Kessy issue and Battery Drain
shreyas1983
C?ID=263316
Hi,
I have an Audi S4 B8 2010. Recently my Subwoofer had a short to ground error in Module 47, and the next day I had 05 Auth Access error, which said "Acc and Auth Aerial Left, Short to Ground". This is the R200 antenna in the left door. I ordered a new antenna from Audi. However after installing it, the fault code remained. (Cleared the code, tried to use Advanced key, came up with Convenience key defective error, and the same DTC as above re-appeared). However if disconnected the antenna, it correctly gave an "open-circuit" fault instead of short to ground. I also seem to be getting battery drain issue. I replaced my battery with OEM spec Varta (110 ah/920 amp) but I am still getting Energy Management DTC, which makes me think something is still draining my battery (most likely CCM). So a few questions please:
1. Am I correct to assume that Kessy module (J518) is part of CCM (BCM 1.1, J393) and is located in the trunk right hand side? I have UK model. CCM part number is 8K0907064DQ. Etka link here: http://etka.cc/audi/part_single/cat.../909/subcategory/909000/part_id/256744/lang/e
2. Is there a way to repair the kessy module? I know there is a repair guide online, which involves replacing a couple of MOSFETs and 6 resistors. However that module looks different to mine (3D0)
Link here: http://www.renntech.org/forums/topi...y-problem-fixed-after-5-dollars-and-1-hour-o/
So is my kessy or CCM unit repairable in the same manner as the one in the above link? I am desperately looking for help please. Audi will most likely charge me over £1000 to have my CCM replaced, so I would like to explore all avenues before I go down that route.
Thanks!
shreyas1983
C?ID=263316
Thanks. I will do that tomm morning.
shreyas1983
C?ID=263316
Here we go:
VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64
Data version: 20160216
Friday,03,June,2016,08:37:07:26042
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 1B 22 30 42 46 47 52 53
          55 56 5F 62 72
VIN: WAUZZZ8K9AA135784   Mileage: 118190km-73439miles
Address 01: Engine (J623-CAKA)       Labels: 06E-907-551-CAK.clb
   Part No SW: 8K0 907 551     HW: 8K0 907 551
   Component: 3.0T SIMOS84  H06 0005
   Revision: --------
   Coding: 0104000C240F0128
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30TFS8K0907551 A01007
   ROD: EV_ECM30TFS8K0907551.rod
   VCID: 6ED3AF87B1F2BF4E9C-803A
Readiness: 0000 0001
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 8K1 927 156 AC    HW: 0B5 927 156 E
   Component: 0B5 30TFSIRdW H04 0004
   Revision: --H04---    Serial number: 0000000403
   Shop #: WSC 00613 210 88222
   ASAM Dataset: EV_TCMDL501 A02051
   ROD: EV_TCMDL501.rod
   VCID: 76E387E7C9A2878E54-8022
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 BE    HW: 8K0 907 379 BE
   Component: ESP8 quattro  H04 0030
   Coding: 296D0A
   Shop #: WSC 06325 123 12345
   VCID: 7DF198CBE494D4D615-8028
   Part No SW: 8K0 907 064 DQ    HW: 8K0 907 064 DQ
   Component: BCM2 1.1      H02 0327
   Coding: 053100
   VCID: 020BEB379D6AAB2E68-8056
   Subsystem 1 - Part No SW: 8T0 959 754 AM    HW: 8T0 959 754 AM
   Component: FBSAUDIB8 IDG  H38 0060
03283 - Antenna for Access & Start Authorization; Left
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 182
                    Mileage: 118143 km
                    Date: 2016.06.01
                    Time: 17:47:52
   Part No SW: 8T2 820 043 AG    HW: 8T2 820 043 AG
   Component: KLIMA 3 ZONEN H08 0171
   Revision: D1000000    Serial number: 01150220100219
   Coding: 66040000
   VCID: 77FD8AE3C6A8FE864F-8022
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000465040
   Coding: 2600D09540348F313F01000300001D0D4F9DC34A02010141000000
   VCID: 3C7755CFBF0E1DDE62-8068
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 170210  H05 0070
   Coding: 00FD11
   Component: RLS  H04 0003
   Coding: 025028
   Component: E1 - LDS  H08 0090
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 R    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0070
   Revision: 11001001    Serial number: 50941004808502
   Coding: 10010D
   VCID: 489F391FFBD6417EF6-801C
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 B    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0053
   Revision: 00000000    Serial number: 15021002870001
   Coding: 050181
   VCID: 39794CDBB03C28F679-806C
00774 - Level Control System Sensor; Rear Left (G76)
                    Fault Status: 00100011
                    Fault Frequency: 11
                    Reset counter: 229
                    Mileage: 118146 km
                    Date: 2016.06.01
                    Time: 19:08:31
                    Bin. Bits: 00000010 00000000
                    Bin. Bits: 00000000 00000000
03262 - Comfort Restriction
            000 -  -  - Intermittent
                    Fault Frequency: 11
                    Reset counter: 229
                    Mileage: 118146 km
                    Date: 2016.06.01
                    Time: 19:08:31
                    Error Code: 2
                    Bin. Bits: 00000000
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EFD0C54L1
   Coding: 30363435363030303030554A3052384B3053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 4189243BD0EC703631-8014
   Serial number: 6334MSME5010304D%
   Serial number: 6344MSME4F615618K
   Serial number: 6352QSME3D4E4F1A+
   Serial number: 6362QSME7C4F2220M
   Serial number: 63732SME4D4F031A6
   Serial number: 63832SME4E4F363AG
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Revision: --------    Serial number: 90304JBG000A5
   Coding: 000036
   VCID: 3E735FC7A9120FCE4C-806A
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 980 P    HW: 8K0 920 980 P
   Component: KOMBIINSTR.   H05 0255
   Revision: 00300000    Serial number: CJ163WF2A
   Coding: 2F1F0900BB001700810401
   VCID: 3F8D22C3AE1806C647-806A
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E1020203AE
   Coding: 00C303
   VCID: 52AB1B770D8AFBAE98-8006
   Component: J367-BDM  H07 0170
   Part No SW: 8K0 907 144 D    HW: 8K0 907 144 D
   Component: DYNAMIKLENK.  H06 0570
   Revision: 50001005    Serial number: --------------
   Coding: 8C0000
   VCID: 306F71FF6346E9BECE-8064
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163     HW: 8K0 907 163
   Component: 4 Wheel Drive H09 0004
   Serial number: 000102100001088
   ASAM Dataset: EV_AllWheelDiffeQSPCAN 003007
   VCID: 6DD1A88BBCF44456A5-8038
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0020
   Revision: S0H04000    Serial number: 00000000013902
   Coding: 01010101000000000000000102
   VCID: 2D51688B74748456E5-8078
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000010113604
   Coding: 011F12204421410001
   VCID: 4581302BCCC45C160D-8010
   Revision: 00002001    Serial number: 0126794883
   Coding: 015B1E2200BD0C010030013680000000
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34882001361801
   VCID: 7AFB93D7F5BAE3EE30-802E
03029 - Subwoofer (R157)
                    Reset counter: 182
                    Voltage: 12.40 V
                    Temperature: 14.0°C
                    Temperature: 15.0°C
                    Bin. Bits: 00000100
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000010128934
   Coding: 011E12204421410001
   VCID: 44872D2FC7FE651E1A-8010
   Revision: 00000003    Serial number: 10000000433464
   VCID: 34677DEF975ED59EAA-8060
   Part No: 8K0 907 357 B
   Coding: 0000005
   Shop #: WSC 06324 000 00000
   VCID: 34677DEF575ED59EAA-8060
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Fault Status: 00101101
                    Fault Frequency: 11
                    Reset counter: 229
                    Mileage: 118146 km
                    Date: 2016.06.01
                    Time: 19:08:31
   Part No SW: 4F0 035 053 K    HW: 4F0 035 053
   Component: Radio U Basic H45 0074
   Revision: AB001007    Serial number: 341BY0A7705767
   Coding: 010003010000000001
   VCID: 254190AB2C84BC162D-8070
   Part No SW: 8T2 035 666 M    HW: 8T2 035 666 E
   Component: H-BN-EU       H47 0187
   Revision: --------    Serial number: 475BY0A7545091
   Coding: 010101000206E1ED25000F1E000000030000
   Subsystem 1 - Part No: 8R0 060 884 DF
   Component: EUR 2016  2204
   Component: DU7 High  H43 0306
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Component: CD-Database  1293
            000 -  -
                    Reset counter: 182
                    Mileage: 118143 km
                    Date: 2016.06.01
                    Time: 17:45:52
                    Bin. Bits: 00001000 00000000
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000102916246
   Coding: 010C12204021210001
   VCID: 428B2B37DDEA6B2E28-8016
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Revision:             Serial number: 0000102916244
End-------------------------(Elapsed Time: 03:34)--------------------------
Jef
HQ
I don't ....................... see anything in the Auto-Scan that makes me think [XYZ] is draining the battery.
As for the fault code in the Kessey:
This is the R200, it looks like the wiring for this does go to a T27b connector at the bottom of the left B pillar.
G200 /1 = blue to T27b/17 to J393 T32e/12
G200 /2 = grey to T27b/5 and from there a green wire to J393 T32e/11
I'd double check the wiring ........................ the wiring from the G200 to that T27b connector.
As for checking for the drain on the battery, you are going to need to lock the car up and start checking your voltage drops across fuses:
http://forums.ross-tech.com/showthr...aw-on-CAN-Gatway-vehilces&highlight=draw+test
Let me know if you have questions about this procedure. Might give me the kick in the pants to slap together a lazy video on that topic.
shreyas1983
C?ID=263316
Thanks. I am going to a place called HazzyDayz tomm to have my CCM replaced or looked at. I will check the wiring and fuses over there. Just pulled out the PCB inside my CCM today and there are faint marks on the it from water damage. To give a bit of history:
I had the car tinted about 5 months ago. A week ago, the car was parked up for a couple of hours, and when I came back, the subwoofer stopped working. The next day my Kessy stopped working. I had an energy management fault active, so I also fitted a new battery. Just out of curiosity, I opened the cover on left side of the trunk which houses my amp, and to my horror, I found that the guys who tinted my car had stuffed bubble wrap and tissue papers all around the amp. So the amp was basically cooking in there while I was rocking the sub! This combined with faint water marks on the CCM PCB made me think that the CCM has gone bust. Funny enough all my speakers work fine, so I am assuming a certain part inside the amp blew up?
Pictures of the CCM attached. The water are very hard to see, unless in proper light...
shreyas1983
C?ID=263316
Quick update. Tried using a fresh wiring room and that did not help. So ended up replacing the module. All is working fine now. Hopefully that has sorted the battery issue. If not, will have to recheck..
