- May 1, 2016
- 32
- 14
- South Africa
- C?ID=117317
Hi Guys
I've been reading the forum for years, but never got around to register. I bought my USB interface cable back in 2011 from the South African distributor. My cable does not have the short serial no. making it impossible to verify my registration. I've emailed the supplier to get hold of the short serial no of my interface.
I have for some time been meaning to read up on how to change the coding of control units. I eventually had a few days during which I could do that and afterwards attempted a few mods on my 2015 S8.
I have however discovered that many of the modules of my vehicle's model do not have labels, even though labels for the same control units (judging from their part / serial numbers) used in other Audi models are available. E.g. Comparing an autoscan of my S8 to that of an A6 which I have found on this forum, it appears that both models (I.e. S8 (A8) / A6) use the same Image Processing Unit (8E). Module 8E has a label file for the A6, but not for the S8 (not sure if VCDS distinguishes between A8 and S8). The same is true of other control units.
Is there a reason why the labels are not available for (apparently) the same control units when fitted to other models?
A Complete autoscan of my vehicle showing missing labels (I would rather not provide a recent scan, because many of my modules do not have their standard coding anymore and I do not wish other people to mess up control units by using my current coding. The scan was therefore done with an older version of VCDS, but the same labels are missing in the latest version) (I was unable to attach the txt file - suppose I have to verified on the forum before I'll be able to do that):
I'm especially interested in the label files for Control Unit 19, 1B, 82, 85 and, 8E.
My understanding is that with earlier versions, one could modify the label files for one model so that they are available for other models, but that is not possible anymore?
Thanks for the assistance.
Friday,17,April,2015,21:47:17:46604
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
VIN: WAUZZZ4H4EN0##### License Plate:
Mileage: 3886km-2414mi Repair Order:
Chassis Type: 4H (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 1B 22 28 34 36 3B
42 44 46 47 52 53 55 56 5F 62 6C 6D 6F 72 81 82 85 88 89 8B
8E 8F 90 A9 BA
VIN: WAUZZZ4H4EN0##### Mileage: 3886km-2414miles
Address 01: Engine (------CTFA) Labels: None
Part No SW: 4H0 907 557 C HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0001
Revision: NCH62---
Coding: 022A00326546010B3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114H0907557C 001002
ROD: EV_ECM40TFS0114H0907557C.rod
VCID: 3069A9566B955FA1DEF-8065
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4H1 927 158 CE HW: 0BK 927 156 AD
Component: 0BK 40TFSIRdW H18 1001
Revision: --H18---
ROD: EV_TCMALX51011_AU64.rod
VCID: 75E75842D4773A894D9-8020
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 AA HW: 4H0 907 379 AA
Component: ESP PREMIUM H10 0665
Coding: D2FDA3004BBFC500E300
ASAM Dataset: EV_ESPPremi 005024
ROD: EV_ESPPremi_AU64.rod
VCID: 71EF6C52A01F16A9911-8024
0717 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 214
Mileage: 3424 km
Date: 2015.04.12
Time: 11:27:00
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 EB HW: 4H0 907 064 EB
Component: BCM2 2.0 H36 0521
Coding: 05B76F0E000000000000
VCID: 6DD77022B427F249B59-8038
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0156
Revision: AA000000 Serial number: 00000098293771
Coding: C038320085047201000001010101112131313333283333
VCID: 356798429CF77A898D9-8060
Part No SW: 4H0 820 043 P HW: 4H0 820 043 P
Component: Klima 4 Zonen H20 0210
Coding: 682100783C0000
ASAM Dataset: EV_AirCondiFront 003001
ROD: EV_AirCondiFront_AU64.rod
VCID: 2D57B0227CA73249F59-8078
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 AG HW: 4H0 907 063 AG
Component: BCM1 2.0 H20 0242
Revision: 14020001 Serial number: 00000064820302
Coding: 0105C01440349FF2F90140C4A0001800009DC3082F080201800008946101170000400008090000
Subsystem 1 - Part No SW: 4H2 955 119 C HW: 4H2 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 130911 H36 0090
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02004E
Subsystem 3 - Part No SW: 4H0 941 531 F HW: 4H0 941 531 F
Component: E1 - LDS H01 0044
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
VCID: 2343561A2263F43953D-8076
Address 10: Park/Steer Assist (J791) Labels: None
Part No SW: 4G0 919 475 C HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0031
Revision: -------- Serial number: 56231409102833
Coding: B81B06
ASAM Dataset: EV_EPHVA2CAU64X0000 001005
ROD: EV_EPHVA2CAU57X0000.rod
VCID: 316FAC52609F56A9D11-8064
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4H0 907 561 C HW: 4H0 907 561
Component: ACC3 H19 0032
Coding: 7C04010101
ASAM Dataset: EV_AdaptCruisContrAU64X 002024
ROD: EV_AdaptCruisContrAU64X.rod
VCID: 2B53BE3A42B33C79EBD-807E
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Revision: -------- Serial number: 003P10019UF+
Coding: 30333045313430303037554A305234483053
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3B738E7AB2D3ACF97BD-806E
Serial number: 3575HRB405L2E3MGCH3M
Serial number: 3585HRB405L2E3MGFOQD
Serial number: 3515JRB400S50VVEJH27
Serial number: 3525JRB400S50VVEN98A
Serial number: 3554VRB401050V9QDGI.
Serial number: 3564VRB400I50U86Q8N0
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Revision: -------- Serial number: 01335NDC001K7
Coding: 00003C
VCID: 377B924A86FB88999F5-8062
Subsystem 1 - Part No SW: 4H0 951 528 A HW: 4H0 951 528 A
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4H0 920 830 S HW: 4H0 920 830 S
Component: TBenRDWACCNV- H53 0622
Revision: 36081096 Serial number: 658030414592019
Coding: 338F0802BF410008010100
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 3567984294F77A898D9-8060
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 P HW: 4H0 919 204 P
Component: Analoguhr D4 H05 0225
Serial number: 2140211000583
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4H0 907 468 AE HW: 4H0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001345728
Coding: 80ED074800
ASAM Dataset: EV_GatewPkoUDS 001019
ROD: EV_GatewPKOUDS_AU57.rod
VCID: 74E16546DF0D23817A7-8021
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 61092655001911046140
Voltage stabilizer:
0267 - Optical data bus
U1049 00 [008] - Open circuit
Reset counter: 217
Mileage: 3462 km
Date: 2015.04.15
Time: 16:24:35
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 M HW: 8K0 907 144 M
Component: DYNAMIKLENK. H06 0730
Revision: 52001005 Serial number: --------------
Coding: 090100
VCID: 397F9472B0EF9EE9691-806C
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0200
Serial number: 003003140001348
VCID: 285941365345176106F-807D
Address 28: HVAC, Rear (E265) Labels: None
Part No SW: 4H0 919 158 J HW: 4H0 919 158 J
Component: Klima Fond H16 0200
Coding: 2800000000
ASAM Dataset: EV_AirCondiHeck 002001
ROD: EV_AirCondiHeck_AU64.rod
VCID: 377B924A8EFB88999F5-8062
Address 34: Level Control (J197) Labels: None
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Coding: 008006
ROD: EV_AirSuspe_AU64.rod
VCID: 2F6BAA2A76AB4059C75-807A
C10C8 00 [008] - -
Reset counter: 214
Mileage: 3459 km
Date: 2015.04.13
Time: 07:05:16
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000098310312
Coding: C0383B0085057201000001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 L HW: 4H0 907 637 G
Component: SARA 6D red H03 0056
Revision: -------- Serial number: EJ1BPA7100EBVF
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_AU57.rod
VCID: 3879917683E587E196F-806D
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H07 0280
Revision: -------- Serial number: 0000097168165
Coding: 011F1E005E0162C202083007
VCID: 4899E1B6FB05F761E6F-801D
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H40 0010
Revision: 00001000 Serial number: 0031444393
Coding: 011100010001
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS.rod
VCID: 326DA35E65996DB1A8B-8067
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0332043337
Coding: 011A0E2280B93185F030C7C4020316470000000000000000000000000000
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591
Component: J245 PS50.030 H08 0006
Coding: 901F00
Subsystem 4 - Part No SW: 4H0 947 135 G HW: 4H0 947 135 G
Component: Dachelektroni H13 0080
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS014 H06 0005
Subsystem 6 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Part No SW: 4H1 035 465 B HW: 4H1 035 465
Component: BO G3 D4 ANC H03 0150
Revision: 11000000 Serial number: 0014375
Coding: 020101
VCID: 26454F0E51510111343-8073
Subsystem 1 - Part No SW: 4H0 035 466 HW: 4H0 035 466
Component: BO D4 SLAVE H51 0180
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H07 0280
Revision: -------- Serial number: 0000098023036
Coding: 011F1E005E0162C202083006
VCID: 3C718D66BFDDABC1727-8069
Component: EPB-4 H03 0015
Revision: -------- Serial number: 00000001026369
ROD: EV_ParkiBrake_AU48.rod
Address 55: Headlight Range (J745) Labels: 4H4-907-357.clb
Part No SW: 4H4 907 357 B HW: 7P6 907 357 B
Component: MxB-ECU 001 0049
Coding: 02F60A2022100200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
ROD: EV_HeadlRegulAUDIMXBAU64X_AU64.rod
Subsystem 1 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F
Component: LED LeiMo li. H07 7530
Coding: E00300
Subsystem 2 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F
Component: LED LeiMo re. H07 7530
Coding: E00300
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A
Component: MxB LeiMo li. H03 0021
Coding: E00300
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A
Component: MxB LeiMo re. H03 0021
Coding: E00300
Part No SW: 4G1 035 053 J HW: 4G1 035 053
Component: Radio U Basic H41 0133
Revision: AB001007 Serial number: 227D 0E7992204
Coding: 060003010000000001
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4H0 035 764 P HW: 4H0 035 764 P
Component: H-BNT-RW H47 0798
Revision: -------- Serial number: 181DP0E7515003
Coding: 03090100020BFDEF65908B0E000000035C0001000000000000
Subsystem 1 - Part No: 8R0 060 884 BN
Component: ROW 2014 0605
Subsystem 2 - Part No SW: 4H0 919 604 G HW: 4H0 919 604 G
Component: DU8 D4 SV NB H48 0021
Subsystem 3 - Part No SW: 4H2 919 600 H HW: 4H2 919 600
Component: E380 BDT D4 H09 0065
Component: CD-Database 5571
02067 - Optical Databus; Unpermitted Wake-Up Request
Reset counter: 216
Mileage: 3462 km
Date: 2015.04.15
Time: 16:15:35
Voltage: 12.10 V
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H07 0280
Revision: -------- Serial number: 0000098280489
Coding: 010F1E00400062C202083006
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4H0 907 428 B HW: 7P6 907 441 D
Component: TopView H05 0220
Revision: 11001001 Serial number: 82330JF0143383
Coding: 020F000101000000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
VCID: 2C51BD2647BD3B41E27-8079
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 4H0 959 107 AC HW: 4H0 959 107 AC
Component: HDSG-Modul H12 0049
Revision: 10012001 Serial number: 094400148
Coding: 021004C020
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6FEB6A2AB62B0059875-803A
Address 6F: Centr. Conv. II (J773) Labels: None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000146911
Coding: 220000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 63C3161A6AE3B43913D-8036
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H07 0280
Revision: -------- Serial number: 0000098280619
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4H2 927 731 A HW: 4H2 927 731 A
Component: GSM-RL H09 0083
Revision: 0R0D5015 Serial number: SN140205 0408
ROD: EV_GSM2x3Mono.rod
Address 82: Heads Up Display (J898) Labels: None
Part No SW: 4H0 919 617 A HW: 4H0 919 617 A
Component: HeadUpDisplay H08 0019
Coding: C20000
ASAM Dataset: EV_HUDContiC7 001025
ROD: EV_HUDContiC7.rod
VCID: 2E55B72E71A14951CC3-807B
Address 85: On Board Cam. (J852) Labels: None
Component: DPC-SG H26 0081
Coding: E8140000
ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873) Labels: None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00015981020702
Coding: 672FF2
ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872) Labels: None
Serial number: 00015981042602
Coding: 272FF2
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4H0 907 541 C HW: 4H0 907 541
Coding: 7C04010101
ASAM Dataset: EV_AdaptCruisContr2AU64X 002021
ROD: EV_AdaptCruisContr2AU57X.rod
VCID: 295F4432484F2E69191-807C
Address 8E: Image Processing (J851) Labels: None
Part No SW: 4H0 907 107 F HW: 4H0 907 107
Component: BV-SG H31 0081
Serial number: 005000210104147
Coding: 01A00A030111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7_AU64.rod
VCID: 2A5DBB3E4D49257110B-807F
Component: RGS-VL H13 0080
Coding: 00660600031F0376000308004248D0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4H0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0003
Serial number: 140326200277
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H07 0008
Revision: 00001001 Serial number: 97812003493201
ROD: EV_AEMLearAU64X.rod
End-------------------------(Elapsed Time: 08:50)--------------------------
