- Jun 19, 2016
- 51
- 16
- USA (Alabama)
- C?ID=88836
Hello to ALL...this is my first post on this forum. I have a 2007 Audi Q7 that has been a rock-solid vehicle for several years, it now has 103k miles on it. Several weeks ago after Sunday breakfast, we all piled into the Q7 and I started it up. It cranked over for several seconds longer than normal and then started up. We then drove about a mile to get home and when we arrived it was running rough. I then shut it off an restarted and it was running very rough and would not idle at all.
I did an Auto-Scan and below is a summary of the malfunctions and the codes are shown further down below:
Hard to believe that this vehicle was running fine just hours before and now look at all this!!! Since this is an FSI motor I decided to look at the intake valves for carbon build-up, and they were pretty bad. I also saw that there was some oil in the spark plug wells, and the plugs looked pretty bad too. So I cleaned up all the valves, installed new cam cover gaskets, new plugs, and bolted everything back together. I crossed my fingers and hit the "start" button and as I figured, it still ran like crap. However I did manage to fix the misfires. Below is an Auto-Scan after all the work.
Summary malfunctions and codes:
1) ABS Brakes
2) Auto HVAC
3) Instruments
4) CAN Gateway
5) HVAC Rear
Address: 03: ABS Brakes
Component: ESP ALLRAD MK25E1 0140
Code: 01826 Sensor for steering angle (G85) supply voltage terminal 30000
Address: 17 Instruments
Component: KOMBIINSTR. M73 H16 0070
Code: 01044 Control Module Incorrectly Coded.
Address: 19 CAN Gateway
Component: J533 Gateway H06 0040
I'd heard that with the EPC could be the throttle valve at the rear of the intake manifold, so I swapped that out with another one and adapted it - no improvement. In fact I also got a few more codes related to the fuel system including N276 Fuel Pressure Sensor. I'm not a whiz at all this technical stuff, so I have to go slow and take small steps. I'm not sure where to even begin with diagnosing things. Any help is appreciated....thank you.
Sincerely,
Jeff
62-Door,Rear Left -- Status: Malfunction 0010
001112 - Evap System Purge Control Valve (N80): Short to Ground
P0458 - 002 - Lower Limit Exceeded - MIL ON
Fault Status: 11100010
Mileage: 165673 km
Date: 2016.03.28
Time: 18:15:45
RPM: 648 /min
Load: 32.5 %
Temperature: 98.0°C
Temperature: 54.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.589 V
005173 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 002 - Lower Limit Exceeded - MIL ON
Mileage: 165673 km
Date: 2016.03.28
Time: 18:15:45
RPM: 648 /min
Load: 32.5 %
Temperature: 98.0°C
Temperature: 54.0°C
Voltage: 14.224 V
000258 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 002 - Lower Limit Exceeded - MIL ON
Mileage: 165673 km
Date: 2016.03.28
Time: 18:15:46
RPM: 598 /min
Load: 39.6 %
Temperature: 98.0°C
Temperature: 54.0°C
Voltage: 13.970 V
000268 - Mass Air Flow Sensor (G246): Signal too Low
P010C - 002 - Lower Limit Exceeded - MIL ON
Mileage: 165673 km
Date: 2016.03.28
Time: 18:15:46
RPM: 598 /min
Load: 39.6 %
Temperature: 98.0°C
Temperature: 54.0°C
Voltage: 13.970 V
000135 - Fuel Rail/System Pressure: Too Low
P0087 - 002 - Lower Limit Exceeded - MIL ON
Mileage: 165673 km
Date: 2016.03.28
Time: 18:15:52
RPM: 612 /min
Load: 55.7 %
Temperature: 98.0°C
Temperature: 54.0°C
Voltage: 13.970 V
009217 - EVAP Leak Detection Pump Control Circuit: Short to GND
P2401 - 002 - Lower Limit Exceeded - MIL ON
Mileage: 165673 km
Date: 2016.03.28
Time: 18:15:55
RPM: 614 /min
Load: 55.7 %
Temperature: 98.0°C
Temperature: 54.0°C
Voltage: 13.335 V
008852 - Fuel Pressure Regulator Valve (N276): Open Circuit
P2294 - 004 - No Signal/Communication - Intermittent - MIL ON
Fault Status: 10100100
Mileage: 165675 km
Date: 2016.03.28
Time: 18:46:04
RPM: 512 /min
Load: 50.6 %
Speed: 2.0 km/h
Temperature: 91.0°C
Temperature: 40.0°C
Voltage: 13.462 V
004763 - Fuel Pressure Regulator Valve; Bank 2 (N276): Open Circuit
P129B - 004 - No Signal/Communication - Intermittent - MIL ON
Mileage: 165676 km
Date: 2016.03.28
Time: 20:14:38
RPM: 994 /min
Load: 54.5 %
Temperature: 74.0°C
Temperature: 36.0°C
Voltage: 11.938 V
P0300 - 001 - Upper Limit Exceeded - MIL ON
Fault Status: 11100001
Mileage: 165676 km
Date: 2016.04.01
Time: 17:10:56
RPM: 1300 /min
Load: 32.9 %
Temperature: 23.0°C
Temperature: 24.0°C
Voltage: 14.097 V
000773 - Cylinder 5: Misfire Detected
P0305 - 001 - Upper Limit Exceeded
Fault Status: 01100001
Mileage: 165676 km
Date: 2016.04.01
Time: 17:10:56
RPM: 1300 /min
Load: 32.9 %
Temperature: 23.0°C
Temperature: 24.0°C
Voltage: 14.097 V
000769 - Cylinder 1: Misfire Detected
P0301 - 001 - Upper Limit Exceeded
Mileage: 165676 km
Date: 2016.04.01
Time: 17:53:46
RPM: 487 /min
Load: 63.1 %
Speed: 1.0 km/h
Temperature: 25.0°C
Temperature: 25.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.843 V
000770 - Cylinder 2: Misfire Detected
P0302 - 001 - Upper Limit Exceeded
Mileage: 165676 km
Date: 2016.04.01
Time: 17:53:46
RPM: 487 /min
Load: 63.1 %
Speed: 1.0 km/h
Temperature: 25.0°C
Temperature: 25.0°C
Voltage: 13.843 V
1) ABS Brakes
2) Auto HVAC
3) Instruments
4) CAN Gateway
5) HVAC Rear
Sincerely,
Jeff
