Hi,
Someone help me with Passat B6 2.0TDI 2008? I have a problem because recode CAN-gatway to LHD and then I lost coding ABS.
It seems to me that ABS module is incorrectly coded, or it may be the cause of the error?
Best regards.
LOG
Best regards.
LOG
Thursday,12,June,2014,14:45:02:26855
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WVWZZZ3CZ8E216250 License Plate:
Mileage: 145030km-90117mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ8E216250 Mileage: 145030km/90117miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 FN HW: 03L 907 309
Component: R4 2,0L EDC G000SG 2643
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 80093 222 71269
VCID: 76E3E11901AFDAAEB1B-8023
008482 - Accelerator Position Sensor (G79)
P2122 - 000 - Signal too Low - Intermittent
Mileage: 145037 km
Date: 2013.08.21
Time: 03:41:54
Voltage: 11.86 V
Voltage: 0.684 V
Voltage: 0.304 V
Bin. Bits: 0 00 0
008487 - Accelerator Position Sensor 2 (G185)
P2127 - 000 - Signal too Low - Intermittent
Mileage: 145037 km
Date: 2013.08.21
Time: 03:41:54
Voltage: 11.86 V
Voltage: 0.684 V
Voltage: 0.304 V
Bin. Bits: 0 00 0
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 K HW: 3C0 614 109 K
Component: J104 C4 440 V2 0005
Revision: --020--- Serial number: 00000785401546
Coding: 0000267
Shop #: WSC 05311 000 00000
VCID: 2643F159918FEA2EC1B-8073
Fault Status: 01101000
Reset counter: 172
Mileage: 145037 km
Date: 2013.08.23
Time: 03:26:54
Hex Value: 0x0000
Voltage: 11.50 V
Bin. Bits: 00011111
Count: 221
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
VCID: 70EFD70163CBF49E6B7-8025
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000008173132
Coding: 00808F0100041A00470A00000F000000000859435C000100000000000000
Shop #: WSC 05124 123 12345
VCID: 71E9D20568C1FD96649-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 060807 003 0205
Coding: 00046997
Shop #: WSC 05124
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__006 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP4SBD2M
Coding: 0012342
VCID: 3B75302D7A0D47C68E5-806E
Subsystem 1 - Serial number: 6333FTS663970448
Subsystem 2 - Serial number: 6343FTS647100549
Subsystem 3 - Serial number: 6353ETS6JLHNSVNH
Subsystem 4 - Serial number: 6363ETS6D4OQSVNP
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AE HW: 3C0 953 549 AE
Component: J0527 0020
Revision: 00026000 Serial number: 3C5953507AT
Coding: 0000111
VCID: 6FEDD47D7EF5EB6672D-803A
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 E HW: 3C0 920 971 E
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0000105
Shop #: WSC 12345 123 45725
VCID: 275DFC5D9685F326FAD-8072
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P083120682
Coding: F9807F060002021002
VCID: 2345E84DE2BD1F06A65-8076
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 39792A25703175D69C9-806C
Component: ELV 027 0380
3C0905861G ELV 027 0380
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1517
Revision: 72009005 Serial number: 00000751398211
Coding: 0000181
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 73430 000 90108
VCID: 356126155C2991B6781-8060
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: A_ KSG PQ46 ELV 042 0472
Coding: 01910A0001860E7F3004941570084FCE007C01
Component: Neigungssensor 004 0611
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08121508002304
Coding: 0001204
Shop #: WSC 00066 000 00000
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000388949
Coding: 0000057
VCID: 2959FA658091C556EC9-807C
03182 - Clutch Position Sensor (G476)
Fault Status: 11111010
Reset counter: 172
Mileage: 145037 km
Date: 2013.08.23
Time: 03:26:54
Voltage: 11.20 V
Count: 57
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0101
Part No: 1K0 035 186 AD
Component: Radio GR0 034 0033
Revision: 0003404S Serial number: VWZ2Z2H6542474
Coding: 0040400
Shop #: WSC 05314 000 00000
VCID: 68DFBF615B1B3C5E337-803D
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0308
Revision: 41004101 Serial number: 00000000274447
Coding: 0000144
01813 - Supply Voltage for Door Controller; Rear Left (J388)
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 172
Mileage: 145037 km
Date: 2013.08.23
Time: 03:27:55
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0308
Revision: 41004101 Serial number: 00000000284053
Coding: 0000144
End ---------------------------------------------------------------------
