AUdi Allroad 2002 - No responce from contoller issue
djhubi1
C?ID=279655
Hi All
I got Audi Allroad from 2002 right hand drive. Yesterday my A/C stop working and I have use my VCDS inteface (HEX+CAN) to check what is going on. Unfortunately I was not able to connect to Auto HVAC and Level control as well. Each time I do trying I have got "no response from controller" message. Interface does communicate to Engine and Transmision without any problem. I have try also to use Auto scan option where it does not see the controllers as well. Please advice guys what I'm doing wrong.
Best Reagrds
djhubi1
C?ID=279655
VCDS Version: Release 15.7.4 (x64) Running on Windows 8.1 x64
Data version: 20160216
Monday,30,May,2016,16:26:48:14784
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2006))
          75 76 77
VIN: WAUZZZ4B43N069257
Address 01: Engine        Labels: 059-907-401-AKE.clb
   Part No: 4Z7 907 401 B
   Component:  2.5l/4VTEDC G000AG D09
   Coding: 01016
   Shop #: WSC 02325
   VCID: 3C7DDCB42C5267DE62-4A08
   WAUZZZ4B43N069257     AUZ7Z0B2264505
Readiness: N/A
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 4Z7 927 156 H
   Component: AG5 01V 2.5lTDI RdW 2121
   Coding: 00001
   VCID: 4B9F8F6879FCD066DB-5038
17090 - Transmission Range Sensor (F125)
            P0706 - 35-00 - Implausible Signal
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 4Z7 907 389 A
   Component: ABS/ESP allrad      D56
   Coding: 06457
   Shop #: WSC 02325
   VCID: 4A918A6C7686C96EE0-5038
01119 - Gear Recognition Signal
            35-10 -  -  - Intermittent
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 981 J
   Component: KOMBI+WEGFAHRS. VDO D12
   Coding: 04460
   Shop #: WSC 00476
   VCID: 2D5BE1F0E728FE56E5-5054
Address 35: Centr. Locks        Labels: 4B0-962-258.lbl
   Part No: 4B0 962 258 N
   Component: Zentralverrieg.,DWA D38
   Coding: 06859
   Shop #: WSC 00198
   VCID: 346DF4940402AF9EAA-4DD6
8 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 -  -
01374 - Alarm triggered by Terminal 15
            35-00 -  -
01370 - Alarm triggered by Interior Monitoring
            35-00 -  -
01559 - Drivers Door
            58-10 - Can't Lock - Intermittent
            59-10 - Can't Unlock - Intermittent
            60-10 - Won't Safe - Intermittent
            61-10 - Won't De-Safe - Intermittent
01561 - Rear left door
Address 45: Inter. Monitor        Labels: 4B0-951-178.lbl
   Part No: 4B0 951 178 A
   Component: Innenraumueberw.    D04
   Coding: 00102
   Shop #: WSC 02325
   VCID: 26491EDCC2DECD0E24-5038
01350 - Alarm via Theft Warning System; Rear
            35-00 -  -
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00030
   Shop #: WSC 02325
   VCID: 040D64541422DF1E5A-4A20
   Part No: 4B0 035 195 H
   Component: symphony II NP2    0151
   Coding: 00200
   Shop #: WSC 00088
   VCID: 254B19D0BFD8C6162D-4DBA
00856 - Radio Antenna
            36-00 - Open Circuit
End-------------------------(Elapsed Time: 05:23)--------------------------
OK, I think I see the problem, at least as far as the HVAC module is concerned. I'm less confident about the Level Control. You're not going to like this, but I'm going to need you to take VCDS back out to your car and do another Auto-Scan. Just before you do it, go to [Options], set Debug Level to 8, and click [Apply]. Then immediately do the Auto-Scan. After it completes, look in the Debug sub-folder. There you should find a file named Debug-Cal.dlm. Send that to Support[at]Ross-Tech[dot]com along with a link to this thread.
Oh wait, you're not Verified. I'm not sure if they'll help you until you Get Verified.
djhubi1
C?ID=279655
Hi Uwe
Many thanks for your help. I have followed your advice and I've sent them the file Debug-Cal.dlm.
Also I have transferred the registration and I'm alreay registered user.
Regards
Yep, all confirmed / verified. Moving this to Product Support.
Oh, and you've got an e-mail. Please post a fresh Auto-Scan after the calibration.
djhubi1
C?ID=279655
Hi Uwe
Thank you for an email. It looks like all works as it should :)
Fresh auto-scan as requested
Tuesday,31,May,2016,21:29:06:14784
          75 76 77
   Coding: 01016
   Shop #: WSC 02325
   VCID: 3C7DDCB42C5267DE62-4AD6
Readiness: N/A
   Coding: 00001
   VCID: 4B9F8F6879FCD066DB-5132
            P0706 - 35-10 - Implausible Signal - Intermittent
   Coding: 06457
   Shop #: WSC 02325
   VCID: 4A918A6C7686C96EE0-5132
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AL
   Component: A6-Klimavollautomat 0105
   Coding: 00004
   Shop #: WSC 02325
   VCID: 64CD44D4F4627F1EFA-2576
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
            57-00 - Electric Circuit Failure
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4Z7 959 655 H
   Component: Airbag 8.4EP        2000
   Coding: 0001106
   Shop #: WSC 02335 785 00200
   VCID: 54AD9414F4C28F9E8A-5132
   Coding: 04460
   Shop #: WSC 00476
   VCID: 2D5BE1F0E728FE56E5-514E
Address 34: Level Control        Labels: 4Z7-907-553.lbl
   Part No: 4Z7 907 553 F
   Component:  - 2C1A1          D060
   Coding: 25500
   Shop #: WSC 45796
   VCID: 4895B064688A3B7EF6-5114
01772 - Signal from Level Control Pressure Sensor (G291)
01400 - Suspension Level Control
            08-10 - Control Limit Surpassed - Intermittent
   Coding: 06859
   Shop #: WSC 00198
   VCID: 346DF4940402AF9EAA-4EE2
8 Faults Found:
            35-00 -  -
            35-00 -  -
            35-00 -  -
   Coding: 00102
   Shop #: WSC 02325
   VCID: 26491EDCC2DECD0E24-5132
            35-00 -  -
   Coding: 00030
   Shop #: WSC 02325
   VCID: 040D64541422DF1E5A-4B20
   Coding: 00200
   Shop #: WSC 00088
   VCID: 254B19D0BFD8C6162D-4E90
End-------------------------(Elapsed Time: 05:14)--------------------------
djhubi1
C?ID=279655
Hi Uwe
How are you ?
After interface callibration which I performed followed your instruction I can't get connection with any vehicle with CAN. We bought Audi A6 from 2007 and I can not connect it with any control unit. Previously before calibration interface work ok with CAN now when I check Port test it disply CAN is not supported.
Regards
Hubert
This type of calibration has no effect on CAN.
What firmware version is in your interface? [Options] -> [Test] will tell you this.
What version of VCDS are you using?
Per an email (between the OP and Andy in our Support team) I believe this was a Beta only FW 1.96 conflict as Uwe suspected.
