Hi,
I've just retrofitted towbar to a new A5.
I've coded everything except ACC - can anyone help me out ? Thanks
VCDS Log:
VCDS Log:
Sunday,29,May,2016,11:11:19:21096
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WAUZZZ8T6GA054517 License Plate: UK
Mileage: 1490km-925mi Repair Order:
Chassis Type: 8T (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 3C 42 44 46 52 53 56 5F
62 69 72
VIN: WAUZZZ8T6GA054517 Mileage: 1490km-925miles
Address 01: Engine (J623-CJED) Labels: 06L-906-264-CJE.clb
Part No SW: 8K0 906 264 B HW: 8K0 906 264
Component: 1.8l R4 TFSI H09 0003
Revision: --H09---
Coding: 1A030032245401022000
Shop #: WSC 06208 123 12345
ASAM Dataset: EV_ECM18TFS0218K0906264B 001003
ROD: EV_ECM18TFS0218K0906264.rod
VCID: 3064A4496B713BBECE-8064
17176 - Databus
U1123 00 [039] - Received Error Message
Mileage: 1492 km
Date: 2016.05.29
Time: 10:57:50
Readiness: 1110 0001
Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
Part No SW: 8K9 927 155 D HW: 0AW 927 156 K
Component: 0AW 18TFSIRdW H08 0002
Revision: --H08--- Serial number: 0000000292
Coding: 000002
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMVL381 A02433
ROD: EV_TCMVL381_AU48.rod
VCID: 3D7A8D7DAC23C6D655-8068
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CN HW: 8K0 907 379 CN
Component: ESP8 front H09 0020
Coding: 059DCC01
Shop #: WSC 06325 123 12345
VCID: 07162F95B67F5C063F-8052
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 KF HW: 8K0 907 064 KF
Component: BCM2 2.0 H15 0711
Coding: 05A44000000000000000
VCID: 7EF84A71E9A51DCE0C-802A
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01060420160591
Coding: 642002C000
VCID: 77F65F55C69F2C864F-8022
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001329804202
Coding: 2600C0108074AFC00081400300001D0D0F1C630826090201000008004401020100000024000000
VCID: 78F45C69CB8123FE46-802C
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150316 H15 0080
Coding: 00FD11
Component: G397_RLFS H06 0004
Coding: 02005D
Component: E1 - LDS H03 0031
Component: AQ_Hum_Sensor H03 0005
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 B HW: 8K0 907 561 B
Component: ACC3 H11 0110
Coding: 00A4B8
VCID: 3162A14D687B32B6C1-8064
Reset counter: 61
Mileage: 1492 km
Date: 2016.05.29
Time: 10:57:50
Temperature: 26.0°C
Voltage: 12.54 V
Hex Value: 0x005D
Lateral Accel.: 0.00 m/s^2
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H49 0610
Serial number: 003KFDD2T6BQ
Coding: 30513938363030303030554A304C38543053
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4894ECA9F3E1937EF6-801C
Serial number: 6334MSME58193573E
Serial number: 6344MSME581B700FL
Serial number: 6352QSME09593654I
Serial number: 6362QSME54585240B
Serial number: 63732SME4F51275A5
Serial number: 63832SME00591C56
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Revision: -------- Serial number: 90372PD6000RS
Coding: 00001E
VCID: 448CF899C7C9B71E1A-8010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 932 S HW: 8T0 920 932 S
Component: KOMBIINSTR. H36 0567
Revision: 00100000 Serial number: 5PN27J44H
Coding: 13A7300007010008010000
VCID: 4894ECA9FBE1937EF6-801C
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 AA HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0070
Revision: 1Z130032 Serial number: 3241Z1631602C4
Coding: 80CF07FF00
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02019864747464545425363E00
VCID: 7CFC4079FFB90FDE22-8028
Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H07 0071
Serial number: 0399232552
Coding: 010311
Shop #: WSC 06324 000 00000
VCID: 3F86F775A62FD4C647-806A
Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H10 0305
Coding: 011C13624000450005
VCID: 56A832D12155358E74-8002
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8K0 909 144 Q HW: 8K0 909 144 L
Component: RCevo H54 0702
Revision: 00000001 Serial number: 0000724030
Coding: 100000000001
ASAM Dataset: EV_RCEPSAU48X 104002
ROD: EV_RCEPSAU48X.rod
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0399601659
Coding: 01000E3820B900018330043680000047
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H10 0305
Coding: 011C13224000450005
VCID: 55AA35DD3C533E967D-8000
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H03 0005
Revision: -------- Serial number: 00000001796003
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A708661BD0DF1EE70-806E
Part No SW: 4G0 035 056 J HW: 4G0 035 056
Component: Radio U STD H60 0133
Revision: AB001007 Serial number: 230CI0G3420513
Coding: 010003020100000001
VCID: 28544C295BA1737E16-807C
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 666 K HW: 8R1 035 666 H
Component: H-BN-EU H49 0946
Revision: -------- Serial number: 514C50GS013821
Coding: 130100040006A9ED31808B5E00000403E40000020000000000
VCID: 4084F489D3D1AB3E3E-8014
Subsystem 1 - Part No: 8R0 060 884 DF
Component: EUR 2016 2204
Component: DU7 High H42 0104
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: CD-Database 6890
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H08 0305
Coding: 010C13224000450005
VCID: 59B239ED504B1AF659-800C
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H07 0100
Revision: 1A001001 Serial number: 00000139642648
Coding: 0100000000000000
Shop #: WSC 25381 123 12345
VCID: 366892518115158E94-8062
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H08 0305
End-------------------------(Elapsed Time: 03:28)--------------------------
