- Mar 4, 2015
- 330
- 83
- Rhode Island
- C?ID=240768
I'm So Sorry So do you want me to run all test's listed in this quote or just the ones I did in the last video? Thanks I will get this lolWhy did you kill the 034 test?
Do over...........all tests and don't rush.
Most tests require gas and brake except 070,071,077,037,041 but some depending on the ECU support take over with brake and gas pressed.
Some require a sweet spot RPM like OXS heaters @ 3500
01-04-108 ( Additional AUX brake booster pump ) NOTE: ( Engine not running and press brake until test commences holding..... then displays result of vacuum pump in 4th field )
These following tests while running!
01-04-071-ON ( LDP Test )
01-04-070-ON ( EVAP )
01-04-077-ON ( Secondary air test ) ( It is normal for this test to abort and may need to be done last on some controllers, however, always check DTC's after test )
01-04-028-ON ( Knock sensor test )
01-04-094/096-ON ( Vario cam timing test )
01-04-030-ON ( Heated OXS bin bits spec 111 front and 110 for rear )
01-04-034/035-ON ( Forward OXS test )
01-04-036-ON ( Rear OXS test )
01-04-037/038-ON ( Age test OXS )
01-04-041/042-ON ( Heater circuit resistance display )
01-04-043/044-ON ( Additional OXS test )
01-04-046-ON ( CAT test )
