2016 Mk7 Golf Sportwagen - BCM Forgets Key Fobs after VCDS Access
type17volkswagen
C?ID=12115
I just got a 2016 Golf Sportwagen. Twice now when I've accessed the BCM and made adaptation or long coding changes the BCM accepts them, however it causes the key fobs to be forgotten. The immo isn't forgetting them because the car will still start, but the remotes won't work. Then the dealer has to do the relearn for me. Which leads me to ask:
* Is my cable (HexCan) so old I shouldn't be using it with the current VCDS version on this car? Is that what's causing the remotes to be forgotten? I read about the HexNet trade-in program and will do it, but would hope it will solve this issue - I'd be bummed if it didn't. Maybe the car's BCM is the issue...
* The Mk5 and Mk6s had an adaptation channel where you could tell the car how many keys you wanted to adapt and then press the button on the key for the car to relearn them. Is it possible still on a Mk7 and if so, where'd the function go? I can't find it in the BCM.
* Finally, it looks like a label file (? - "no ASAM data" - ?) is missing for the engine so I saved it but I couldn't find where to upload it...
Here's my scan.
 VCDS Version: Release 15.7.4 Running on Windows 10 x86
Data version: 20160216
Thursday,12,May,2016,19:43:17:57723
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VWC17AU5GM000000   Mileage: 438km-272miles
Address 01: Engine (J623-CXBB)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091A00122424002F0000
   Shop #: WSC 00066 790 00060
   ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
   ROD: N/A
   VCID: 3F87262EA69CC7C647-806A
No ASAM data for: "EV_ECM18TFS0208V0906264F" (VW37)
Address 02: Auto Trans (J217)       Labels: 09G-927-749.clb
   Part No SW: 09G 927 749 AP    HW: 09G 927 749 AP
   Component: AISIN AG6 G3  129 2943
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_AU37.rod
   VCID: 0717FECEBECC4F063F-8052
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 51915000000026
   Coding: 04FA6AA124200972007D020181C5292056249000408194B400430050C002
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
   VCID: 4B9F02FEE2246B66DB-801E
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 02020004100100000000000010000002
   ROD: EV_ACManueBHBVW37X_SE37.rod
   VCID: 050BF4C684C05D164D-8050
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 087 T    HW: 5Q0 937 087 T
   Revision: --------    Serial number: 86580907151710
   Coding: 000018424041804169E44000000407001000000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 4C9D01E2E72A6C5ED2-8018
   Slave 1:
   Component: WWS    150512  043 0581
   Serial number:         150730234500
   Coding: 0E4DFD
   Serial number: 003GCR02B5XN
   VCID: 47973ECEFE4C8F06FF-8012
   Seat occupant detection; front passenger side:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000000000032W085
   Coding: 303133
   Subsystem 2 - Part No SW: -----------    HW: 480 001 606 15
   Serial number: 3570000000036125F419
   Subsystem 3 - Part No SW: -----------    HW: 480 001 906 15
   Serial number: 35800000000E9329251I
   Subsystem 4 - Part No SW: -----------    HW: 480 400 206 15
   Serial number: 35100029D1B41482B37%
   Subsystem 5 - Part No SW: -----------    HW: 480 401 506 15
   Serial number: 3520002AD1B5A87412DB
   Subsystem 6 - Part No SW: -----------    HW: 480 401 506 15
   Serial number: 3550002B31B5A88021B0
   Subsystem 7 - Part No SW: -----------    HW: 480 401 506 15
   Serial number: 3560002B91B5A8834055
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150603400959
   Coding: 0410
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 5G1 920 840 A    HW: 5G1 920 840 A
   Component: KOMBI         242 6420
   Coding: 0BB4110AA180CF0502086A001000000000000000
   VCID: 254B944624007D162D-8070
   Part No SW: 5Q0 907 530 AE    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2223
   Revision: --------    Serial number: 05071510001658
   Coding: 0101000830085900FB0000081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00225
   ROD: EV_GatewConti.rod
   VCID: 74EDB902DF5A549E6A-8020
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P
   Component: E221__MFL-DC1  H16 0101
   Serial number: 27150001234960125244
   Coding: 31FFFF
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 020715060502ZV
   Coding: 003003200000040000000000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 418320D6D068B13631-8014
   Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
   Serial number: 00000000000001489078
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   ROD: EV_SteerAssisMQB.rod
   VCID: 438F2ADECA74A32623-8016
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 150715060508BI
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 408525D2DB62B83E3E-8014
   Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
   Serial number: 00000000000001534463
   Coding: 091000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 02730200FF00000051220001001808001F0100D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 6CDDA162876A8C5EB2-8038
   Media Player Position 1:
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H52 1028
   Serial number: VWZ8Z9RES00E5W
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0566
   Coding: 02730202C2821A017F1E06000000
   Shop #: WSC 00066 790 00322
   ROD: EV_OCULowMQB.rod
End-------------------------(Elapsed Time: 04:15)--------------------------
I really doubt that, or that upgrading to a HEX-NET would change much.
As I haven't heard of any other reports like this, I have to ask: Exactly what did you change?
There should be a Measuring Value (use the Search) for "Number of transmitters adapted"
type17volkswagen
C?ID=12115
Thank you for replying. As far as I recall, I only enabled the comfort open and close. I don't do much (or fancy) with the coding on my cars. I traded a 2015 Golf for this. I had coded it a few times over the year I owned it and never had any issues.
I appreciate you saying the upgrade might not correct this. I suspect the BCM may be the issue because the first repair took the dealer 3 days working with VW to get their computer to talk to it. They could access all the controllers EXCEPT the BCM which caused the delay.
I'll check the measuring blocks to find the number of keys adapted. Thanks for pointing me to that. So that I don't have to go back to the dealer, is there a way to re-adapt the transmitters in the Mk7, like in the Mk6?
Thank you for the great support!
Not sure. All the MQB cars we have access to at the moment have KESSY, meaning the remotes and the keys are matches all at once.
I wonder if they actually need to be re-adapted, or just re-synched. On older cars, there used to be a procedure where you left one key in the ignition (with the ignition ON) then took they other one and locked the car from the outside, and then did some button presses, that would re-synch remotes that were previously adapted.
^^ ^^ Uwe: don't have KESSY, but I did search the term "key" in advanced measurement on the instrument module (hex17) - results below:
Don, I think fro the remote transmitters, the area of interest is the BCM at 09, no?
Uwe: correct, of course - my bad, apology. Results from my test jig
type17volkswagen
C?ID=12115
Yeah the first time it happened I tried the re-synch steps shown in the owner's manual (VW changed the steps from those you describe) - no luck. I also tried this time no luck.
THANK YOU for asking me what I did! You helped me solve it by asking the question.
First, I did the search DV52 showed - thank you for teaching me something new (word search) DV52. I was able to confirm that 2 keys were already adapted, so it wasn't that the controller was "forgetting" them.
The "what did you change" question prompted me to run through the BCM long coding again. The moment I saw the setting for region (NAR or ROW) it dawned on me that different radio frequencies are used in the regions. I changed it back to NAR and the remote transmitters starting working again. In the past, I would always change the region in the Instruments controller so I didn't have to hear the key-in-door chime. Not thinking about it being in the BCM, I changed it there - my error. I guess they built in both antennas in the BCM to cover both frequencies and that setting toggles them... I wanted to mention this for the next poor guy that messes himself up this way.
Thank you guys for supporting me through this, especially since it was not the product - 100% user error.
