audi a8 sports differential fault
   #21
Gone But Not Forgotten
Every genuine VAG part has a 9 digit number and letters to identify a version or supersession.
I would take those part #s and verify in the EPC that they are correct for the respective location or description based on VIN and PR code #s.
   #22
nathan
C?ID=167279
thanks jack i understand now
unfortunatly i dont have epc im afraid
the parts were ordered from an audi main dealer
there part referance number was
0bf598081a. (Brown plug) cant get the bugger off yet new one is marked 8k0 927 222 c
0bf598082a. (Black plug) 8k0 927 221b taken off new one marked 8k0 927 221 c
am going to now machine a new deep socket so as to enable me to get the part off without damage to diff casing hopefully
   #23
nathan
C?ID=167279
apologies guys
forgot to update this thread
i replaced the second sensor and had a look in vcds and found a few settings to try
changed the second sensor after having to makea special socket to get the original off (the socket needs to be very very thin walled so i started with a standard one and put it in lathe and turned it down until it was 0.5mm thick wall thickness )
changed the sensor ok imported the sensor info
then found a setting to refill hydraulic lines
bleed hydraulic lines
pressure check
did this twice in a row and then tested ..... been working fine ever since
hope this helps if anyone else has a similar problem
