- Mar 30, 2014
- 2
- 0
- C?ID=115981
The MIL on our 2010 Jetta Sportwagon TDi is on. Below is the portion of the scan that describes the problem that activated the MIL. Pardon the cut and paste - I did not see the usual paperclip or other symbol to attach a document. The "problem" I'm having with VCDS is in understanding the details of the information. I've looked for the answers, but have not found them. So:
1. Does "Malfunction 0010" have a specific VW meaning, or is just VCDS-speak for 'there is a problem here'?
2. Is "Mileage 78872 km" the mileage at which the fault was last encountered? Or something else?
3. What is "Date: 2010.9.11". It is obviously not the date of the last fault. Is it the date of the first fault? Or a date related to the Internal Pressure Sensor?
4. If it is the date of the first fault, why has my dealer's shop not already corrected the problem?
5. What is "Fault Status: 10100000"?
6. What is the meaning of "Ign. Timing: 0BTDC" for a diesel engine? Is it when the sensor sensed autoignition?
Finally, I infer that We have either a failing pressure sensor or a problem with its wiring. Any disagreement with that?
Thanks for whatever information you can provide.
(BTW: The Nav and Radio malfunctions are (i) they were not turned on and (ii) there is an intermittent in the antenna. The Tire Pressure malfunction is probably that the car had not been driven and the sensors were therefore not active.)
Brant
Brant
Monday,16,May,2016,10:15:06:53108
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: 3VWTL8AJ5AM683562 License Plate:
Mileage: 79260km-49249mi Repair Order:
Chassis Type: AJ (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 4F 52 56 62 65 72
77
VIN: 3VWTL8AJ5AM683562 Mileage: 79260km-49249miles
Part No SW: 03L 906 019 CM HW: 03L 906 022 TS
Component: R4 2,0L EDC G000AG 9971
Revision: 12H03--- Serial number:
Coding: 0050078
Shop #: WSC 26097 444 12534
VCID: 78F506D60B1C3FFE46-802C
005073 - Cylinder 2 Internal Pressure Sensor
P13D1 - 000 - Short to Plus - Intermittent - MIL ON
Fault Frequency: 12
Mileage: 78872 km
Date: 2010.09.11
Time: 08:48:50
RPM: 1472 /min
Speed: 74.0 km/h
Bin. Bits: 00000000
Absolute Pres.: 91.0 bar
(no units): 5.10
Ign. Timing: 0.5 0BTDC
(no units): 9.20
005075 - Cylinder 2 Internal Pressure Sensor
P13D3 - 000 - Implausible Signal - Intermittent
Mileage: 78081 km
Date: 2010.08.18
Time: 10:48:06
RPM: 1357 /min
Speed: 29.0 km/h
Bin. Bits: 00001000
Absolute Pres.: 68.0 bar
(no units): -12.80
Ign. Timing: 0.9 0BTDC
(no units): 9.20
P13D3 - 003 - Implausible Signal - Intermittent
Fault Status: 00100011
Mileage: 78288 km
Date: 2010.08.21
Time: 10:09:29
RPM: 1863 /min
Speed: 94.0 km/h
Bin. Bits: 00001010
Absolute Pres.: 50.0 bar
(no units): 11.50
(no units): 9.20
Readiness: 1 3 0 0 0
