2016 Golf, 2.0T CXCA
Jef
HQ
Monday,16,May,2016,13:05:00:47536
VCDS Version: 16.5.0.4  HexNet CB: 0.4317.4
Data version: 20160506 DS251
VIN: 3VW4T7AU6GM028411   License Plate:
Mileage: 40km-24mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW4T7AU6GM028411   Mileage: 40km-24miles
Address 01: Engine (J623-CXCA)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00124424002F0000
   Shop #: WSC 00066 790 00060
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
   ROD: EV_ECM20TFS0205G0906259D.rod
   VCID: AF2110F1F6A47C3B52-80FA
Readiness: 1010 1101
   Part No SW: 0D9 300 041 C    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4903
   Revision: 06253104    Serial number: TFK01507210946
   ROD: EV_TCMDQ250021.rod
   VCID: 9873CB2D632A9B8323-80CC
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 52345000002434
   Coding: 01FA6BA134220974007B020181C42980D62C9000408194B400430050C009
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
   VCID: CBD96461627C201B5E-809E
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 00020004200100000000000000000002
   ROD: EV_ACManueBHBVW37X.rod
   VCID: C6CF5555791EDD7381-8092
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86581408150681
   Coding: 000018464041804969E44000001407201000000000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: FAB7F1A57D666993B5-80AE
   Component: WWS    150727  043 0581
   Serial number:         151016185620
   Serial number: 003GCR033YMY
   VCID: C7D158517E14C47B7A-8092
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH000000000003IBDSX
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 001 408 15
   Serial number: 35700000000631A03612
   Subsystem 3 - Part No SW: -----------    HW: 480 001 308 15
   Serial number: 35800000000FFBA0361Y
   Subsystem 4 - Part No SW: -----------    HW: 480 401 708 15
   Serial number: 3510002AF1D1B62460D7
   Subsystem 5 - Part No SW: -----------    HW: 480 401 708 15
   Serial number: 3520002A31D1B62092A.
   Subsystem 6 - Part No SW: -----------    HW: 480 401 108 15
   Serial number: 35500029B1C1EFA1614E
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 108 15
   Serial number: 3560002C31D1B625D1B9
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20151008501407
   Coding: 0410
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: BFC140B126C48CBBC2-80EA
   Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A
   Component: KOMBI         342 6420
   Coding: 0BBD090AA180CF0502086A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_VW37.rod
   VCID: AC1B07FDC7B2072377-80F8
   Part No SW: 5Q0 907 530 AE    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2223
   Revision: --------    Serial number: 03091510802798
   Coding: 0101000830085900FB0000281C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07026
   ROD: EV_GatewConti.rod
   VCID: F4ABDF9D5F021FE3EF-80A0
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q
   Component: E221__MFL-DC1  H10 0101
   Serial number: 29150001613170095327
   Coding: 31FFFF
   Serial number: 290815060504PK
   Coding: 003E03200000040000000000
   VCID: C3C94C414A2CE85BA6-8096
   Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
   Serial number: 00000000000001947408
   Coding: 011000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8102
   ROD: EV_SteerAssisMQB_VW37.rod
   VCID: B9352EA938E0A28BFC-80EC
   Serial number: 24061506050D1R
   VCID: C2C749455536E153AD-8096
   Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
   Serial number: 00000000000001954856
   Coding: 091000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 02730000FF00000051220001001808001F0203D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: EC9BC7FD0732C72337-80B8
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H52 1028
   Serial number: VWZ8Z9RES00S0C
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 150804201515
   VCID: EB99C4E1023CC01B3E-80BE
End----------(Elapsed Time: 01:33, VBatt start/end: 14.0V/14.0V)-----------
