hello this is my first time posting. We have an 2008 audi a3 2.0t bpy that is throwing the 008567 p2177 code Bank 1; System Too Lean off Idle: Upper Limit Exceeded .I have replace both pressure sensors and fuel filter verified that are the Correct #'s. Smoked check the intake, check the duty cycle on the fuel pump (g6)45% @IDEL WARM 62%@ full boost pulling onto highway. check for exaust leaks (slight @flex) I also swap a good air mass meter just to try. When looking 2 Blocks 103 106 AND 230 numbers look good
Could I have a bad fuel pressure sensor ?
Wednesday,25,May,2016,16:16:53:28770
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WAUHF78P58A125039 License Plate: 8AFSS9
Address 01: Engine Labels: 06F-907-115-AXX.clb
Control Module Part Number: 8P0 907 115 P HW: 8P0 907 115 B
Component and/or Version: 2.0l R4/4V TFSI 0010
Software Coding: 0103010A18070160
Work Shop Code: WSC 06314 000 00000
VCID: 3F875B916E0DDEC647-806A
008567 - Bank 1; System Too Lean off Idle
P2177 - 001 -
Fault Status: 01100001
Mileage: 225664 km
Date: 2016.05.23
Time: 22:08:57
RPM: 2116 /min
Load: 25.5 %
Speed: 56.0 km/h
Temperature: 85.0°C
Temperature: 42.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.970 V
Readiness: 0000 0001
P2177 - 001 -
Mileage: 225664 km
Date: 2016.05.23
Time: 22:08:57
RPM: 2116 /min
Load: 25.5 %
Speed: 56.0 km/h
Temperature: 85.0°C
Temperature: 42.0°C
Voltage: 13.970 V
