- Jun 4, 2014
- 2
- 3
- C?ID=160386
Hi Lads,
This is my first post, so any help or pointers would be gratefully received.
2 days ago, my 2008 VW Touran 1.9 TDI lost all power, and when I tried a restart there was no life in the dash. The car was left parked for approx 1/2 and hour and then restarted fine. I ran a VAG-COM scan which returned a load of errors, so in an attempt to weed out misleading errors, I cleared all DTC's
Yesterday, the car lost power again, and 1/2 an hour later started fine again. I ran a fresh VAG-COM scan. The results were more or less the same with a most of the same errors re-appearing. The bit that jumped out was the fact that some had a weird date and time recorded alongside.
i.e. it's a 2008 vehicle, yet the log recorded a date of "September 2005"....and the DTC's had all been cleared the previous day. Also, how come the time was recorded at 31 hours 63 minutes and 63 seconds. Sounds like something seriously wrong with an internal clock.
Today the car died again for the 3rd time in 3 days. This time I can't get it started at all.
The symptoms are
1..When open the driver door, the mileometer lights up with the mileage.
2..When I turn the ignition key, there is no power to the dash, (other than the mileometer display). The car won't start.
3..I car hear what sounds like a ignition relay clicking once when I turn the key.
Here's the VCDS log. Can anyone help me?
Date: 2005.09.13
Time: 31:63:63
The symptoms are
Wednesday,04,June,2014,22:04:35:03430
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: License Plate:
Mileage: 87270km-54227mi Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56
VIN: WVGZZZ1TZ8W115912 Mileage: 87270km/54227miles
[COLOR="#FF0000"]08-Auto HVAC -- Status: Malfunction 0010[/COLOR]
[COLOR="#FF0000"]09-Cent. Elect. -- Status: Malfunction 0010[/COLOR]
[COLOR="#FF0000"]18-Aux. Heat -- Status: Malfunction 0010[/COLOR]
[COLOR="#FF0000"]46-Central Conv. -- Status: Malfunction 0010[/COLOR]
Part No SW: 1K0 820 047 HB HW: 1K0 820 047 HB
Component: Climatic PQ35 141 1010
Revision: 00141028 Serial number: 00000000000000
VCID: 6BDFF0814A8896465E5-803E
[COLOR="#FF0000"]3 Faults Found:
009 - Open or Short to Ground
004 - No Signal/Communication[/COLOR]
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007970338
Coding: 00890F2100040F0047120C000000000000087B075C000100000000000000
Shop #: WSC 01324 785 00200
VCID: 6FE7E4917E906A6672D-803A
Subsystem 1 - Part No: 2K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 211207 021 0501
Coding: 00038805
Shop #: WSC 01324
[COLOR="#FF0000"]4 Faults Found:
02403 - Terminal 15 for Interior
Fault Status: 01101100
Reset counter: 230
Mileage: 87277 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.25 V
Reset counter: 230
Mileage: 87277 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.25 V
Reset counter: 230
Mileage: 87277 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.25 V
Reset counter: 230
Mileage: 87277 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.25 V
OFF[/COLOR]
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 752 0100
Coding: 0000042
VCID: 7F0734D12EF01AE6E2D-802A
Part No SW: 1T0 920 964 A HW: 1T0 920 964 A
Revision: V0002000 Serial number: VWX7Z0H03N910W
Coding: 0001401
Shop #: WSC 00000 067 57207
VCID: 346D2BFD573609BE4FF-8061
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 T
Component: Zuheizer 050 2504
Revision: 00050000 Serial number: 09009839000000
Coding: 0000011
VCID: 366911F5414A1BAE71B-8063
[COLOR="#FF0000"]2 Faults Found:
02085 - Incorrect Control Module Installed
Reset counter: 230
Mileage: 87277 km
Reset counter: 230
Mileage: 87277 km
Time Indication: 0[/COLOR]
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 060108F1001195
Coding: E9801F06000A028003
VCID: 306527EDA32E359E2B7-8065
Component: IMMO VDD 1212
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1202
Coding: 0000565
VCID: 38751FCD4B5EEDDE637-806D
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 80C8020C7F2D8405485B030010CC
VCID: 8005372DD30EE51E1B7-80D5
[COLOR="#FF0000"]1 Fault Found:
01312 - Powertrain Data Bus
013 - Check DTC Memory[/COLOR]
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000564
VCID: 39731AC97054F4D69C9-806C
Part No: 1K0 035 186 AD
Component: Radio GR0 034 0033
Revision: 0003404S Serial number: VWZ2Z2H4973782
Coding: 0020200
VCID: 68D58F8D5B7EBD5E337-803D
End ---------------------------------------------------------------------
