Tuesday,03,June,2014,10:57:05:45597
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WVWZZZ1KZ7M187787 License Plate:
Mileage: 74580km-46341mi Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ7M187787 Mileage: 74580km/46341miles
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 EQ
Component: SIMOS71 1.6l 2V 9446
Revision: --H03--- Serial number: VWZ7Z0G9073935
Coding: 0000075
Shop #: WSC 00066 000 00000
VCID: 72EF25466D1D3C8E9D3-8027
16864 - Coolant Fan Control Circuit 1
P0480 - 009 - Electrical Malfunction - MIL ON
Mass Air / Rev.: 0.0 mg/str
Temperature: 51.0°C
Voltage: 12.04 V
Readiness: 1110 1101
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No: 09G 927 750 ET
Component: AQ 250 6F 0842
Coding: 0008264
VCID: 8719E492F69FA9265AD-80D2
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F89BC726ECFA1E6A2D-806A
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BM HW: 1K0 907 044 BM
Component: ClimatronicPQ35 110 1010
Revision: 00110021 Serial number: 00000000000000
VCID: 73E1204212073586965-8026
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000137061
Coding: 01010E2700041800000A00000F00000000095D035C
VCID: 2B51F8228AB72D461E5-807E
Component: Wischer 250507 020 0501
Coding: 00038805
Shop #: WSC 00066
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 89
Mileage: 74585 km
Voltage: 11.90 V
Component: 2L AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD15C70V
Coding: 0012876
VCID: 3D75C67A64C3B3F6B01-8068
Subsystem 1 - Serial number: 6332MSME180C4925C
Subsystem 2 - Serial number: 6342MSME180407530
Subsystem 3 - Serial number: 6351HSME0D210B2C8
Subsystem 4 - Serial number: 6361HSME0D212640$
Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP
Component: Lenksäulenmodul 636 0070
Coding: 0010011
VCID: 800BFF8ED3B19E1E1B7-80D5
Part No SW: 1K0 920 863 A HW: 1K0 920 863 A
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0G9073935
Coding: 0016103
Shop #: WSC 36002 360 89777
VCID: 295D022A804B3F56EC9-807C
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 130407F1001018
Coding: 3F3F034007001002
VCID: 2F69EC32BEAF516632D-807A
Component: IMMO 3HL 1610
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1133
Revision: 32008001 Serial number: 00000056978505
Coding: 0000180
VCID: 3B71C8627AD7BDC68E5-806E
Fault Status: 01100101
Reset counter: 89
Mileage: 74585 km
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.068 H07 1806
Shop #: WSC 02069 000 90108
VCID: 3463E35E578972BE4FF-8061
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 80900A000106087F2D04840560084F03E0F8A0
VCID: 8301F082C2A78506065-80D6
Fault Status: 01101101
Reset counter: 89
Mileage: 74585 km
Time: 00:39:27
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1133
Revision: 32008001 Serial number: 00000025578507
Coding: 0000180
VCID: 3C73CB7E7FD9BAFE87F-8069
Reset counter: 89
Mileage: 74585 km
Part No SW: 1K0 035 186 T HW: 1K0 035 186 T
Component: Radio BVX 034 0046
Revision: 00034000 Serial number: VWZ1Z2G4524116
Coding: 0040400
VCID: 3779D45246FF99A66AD-8062
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1120
Revision: 11006001 Serial number: 00000001587155
Coding: 0000144
00934 - Electric Window Motor; Rear Left (V26)
Reset counter: 89
Mileage: 74585 km
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1120
Revision: 11006001 Serial number: 00000001584091
Coding: 0000144
VCID: 3E77C17669C5A8EEA9B-806B
00935 - Electric Window Motor; Rear Right (V27)
Reset counter: 89
Mileage: 74585 km
End ---------------------------------------------------------------------
