication of faulty module. Maybe SW update helps "SOME RARE CASES", if available, but mostly not.
                    Fault Frequency: 12
                    Reset counter: 99
                    Mileage: 109779 km
                    Voltage: 12.80 V
                    Count: 41
                    Hex Value: 0x1271
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 99
                    Mileage: 107083 km
                    Voltage: 13.20 V
                    Count: 42
                    Hex Value: 0x12E8
                    Hex Value: 0x8001
                    Hex Value: 0x0101
Jef
HQ
Address 44: Steering Assist is the electric power steering rack, not the steering wheel. So check your powers/grounds for the power steering rack.
vagtuning
VCDS Super-User
C?ID=57100
Just a try :
If fault code 03200 or 16352 is present in the Electromechanical Parking Brake (EPB) module,
it may be due to the switch and module not being synchronized.
To synchronize the EPB switch and EPB control module:
• Insert the ignition key to the run position
• Press and hold the EPB switch
• Cycle the ignition off and then back to the run position
• Let off of the EPB button.
But i think you will have to get a new 3AA EPB-Module...not the first one that quits
with those and/or other...
Gone But Not Forgotten
When checking for power and grounds at 0x44........... be sure you can "carry current", not just measure voltage with a meter.
