Ohm value for Mkv in tank fuel level sender
MVB_
C?ID=164610
Anyone known the values for testing the fuel level sender?
Wednesday,15,June,2016,11:17:58:05634
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: WVWEV71K18W289   License Plate: 6-15-16
Mileage: 72410km-44993mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 37 42 44 46 47 52 55 56 65
VIN: WVWEV71K18W289  Mileage: 72410km-44993miles
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 S    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0H23N78HA
   Coding: 0403010A18070160
   Shop #: WSC 01279 785 00200
   VCID: 366901F741517F8E94-8062
   Revision: 00H11001
   Coding: 0021122
   VCID: 73EFF8E312A32AA673-8026
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   VCID: 7CFDD3DF3FFD65DE22-8028
   Revision: 00H54000    Serial number: 00000008138279
   Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: 71E3F2EB68BF18B681-8024
   Component: Wischer 050308 021  0501
   Coding: 00038805
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0275604
   Coding: 0000000
   VCID: 336F38E352236AA6B3-8066
            000 -  -
                    Reset counter: 42
                    Mileage: 71675 km
                    Time: 04:19:23
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0AT5E5
   Coding: 0013899
   Shop #: WSC 01269 785 00200
   VCID: 6CDDE39F4F9DF55EB2-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME394244311
   Subsystem 3 - Serial number: 6342MSME2E32735AI
   Subsystem 4 - Serial number: 6352QSME5B497921P
   Subsystem 5 - Serial number: 6362QSME581B3F0F-
   Subsystem 6 - Serial number: 63727SME14173134R
   Subsystem 7 - Serial number: 63827SME14331A41V
   Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
   Component: J0527           752 0100
   Coding: 0002022
   VCID: 0103A22B581F083671-8054
   Part No SW: 1K6 920 974 A    HW: 1K6 920 974 A
   Component: KOMBIINSTRUMENT VDD 2216
   Revision: V0002000    Serial number: VWX7Z0H23N78HA
   Coding: 0007203
   VCID: 32613DE7AD3963AEB8-8066
   Revision:   H07 01    Serial number: 060308F2001324
   Coding: E9811F075003020000
   VCID: 306537EFA33551BECE-8064
   Component: IMMO            VDD 2216
   Shop #: WSC 09128 444 84839
Address 37: Navigation        Labels: 1K0-919-887-MFD2.lbl
   Part No: 1K0 919 887 GX
   Component:      Navigation     0050
   Coding: 0000101
   VCID: 152BE67B3C979496BD-8040
            000 -  -
   Component: Tuer-SG         006 1207
   Coding: 0001077
   VCID: 38750FCF4B4589FE86-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 356B06FB5C5774969D-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 13900E885103403F2D04058FB0080A04889C00
   VCID: 040DAB3F470D1D1E5A-8050
Address 47: Sound System        Labels: 3C0-035-456.lbl
   Part No SW: 1K6 035 456 B    HW: 1K6 035 456 B
   Component: 08K Audioverst.     0006
   Revision: 00004000    Serial number: 00000008137952
   VCID: 2B5F20838A133266FB-807E
   Coding: 0001076
   VCID: 39730ACB704F90F679-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74EDFBFF17AD2D9E6A-8020
Address 56: Radio        Labels: 1K0-035-095.lbl
   Part No: 1K0 035 095 HX
   Component:        Radio        0050
   Coding: 0010046
   Shop #: WSC 09130 444 84839
   VCID: 0201AD275D19132E68-8056
   Coding: 0100101
End-------------------------(Elapsed Time: 02:01)--------------------------
DrPeter
16.4905° S, 151.7375° W
- This is based on my research, deemed accurate, not 100% guaranteed.
Sensor at top = 50Ω
Full Tank = 70Ω
¾ Tank = 120Ω
½ Tank = 170Ω
¼ Tank = 220Ω
Reserve = 245Ω
Empty = 270Ω
Sensor at bottom = 290Ω
(Tolerance = 2-5Ω)
Hope this helps,
drpeter
