- Jan 29, 2014
- 21,923
- 9,308
- Montgomery, NY, USA
- C?ID=57337
Jason makes a great diplomat..........
Old car... With unusual TCM. New interface (HEX-NET)..
I would like to send you an old cable to try. Please confirm your address is the same as it was in 2014.
VCDS works fine. What's not 100% clear is whether the HEX-NET works with that TCU. Since we now have an address, there's a KII-USB on its way to you to check whether the problem might be the HEX-NET. We also have a K-Line 01J TCU coming so we can test in-house.
Tuesday,14,June,2016,18:31:12:59763
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Address 02: Auto Trans Labels: 01J-927-156.lbl
Control Module Part Number: 8E0 910 155 F HW: 01J 927 156 HH
Component and/or Version: V30 01J 1.8l5VT USA 3220
Software Coding: 0001001
Work Shop Code: WSC 05142 444 83694
VCID: 2851EAB6981A687E16-515A
17090 - Transmission Range Sensor (F125)
P0706 - 000 - Implausible Signal - MIL ON
RPM: 1536 /min
(no units): 2.0
Torque: 0.0 Nm
Temperature: 54.0°C
T.B. Angle: 0.0°
Bin. Bits: 0001 0 0
18161 - Tiptronic Switch (F189)
P1753 - 000 - Implausible Signal
I'm thinking the firmware in the HEX-NET does not properly accommodate this TCU's rather unusual timing requirements. I'm confident we can fix that with an update.now what about my hex net why is not communicate with the transmission???
Hang onto the KII-USB we sent you for now. As I mentioned earlier, we've got a TCU on the way so we can try to reproduce this and then fix it
Been here?
http://wiki.ross-tech.com/wiki/index.php/17090
http://wiki.ross-tech.com/wiki/index.php/18161/P1753
Both have notes regarding your CVT.
