Dear all,
Having this problem with a Seat Toledo that is trowing the following fault codes from time to time toghether with engine running rough for a few moments.
Same fault codes are apearing in a day or two of driving. Thinking first that the engine speed sensor might cause this misfires and I changed it with a new one, but same faults over and over again.
Can be the coil pack faulty?If so why is the engine speed sensor fault present?
Is the sensor ok but is not reading impulses from the crankshaft from time to time?
Can be the magnetic ring from the crankshaft oil seal loose?
Any of you had encountered this issues?
Kind regards,
Mircea
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 036 906 034 BD
Component and/or Version: MARELLI 4LV 3550
Software Coding: 00031
Work Shop Code: WSC 00046
VCID: 55A14858AF6CD9B6981-4B50
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16686 - Cylinder 2
P0302 - 35-10 - Misfire Detected - Intermittent
16687 - Cylinder 3
P0303 - 35-10 - Misfire Detected - Intermittent
17751 - Ignition Coil Power Output Stage 2
P1343 - 35-10 - Shorted to Ground - Intermittent
16706 - Engine Speed Sensor (G28)
P0322 - 35-10 - No Signal - Intermittent
Readiness: 0010 0001
Kind regards,
Mircea
