Good morning! Here in my country we get a quite basic version of the Jetta TSI 1.4 labeled "Trendline", which comes with the RCD-310 stereo. I need to recode the radio to enable USB AUX input, but I get no label files for it. Can you help me with this? Thanks in advance.
The module in question is this one, and RCD-310:
Address 56: Radio (J503) Labels: None
Part No SW: 1K0 035 164 H HW: 1K0 035 164 H
Component: LOW NAR H04 0007
Revision: -----08S Serial number: VWZ4Z6R3894569
Coding: 00000204020006
Shop #: WSC 00066 790 00185
VCID: 271E32BC566BED063C-8072
Full auto scan (it's old but I checked the car yesterday and still no labels):
Wednesday,28,October,2015,16:41:49:34553
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: 3VW6L6AJ0FM336116 License Plate:
Mileage: 6420km-3989mi Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: 3VW6L6AJ0FM336116 Mileage: 6420km-3989miles
Address 01: Engine (J623-CAXA) Labels: 03C-906-016-CAX2.clb
Part No SW: 03C 906 016 HL HW: 03C 907 309 S
Component: 1.4l R4 TSI H13 8202
Revision: LCH13--- Serial number: 00000000000000
Coding: 00250012002400000000
ASAM Dataset: EV_ECM14TFS01103C906016HL 001003
ROD: EV_ECM14TFS01103C906016HK.rod
VCID: 70AC19E0AB25EABEAD-8024
Readiness: 0000 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 062 B HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6201
Revision: 00043014 Serial number: CU501502046164
Shop #: WSC 02069 000 90108
VCID: 2B16CE8C8A83C966D8-807E
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
Component: MK70 M MASR 0106
Revision: 00H35001
Coding: 0001377
VCID: 7BB63ECC3A6399E608-802E
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 1K8 907 426 K HW: 1K8 907 426 K
Component: AC Manuell H20 0707
Revision: 00001002
Coding: 0010004002
Shop #: WSC 00066 000 00319
VCID: 3B36FECCB2E359E648-806E
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0174
Revision: BL122001
Coding: AF200A3A802F3ED4008000010500832403200086508089205C8020000040
Shop #: WSC 00066 123 12345
VCID: 78BC21C0CB55B2FE65-802C
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 F HW: 5C0 959 655 F
Component: AirbagVW10 014 0613
Serial number: 003JQM069X9+
Coding: 0000504A
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 3522E8F494C78F96BE-8060
Serial number: 3572MSME14751D4EZZZ%
Serial number: 3582MSME22761D4EZZZ0
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME7A730F35ZZZ$
Serial number: 3526KSME67520F35ZZZX
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 BL HW: 5K0 953 569 AD
Component: LENKS.MODUL 016 0162
Revision: FF010042 Serial number: 20150225300175
Coding: 0882440008
ROD: EV_SMLSNGVOLWS.rod
VCID: 78BC21C0C355B2FE65-802C
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Component: E221__MFL-TAT H04 0019
Serial number: 0731513274501340AD1B
Coding: 280000
Part No SW: 5C6 920 864 HW: 5C6 920 864
Component: KOMBI H04 0905
Coding: 170B01
Shop #: WSC 00066 123 00319
VCID: 6B960E8C8203096698-803E
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AP HW: 7N0 907 530 AK
Component: J533 Gateway H57 1653
Revision: H57 Serial number: 30031503001712
Coding: 351002
Shop #: WSC 00066 000 00000
VCID: 7EB037D8E9718CCE2F-802A
Component: IMMO H04 0905
VCID: 6A980B888DF9106EE3-803E
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Component: TUER-SG FT 002 0515
Revision: 13110009 Serial number: 0009414621
Coding: 0404F5
Shop #: WSC 00066 790 00192
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 5BF65E4C52A379E668-800E
Slave Driver:
Subsystem 1 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587150302180939
67584 - Warning Light for Front Door
B11F5 01 [009] - Electrical Failure
Reset counter: 29
Mileage: 6423 km
Date: 2015.10.28
Time: 16:39:32
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 68 3501
Revision: 00H22000
VCID: 393AE4C470DF6BF65A-806C
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Component: TUER-SG BT 002 0515
Revision: 15110009 Serial number: 0009523430
Coding: 0404F4
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 5CF45D5057AD7EDE61-8008
Slave Passenger:
Subsystem 1 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14102586150224110458
Fault Frequency: 72
Reset counter: 67
Mileage: 2716 km
Date: 2015.08.24
Time: 20:18:01
Bin. Bits: 010
Address 77: Telephone Labels: None
Part No SW: KTC 364 95B HW: KTC 364 95B
Component: SWP:3.31.6 H24 0220
Shop #: WSC 21977 142 74100
VCID: 2F2EDA9CBE9BB546F4-807A
End-------------------------(Elapsed Time: 01:15)--------------------------
