Audi Q5 update adaptive BI-Xenon Help!
paul
C?ID=80508
Hi all, apologies for posting this here, awaiting my verification to be done as a genuine lead owner!
I have a 2009 Audi Q5 with the bi-xenons and adaptive lights installed and I want to update to the later style lights.
I have the correct new light units and aware that the wiring needs to be changed to remove the old levelling system and wired into the BCM . module J519. I believe I need a new module to allow this update to happen?
Is this retrofit possible, I don't see why it should be a problem and I have read this thread:
http://forums.ross-tech.com/showthread.php?146-Q5-8R-Chassis-Xenon-Retrofit/page2&
Do I need a specific module to replace my old BCM? I believe it is 8K0-907-063-DJ that may be required or will others work?
I have spent a lot already and at this rate it would have been cheaper to swap the car! Still like to try and achieve what is possible that seemingly can't be done as I love my car and its already a good spec etc.
Also I assume only way to remove component protection is by visiting Audi? (Should I get a used part)
Verified.
Moving to Retrofits.
Please post an Auto-Scan so people can see how your car is currently equipped and configured.
paul
C?ID=80508
Perfect, many thanks for the swift verification!
As requested scan is (fault codes as started to take car to bits!)
 Friday,13,May,2016,16:27:43:52379
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WAUZZZ8R09A005482   License Plate: Q513MAY16
Mileage: 102920km-63951mi   Repair Order:
Chassis Type: 8R (8T0)
Scan: 01 02 03 05 08 09 0E 10 13 14 15 16 17 19 1B 20 42 46 52 53
          55 56 5F 62 69 6C 6D 72
VIN: WAUZZZ8R09A005482   Mileage: 102920km-63951miles
0E-Media Player 1 -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Cannot be reached 1100
Address 01: Engine (J623-CCWA)       Labels: 059-907-401-V1.clb
   Part No SW: 8R0 907 401 J    HW: 8K1 907 401 A
   Component: 3.0TDI EDC17  H01 0008
   Revision: 15H01---
   Coding: 0121002C240F0A20
   Shop #: WSC 06335 123 12345
   ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
   ROD: EV_ECM30TDI0118R0907401J.rod
   VCID: 3972C442B89509F65A-806C
7140 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
                    Mileage: 102164 km
                    Date: 2016.04.01
                    Time: 14:39:06
5475 - Intake Manifold Tuning Valve Control Circuit
          P1028 00 [032] - Open Circuit
                    Mileage: 102929 km
5476 - Control Circuit for Intake Flap Bank 2
          P319E 00 [032] - Open or Short to Ground
7156 - Intake Manifold Flap Position Sensor (Bank 1)
          P2015 00 [175] - Implausible Signal
                    Fault Frequency: 66
                    Mileage: 98380 km
                    Date: 2015.10.10
                    Time: 12:38:25
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 8R0 927 156 AD    HW: 0B5 927 156 E
   Component: 0B5 30 TDIRdW H04 0002
   Revision: --H04---    Serial number: 0000000349
   Shop #: WSC 00060 210 176746
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 7DFA1052EC3DF5D636-8028
Address 03: ABS Brakes (J104)       Labels: 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 C    HW: 8R0 907 379 C
   Component: ESP8 quattro  H06 0230
   Coding: 0FFD00
   Shop #: WSC 06335 001 12345
   VCID: 4084A9A6D34F583E1D-8014
02214 - Tire Pressure Warning
            000 -  -  - Intermittent
                    Reset counter: 225
                    Mileage: 101871 km
                    Date: 2016.02.17
                    Time: 22:13:55
                    Hex Value: 0x4A00
                    Hex Value: 0x4006
                    Hex Value: 0x1F1B
                    Hex Value: 0x0EB7
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 AQ    HW: 8K0 907 064 AQ
   Component: BCM2 1.1      H80 0143
   Coding: 051500
   Shop #: WSC 06335 000 00000
   VCID: 7F06EA5AEE31E7C624-802A
   Component: ELVAUDIB8  H36 0041
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 205
                    Mileage: 102929 km
                    Date: 2016.05.08
                    Time: 16:28:32
03284 - Antenna for Access & Start Authorization; Right
                    Fault Status: 00101011
                    Reset counter: 230
                    Mileage: 102159 km
                    Date: 2016.03.28
                    Time: 13:13:18
00955 - Key 1
                    Reset counter: 217
                    Mileage: 100943 km
                    Date: 2016.02.07
                    Time: 14:53:48
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 230
                    Mileage: 102159 km
                    Date: 2016.03.28
                    Time: 15:07:18
   Part No SW: 8T2 820 043 T    HW: 8T2 820 043 T
   Component: KLIMA 3 ZONEN H06 0140
   Revision: D1000000    Serial number: 0124.09.080237
   Coding: 36150000
   VCID: 438EA6AAC259432600-8016
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000248302
   Coding: 2600D0914074BF311F01000300001D0D4F9DE74800010141000000
   VCID: 3064F96663EFC8BEED-8064
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 080625  H10 0041
   Coding: 01DD13
   Component: RLS  H04 0003
   Coding: 024D25
                    Reset counter: 232
                    Mileage: 102216 km
                    Date: 2016.04.04
                    Time: 08:48:00
                    Reset counter: 205
                    Mileage: 102929 km
                    Date: 2016.05.08
                    Time: 16:28:00
01800 - Light Switch (E1)
                    Reset counter: 205
                    Mileage: 102929 km
                    Date: 2016.05.07
                    Time: 18:17:00
03280 - Switch Position of Light-Switch Knob
                    Fault Status: 01101000
                    Reset counter: 205
                    Mileage: 102929 km
                    Date: 2016.05.07
                    Time: 18:33:00
Address 0E: Media Player 1
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0020
   Revision: 11001001    Serial number: 52840828702712
   Coding: 320105
   VCID: 3B7EDE4ABAA93BE648-806E
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561     HW: 8R0 907 561
   Component: ACC2          H01 0020
   Coding: 0079AF
   VCID: 76E80F7EC10BA68E77-8022
                    Fault Status: 00101101
                    Reset counter: 232
                    Mileage: 102164 km
                    Date: 2016.04.01
                    Time: 14:39:06
                    Temperature: 22.0°C
                    Voltage: 14.34 V
                    Bin. Bits:    00000
                    Hex Value: 0x044B
                    Hex Value: 0x0022
                    Speed: -3.6 km/h
                    Lateral Accel.: 0.00 m/s^2
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 A    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H08 0051
   Revision: 00000000    Serial number: 08100804630002
   Coding: 070181
   Shop #: WSC 00048 210 91003
   VCID: 3874C1468B9F10FEA5-806C
Address 15: Airbags (J234)       Labels: 8R0-959-655.clb
   Part No SW: 8R0 959 655 B    HW: 8R0 959 655 B
   Component: AirbagVW-AU10 H02 0310
   Serial number: 003E8D024W6$
   Coding: 30353131313030303030554A305238523053
   ASAM Dataset: EV_AirbaAU10SMEAU416 001001
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 438EA6AACA59432600-8016
   Serial number: 6334MSME42752179A
   Serial number: 6344MSME3F063469K
   Serial number: 6352QSME57111412%
   Serial number: 6362QSME780E1D3AY
   Serial number: 63732SME5F0F02283
   Serial number: 63832SME3609291A/
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [137] - Open or Short to Plus
                    Mileage: 102929 km
                    Date: 2016.05.08
                    Time: 16:28:29
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [137] - Open or Short to Plus
                    Mileage: 102929 km
                    Date: 2016.05.08
                    Time: 16:28:31
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90319HJA0004M
   Coding: 00003F
   VCID: 3E78D75EA9BB2ECE6F-806A
00457 - Control Module for Network (J519)
                    Reset counter: 245
                    Mileage: 102929 km
                    Date: 2016.05.08
                    Time: 16:28:27
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 980 G    HW: 8R0 920 980 G
   Component: KOMBIINSTR.   H07 0224
   Revision: 00100000    Serial number: 9EX61M9A8
   Coding: 2F0722003F002600010400
   VCID: 3D7AD052A4BD35D676-8068
                    Reset counter: 205
                    Mileage: 102929 km
                    Date: 2016.05.08
                    Time: 16:28:31
   Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0094
   Revision: 4FB50047    Serial number: 4700F08A108020
   Coding: 000303
   VCID: 4A908B8EE573926EC3-801E
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0100
                    Reset counter: 230
                    Mileage: 102159 km
                    Date: 2016.03.28
                    Time: 14:28:00
00384 - Optical Databus
                    Reset counter: 205
                    Mileage: 102929 km
                    Date: 2016.05.07
                    Time: 18:02:38
                    Reset counter: 205
                    Mileage: 102929 km
                    Date: 2016.05.08
                    Time: 16:28:29
   Part No SW: 8K0 907 144 C    HW: 8K0 907 144 C
   Component: DYNAMIKLENK.  H06 0500
   Revision: 50001003    Serial number: --------------
   Coding: 020000
   Shop #: WSC 06334 000 00000
   VCID: 2F66FA1A7ED1D746F4-807A
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8K0 857 511 C    HW: 8K0 857 511 A
   Component: FLA           H04 0003
   Revision: AA001002
   Coding: 02022064747464545425363E
   VCID: 3162FC6268E5C1B6E2-8064
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000007811754
   Coding: 011D12205001440004
   VCID: 4182ACA2D845513612-8014
   Revision: 00002001    Serial number: 0115366161
   Coding: 013F0E2220393495072005
   Shop #: WSC 06342 000 00000
   Subsystem 3 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
   Subsystem 4 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J394EE16SKB10  H01 0180
02615 - Fuel Tank Cap; Lock
                    Fault Status: 00101001
                    Reset counter: 215
                    Mileage: 98380 km
                    Date: 2015.10.09
                    Time: 16:26:19
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 215
                    Mileage: 98380 km
                    Date: 2015.10.10
                    Time: 11:22:07
02201 - Trunk / Luggage Compartment Closing Assist; Position - Unlocked (F332)
                    Reset counter: 230
                    Mileage: 102159 km
                    Date: 2016.03.28
                    Time: 15:07:20
02202 - Trunk / Luggage Compartment Closing Assist; Position - Locked (F332)
                    Reset counter: 230
                    Mileage: 102159 km
                    Date: 2016.03.28
                    Time: 15:07:20
                    Reset counter: 245
                    Mileage: 102929 km
                    Date: 2016.05.08
                    Time: 16:28:32
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000007830863
   Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
   Component: EPB Audi B8   H06 0070
   Revision: 00000003    Serial number: 00000000252235
   VCID: 3260F36E6DE3FAAE9B-8066
Address 55: Headlight Range
Address 56: Radio
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000007853194
   Coding: 010C12204001240004
02123 - Door Warning Light / Entry Light
                    Fault Status: 00101100
                    Reset counter: 230
                    Mileage: 102159 km
                    Date: 2016.03.28
                    Time: 13:58:18
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
   Revision: 1G001001    Serial number: 00008200507765
   Coding: 0109080000000000
   VCID: 356AC8729C8DED96BE-8060
   Part No SW: 8R0 907 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J89A0PH
   Coding: 1033010
   Shop #: WSC 06435 000 00000
   VCID: 73EE366A1279B3A650-8026
   Part No SW: 8R0 827 851 A    HW: 8R0 827 851
   Component: J605  Master  H24 0210
   Revision: --------    Serial number: 8R0827851
   VCID: 3A70DB4EB59302EE53-806E
   Subsystem 1 - Part No SW: 8R0 827 852 A    HW: 8R0 827 852
   Component: J756  Slave  H24 0240
02364 - Closing Assistance
                    Fault Frequency: 0
                    Reset counter: 181
                    Mileage: 98765 km
                    Date: 2015.10.17
                    Time: 11:54:06
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000007853244
                    Reset counter: 230
End-------------------------(Elapsed Time: 04:31)--------------------------
