Can not enter instrument option
Roberi
Norway
C?ID=277889
Hello. I bought a Micro-CAN from ross tech's website a few weeks ago and everything worked perfectly until a few days ago. I can not enter the instrument option anymore. When I press it, it takes forever to load, and when it does load this is all that appears (See picture). Does anyone here know why?
IXNhSMo
Roberi
Norway
C?ID=277889
Strange. What kind of car?
We've seen that kind of thing occasionally on early D3 A8s. The fix on those is a cold-boot of the instrument cluster.
Roberi
Norway
C?ID=277889
I have an audi a3 2006 8P.
How do you cold-boot the instrument cluster? I could try that .
Zenerdiode
Newcastle, England
C?ID=24330
If you use some Factory WD you could see which fuses supply the Instrument Cluster. Remove all for about 2 minutes, reconnect and try VCDS again. You could also disconnect the battery for about the same length of time, but be prepared to reset the electric windows and/or the radio going 'SAFE'.
Roberi
Norway
C?ID=277889
Thanks, I am going to try that.
If the electric components does go into safe mode, how do I reset it? :)
Radio should going into SAFE mode not be a problem on a car that new.
Roberi
Norway
C?ID=277889
Now it is working! I removed the fuse connected to the instrument cluster and reconnected it back again.
Thanks to both of you for your help!
