bosch abs 5.3 login and coding. 01 quatro modual to 2000 passat
OKrepairer
Cornish ME, USA
C?ID=271523
Do you know if this can be done? I can comunicate fine with controller from audi but it rejects all login codes. I cannaot proceed from there. ill have to post modual numbers later but all are same except last three. the replacement for my 2wd passat came from awd audi :( im pretty poor lol. thanks for any help :) I have watched your help vid. thanks for it :)
Unclear. A 2000 Passat definitely didn't have ESP. A 2001 Audi might have. If you're trying to install an a module that had ESP, it definitely won't work. Bottom line: Post an Auto-Scan so we can see what you've got.
OKrepairer
Cornish ME, USA
C?ID=271523
Ok Uwe! Thanks Boss!!! I will do..at work for the day ugh
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
It's very unlikely to work. A lot of people have (inadvertently) tried it and failed. I'll bet five virtual internet bucks you have a trouble code for a front right ABS wheel speed sensor too. Don't know why, but it showed up four out of four times I've seen mismatched modules installed.
Gotta get the right one. If in doubt, as Uwe said, post an Auto-Scan. Include your VIN if it's not already in the scan. We can help you identify valid replacement parts. Often there's more than one valid replacement part, which can help with this age of car if you're looking around for salvage or repaired parts.
Jason
OKrepairer
Cornish ME, USA
C?ID=271523
Jason
You are right about right front sensor code! thought it may have been stored from other car. I do have asr and esp and with replacement mod. I got the message center back. "It no longer reads stop brake fault" but still have abs light on cluster! asr and esp are still disabled though lol. guese ill stop here or should i try for craps sake to generate a login code from the soft coding?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
OKrepairer
Cornish ME, USA
C?ID=271523
did you guys get the auto scan
VCDS Version: Release 15.7.4 Running on Windows 10 x86
Data version: 20160216
Tuesday,07,June,2016,20:13:05:18282
Chassis Type: 3B - VW Passat B5 (1997 > 2005)
   Mileage: 328820km-204319miles
Address 01: Engine        Labels: 078-907-551-ATQ.lbl
   Part No: 3B0 907 551 AN
   Component: 2.8L V6/5V      G   0003
   Coding: 07501
   Shop #: WSC 00028
   VCID: 6FEDBB412DDA664697-5140
18057 - Powertrain Data Bus
            P1649 - 35-00 - Missing Message from ABS Controller
16815 - Warm Up Catalyst; Bank 2
            P0431 - 35-10 - Efficiency Below Threshold - Intermittent
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst
            P1176 - 35-10 - Control Limit Reached - Intermittent
17831 - Secondary Air Injection System; Bank 1
            P1423 - 35-10 - Insufficient Flow - Intermittent
Address 03: ABS Brakes        Labels: 8E0-614-111-EDS.lbl
   Part No: 8E0 614 111 A
   Component: ABS/EDS 5.3 QUATTRO D10
   Shop #: BB 24334
   VCID: 1C37BC8D8CECADDE82-5140
            30-00 - Open or Short to Plus
   Part No: 6Q0 909 605 B
   Component: 03 AIRBAG VW5       0003
   Coding: 12339
   Shop #: WSC 00028
   VCID: 36634E251200178E94-4B00
Address 17: Instruments        Labels: 3B0-920-xx2-17.lbl
   Part No: 3B0 920 920 B
   Component: B5-KOMBIINSTR. VDO V23
   Coding: 07265
   Shop #: WSC 00028
   VCID: 1D31B18997F6A4D675-5140
   Part No: 6N0 909 901
   Coding: 00004
   Shop #: WSC 00028
   VCID: 70EFB83D30E479BE8E-5140
   Part No: 1J0 959 799 AJ
   Component: 6W Zentral-SG Komf. 0001
   Coding: 04096
   Shop #: WSC 00028
   VCID: 0603FEE52260470E44-4AE8
   Subsystem 1 - Part No: 1J1959801D
   Component: 6W Tõrsteuerger. FS0002F
   Subsystem 2 - Part No: 1J1959802E
   Component: 6W Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811D
   Component: 6W Tõrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812D
   Component: 6W Tõrsteuerger. HR0002r
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
            35-00 -  -
01358 - Internal Central Locking Switch; Driver Side (E150)
00912 - Window Regulator Switch; Front Left (E40)
            35-00 -  -
   Part No: 1J0 035 180 B
   Component:  Radio DE2         0003
   Coding: 04041
   Shop #: WSC 00028
   VCID: 1E33B6859AF0BFCE6C-51D4
            00-10 -  -  - Intermittent
End-------------------------(Elapsed Time: 04:46)--------------------------
OKrepairer
Cornish ME, USA
C?ID=271523
Thanks for your help you all rock!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Yes thanks, but it looks like this model-year may be too old to report its VIN in the Auto-Scan automatically. Can you post it? Quoting parts for that era Passat is a little perilous due to the CAN switchover and the B5 to B5.5 refresh around that time, so I prefer not to wing it just based on the model-year.
Jason
I agree, that ABS/ESP module is not gonna work in this car.
It's definitely a CAN-bus (internally) car. The -920- (vs. -919-) cluster tells us that. I *think* all the B5.5 cars were Immo-3 and know their VIN. But it would still be good to know the VIN. ;)
OKrepairer
Cornish ME, USA
C?ID=271523
Okay so here is the VIN WVWMD23B8YP215692 I have already tried to fix oe mod myself and made it worse when cracking it open. so i dont wanna send it for repair now
