2007 a8 instrument cluster swap
e36graduate
C?ID=90163
Friend has an a8 (2007) and swapped his malfunctioning cluster for same year and model cluster, however it seems it he new cluster doesn't work 100% and a bunch of lights are on.
Can this be corrected with vag tool ?
Hmm, had to say much without seeing a full scan; preferably two full scans, one with the old cluster in the car and one with the new one.
e36graduate
C?ID=90163
I guess I need to buy a Ross-tech vag tool. I did get a response from another source that vcds won't work on this swap,
"is is a result of Component Protection (Anti Theft) feature being activated. It's not possible to use 2nd hand parts on the high end Audi models (A8/A6/Q7).
Component Protection can only be removed via Dealer Scan Tool and online Access with Geko (server connection to database in Germany) or using specialty tool. Not possible to resync with VCDS, etc. "
Here is a link to service that explains Component Protection details:
http://www.speedosolutions.com/Component-Protection-RemovalAdaptation--Audi-C6-A6-Q7_p_59.html
jakematic
NC USA
C?ID=129085
You show as a verified VCDS User - that makes me think you have already purchased a genuine Ross-Tech cable.
Yep, CP can only be removed by a dealer.
Post up a scan and if you see a code like this, you will know for sure you have CP on that module.
