- Mar 30, 2015
- 191
- 130
- Melbourne/Belgrade
- C?ID=240855
Hi, today I've updated to 16.6 and right after I have been continuously losing communication with ECU (01) when DTC read selected or when adaptation screen selected. VCDS just freeze and I must kill process from task manager.
Problem is AC pressure signal implausible and I want to test it's data in engine MVB
I have already sent email to support with Controller channel map scan. This is just reminder to fix bugs before release
Monday,27,June,2016,15:39:58:48102
VCDS Version: 16.6.0.2
Data version: 20160602 DS251
Workshop Code: 011 12345 012345
VIN: WAUZZZ8K79N068672 License Plate: DEKI A4
Mileage: 80950km-50299mi Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 07 08 09 0E 10 15 16 17 19 37 42 46 47 52 53 55
56 62 72 77
VIN: WAUZZZ8K79N068672 Mileage: 80950km-50299miles
Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 MK HW: 03L 906 022 B
Component: R4 2,0L EDC H01 4379
Revision: 11H01---
Coding: 0104002C02072118
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM20TDI03L906022MK A01006
ROD: EV_ECM20TDI03L906022C.rod
VCID: 7AFBCC22FD64BF9397-802E
5568 - Sensor for Ambient Air Temperature (G17)
P0073 00 [039] - Signal too High
Mileage: 80950 km
Date: 2016.06.27
Time: 14:59:07
Engine speed: 830.50 /min
Normed load value: 29.4 %
Coolant temperature: 79 °C
Intake air temperature: 36 °C
Voltage terminal 30: 13.700 V
Crankshaft speed (RPM): 830.5 /min
Vehicle speed: 0.00 km/h
Vehicle voltage terminal 30: 13700 mV
Coolant temperature: 79.5 °C
Fuel temperature: 44.5 °C
Control Module temperature: 47.9 °C
Engine oil temperature: 70.3 °C
Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
Part No SW: 8K0 927 155 AF HW: 0AW 927 156 H
Component: 0AW 20TDI RdW H01 0006
Revision: --H01--- Serial number: 0000000628
ASAM Dataset: EV_TCMVL381 A02005
ROD: EV_TCMVL381_AU48.rod
VCID: 77FDD516CE76A2FBE8-8022
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AE HW: 8K0 907 379 AE
Component: ESP8 front H04 0240
Coding: 170500
Shop #: WSC 02391 823 56573
VCID: 7CF7CA3AFF5081A385-8028
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H80 0145
Coding: 010100
Shop #: WSC 02399 823 56573
VCID: 306F2E0A6398B5C369-8064
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 147
Mileage: 80950 km
Date: 2016.06.27
Time: 14:55:02
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 T HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 329CY097639641
Coding: 0000001
Shop #: WSC 02135 785 00200
VCID: 4A9B5CE22504EF1347-801E
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000242836
Subsystem 3 - Serial number: 0118.02.090000000100010208ÿ
Subsystem 4 - Serial number: 010208ÿ
Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
Component: KLIMA 1 ZONE H06 0150
Revision: A1000000 Serial number: 01040320092128
Coding: 34000000
VCID: 70EFEE0AA318F5C329-8024
00457 - Control Module for Network (J519)
Reset counter: 147
Mileage: 80950 km
Date: 2016.06.27
Time: 15:27:16
Fault Status: 01101000
Reset counter: 147
Mileage: 80950 km
Date: 2016.06.27
Time: 15:27:16
Temperature: 1.0°C
03023 - Running-in Requirement
Fault Status: 01100101
Reset counter: 147
Mileage: 80950 km
Date: 2016.06.27
Time: 15:27:16
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H24 0253
Revision: 05024001 Serial number: 00000000333610
Coding: 2600509141340A010001000300001D0D0F1C430800010001000000
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 170309 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 P HW: 8K0 941 531 P
Component: E1 - LDS H07 0090
Fault Status: 01101100
Reset counter: 147
Mileage: 80950 km
Date: 2016.06.27
Time: 14:54:00
Reset counter: 147
Mileage: 80950 km
Date: 2016.06.27
Time: 14:54:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T1 035 110 C HW: 8T1 035 110 C
Component: MP3-Changer H43 0390
Revision: 00043003 Serial number: AUZ5ZBI8762807
VCID: 2A5B3C628544CF13A7-807E
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 G HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0040
Revision: 11001001 Serial number: 40040906411631
Coding: 100103
VCID: 3D71073EA4CA48ABF2-8068
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H27 0410
Serial number: 0038JD1EDRU%
Coding: 30343435363030303030554A304C384B3053
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C770A3AB7D041A3C5-8068
Serial number: 6334MSME446238336
Serial number: 6344MSME430351370
Serial number: 6352QSME611E490CO
Serial number: 6362QSME6F1C3008N
Serial number: 63732SME38214F3C4
Serial number: 63832SME5C215304W
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304ICD0007Z
Coding: 000016
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 C HW: 8K0 920 930 C
Component: KOMBIINSTR. H18 0224
Revision: 00200000 Serial number: 9E234JU29
Coding: 0307080002000008000000
Shop #: WSC 60326 001 00002
VCID: 2D51377E74AAD82B42-8078
Reset counter: 147
Mileage: 80950 km
Date: 2016.06.27
Time: 14:54:58
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 P HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0095
Revision: EB500046 Serial number: 4600E093038062
Coding: 000303
VCID: 4E9350F2196CC3331B-801A
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H52 1060
Revision: 00000000 Serial number: 333CQ097650249
Shop #: WSC 00493 128 21336
VCID: 3B7509267ADE469BCC-806E
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000008590183
Coding: 011C02205000410001
VCID: 41897BCED8322C4B96-8014
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0117405472
Coding: 0100062000390084012001
Subsystem 1 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS034 H06 0037
Reset counter: 147
Mileage: 80950 km
Date: 2016.06.27
Time: 14:55:02
Address 47: Sound System (J525) Labels: 8T0-035-223-BAM.clb
Part No SW: 8T0 035 223 AE HW: 8T0 035 223 R
Component: DSP Basic H08 0300
Revision: S2600000
Coding: 010101
VCID: 71E9EB0EA812FCCB26-8024
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000008605493
VCID: 408F7ECAD338254399-8014
Reset counter: 147
Mileage: 80950 km
Date: 2016.06.27
Time: 14:54:57
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 G HW: 8K0 907 801 G
Component: EPB Audi B8 H08 0080
Revision: 00000003 Serial number: 00000000324964
VCID: 33652106928E8EDB14-8066
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Coding: 0000004
VCID: 77FDD5160676A2FBE8-8022
Part No SW: 4E0 910 541 T HW: 4F0 035 541 N
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 379C+097582718
Coding: 0000001
VCID: 31692B0EA892BCCB66-8064
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: TSG HL H10 0251
Revision: Serial number: 0000100832033
Coding: 010C02204000210001
VCID: 448772DAC7203963BD-8010
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100832030
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005308170
Coding: 0010910
VCID: 2C573A7A8FB0D12355-8078
End-------------------------(Elapsed Time: 03:51)--------------------------
