2016 Passat, 2.0T from China
Shi Wei
China
C?ID=68217
Thursday,28,April,2016,20:36:08:59248
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWAR23C3GEXXXXXX   License Plate:
Mileage: 26km-16mi   Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 42 44 52 55
          5F 65 6C 6D A5
VIN: WVWAR23C3GE171169   Mileage: 26km-16miles
Address 01: Engine (J623-CHHB)       Labels: 06K-907-425-V1.clb
   Part No SW: 3G0 906 259 C    HW: 06K 907 425 E
   Revision: --H13---
   Coding: 092500324466050B3000
   Shop #: WSC 05311 115 00313
   ASAM Dataset: EV_ECM20TFS0203G0906259C 001004
   ROD: EV_ECM20TFS0203G0906259C.rod
   VCID: 2C57DBF447EC475EF2-8078
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0DL 300 011 C    HW: 0BH 927 711 F
   Component: GSG DQ500     H10 5207
   Revision: 00H10V01
   ROD: EV_TCMDQ500021_AU21.rod
   VCID: 285F27E453146B7E16-807C
   Revision: 00000000    Serial number: 60156000000467
   Coding: 40EC6A8F34276B6D0778030641CC4902562CD6E0C08292FD384250886209
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
   VCID: 7AFB2DACFD3829EE30-802E
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0710
   Revision: 00036000    Serial number: 0392846356
   Coding: 0F00000F03
   ROD: EV_KessyHellaMQBAB_SK48.rod
   VCID: 3A7BEDACBDB8E9EE70-806E
1077250 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 50
                    Mileage: 26 km
                    Date: 2011.03.19
                    Time: 05:50:26
   Part No SW: 5G0 907 044 BG    HW: 5G0 907 044 BG
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 1202002410010000111050001000180A
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 6DD116F0BC768E56A5-8038
   Slave 1:
          B10CD 00 [008] -  -
                    Reset counter: 50
                    Mileage: 26 km
                    Date: 2011.03.19
                    Time: 05:50:26
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 865814011600FN
   Coding: 00911E46C2C102FF17844094B11C57281880000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 030550488AF2682663-8056
   Slave 1:
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    151218  042 0607
   Serial number:         160112183231
   Slave 2:
   Subsystem 2 - Part No SW: 8UD 955 559 B    HW: 8UD 955 559 B
   Serial number: 30008338
   Coding: 00006E
   Slave 3:
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 30 10 2015  10001313
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY160113L97
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064736889
527872 - Transport Mode Active
          U1105 00 [008] - -
                    Reset counter: 50
                    Mileage: 26 km
                    Date: 2011.03.19
                    Time: 05:50:27
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616021
   Coding: 0271161851
   Shop #: WSC 05311 115 00090
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_VW48.rod
   VCID: 0D117670DCB62E5605-8058
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Coding: 320047C359FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3467C3949FDC1F9EAA-8060
0110 - Transport Mode Active
          U1105 00 [008] - -
                    Reset counter: 50
                    Mileage: 26 km
                    Date: 2011.03.19
                    Time: 05:50:27
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 08011641350115
   ROD: EV_DRCONTITEMIC.rod
   VCID: 377DF4988EAAF4868F-8062
   Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003STP1X6ML$
   Coding: 98FCC0C0008000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X_VW48.rod
   VCID: 7F0DDCB8E61A0CC607-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 002 101 16
   Serial number: 3576U00000093048B819
   Subsystem 2 - Part No SW: -----------    HW: 454 002 001 16
   Serial number: 3586U0000009A9D8681U
   Subsystem 3 - Part No SW: -----------    HW: 454 800 801 16
   Serial number: 3516RFF867F09000000V
   Subsystem 4 - Part No SW: -----------    HW: 454 800 601 16
   Serial number: 3526R41077909000000.
   Subsystem 5 - Part No SW: -----------    HW: 454 802 012 15
   Serial number: 3556V316D8A09000000E
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160112400405
   Coding: 0410
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D71E6B0AC96DED655-8068
   Part No SW: 3G0 920 791 A    HW: 3G0 920 791 A
   Component: KOMBI         410 1340
   Coding: 07A4189BBE80000802886B051001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009048
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
   VCID: 275D24D85E0A64061F-8072
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 29011610800827
   Coding: 030300047F015900FB00225A9E0F00010001070000000000000000000000
   ROD: EV_GatewConti.rod
   VCID: 79F932A0F83E22F639-802C
   Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29160000060660026023
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 1979258803
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Serial number: HA1-00019.12.15
   Coding: 0301
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 4A9BBD6CED58796EE0-801E
   Serial number: 16000009473015
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E90A80A04E6AB681-8024
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
   Component: Sitzmemory    H04 0020
   Serial number: Y0006PAQ16344
   Coding: 0010000200000500818280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide_VW48.rod
   Serial number: 141215ELC0257A
   Coding: 003F1A20D200020000001000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 43859048CA72A82623-8016
Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000592711
   Coding: 01010010005001
   Shop #: WSC 00015 115 00313
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_SK48.rod
   Serial number: 121215ELB06698
   Coding: 003F1020DE00020200001000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 428B954CD568A12E28-8016
   Component: AFS-ECU       H01 0120
   Coding: 03A202004F210200
   Shop #: WSC 05311 000 08193
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: 3F8D9CB8A69ACCC647-806A
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 3G0 035 048     HW: 3G0 035 048
   Component: MU-H-N-CN     050 0038
   Serial number: K5F AW79Y06013
   Coding: 02840205FF00000051150001001028001F0108E401200000DE
   ASAM Dataset: EV_MUHig4CGen2AW7 001081
   ROD: EV_MUHig4CGen2AW7_BY63.rod
   VCID: 5EB3413C41D0E5CE2C-800A
   Media Player Position 1:
   Radio Tuner - Digital:
   Subsystem 2 - Part No SW: 3G0 919 606     HW: 3G0 919 606
   Component: ABT_High-2  H52 1028
   Serial number: VWZ8Z9REY000BS
   Engine Control Module 2:
   Subsystem 3 - Part No SW: -----------    HW: -----------
   Component: -------------  --- ----
   Seat Adjustment Driver Side:
   Subsystem 4 - Part No SW: V03 959 801 BT    HW: -----------
   Component: CHN 2016  --- 7512
   Air Conditioning Compressor:
   Diesel Pump Control Unit:
   Door Electronics Driver Side:
   Subsystem 7 - Part No SW: -----------    HW: -----------
   Brake Assistance:
   Subsystem 8 - Part No SW: -----------    HW: -----------
   Interior Monitoring:
   Subsystem 9 - Part No SW: -----------    HW: -----------
   Sound System:
   Subsystem 10 - Part No SW: -----------    HW: -----------
   Door Electronics Rear Left:
   Subsystem 11 - Part No SW: -----------    HW: -----------
   Subsystem 12 - Part No SW: -----------    HW: -----------
   Subsystem 13 - Part No SW: -----------    HW: -----------
   Subsystem 14 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 2009
   Serial number: 40000000013826
   ROD: EV_RDKBERU30_SK37.rod
Address 6C: Back-up Cam. (J772)       Labels: None
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 0184420162002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   VCID: 77FD3498CE2A34864F-8022
Address 6D: Trunk Elect. (J605)       Labels: None
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30446314200000
   Coding: 0208
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   ROD: EV_DeckLidCONTIAU736_SK48.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
   Part No SW: 3Q0 980 654 C    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0023
   Serial number: 28011611P21398
   Coding: 000408020400060100222344C050A10000000E300040
   ROD: EV_MFKBoschMQBB_VW36.rod
End-------------------------(Elapsed Time: 05:57)--------------------------
