Rough start with vag installed
e36graduate
C?ID=90163
Bizarre, car always starts right up every time.......except today when I received my new vag tool from Ross tech. I ran auto check and cleared up existing faults. I then was inside engine command trying to find misfire location and decided to start car. She started but was very rough, settled down and began to idle properly.
Did I do something wrong by starting car while currently in an engine component of vag tool?
Anyone know how to monitor misfires?
NostraJackAss
It is always helpful to post an auto-scan.....
Not unless you were performing an ADP during the crank.....were you?
Misfire can be checked in 0x01-08-014 for all ZYL count.
ZYL 123 @ 0x01-08-01
ZYL 345 @ 0x01-08-016 etc etc.....
I suspect this is the 2007 RS4 in the order notes but the scan would be helpful. If that vehicle had fault codes, perhaps misfire in addition to fuel trim problems due to vacuum leaks or similar, clearing faults would clear learned (and possibly corrupted) fuel trims so that may explain the extended crank?
e36graduate
C?ID=90163
What is adp ?
Again, there were no relevant codes prior to the funny stumble start, and no issues with car at all, however I started car just after cleaning all nav related codes, messing with headlight level learning, etc and was in the process of trying to find cylinder misfire within engine control module.......I think I was within a field where field was showing various engine data when I started it up and had a rough stumble start?
She started up fine after that? No codes?
e36graduate
C?ID=90163
Here is my first scan of the RS4......car has aftermarket NAV system so you will see a bunch of codes related to that.
The RS was lowered and I have intermittent bouncy headlights......trying to figure out how to calibrate with VAG?
Tuesday,03,June,2014,11:20:12:04346
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
          67 69 75 76 77
Address 01: Engine        Labels: 079-910-560-BNS1.lbl
   Part No SW: 8E1 910 560 A    HW: 8E1 907 560
   Component: 4.2L V8/4V FSI     ª0060
   Revision: 57H13---    Serial number: XXXXXXXXXXXXXX
   Coding: 01040009180F0160
   Shop #: WSC 01013 444 54453
   VCID: 2447F869E7CB053EDFF-8071
001153 - Coolant Fan Control Circuit 2
               P0481 - 002 - Electrical Malfunction - Intermittent
                    Mileage: 115640 km
                    RPM: 1157 /min
                    Load: 27.4 %
zA                    Speed: 15.0 km/h
                    Temperature: 96.0°C
                    Temperature: 43.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.589 V
   Part No SW: 8E0 910 517 G    HW: 8E0 614 517 BD
   Component: ESP8 quattro    H06 0150
   Coding: 0004533
   Shop #: WSC 06335 000 00000
   VCID: 2B5513558A15CA461E5-807E
   Part No: 8E0 820 043 AD
   Component:   A4 Klimaautomat   1424
   Coding: 00000
   Shop #: WSC 63351
   VCID: 63C5BB75F1454206E65-515E
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 - -
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 01023
   Shop #: WSC 06335
   VCID: 3D712D0D376154F6B01-4B1A
            30-00 - Open or Short to Plus
01800 - Light Switch (E1)
            27-00 - Implausible Signal
Address 11: Engine II        Labels: 079-910-560-BNS2.lbl
   Shop #: WSC 06436 444 58807
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H12 3840
   Revision: 91H12384    Serial number: 0036N0G00ZVS
   Coding: 0432607
   VCID: 3C7720097F7B5DFE87F-8069
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 3BHJS
   Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB40382CD0BWÿ†63
   Subsystem 5 - Serial number: 2CD0BWÿ†6342DRB403864F0EYÿ†63
   Subsystem 6 - Serial number: 64F0EYÿ†6352ARB40159FA2E ÿ†63
   Subsystem 7 - Serial number: 9FA2E ÿ†6362ARB4015EEE06.ÿ†63
   Subsystem 8 - Serial number: EEE06.ÿ†63729RB40160DBE3Vÿ†63
   Subsystem 9 - Serial number: 0DBE3Vÿ†63829RB40160DB74Qÿ
   Subsystem 10 - Serial number: 0DB74Qÿ
Address 16: Steering wheel        Labels: 8E0-953-549-T.lbl
   Part No: 8E0 953 549 T
   Component: Lenksáulenmodul     0301
   Coding: 04441
   Shop #: WSC 06335
   VCID: 448758E9548B253EFFF-4B1A
01304 - Radio
            49-00 - No Communications
01301 - Control Module for Voice Recognition (J507)
   Part No SW: 8E0 920 981 S    HW: 8E0 920 981 S
   Component: KOMBI+WFS 4     H14 0040
   Revision: 0040        Serial number: 00000000000000
   Coding: 0023261
   Shop #: WSC 01122 444 54077
   VCID: 3D712D0D676154F6B01-515E
01304 - Radio
   Coding: 0023261
01304 - Radio
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: F1E9413DBBB96096E49-4B00
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 CG
   Component: Komfortgerát T7B    4135
   Coding: 11820
   Shop #: WSC 06335
   VCID: 78FFFC1958C3B1DEA37-4B00
   Subsystem 1 - Part No: 8E1959801G
   Component: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0706
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
01369 - Alarm triggered by Hood Switch
            35-00 - -
01374 - Alarm triggered by Terminal 15
            35-00 - -
Address 55: Xenon Range        Labels: 4F0-910-357.lbl
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   VCID: 2959E95D80E9D856EC9-807C
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H03 0010
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH05 0030
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
   Component: Reifendruck 3   H04 0130
   Coding: 0062523
   Shop #: WSC 02197 785 00200
   VCID: 2A5B165186EFD34EE53-515E
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
   Component: Parkhilfe 4-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802020618
   Coding: 0000304
   VCID: 3169013DAB39A096249-515E
dafrazi
Norristown, PA
C?ID=173774
Measuring Blocks 14 through 17 and 19 will show the misfires. The third data set from the left in Block 14 will show total number of misfires. Blocks 15-17 shows misfires on Cylinders 1-8. The Cylinder 1 being the left most on Block 15. The cylinder count increases as you move right through to Block 17. FYI, if you scan a V10 or V12, cylinders 10-12 are on Block 19.
Your going to need this. Link to measuring block list: http://www.ross-tech.com/vag-com/m_blocks/
If your RS has dual ECUs the misfires will be shown in the Engine II module; otherwise, they will be shown in the Engine module.
e36graduate
C?ID=90163
Thanks!!!
dafrazi...you are correct....the measuring blocks were not in the Engine module...had to find them in the Engine II......dual ECU's ...oh no.
e36graduate
C?ID=90163
Couple of questions for the PRO's:
1. The bulb out code for the License Plate, listed above, I have read this cannot be vag'd out? I put in some LED's that were supposed to fix the code? Any input?
2. The VIN discrepancy in the HVAC system? Used part in car? Anyway to rewrite the VIN?
3. The intermittent Cooling fan? Which fan is this and should I plan on replacing it soon? Fault frequency 10? Does this mean its happened 10 times? Reset counter of 255? Whats that mean?
Thanks in advance.
jakematic
NC USA
C?ID=129085
If the vehicle did not come from the factory with LEDs, that's tricky at best.
Has to do with amperage draw of incandescent -v- LED that is measured by the vehicle.
Lots of info on 01794 on the wiki.
Don't know, but suggest getting a Factory repair manual if you plan to do any amount of DIY.
You've got VCDS so you're already most of the way there :cool:
