Battery Drain Issue - Company Comfort Databus in Single Wire
gooselogan
C?ID=293608
I've got a battery drain issue on my 05 Caddy and hoping someone might be able to help. I've not needed to use VCDS before as anything I've had to repair has been mechanical or older vehicles, so I've borrowed a VCDS cable off my friend who is currently out of the country to try and find the problem.
I've run a scan and come up with the following
Monday,02,May,2016,15:16:15:16146
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: WV1ZZZ2KZ6X052017   License Plate: HG55 VXP
Mileage: 296900km-184485mi   Repair Order: 004
Chassis Type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 46 52 56
VIN: WV1ZZZ2KZ6X052017   Mileage: 296900km-184485miles
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 AQ    HW: 028 101 239 0
   Component: R4 1,9l EDC  000SG  7529
   Revision: --H01---    Serial number: VWZ7Z0E2848841
   Coding: 0000031
   Shop #: WSC 00379 210 02853
   VCID: 6ED9F13179A8174E9C-803A
   Part No: 1K0 907 379 P
   Coding: 0017106
   Shop #: WSC 35110 377 00162
   VCID: 3F877C756E42AEC647-806A
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000005113879
   Coding: 80884F030004100000000000000000000009FB075C
   Shop #: WSC 35110 377 08192
   VCID: 2A513D2185C03B6E00-807E
   Subsystem 1 - Part No: 2K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW357  012  0402
   Coding: 00065493
   Shop #: WSC 35110
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 09 AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD088XV3
   Coding: 0012345
   VCID: 7DFBC67D24CE7CD615-8028
   Part No SW: 1K0 953 549 AE    HW: 1K0 953 549 AE
   Component: Lenks‰ulenmodul 634 0070
   Coding: 0000002
   VCID: 75EBDE5D1CFE24965D-8020
   Part No: 2K0 920 942 C
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0017401
   Shop #: WSC 00999 444 64523
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105A22068B
   Coding: 1D0F0140077001
                    Reset counter: 124
                    Mileage: 296909 km
                    Time: 00:00:01
   Component: IMMO            VDD 1012
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2316
   Coding: 0000560
   VCID: 3669195141786F8E94-8062
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 008A0C087F2D8404085A010010C0
   VCID: 79F3D26D30E640F639-802C
   Part No: 1T0 959 702 B
   Coding: 0000560
   VCID: 37771455467296868F-8062
   Part No: 1K0 035 186 P
   Component: Radio GR0       015 0019
   Revision: 0001503S    Serial number: VWZ2Z2E2682372
   Coding: 0020200
   VCID: 336F2045520A7AA6B3-8066
End-------------------------(Elapsed Time: 01:50)--------------------------
So if my understanding is right there is something causing the single wire fault meaning its not going to sleep and causing the drain?
I've also done a voltage drop test on fuses and the only one that is coming back is the one for interior lights and module J519.
Can someone help and explain where I go from here? What I should be checking on VCDS, disconnecting modules etc?
Single-wire is a fallback mode when one of the two wires of the twisted pair is broken, not connected, or otherwise in some state (such as shorted to something else) in which it cannot transmit data. If it were mine, I think I'd start with continuity checks on both wires of that bus everywhere it goes, starting with the 09 and 46 modules.
gooselogan
C?ID=293608
Would unplugging modules until that code went away point me in the right direction?
I ask as I checked the easiest and common issues of the door wiring and when I unplugged the passenger doro the single wire code went and I was left with it no being able to find the door module. But when I did the same on the driver side I still had the single wire fault.
DrPeter
16.4905° S, 151.7375° W
