Saturday,07,May,2016,12:20:49:63885
-- Windows Based VAG/VAS Emulator Running on Windows 7 x64
Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWLF7AUXGW143714 License Plate: R-R8ED
Mileage: 2746km-1706mi Repair Order: 002
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 52 55 5F 75 A9
VIN: WVWLF7AUXGW143714 Mileage: 2746km-1706miles
03- Brakes -- Status: Malfunction 0010
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (J623-CYFB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 H HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122426000E3000
Shop #: 01357 011 00200
Dataset: EV_ECM20TFS0208V0906259H 001003
ROD: EV_ECM20TFS0208V0906259H_VW37.rod
VCID: 45AFAADDC4586B160D-8010
17789 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [032] - -
17178 - Databus
U1123 00 [040] - Received Error Message
Mileage: 1508 km
Date: 2016.04.10
Time: 00:01:29
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A H53 4904
Revision: 06253104 Serial number: TFK01507222501
Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021_AU37.rod
VCID: 538B84853A0CC5A693-8006
P1734 00 [002] - -
Address 03: Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 62675000007142
Coding: 01FA6BA15424096F057E030141C76980D62A90A0C08296B700400058C208
Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 79D7162DF820DFF639-802C
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 93
Mileage: 1508 km
Date: 2016.04.10
Time: 00:01:29
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 69
Mileage: 425 km
Date: 2016.03.12
Time: 08:55:26
16412 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Reset counter: 93
Mileage: 1508 km
Date: 2016.04.10
Time: 00:01:39
16413 - Display for Tire Pressure Monitoring
Reset counter: 93
Mileage: 1508 km
Date: 2016.04.10
Time: 00:01:39
Address 05: /Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0381170350
Coding: 030C0C
Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A55C921BDA614EE70-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020004200100000005000012111402
Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 6AF539618D86646EC0-803E
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 085 AJ HW: 5Q0 937 085 AF
Component: MQBAB HNA H24 0175
Serial number: 01061526800719
Coding: 00011A46C041A2E169E44000091C07201800000000000000000000000000
Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 01277ECD90F0873671-8054
Slave 1:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150913 043 0551
Serial number: 150923065755
Slave 2:
Component: 037 0059
Serial number: S4Y15M10D08H14M47S47
Coding: 90A8DD
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR03JHX1
Dataset: EV_AirbaVW20SMEVW37X 002144
VCID: 47B3A0D5FE547906FF-8012
Seat occupant detection; front passenger side:
Component: BF-Gewichtss. H11 0021
Serial number: IBH00000000000350XQR
Coding: 303058
Subsystem 2 - Part No SW: ----------- HW: 480 002 409 15
Serial number: 3570000000079A2CE61X
Subsystem 3 - Part No SW: ----------- HW: 480 002 409 15
Serial number: 3580000000025B38761G
Subsystem 4 - Part No SW: ----------- HW: 480 403 009 15
Serial number: 3510002B91CF2DA03258
Subsystem 5 - Part No SW: ----------- HW: 480 402 109 15
Serial number: 35200029F1D1B5D3419B
Subsystem 6 - Part No SW: ----------- HW: 480 402 309 15
Serial number: 3550002B91CF2D72F21J
Subsystem 7 - Part No SW: ----------- HW: 480 402 309 15
Component: FrontSensor_P 001 6149
Serial number: 3560002A71CF2D741215
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 01101504220697
Coding: 0410
Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 073360D5BED4B9063F-8052
Part No SW: 5G1 920 858 A HW: 5G1 920 858 A
Component: KOMBI 303 6420
Coding: 0BAD081A2B80CF0502082A001400000000000000
Dataset: EV_DashBoardVDDMQBAB 009046
VCID: 2E7DF57171EEC84EDC-807A
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW High 128 1223
Revision: -------- Serial number: 0004019696
Coding: 0101000830085900FB00022A1C0F00000001050000000000000000000000
Dataset: EV_GatewLear 013020
ROD: EV_GatewLear.rod
VCID: 75CF1A1DD438BB965D-8020
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H10 0101
Serial number: 29150001859120045386
Coding: 31FFFF
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Serial number: HA1-00019.08.15
Coding: 0001
Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_AU21.rod
VCID: 4AB599E1ED46846EE0-801E
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000217419002
Coding: 5D00000000000000
Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 3449E7199FC2E29EAA-8060
Component: FS 020 0041
Serial number: 140915BIC07746
Coding: 007F1320DC00040000000000
Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 43ABB4C5CA6C552623-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000007465999
Coding: 111000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8102
Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB.rod
VCID: 3957D62DB8A01FF679-806C
Component: BFS 020 0041
Serial number: 240915BIN1627A
Coding: 007F1320DC00040000800000
Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 42A5B1C1D5765C2E28-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000007595021
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: - H07 0090
Coding: 022A01010B000400
Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: 40A1BBC9DB7A4E3E3E-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035--STD2.clb
Part No SW: 3Q0 035 844 HW: 3Q0 035 844
Component: MU-S-S-US H25 0245
Serial number: VWZAZ2R0458885
Coding: 02730000FF00000051220001001808001F0207D40120010002
Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 6CF93F7987727A5EB2-8038
Media Player Position 1:
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H43 4060
Serial number: VWZ6Z9R2671108
5688 - Control Head for Mulimedia System
B13C9 F2 [008] - On/Off Switch
Reset counter: 91
Mileage: 126 km
Date: 2016.03.05
Time: 11:32:20
1637 - Interface for External Media
U11B8 00 [008] - No Communications
Reset counter: 90
Mileage: 1508 km
Date: 2016.04.10
Time: 00:00:23
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730002C2821A017F1E06020000
Dataset: EV_OCULowMQB 001006
ROD: EV_OCULowMQB.rod
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 150908202013
Dataset: EV_SoundActuaGen2AU64X 003010
VCID: 2F43E87576E4C146D7-807A
End-------------------------(Elapsed Time: 03:39)--------------------------
