- Sep 6, 2014
- 4,604
- 5,503
- The Land of OCC, NY, USA, Earth
- C?ID=31688
Since there always seems to be interesting airplane articles popping up in the news, why not give them their own thread?
https://hushkit.net/2016/05/25/the-ten-worst-soviet-aircraft/
The 11 worst Soviet aircraft of all time, in particular:
7. Silvanskii IS
Silvanskii is a name synonymous with Russian fighters..oh, wait – no it’s not. And there is a very good reason that it’s not. In the midst of Stalin’s muddled and oppressive USSR, one A.V. Silvanskii secured state funding to create a new fighter in 1937. The concept seemed sound- it was a low-winged monoplane with a 1,000 horsepower radial engine, armed with two heavy machine guns. As development began it soon became apparent that Silvanskii was a reckless bodger. By 1938 the prototype aircraft was virtually complete. Initial tests of the undercarriage revealed that the wheel wells were too small- the undercarriage did not fit into the wing in the retracted position. How this elementary mistake had been made is hard to understand, but the solution was simple- the undercarriage legs were shortened. Now the undercarriage could be retracted it was realised that the wheel bays were too shallow so the undercarriage would stick out into the airstream producing drag. Deciding not to rectify this issue, the team then fitted the propeller. Though the aircraft now had a shorter undercarriage than originally designed, no-one saw fit to think through the consequences of this modification; the propeller was now too large and would smash against the ground on take-off. Ever the master of methodical engineering, Silvanskii took a saw to the offending propeller and lopped four inches off each blade. The manager of the GAZ state aircraft factory watched this slapstick affair with dismay and growing alarm. He quite sensibly refused Silvanskii permission to fly from the factory airfield. The persistent Silvanskii looked for an alternative airfield for his fighter and charmed the State Flight Research Institute (LII) in Moscow into providing a runway and a test pilot for the maiden flight. One cold morning in early 1939, the LII test pilot strapped himself into the aircraft, known simply as the IS or ‘Istrebitel’ (fighter) and prepared to fly. The machine had other ideas, but thanks to a combination of full throttle and extremely dense cold air the machine was coaxed into taking off for one hair-raising circuit flown dangerously close to the stall. On landing the pilot damned the aircraft as unflyable. The Silvanskii bureau was bankrupted and the hapless designer was banned from working in aeronautical design.
— Joe Coles, Hush-Kit
