Block 81
zdive65
C?ID=276742
I have a mkv r32 turbo, just purchased the wifi version. I not able to view block 81, any help is appreciated.
Santos
How are you accessing it?
Did you click [Select] [01-Engine] [Functions] [Advanced Measuring values] ?
zdive65
C?ID=276742
I accesses as stated, then it goes to page with loc 1-1 etc. Nothing happens from here.
Scroll down to locations that start with 81 and tick the check-boxes next them, then click [Submit].
zdive65
C?ID=276742
I did scroll to loc 81 and selected it. No information.
Santos
what device are you using to view VCDS-Mobile? Can you post an autoscan from the vehicle?
Block 081 on my chipped MKV GTI. The tuner had some fun with the fields :):
zdive65
C?ID=276742
I hex net connected my wifes stock tiguan last night. Same isdue, no data for block 81
zdive65
C?ID=276742
WVWKC71KX8W046730
Scan: 01 02 03 08 09 0F 15 16 17 19 22 25 42 44 46 47 52 55 56 65
VIN: WVWKC71KX8W046730
01-Engine -- Status: Communication Error 1010
02-Auto Trans -- Status: Communication Error 1000
03-ABS Brakes -- Status: Communication Error 1010
15-Airbags -- Status: Communication Error 1000
22-AWD -- Status: Communication Error 1010
44-Steering Assist -- Status: Communication Error 1000
55-Xenon Range -- Status: Malfunction 0010
Address 01: Engine	Labels: None
	Part No SW: 022 906 032 KE	HW: 022906032GP
	Component: C2-S4-R32T      G  1 2.28
	Revision: 1QH02---	Serial Number: VWX7Z0G53NK88N
	Coding: 0000178
	Shop #: WSC 00001 000 00000
	VCID: 58F31B63BF047B6F2673CA33A2-800D
009267 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
	P2433 - 001 - Short to Plus - MIL ON
005253 - Secondary Air Injection Valve 2 (N320)
	P1485 - 004 - Open Circuit - MIL ON
005170 - Secondary Air Injection Solenoid Valve (N112)
	P1432 - 004 - Open Circuit - MIL ON
001632 - Intake Manifold Tuning Valve Control Circuit (Bank 1)
	P0660 - 004 - Elect. Malfunction
Address 02: Auto Trans	Labels: None
	Part No SW: 02E 300 011 CC	HW: 02E927770AD
	Component: GSG DSG         082  1405
	Revision: 05108020	Serial Number: 00001008310253
	Shop #: WSC 04940 001 00001
	VCID: 52E7E94B99F8513FD83788CBF4-8007
No fault codes found.
Address 03: ABS Brakes	Labels: None
	Part No SW: 1K0 907 379 AB	HW: 1K0907379AB
	Component: ESP 4MOTION MK60     0102
	Revision: 00H13001
	Coding: 0021128
	Shop #: WSC 01279 785 00200
	VCID: 72A749CB39B8313F3877E84B14-8027
Address 08: Auto HVAC	Labels: None
	Part No SW: 1K0 907 044 BS	HW: 1K0907044BS
	Component: ClimatronicPQ35 120  1111
	Revision: 00120021	Serial Number: 00000000000000
	VCID: 79B57EE764CE426779BD37BFF1-802C
00716 - Air recirculation Flap Positioning Motor (V113)
Address 09: Cent. Elect.	Labels: None
	Part No SW: 3C0 937 049 AJ	HW: 3C0937049AJ
	Component: Bordnetz-SG     H54  2202
	Revision: 00H54000	Serial Number: 00000007287340
	Coding: E68F8F214004150047140000001400000008730B5C000100000000000000
	Shop #: WSC 22228 444 53823
	VCID: 71A546C73CBE0A27C16DDF5F19-8024
	Subsystem 1 - 	Part No SW: 1K1-955-119-E
	Component: Wischer 250607 021   0501
	Coding: 0038805
	Subsystem 2 - 	Part No SW: 1K0-955-559-AF
	Component: RLS     030707 046   0204
	Coding: 0207646
10 Faults Found:
02398 - Control Circuit for Rear Windshield Washer Pump
00906 - Horn (H1)
01495 - Bulb for High-Beams; Left (M30)
Address 0F: Digital Radio	Labels: None
	Part No SW: 8E0 035 593 H	HW: 8E0035593H
	Component: SDAR SIRIUS     H06  0080
	Revision: 00000000	Serial Number: AUZ4Z7G0096188
	VCID: 2E1F9DBBED0055DF9CCFFC3B80-807B
Address 15: Airbags	Labels: None
	Part No SW: 1K0 909 605 AB	HW: 1K0959339G
	Component: 6T AIRBAG VW8R  034  8000
	Revision: 05034000	Serial Number: 003B6D0912GI
	Coding: 0013908
	Shop #: WSC 01269 785 00200
	VCID: 6C9B57B31B9CE7CFF23BA603A6-8039
	Subsystem 1 - 	Part No SW: 1K0-959-339-G
	Component: BF-Gewichtsens. 007  0007
Address 16: Steering wheel	Labels: None
	Part No SW: 1K0 953 549 AQ	HW: 1K0953549AQ
	Component: J0527           036  0070
	Coding: 0012122
	VCID: 814596078C1E9AA7B10D8F1F49-80D4
	Subsystem 1 - 	Part No SW: XXX-XXX-XXX-XX
	Component: E0221           002  0010
Address 17: Instruments	Labels: None
	Part No SW: 1K6 920 974 D	HW: 1K6920974D
	Component: KOMBIINSTRUMENT VDD  1216
	Revision: V0002000	Serial Number: VWX7Z0G53NK88N
	Coding: 0007203
	Shop #: WSC 00000 785 00200
	VCID: 352DB2D708566607DD154B6F6D-8060
8 Faults Found:
Address 19: CAN Gateway	Labels: None
	Part No SW: 1K0 907 530 K	HW: 1K0907951
	Component: J533__Gateway   H04  0021
	Revision:   H04 02	Serial Number: 190607F1002365
	Coding: FF8F036207000000
	VCID: 2F2180BFEA0A5CD797D90927BF-807A
8 Faults Found:
01312 - Powertrain Data Bus
01324 - Control Module for All Wheel Drive (J492)
Tuna has been there. Possible they just blanked out that data?
Tiguan: What year. We have access to several. Santos: Try one please.
PS: What are you looking for in Group 081?
Santos
When you go into advanced measuring blocks, do you see a listing of items? or do you see characters? numbers only?
zdive65
C?ID=276742
To be honest, im not sure what i need in 81. I was told there maybe conflict between UM dsg tune and C2 ecu tune so i was told to get block 81.
I went to a local shop and he scanned the same thing i got. So maybe it nothing located there.
Thanks for all of your help.
Hope i can return the favor!
