I have searched the wiki files codes for 18062 and the closest is 18061/18063. Is there any information available regarding code 18062 please?
I'm not sure I understand what you're trying to tell us here. Maybe an Auto-Scan would shed some light on things?Thanks I checked using VCDS and no faults are reported. Apparently it is intermittent and because no data seems to be available I can't carryout a checking procedure.
I completed an auto scan, its on my other computerI'm not sure I understand what you're trying to tell us here. Maybe an Auto-Scan would shed some light on things?
Little hijack -sorry-, do you have some manufacture information on that. I have never heard of that. As far i can tell a engine temp sensor is a NTC or PTC.You do know that some sensors (pressure and temperature, among others) are actually tiny micro-controllers and don't send a voltage level any more, they actually send a data-stream over a single wire LIN-bus? .
Read about LIN on Wikipedia. For a real example - and when you've got a bit of time - read this thread. It shows there is a sensor for the HVAC that is in fact on the front Central Electrics LIN. It incorporates a temperature sender and pressure transducer in the one housing and transmits its data via the Homelink Garage door opener to the Cent Elec Module (09). Cent Elec then transmits the pressure/temp data over CAN to the HVAC controller.(LIN-Bus)...do you have some manufacture information on that. I have never heard of that. As far i can tell a engine temp sensor is a NTC or PTC.
One auto scan as requested.I am tempted to lock this topic, you have been asked for an Auto-Scan more than once now and you still haven't provided it. In many cases it isn't just about the fault code but more so about what other components say or what they are... Please don't waste peoples don't with incomplete inquiries, post an Auto-Scan and complete vehicle details!
Sunday,29,May,2016,10:34:52:61979
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WV1ZZZ7HZ6H036014 License Plate:
57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ6H036014 Mileage: 209350km-130084miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 038 906 016 M HW: 028 101 185 6
Component: R4 1,9L EDC 0000SG 6278
Revision: 12345678 Serial number: VWZ7Z0E2628424
Coding: 0101031
Shop #: WSC 02756 785 00200
VCID: 1E33B01ECA45CECE6C-5140
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 000 - - Intermittent
RPM: 2058 /min
Torque: 6.0 Nm
Speed: 27.0 km/h
Load: 6.3 %
Voltage: 14.44 V
Temperature: 25.2°C
Temperature: 66.6°C
Temperature: 16.2°C
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 7H0-907-37x-ASR-F.lbl
Part No: 7H0 907 379 G
Component: ASR FRONT MK25 0103
Coding: 0007205
VCID: 3979438273AB89F679-5124
Address 09: Cent. Elect. Labels: 7H0-937-049.lbl
Part No: 7H0 937 049 M
Component: BORDNETZ SGVER 1.0 0901
Coding: 0000004
Shop #: WSC 02770 785 00200
VCID: 3C775A967C99BCDE62-5124
Part No: 1C0 909 605 A
Component: 3B AIRBAG VW51 0008
Coding: 13122
Shop #: WSC 02756
VCID: 224B84EEAE3DEA2E48-5124
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H0 920 951 F
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 01411
Shop #: WSC 00001
VCID: 2F6D7DDAEDEF5746D7-5106
WV1ZZZ7HZ6H036014 VWZ7Z0E2628424
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 02770
VCID: 70EFBEA6305108BE8E-5124
Address 45: Inter. Monitor Labels: 7Hx-951-171.lbl
Part No: 7H0 951 171
Component: Innenraumueberw. 2815
Coding: 0000021
VCID: 67DDD5FA559FCF06DF-517C
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: C2B Komfortgerát 0004
Coding: 00016
VCID: 326B74AEFEDD7AAEB8-4B00
77-00 - Internal Supply Voltage
36-00 - Open Circuit
End-------------------------(Elapsed Time: 06:45)--------------------------
Thanks for replying Jack. With regards the part # sensor replaced I am assuming that you are referring to the coolant sensor I just replaced!Is it the correct part # sensor replaced?
"Beware of FOD ...........Give before it hurts".
