Audi A4 2004 transmmision PRND blink
crisseibert
boston
C?ID=224999
i just got this Audi A4 2004 the PRND dash board light its blink....the car drive fine no problem....i try to conect vcds to check transmission but i cant communicate..any help?...thanks
Are there any other warning lights one? For example, the ABS or the Airbags?
What do you get when you do [Options] -> [Test]?
crisseibert
boston
C?ID=224999
i have air bag on it …?
options test?
So you're telling us you have communications with other systems, just not the TCU?
If so, please post an Auto-Scan.
You may also want to tell us what type of transmission this car has. There were two totally different types installed in these cars. One is a conventional automatic, the other is a CVT.
crisseibert
boston
C?ID=224999
Address 01: Engine        Labels: 06B-909-518-AMB.lbl
   Part No SW: 8E0 909 518 AK    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0003
   Coding: 0016584
   Shop #: WSC 00672 785 00200
   VCID: F9BAAA40B189B2F6B9-5184
18032 - MIL Request Signal Active (Check TCM for errors too!)
            P1624 - 008 -
Readiness: 0110 1101
Address 02: Auto Trans        Labels:
   VCID: D5E2C6F02C51B696FD-FFFE
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517
   Component: ABS/ESP front       3429
   Coding: 04279
   Shop #: WSC 00672
   VCID: E582F6307D3126166D-5184
            35-10 -  -  - Intermittent
   Part No: 8E0 820 043 AC
   Component:   A4 Klimaautomat   1219
   Coding: 00001
   Shop #: WSC 05142
   VCID: E288ED2C6C1F512E88-5184
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  USA 0517
   Coding: 00003
   Shop #: WSC 00672
   VCID: B52266708D1196961D-4B3C
00984 - Left Tail Light (M4)
            57-00 - Electric Circuit Failure
01326 - Control Module for Multi-Function Steering Wheel (J453)
Address 15: Airbags        Labels: 8H0-959-655-84.lbl
   Part No: 8H0 959 655 B
   Component: Airbag 8.4EC        2015
   Coding: 0010105
   VCID: B93A6A40F10972F6F9-5184
01217 - Side Airbag Igniter; Driver Side (N199)
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0611
   Coding: 01041
   Shop #: WSC 00672
   VCID: BE30795CB82755CECC-4B3C
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8H0 920 950 HX
   Component: KOMBI+WEGFAHRS. RB8 D22
   Coding: 02201
   Shop #: WSC 05146
   VCID: 895ADA80B169A276A9-5184
   WAUAC48H24K008914     AUZ6Z0C0298519
01176 - Key
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8H0 959 433 C
   Component: Komfortgerát T7B    1412
   Coding: 11836
   Shop #: WSC 00862
   VCID: B4245B74866B8F9E2A-4B3C
   Component: Tõrsteuer.FS BRM 0001
            29-00 - Short to Ground
   Part No: 8E0 035 195 G
   Component: symphony II PM6    0410
   Coding: 00000
   Shop #: WSC 05142
   VCID: AB1640085855D0667B-50D0
8 Faults Found:
00878 - Connection to Speaker Front Left
            36-10 - Open Circuit - Intermittent
00879 - Connection to Speaker Front Right
00856 - Radio Antenna
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
            35-00 -  -
            37-10 - Faulty - Intermittent
End-------------------------(Elapsed Time: 08:56)--------------------------
crisseibert
boston
C?ID=224999
just the TCU…….but everything else is fine….my transmission is …CVT
crisseibert
boston
C?ID=224999
Any help please!
Moving to Car Repair Support.
OK, normally I would ask you if you've verified power, ground, and a clean K-line connection to the TCU, which on the 01J is bolted on the tranny. And if all that is good, I'd say: "Sounds like you need a TCU / mechatronic".
However, the 01J in this 8E chassis (which uses K-line for diagnostics) had some very unusual timing requirements. We have a work-around for this in VCDS for the older interfaces, where such timing is handled in VCDS itself. Now with the HEX-NET you're using, that timing is handled in the interface itself rather than in VCDS, and I'm not sure the exception ever made it into the HEX-NET. So if you like, we'll send you an older interface to try before you condemn the mechatronic.
crisseibert
boston
C?ID=224999
Ok thanks for respond..... I check ground is fine!!!
....I use my hex net with cable... It should work fine....this is the most expensive I bought..!!
Old car... With unusual TCM. New interface (HEX-NET)..
I would like to send you an old cable to try. Please confirm your address is the same as it was in 2014.
crisseibert
boston
C?ID=224999
ok when you say ….we'll send you an older interface to try …what interface i need?
I don't know that you need any. I just want to be sure your lack of communications with this module isn't due to a known issue we may have overlooked.
crisseibert
boston
C?ID=224999
thanks …i have one ...A8 2004.. and another ...A4 2003 the hex net work fine to communicate with the transmission….do you think even work with those 2 cars maybe may not work with the Audi A4 2004..?
Does the other A4 also have a CVT transmission? I know for sure the A8 does not.
crisseibert
boston
C?ID=224999
no they don't…….you right…both don't have...
NostraJackAss
Coding: 0016584 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< That 8 means you have absolutely a CVT.
It would be best to test for power and ground at the CVT or supply a direct pigtail to isolate power ground and K line.
Please post a picture of the white tag in trunk and a picture of production date in door jam.
Power Terminal 15 PIN 10
Terminal 31 ground PIN 8
K line PIN 6
Is A76 from cluster to T10a/6 merge of K line to J217 okay?
Is ground for F186 T10j/6 for display of gear monitor?
P1624 - 008 -
This error indicates that the trans is active to me and talking to the engine controller on the CAN.
crisseibert
boston
C?ID=224999
thanks!!!! This what i got when i try to communicate with transmission
Internal error {x}
{x} KWP2000 address translation error
Please contact ross tech
crisseibert
boston
C?ID=224999
thanks!!!!!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I ordinarily try not to put words in Uwe's mouth, but in this case, I think you may not have clearly understood what he was saying. Ross-Tech aren't asking you to give up your HEX-NET. Just as a test, he's offering to temporarily loan you a different type of interface that's known to work well with your older A4's very unique transmission controller (I would guess a HEX-USB+CAN, or possibly a KII-USB) because he's not sure if the new HEX-NET has been tested to work with it. If a HEX-USB+CAN different interface doesn't work either, then you'll know something is probably wrong with your transmission controller. But if it does work, Ross-Tech knows that HEX-NET may need a minor software fix so it can talk to your TCM, and they can work with you on that.
So, your best course of action is to reply to Uwe's comment asking about your shipping address, so they can help you out.
Jason
