First vw first problem
DarrylMan
C?ID=217069
So.....went out this morning to a dead battery:mad: fortunately I had recently gather some of the tools required to work on these things, (triple squares, pentalobe screwdrivers and vag-com). Battery swap was not that bad, watched a you tube video and away I went. After the swap was completed I hooked up vagcom and cleared everything, the only problem I have is my radio is now dead, no power, vagcom says "no signal from controller". I checked all fuses on both sides of the dash, all good. I was prepared to recode as I found a "Radio Secure key" ( a little plastic dog tag with code) in the battery compartment, but the radio won't power up to put code in. Radio was working fine when I parked the night before. Any thoughts? or am I off to the stealer.....I mean dealer.
Yeah, kinda tough to post much of any kind of useful response without knowing what year and model car he's got, but obviously a full Auto-Scan would tell us all that and more.
DarrylMan
C?ID=217069
My bad, thought I filled out my sig:confused:, here is latest autoscan
 Wednesday,04,June,2014,10:52:50:21461
VCDS Version: 12.12.2.0
Data version: 20140212
Dealer/Shop Name: Home
VIN: WVGZG77L55D063859   License Plate: 04-06-14
Mileage: 141420km-87874mi   Repair Order: 10
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZG77L55D063859   Mileage: 141420km/87874miles
Address 01: Engine        Labels: 022-906-032-BMX.lbl
   Part No SW: 022 906 032 FT    HW:
   Component: MOTRONIC ME7.1.1G   6618
   Revision: 00000000    Serial number: VWZ3Z0E5309716
   Coding: 0000133
   Shop #: WSC 22607 444 83916
   VCID: 62CBBE30BE1C640EED3-5140
16452 - MAP/MAF <-> Throttle Position Correlation
            P0068 - 001 -  - MIL ON
Readiness: 0010 1101
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Part No: 09D 927 750 BA
   Component: AL 750 6A           0892
   Coding: 0004153
   VCID: 6ED3DA007AC4D06E79B-5140
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0014338
   Shop #: WSC 31414 000 00000
   VCID: 3D712D4C67227BF6B01-5140
No Faults Found
   Part No SW: 3D0 909 135 P    HW: 5WK 470 25
   Component:    Kessy            6610
   Revision: 66105312    Serial number: VWZ3Z0E5309716
   Coding: 0000232
   VCID: 326B0E70AE7CB48E5D3-5140
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 H
   Component: CLIMAtronic R/L   X 3716
   Coding: 0020030
   VCID: 3561356C5F12A3B6781-5140
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 M
   Component:                     3001
   Coding: 0101599
   VCID: 468342A032F4382EE1B-5140
   Part No: 3D0 909 601 H
   Component: 01 Airbag 8.4E++H01 0562
   Revision: BB38727     Serial number: 0000605:
   Coding: 0012337
   VCID: 285FEC1898A0CE5EF37-5140
   Subsystem 1 - Part No: 7L0 959 339 D
   Component: BF-Gewichtsens. 005 0007
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000031
   VCID: 408F54B810D0161EDB7-5140
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 970 R
   Component: KOMBIINSTRUMENT RB8 2010
   Coding: 0007231
01304 - Radio
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: F0EF4478E0F0469EEB7-515E
01304 - Radio
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
   VCID: 458145AC0FF23336E81-5140
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F0D17442DAEA9E6E2D-5140
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000002
   VCID: E6C32220D234982E81B-5140
   Part No: 7L0 959 760
   Component: Sitzverstellung     0702
   VCID: F7FD7F64859E11A62AD-5140
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  0001
   Coding: 0000002
   VCID: E7DD2F24D53E8126BAD-5122
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L0 959 933 E
   Component: 2L HSG              0201
   Coding: 0000085
   VCID: 3E732A406A2460EEA9B-4B00
   Subsystem 1 - Part No: 7L0 959 701 G
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 G
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 C
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 C
   Component: Tuersteuergeraet HR 0201
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 K
   Component: Front Wiper         4027
   Coding: 0000855
   Shop #: WSC 31414 000 376832
   VCID: 3C7720487C3872FE87F-515E
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 31414
No Faults Found
Address 6E: Ctrl Head Roof        Labels: 7L6-919-044.lbl
   Part No: 7L6 919 044 K
   Component: DACHDISPLAY         0538
   Revision: 00700538    Serial number: 2009289.06
   VCID: 3F8D57446D2E69E6A2D-5140
Address 76: Park Assist        Labels: 3D0-919-283.lbl
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 3979395C730A47D69C9-5140
DrPeter
16.4905° S, 151.7375° W
Hi,
Try removing power from the Radio for a few minutes, this some times can help re-boot the Radio.
- You can do this by pulling out fuse SC11-10Amp, fuse holder right side
or
- You can remove the Radio and unplug it (better way) and at that point you can also check the fuse on back of the radio.
Once the Radio is back on-line it should not be necessary to enter the Radio Code, as this Radio should be able to ID the vehicle it was in last and then turn on without a code.
Hope this helps,
drpeter
DarrylMan
C?ID=217069
Thanks, will try the fuse thing for now as I don't have the radio removal tools yet.
DarrylMan
C?ID=217069
Sweet;) that did the trick, thanks for your input.
DrPeter
Cool! Glad to help, this also can apply to other 'smart' Radios, like the Jetta/Golf...
drpeter
