Mk6.:R haldex issue?
Shafo
South Africa
C?ID=163752
Hey folks!
So my personal vehicle decided to start giving issues...2012 golf 6 r DSG with 60k kilos..
Roads were a bit wet today so I'm cruising in second behind a granny ..get a gap and put my foot down to overtake her...car kicks down to first and all hell breaks loose ...suddenly I get hectic torque steer and front wheel hop..traction control light that I hardly ever see in this car comes on with the loss of traction.. I thought it may have just been a hiccup so I come to a complete stop and pull away at wot and all is good.no tc light no spinning...I then cruise in second again and put my foot down and the exact same thing happens.car loses traction on the front wheels miss shifts into limiter and then changes to second... I have for a while been suspicious about the awd as there are certain times when ,even on a dry surface, the car does lose traction obviously not as bad as in the rain today..but it just doesn't seem right... I've had this car for over a year now and this has definitely not happened before
I scanned the car and have absolutely zero faults besides a stupid hvac fault that's been there forever...
So my question is...with the 4 motion system should there ever be a point, even on a wet surface, where the front wheels spin so bad that it replicates a fwd cars wheel hop?
Could there possibly be an issue in the the rear diff that would cause this without there being a fault code?
Are there any logs I could do on the awd that could help?
The car is still under warranty but the "technicians" at my local dealer are absolutely incompetent ...when I gave the workshop foreman a call he asked "isn't it supposed to do that?"
I called a master tech buddy of mine and he claims there is usually a fault code when something goes wrong
I'd really appreciate your views guys
my maintenance plan is almost up and need to have this sorted before that happens
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Some additional information from this vehicle would be helpful. Please run an AutoScan and paste the results into this thread/topic .This will allow us to see details regarding which modules are installed in this vehicle, how they're currently coded, and what (if any) fault codes are present.
This video may be helpful:
http://www.youtube.com/watch?v=RCBt6d42-Fc
Please let us know if you need any assistance with this function.
Shafo
South Africa
C?ID=163752
Ok will do first thing in the morning
I don't think Sebastian actually mean to say "email". Please post the scan here. :)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Indeed, boiler plate fail... ;) Fixed that...
Shafo
South Africa
C?ID=163752
VCDS Version: Release 15.7.4 (x64) Running on Windows 7 x64
Data version: 20160216
Tuesday,14,June,2016,15:09:59:48700
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 55 56 62 72
          77
VIN: WVWZZZ1KZDW071255   Mileage: 60530km-37611miles
Address 01: Engine (CDL)       Labels: 06F-907-115-CDL.clb
   Part No SW: 1K8 907 115 D    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: 5BH21---    Serial number:
   Coding: 0403000C1C0F0160
   VCID: 2F6BAB3BBEA37046D7-807A
Readiness: 0000 0001
   Part No SW: 02E 300 014 S    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3526
   Revision: 05551213    Serial number: 00001206282544
   VCID: 224D520FFD71CD2E48-8076
   Revision: 00H31001
   Coding: 163BE00D092980FB680D07E9901E0181350000
   VCID: 7DF74173E44F52D615-8028
   Part No SW: 5K0 907 044 GK    HW: 5K0 907 044 GK
   Component: Climatronic   H19 1212
   Revision: 00001004
   Coding: 0010002002
   VCID: 7AFD4A6FFD6165EE30-802E
9496597 - Sunlight Photo Sensor
          B10E8 15 [009] - Open or Short to Plus
                    Reset counter: 66
                    Mileage: 59719 km
                    Date: 2016.03.06
                    Time: 21:17:30
9496613 - Sunlight Photo Sensor
                    Reset counter: 66
                    Mileage: 59719 km
                    Date: 2016.03.06
                    Time: 21:17:30
   Part No SW: 1K0 937 084 H    HW: 1K0 937 084 H
   Component: BCM PQ35  B   111 0709
   Revision: AB111709
   Coding: 48180A3AE833F1C0408800C0340408644FF50488732D8D20E48400240040
   Shop #: WSC 03145 996 12345
   VCID: 3363A74B928B54A6B3-8066
   Subsystem 1 - Part No: 5K2 955 119
   Component: Wischer 13071  26  0512
   Coding: 009795
   Component: RLS 180712 05  54  0403
   Coding: 0630AD
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0012
   Revision: --------    Serial number: 12501216601444
   Coding: 108104
   VCID: 387990678BEDB7FE86-806C
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RAMYPT%
   Coding: 00003958
   ROD: EV_AirbaVW10SMEVW360_SE36.rod
   VCID: 316FAD43609766B6C1-8064
   Serial number: 3572MSME7D24166EZZZ3
   Serial number: 3582MSME556C556FZZZA
   Serial number: 3512QSME623D1C1CZZZ+
   Serial number: 3522QSME5A501C01ZZZQ
   Revision: --------    Serial number:  90422LGK000EJ
   Coding: 1892140000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 76E55E5FC979018E54-8022
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0032
   Serial number: 0052620
   Coding: 830000
   Part No SW: 5K6 920 873 B    HW: 5K6 920 873 B
   Component: KOMBI         H05 0705
   Coding: 170F01
   VCID: 3567995394FF4A969D-8060
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 150712F2003648
   Coding: 350003
   VCID: 3F8BFB7BAEC380C647-806A
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 4587E9930C1FDA160D-8010
   Component: IMMO          H05 0705
   VCID: 6ADD7A2F8DC1D56EC0-803E
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2106
   Coding: 0000692
   VCID: 377B935B46F3B8868F-8062
   Part No: 5N0 909 144 P
   Component: EPS_ZFLS Kl. 251    3305
   Revision: 00H22000
   VCID: 3E75867F69C989CE4C-806A
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Component: Tuer-SG         009 2120
   Coding: 0000948
   VCID: 3363A74B528B54A6B3-8066
   Coding: 1475932
   VCID: 3461A4575785539EAA-8060
   Component: AFS-Lst.-Modul l    0005
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000022
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  005 0234
   Revision: 00000001    Serial number: VWZ1Z3M7259543
   Coding: 05000400040005
   VCID: 244154172765C31E3A-8070
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 356799535CFF4A969D-8060
   Coding: 0000144
   VCID: 36659E5F41F9418E94-8062
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Revision: 1B001001    Serial number: 00007663155375
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 397F9563B8E7AEF679-806C
End-------------------------(Elapsed Time: 02:39)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Usually with the haldex systems what we have seen is the pump or the electronics going bad, VW has a repair kit available which includes a new pump but in your case I don't see that to be the issue. Both a bad pump and bad electronics in the past have always had clear indicators set as fault codes. In addition your description isn't exactly pointing towards a bad haldex in the first place.
Loosing traction isn't necessarily unusual, even with a 4wd car. The 4Motion system works by not being a permanent all wheel drive, it will divert power based on slip and throttle as it sees fit. So some slip is expected, assuming its just for a short time frame. You could log some measuring values while trying to reproduce the situation. If you want to read up on the topic, I'd recommend SSP 414 (should be available through http://erwin.volkswagen.de).
Shafo
South Africa
C?ID=163752
"So some slip is expected, assuming its just for a short time"
I do agree...but the whole of first gear seems a bit too long for me!! I've spoken to some other people with the same vehicle and they confirm that no matter how hard they push their vehicles in the wet, they have not traction issues...maybe a pump starting to give in??? Agggghhh horrible knowing something is amiss and I can't prove it.. thanx for your advice in any case !! I will definitely post back once I've come to conclusion
