Non start Skoda Fabia 1.2 2004myr Immobiliser fault
zola1
C?ID=112658 (NRRT)
Hi ,
Can anyone help with :-
I have inadvertently immobilized a car i was working on !.
Here is the saga, tried to get a dump from the engine ecu immobilser eeprom to obtain the Cars SKC code, I WAS UNSUCCESSFUL !....please log below showing XXXXXXXXXXXXX instead of VIN/IMMO numbers.
I now have the following error codes, here is the Auto Scan.
Wednesday,04,June,2014,20:25:52:30340
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: TMBPY46Y533867733   License Plate: 04
Mileage: 96170km-59757mi   Repair Order:
Chassis Type: 6Y (6Y - Skoda Fabia (1996 > 2008))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBPY46Y533867733   Mileage: 96170km/59757miles
   Part No: 03E 906 033 A
   Component: 1.2l/4V SIMOS3 G00HS4672
   Coding: 00000
   Shop #: WSC 105112
   VCID: 1E37A6949AC151EE89B-5120
  [COLOR="#FF0000"][B] XXXXXXXXXXXXXXXXX     XXXXXXXXXXXXXX[/B][/COLOR]
18020 - Engine Control Module Incorrectly Coded
            P1612 - 35-00 -
Readiness: 1110 0101
Address 03: ABS Brakes        Labels: 6Q0-907-37x-ABS.lbl
   Part No: 6Q0 907 379 G
   Component: ABS 5.7     FRONT   V30
   Coding: 00044
   Shop #: WSC 13765
   VCID: 418D3DE84BFF4E16D49-5120
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 C
   Component: 00 BN-SG.           1S33
   Coding: 25610
   Shop #: WSC 13765
   VCID: 3B714F00291324C68E5-5120
   Part No: 1C0 909 601 A
   Component: 11 AIRBAG VW51      0008
   Coding: 12593
   Shop #: WSC 13765
Address 17: Instruments        Labels: 6Y0-920-xx0-17.lbl
   Part No: 6Y0 920 960 M
   Component: KOMBI+WEGFAHRSP VDO V07
   Coding: 00401
   Shop #: WSC 24066
   VCID: 46872EF462D1692EE1B-5102
   TMBPY46Y533867733     SKZ7Z0C2060243
   Part No: 6N0 909 901
   Component: 31 GATEWAY  CAN    1S33
   Coding: 00014
   Shop #: WSC 13765
   VCID: F0EB282CB0D5179EEB7-5120
   Part No: 6Q0 423 156 S
   Component: LenkhilfeTRW        V260
   Coding: 10140
   Shop #: WSC 13765
   VCID: 3F893B103D0B38E6A2D-5102
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 E
   Component: 31 Komfortgerát     0002
   Coding: 00067
   Shop #: WSC 13765
   VCID: 3D75411837072AF6B01-4AE6
   Subsystem 1 - Part No: 6Q2959802A
   Component: 31 Tõrsteuer.FS TFK 0004
   Subsystem 2 - Part No: 6Q2959801A
   Component: 31 Tõrsteuer.BF TFK 0004
Address 56: Radio        Labels: 1U0-035-156.lbl
   Part No: 6Y0 035 156 D
   Component:  Radio YD5          0010
   Coding: 00400
   VCID: 37795330153B00A66AD-49C0
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 44: DTCs cleared
Address 46: DTCs cleared
Address 56: DTCs cleared
   Coding: 00000
   Shop #: WSC 105112
   VCID: 1E37A6949AC151EE89B-5102
   Coding: 00044
   Shop #: WSC 13765
   VCID: 418D3DE84BFF4E16D49-5102
   Coding: 25610
   Shop #: WSC 13765
   Coding: 12593
   Shop #: WSC 13765
   Coding: 00401
   Shop #: WSC 24066
   VCID: 46872EF462D1692EE1B-5120
   Coding: 00014
   Shop #: WSC 13765
   Coding: 10140
   Shop #: WSC 13765
   VCID: 3F893B103D0B38E6A2D-5120
   Coding: 00067
   Shop #: WSC 13765
   Coding: 00400
   VCID: 37795330153B00A66AD-49D8
I have used VCDS on it before and i have saved the VIN/IMMO and Soft Coding numbers , could anyone advise me of how i can reprogramme the ECU to get the VIN and IMMO to show up in the EXTRA window and get the coding proceedure ?..Please note i do not have the cars SKC number....my attempt a retriving this via the eeprom dump did not work...
Any help on this would be much appreciated,
If you need any further info eeprom dumps etc please let me know.
Cheers
Derrick
How do you figure this is a 2004 car? The VIN clearly shows it as a 2003.
Without the PIN code, VCDS cannot match Immo-3 components.
I'm curious: What "tool" buggered up the ECU in this car?
NostraJackAss
:p
I can help but I don't see a code for the Immobilizer being blocked.
How about just recoding the unit?
Jef
HQ
IMHO, you need to locate some one who has the proper tools to decrypt the PIN from the instrument cluster... a good locksmith. It has been my experience, based on customer feedback, when issues like this occur, said items to decrypt PINs are... um... 便宜是有原因的。
Hopefully if you can get the PIN, then you can connect to ECM, go into Adaptation channel 50, set the new value to 0+[four digit PIN], then Test and Save, confirm Yes, exit out of the ECM and remove the key from the ignition and wait 60 seconds and hope for the best.
NostraJackAss
Since the ecu is now in a state of SHOCK from wang chung it seems.......tell me if you can log into the controller in 0x01-11 or 16 security access with PIN # 65535........?
What was the coding of the unit before messing with it?
zola1
C?ID=112658 (NRRT)
Hi Jack,
thank you for your eply, i 'm in a big mess on a non start situation (lesson learnt here everyday :confused:)
could you please guide me on how to log into the controller in 0x01-11 or 16 security access with PIN # 65535........?
thank you
do you mean the soft coding ?
on the non start dtc's i get :-
code 18020
17978
18048
zola1
C?ID=112658 (NRRT)
thank you for your advice it is much appreciated, i'm in a world of self inflicted eeprom interogation pain !
i don't have the PIN, i was attempting to retrive it from the eng eeprom pt no sti 93c76c SOIC 8pin, but the dumps made no sense. i have them but i'm unsure of there is access to the SKC in them
derrick
zola1
C?ID=112658 (NRRT)
Hi Uwe, the tool was me :o.......i am certainly learning a hard lesson on this one !
Well, OK, but what I really meant was: What tool(s) did you use?
zola1
C?ID=112658 (NRRT)
I was trying out a new USB eeprom programmer http://www.ebay.co.uk/itm/TRUE-USB-...ther_Computing_Networking&hash=item1c2c4f7445
and didn't follow the process ...got in mess and ended up loosing vital data, VCDS has enabled me to gather some fault codes and i have just managed to get hold of the 4digit PINCODE
Plan to resolder the SMD eeproms back on the Eng ecu and the instrument cluster (the cluster is where i finally got a complete correct dump, this enable me to get the pincode)
Jeff has suggested i try this experiment
Any tips on the exact procedure ?
Derrick
NostraJackAss
Hey Derrick....
See if you can log into the cluster with 0x17-11 or 16 with - 02286
The engine dumps are screwed.....
Were you able to login to the engine controller with 65535 ?
zola1
C?ID=112658 (NRRT)
Hey Derrick....
ok, i've dropped you an email, but i'll repeat it on here so everyone can take a look .
> Hi Jack,
> Thank you for the reply, here are my latest attempts to get the immo back in,
> 1) Stripped cluster down desoldered eeprom to obtain a good dump, sent this away to an eeprom guy, he said all good, and managed to get the Instru cluster PIN 2286, reassembled cluster refit to car.
> 2) As i did'nt have an original good dump form the Eng ECU, the eeprom guy kindly sent me a good dump and PIN 2286 from a used but working ECU (same pt no year etc).
> I then wrote that to eeprom, read it, it looked ok to me ........ then i resoldered the eeprom back to Eng pcb, refitted Eng ECU to car.
> 3) Turned on ign, fuel pump ran for a couple of secs..... but IMMO light flashes.....opened VCDS Engine, i could now see the my cars original VIN/IMMO feels like i am getting somewhere ,........ now i guess the reason the Immo is still flashing is because the eeprom in the engine ecu is carrying the immo coding form the previous car it was in ?
> Tried :-
> Could not access Security Access as it s greyed out on Eng & Instrument screens ?.....tried to Login to both ECU's using the relevant PIN's .....No GO !
> Carried out Auto Scan,
> Saturday,07,June,2014,09:30:05:30340
> VIN: TMBPY46Y533867733 License Plate: KX04 UCD
> Component: 1.2l/4V SIMOS3 00HS4672
> Coding: 00031
> Shop #: WSC 13765
> TMBJY46Y033865586 SKZ7Z0C2059246
> 4 Faults Found:
> 17511 - Oxygen (Lambda) Sensor Heating; B1 S1
> P1103 - 35-10 - Performance too Low - Intermittent
> 17925 - Power Supply Relay for ECU (J271 or J363)
> P1517 - 35-10 - Electrical Malfunction - Intermittent
> 16500 - Engine Coolant Temp. Sensor (G62)
> P0116 - 35-10 - Implausible Signal - Intermittent
> 17978 - Engine Start Blocked by Immobilizer
> P1570 - 35-00 -
> Readiness: 0000 0000
> Coding: 00401
> Shop #: WSC 24066
> 1 Fault Found:
> 01177 - Engine Control Unit
> 65-10 - Unauthorized - Intermittent
> I cleared the DTC's and reran Auto Scan,
> Saturday,07,June,2014,09:35:00:30340
> Mileage: 96170km-59757mi Repair Order: 2nd scan post clr of dtcs
> Coding: 00031
> Shop #: WSC 13765
> No fault code found.
> Coding: 00401
> Shop #: WSC 24066
> Not sure this the True state of the network as immo light flashing and i did not want to crank for start in case it caused more issues, my guess is the immo is still in and there is no sync between key/eng/cluster immo path.
> Any thoughts on my next step ?
UPDATE 12:25PM GMT
I sent the same Eng dump to a website that offers a "Dump to PIN" service, got a completely different PIN 1568
here is his reply
Hi,
The stamp you have sent is the garage where the car is serviced.
Importer and dealer codes can be read by VAS-5051/5052 diagnostics scanner.
For info about dealer code (WSC: WorkShop Code) go to http://www.ross-tech.com/vcds/tour/option_screen.html
Scroll down until "Workshop Identification".
And http://www.ross-tech.com/vag-com/faq_2.html :
Scroll down until "2.9 What's the Work Shop Code?"
By the way the 4/5 digit PIN should work in VCDS to login into Immobilizer.
BR,
IPC Team
> Op 7 juni 2014 om 12:03 schreef Derrick Wiltshire <zola-1@ntlworld.com>:
> On 07/06/2014 10:14, Immobilizer Pincode Calculator wrote:
>> Hi,
>> Used Token: 839F4E-7B33A8-B5B427-0BE411-71B747
>> Brand: VAG
>> SN: SKZ7Z0C2059246
>> PIN Code: 01568
>> 4 digit PIN: 1568
>> Are you sure about dealer ID 7.04 ? 7.04 is not a valid input, I've entered 704 and the result is:
>> 7 digit PIN (07-06-2014): 415536
>> 7 digit PIN (08-06-2014): 471312
>> 7 digit PIN (09-06-2014): 532016
>> Notice: 7 digit PIN is only valid for ONE day. 4 digit pin should be OK for keylearning.
>> BR,
>> IPC Team
I have followed that request for the Importer code (210 for the UK) and dealer code 13765 and have sent to him, await the correct 7 digit PIN, in the hope that will let me LOGIN to the Engine ECM.
Summary,
Well some progress has been made as i can now can see both the VIN/IMMO numbers in the Extra fields of both Engine ECM and Instrument Cluster, but i feel the PINCODE issue is the the one i have yet to get a steer on !
Any thoughts guys ?
> Derrick
NostraJackAss
STOP sending and trying to use all pin codes from every person out there on the net.
You are convoluting the process.....
Just because a VIN is present doesn't mean its better.........or any closer.
Put the eeprom with xxxxxxx back on and see if you can login to the controller with 65535 after 10 minutes with key on and communication taking place.
or
Send me the equipment to sort it out or send it to someone that is in your area with a good rep.....
zola1
C?ID=112658 (NRRT)
or
Communication but, No response from controller.
Sent you email with answers and dumps.
thank you.
NostraJackAss
So now that you are running Immo defeat from your vendor according to email does the car now run?
