16.5.1 BETA problem - ROD files missing for UK 2016 Polo 1.2TSI
Alphadrone
C?ID=157250
Hi there,
I have just run into an issue with the wife's new car - 2016 UK Spec Polo 6C 1.2TSI.
I initially ran a scan a couple of weeks ago using VCDS 15.7.4 and all modules were found OK and have ROD files ok no problems.
On reading about the possible issues making changes on latest platform 2016 cars using the USB-HEX interface, I have installed the latest BETA 16.5.1 and updated the interface firmware (one way street, I understand) all OK.
I came to make some adaptations today and have run into an issue where I have missing ROD files for most of the modules that I need to play with and so cannot make any adaptions. I also note that the mileage was not detected, I entered it manually. I can't roll back to 15.7.4 due to the firmware update.
The only observations that I can see is that the original scan with the non BETA software shows ROD files with "VW26" quoted. The BETA scan talks about "VW25". Can you please explain what might be going on. The 2 scans are attached below...
Many thanks in advance.
Initial VCDS 15.7.4 SCAN:
Thursday,19,May,2016,14:08:27:42987
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWZZZ6RZGY264322   License Plate:
Mileage: 86km-53mi   Repair Order:
Chassis Type: 6R (6C0)
Scan: 01 02 03 08 09 10 15 17 19 44 5F
VIN: WVWZZZ6RZGY264322   Mileage: 86km-53miles
Address 01: Engine (J623-CJZC)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BB    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H23 9085
   Revision: R4H23---
   Coding: 01250032232411080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS01104E906027BB 001009
   ROD: EV_ECM12TFS01104E906027BB_SE25.rod
   VCID: 65CB807264C62D16ED-8030
   Part No SW: 0CW 300 048 S    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 6501
   Revision: 00043014    Serial number: CU501603215051
   ROD: EV_TCMDQ200021_AU37.rod
   VCID: 4C9D55D6E76CFC5ED2-8018
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08504303160312
   Coding: 23DD2885892933C41117106B0053C41491CC88080005CB098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 37771A3A8EEA6F868F-8062
Address 08: Auto HVAC (J301)       Labels: 6C0-820-045.clb
   Part No SW: 6C0 820 045 C    HW: 6C0 820 045 C
   Component: AC Manuell    H03 0202
   Serial number:  1603291B-2010
   Coding: 200100001000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26_VW26.rod
   VCID: 1F47D29A061A37C667-804A
Address 09: Cent. Elect. (J519)       Labels: 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0087
   Serial number: 006098086702
   Coding: 030018404213005B0F244080B10703C810005B0257010000000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_SE25.rod
   VCID: 306521266B84B8BECE-8064
   Subsystem 1 - Part No SW: 6R0 959 802 DK    HW: 6R0 959 802 DK  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 0620
   Serial number: KU0KU014031660747033
   Coding: 1400A0
   Subsystem 2 - Part No SW: 6R0 959 801 DH    HW: 6R0 959 801 DH  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 0620
   Serial number: KU0KU011031660710700
   Coding: 0400A0
   Subsystem 3 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY113040E1X
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000034624575
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Revision: --------    Serial number: 39331609110433
   Coding: 0031051011
   ROD: EV_EPHVA18AU3700000_AU37.rod
   VCID: 438F7EEACA32332623-8016
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
   Component: VW20Airbag00B 002 0380
   Revision: --------    Serial number: 003TH004GVZ6
   Coding: 88C0C000000000005C000000008800000000
   ROD: EV_AirbaVW20BPAVW26X_SE25.rod
   VCID: 3A71030EBDF872EE70-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 821 803 16
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00A11FED6D3123X
   Subsystem 2 - Part No SW: -----------    HW: 410 821 803 16
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00182957E81721H
   Subsystem 3 - Part No SW: -----------    HW: 442 152 503 16
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00BD1FE78C382B2
   Subsystem 4 - Part No SW: -----------    HW: 442 152 503 16
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00BB1FE78C2A13-
   Part No SW: 6C0 920 940 C    HW: 6C0 920 940 C
   Component: KOMBI         201 1420
   Coding: 272401082180260001082A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_VW26.rod
   VCID: 244DDD762F7C141E3A-8070
Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0087
   Revision: --------    Serial number: 006098086702
   Coding: 030100046F0A560071000000000000010001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_SE26.rod
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 0671602043500217AD1B
   Coding: 280000
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 53090J52422821812171
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 AG    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3232
   Serial number: CG3V0853
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW_VW26.rod
   VCID: 6ED9FF5EB130EE4E9C-803A
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 820 A    HW: 3Q0 035 820 A
   Component: MU-S-D-ER     H24 0245
   Serial number: VWZAZ2S5039477
   Coding: 02620000BE00000051111101008808001F0100C60120010001
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 2757CA7A5E4AFF061F-8072
   Media Player Position 1:
   Subsystem 1 - Part No SW: 6C0 919 603     HW: 6C0 919 603
   Component: ABTm_Std2  H53 1031
   Serial number: VWZ8Z9SKU00V4B
End-------------------------(Elapsed Time: 02:59)--------------------------
Today's VCDS 16.5.1 BETA Scan:
Monday,06,June,2016,14:30:35:42987
VCDS Version: 16.5.1.2 (x64)
Data version: 20160524 DS251
Mileage: 271   Repair Order:
   Revision: R4H23---
   ROD: EV_ECM12TFS01104E906027BB.rod
   VCID: 65CB807264C62D6B10-8030
   CAN Converter 01:
   ROD: EV_TCMDQ200021.rod
   VCID: 4C9D55D6E76CFC232F-8018
   VCID: 37771A3A8EEA6FFB72-8062
   ROD: N/A
   VCID: 1F47D29A061A37BB9A-804A
No ASAM data for: "EV_ACManueKMMValeoPQ26" (VW25)
   ROD: N/A
   VCID: 306521266B84B8C333-8064
   Coding: 1400A0
   Coding: 0400A0
No ASAM data for: "EV_BCMA0" (VW25)
   Coding: 0031051011
   ROD: N/A
   VCID: 438F7EEACA32335BDE-8016
No ASAM data for: "EV_EPHVA18AU3700000" (VW25)
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3A71030EBDF872938D-806E
   ROD: N/A
   VCID: 244DDD762F7C1463C7-8070
No ASAM data for: "EV_DashBoardVDDMQBAB" (VW25)
   ROD: N/A
   Coding: 280000
No ASAM data for: "EV_GatewA0Lear" (VW25)
   Coding: 000700
   ROD: N/A
   VCID: 6ED9FF5EB130EE3361-803A
No ASAM data for: "EV_SteerAssisUDSTRW" (VW25)
   ROD: N/A
   VCID: 2757CA7A5E4AFF7BE2-8072
No ASAM data for: "EV_MUStd4CTSAT" (VW25)
1543 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 44
                    Mileage: 86 km
                    Date: 2016.05.19
                    Time: 14:14:10
End-------------------------(Elapsed Time: 02:37)--------------------------
Eric
HC800000
Look at it in a positive way, if you hadn't gone and done that, it's possible nobody else would have reported this issue and we'd have it in release 16 instead of a beta :)
It sounds like VCDS is either having trouble retrieving your VIN or tying it to your car's platform (which is indeed VW26), but how that's happening isn't obvious to me at this point. Can you go to options, set Debug to 1024, save, run the autoscan again, and send all the files in the debug subfolder to support@ross-tech.com ? Thank you.
Alphadrone
C?ID=157250
Thanks Eric! :)
I will send you the info ASAP.
