2016 Audi Q7 CYRB from China
Shi Wei
China
C?ID=68217
Saturday,14,May,2016,15:28:49:32941
VCDS Version: 16.5.0.4
Data version: 20160506 DS251
VIN: WAUAFC4M4GD0XXXXX   License Plate:
Chassis Type  4M (4M1)
Scan: 01 02 03 06 08 09 15 16 17 19 36 42 44 52 5F 6C 6D 81 A5 BB
          BC
Address 01: Engine (J623-CYRB)       Labels: None
   Part No SW: 4M0 906 259     HW: 06L 907 425
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 2A2A00322526050B34000000000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM20TFS0204M0906259 001003
   ROD: EV_ECM20TFS0204M0906259.rod
   VCID: 70E40648AB23BEC38B-8024
Readiness: 1010 0001
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 4M0 927 158 B    HW: 0D5 927 156 H
   Component: 0D5  20TSIRdW H03 1003
   Revision: --H03---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 336EC9449AB5C5DBB6-8066
   Part No SW: 4M0 907 379 K    HW: 4M0 907 379 K
   Component: ESP9 Premium  H08 0517
   Coding: 289840B230A50A9B96A6589400835292E6A6D214020C50691A004A4967654B
   ASAM Dataset: EV_ESP9BOSCHAU736 011006
   ROD: EV_ESP9BOSCHAU736_AU73.rod
   VCID: 3F869574A6FD11BB42-806A
12669184 - No Communications with Airbag Control Module
          U0151 00 [032] - -
                    Mileage: 31 km
                    Date: 2016.03.26
                    Time: 16:57:05
   Part No SW: 4M0 959 760     HW: 4M0 959 760
   Component: MEM-BFS       008 0014
   Serial number: 00000175891996
   Coding: 000010000000B0010000210101010000000000000000000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
   ROD: EV_SCMDriveSideCONTIAU736_AU73.rod
   VCID: 75EA375CD4419BEB58-8020
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 4M0 820 043 Q    HW: 4M0 820 043 Q
   Component: Klima Zone 3  H52 0081
   Coding: 640809885144000D10000180000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   Subsystem 2 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000679643
   Part No SW: 8W0 907 063 AG    HW: 8W0 907 063 G
   Component: BCM1 MLBevo   H12 0228
   Coding: C2500942C10800CD01148714582E08F911033100900000000000000020001A0100410022025405
   ASAM Dataset: EV_BCM1BOSCHAU736 015005
   ROD: EV_BCM1BOSCHAU736_AU49.rod
   VCID: 000456889B83AE437B-8054
   Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C
   Component: WWS536 150919  043 0893
   Serial number: 895553?0401526200473
   Coding: 1BC7F7
   Serial number: 60916372
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 N    HW: 4M0 941 531 N
   Component: E1 - LDS  H06 0008
   Serial number: 22 10 2015  00135124
   Subsystem 4 - Part No SW: 4M0 857 511 A    HW: 4M0 857 511 A
   Component: Y7_Innenspieg  H08 0002
   Serial number: GX1CE131101511521171
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 AB    HW: 4M0 947 135
   Component: J528-Dachele  H13 0080
   Serial number: Q00063890
   Subsystem 6 - Part No SW: 4M0 925 301 A    HW: 4M0 925 301 A
   Component: SL-Q7NF/AU736  H09 0006
   Serial number: 00000000000000020792
66915 - Light Switch
          B126A F1 [008] - Between Valid Positions
                    Mileage: 31 km
                    Date: 2016.04.10
                    Time: 11:13:51
                    average_Voltage_terminals: 14.10 V
                    Outside air temperature sensor-Resistance: 0.00 KOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 23.00 癈
                    interior_temperature: 24.50 癈
                    Vehicle speed: 0.00 km/h
                    Terminal control-Terminal 75 status: Not available
                    Terminal control-Terminal 15 status signal: OFF
                    Terminal control-Terminal 15 via CAN: Not available
                    Terminal control-Term 75; qualification: OFF
          U1101 00 [008] - Active
                    Mileage: 31 km
                    Date: 2016.03.24
                    Time: 08:56:23
                    average_Voltage_terminals: 13.30 V
                    Outside air temperature sensor-Outside air temperature on CAN: 19.00 癈
                    interior_temperature: 19.50 癈
                    Terminal control-Terminal 75 status: OFF
                    Terminal control-Terminal 15 via CAN: OFF
Address 15: Airbags (J234)       Labels: None
   Part No SW: 4M0 959 655     HW: 4M0 959 655
   Component: Airbag10.44   H50 0084
   Serial number: 003L10013KTZ
   Coding: AACCF0180080000058F000F3C00C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_AU73.rod
   VCID: 78F43E68C353E68343-802C
   Subsystem 1 - Part No SW: -----------    HW: 442 063 010 15
   Serial number: 3577Y00B71A87823150X
   Subsystem 2 - Part No SW: -----------    HW: 442 063 010 15
   Serial number: 3587Y00B71A87822C1B8
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 110 15
   Serial number: 3517700C11D6910200B-
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 110 15
   Serial number: 3527700C11D6910661D7
   Subsystem 5 - Part No SW: -----------    HW: 442 0C0 311 15
   Serial number: 3557500BF1D690F3421J
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C0 311 15
   Serial number: 3567500BF1D690F4B34W
   Central Sensor XY:
   Subsystem 7 - Part No SW: -----------    HW: 410 201 610 15
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O7800BF18AA413A056
13644032 - FlexRay Databus
          U1031 00 [136] - No Synchronization
                    Mileage: 31 km
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 4M0 907 129 HD    HW: 4M0 907 129 HD
   Component: Lenks.Modul   H11 0008
   ROD: EV_SMLSKLOAU736_AU49.rod
   VCID: 79F23B6CF859FF8B3C-802C
Address 17: Instruments (J285)       Labels: None
   Part No SW: 4M0 920 770 A    HW: 4M0 920 770 A
   Component: TBenRDW       H15 0417
   Coding: 04A400C0288000081703E8601000000000000000
   ASAM Dataset: EV_DashBoardAU736 001020
   ROD: EV_DashBoardAU736.rod
   VCID: 2B5ED12442859D1BFE-807E
   Part No SW: 4M1 907 468 A    HW: 4M1 907 468 A
   Component: Gateway       H13 1078
   Revision: 3B040053    Serial number: 5343B00B115B02
   Coding: 0301000100000F40280700000059003048120007008000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736.rod
   VCID: 356AF75C94C1DBEB98-8060
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20151111034221 00393
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 4185648403
   Component: MEM-FS        008 0014
   Serial number: 00000175890306
   Coding: 001813000000B0010000210101010000000000000000000000000000000000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
9655827 - Motor for Seat Backrest Adjustment
          B1356 13 [040] - Open Circuit
                    Mileage: 31 km
                    Date: 2016.04.17
                    Time: 08:30:26
   Part No SW: 4M0 959 593 D    HW: 4M0 959 593 C
   Component: TSG FS        005 0039
   Serial number: 0000174193193
   Coding: 001F9A005E00000000013082
   ROD: EV_DCU2DriveSideMAXHCONT.rod
   VCID: 3D7AEF7CACF103AB50-8068
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 4M0 909 144 G    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H19 0004
   Serial number: 0000369541
   Coding: 90000001000100
   ASAM Dataset: EV_EPSVWBSAU736 008020
   ROD: EV_EPSVWBSAU736_AU49.rod
   Part No SW: 4M0 959 592 D    HW: 4M0 959 592 C
   Component: TSG BFS       005 0039
   Serial number: 0000174823949
   Coding: 001F9A005E00000000013080
   ROD: EV_DCU2PasseSideMAXHCONT.rod
   VCID: 3C7CE278B7EB0AA367-8068
   Part No SW: 4M0 035 049 A    HW: 4M0 035 049 A
   Component: MU-H-LN-CN    051 0038
   Serial number: K5F AW7G704SFK
   Coding: 01370605FF0A000013150001001A00102F001BE4017001005E
   ASAM Dataset: EV_MUHig6C3Gen2AW7 001290
   ROD: EV_MUHig6C3Gen2AW7_VW37.rod
   VCID: 27562D145E6DB97B1A-8072
   Subsystem 1 - Part No SW: V03 959 801 LK    HW: -----------
   Component: CHN 2016  --- 7512
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9FJ4017QY
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4M0 919 615 E    HW: 4M0 919 615 E
   Component: ControlUnit_P  H14 0165
   Serial number: 05111500000000000198
   Compact Disc Database:
   Component: Gracenote2  --- 2009
                    Mileage: 31 km
                    Date: 2016.03.26
                    Time: 14:32:08
                    Voltage terminal 30: 13.6 V
5648 - Control Head for Multimedia System; Right Arrow Button
          B1291 FB [008] - Unknown Error Elaboration
                    Mileage: 31 km
                    Date: 2016.05.13
                    Time: 11:07:14
                    Voltage terminal 30: 12.9 V
5725 - Control Head for Multimedia System; Touchpad
          B1889 07 [008] - Mechanical Failure
                    Mileage: 31 km
                    Date: 2016.04.02
                    Time: 14:31:25
                    Voltage terminal 30: 12.6 V
Address 6C: Back-up Cam. (J772)       Labels: None
   Part No SW: 4M0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0130
   Coding: 0237060102002001000040
   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 004008
   ROD: EV_CamSysRVRVCPANAMLBEv_AU49.rod
   VCID: 72E00C40A52F8CD37D-8026
Address 6D: Trunk Elect. (J605)       Labels: None
   Part No SW: 4M0 959 107     HW: 4M0 959 107
   Component: HDSG-Modul    H12 0143
   Revision: --------    Serial number: 30329824600000
   Coding: 0050
   ASAM Dataset: EV_DeckLidCONTIAU736 001010
0069 - Rear Lid Closing Assistance
          B113E 07 [008] - Mechanical Failure
                    Mileage: 31 km
                    Date: 2016.03.28
                    Time: 08:43:10
                    Status of closing assist-Limit switch for pull-shut assist.: not activated
                    Status of rear lid lock-Safety catch: closed
                    Status of rear lid lock-Main catch: Open
                    Status of rear lid lock-Rear lid lock: Open
   Part No SW: 4M1 713 041 D    HW: 4M1 713 041 D
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20151009002236
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 264820105967A07321-8072
Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
   Part No SW: 4M0 907 217 C    HW: 4M0 907 217 A
   Component: BVS           H12 0030
   Coding: 0407030600000601022020A0A50000B400F0C0100000
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 2E58D8307197E833D9-807A
1123714 - Databus
                    Reset counter: 0
                    Mileage: 31 km
                    Date: 2016.04.11
                    Time: 11:08:12
                    Control Module temperature: 33 癈
                    Voltage terminal 15: 12.20 V
Address BB: Door Rear Drv        Labels: None
   Part No SW: 4M0 959 595 D    HW: 4M0 959 595 C
No ASAM data for: "Unknown" (AU73)
Address BC: Door Rear Pass        Labels: None
End-------------------------(Elapsed Time: 05:27)--------------------------
